Re: [U-Boot] Query on S3C2412
ccng'g to minkyu
On 25 July 2012 17:07, Subash Patel subash.ramaswamy@linaro.org wrote:
Hi Chander,
Do you or Minku or someone in SLSI maintain mainline u-boot for old SoC's like S3C24XX? Your answer may be useful to Jose.
Regards, Subash
On 07/25/2012 04:42 PM, José Miguel Gonçalves wrote:
Hi Subash,
That board that I mentioned in the patch was a Silex SX-560:
http://www.silexamerica.com/products/embedded_wireless/intelligent_modules/s...
You can get the open-source code for it (including u-boot) from here:
http://www.silexamerica.com/opensource/index.html
BTW, I have now switched to this S3C2416 based board:
http://www.armdesigner.com/MINI2416.html
and I'm in the process of updating the u-boot code supplied (a 1.3.4 version patched by Samsung for the SMDK2416) to the latest u-boot source code. Do you know if Samsung (or someone else) provided a more recent u-boot for the SMDK2416 (or any other S3C2416 board)?
Best regards, José Gonçalves
On 07/25/2012 11:52 AM, Subash Patel wrote:
Including even Ben who posted your patch.
Regards, Subash
On 07/25/2012 04:20 PM, Subash Patel wrote:
Hi Jose,
I am from Samsung Electronics, SLSI and work in the open source project called Linaro.
I find that you have posted a patch to fix booting s3c2412 based board recently, and hence assume that you are using that SoC. I am trying to cleanup some code for these old boards now. Unfortunately my inside- contacts in company do not have any u-boot for this SoC. Although we work on the SMDK boards internally, I will try to fix up u-boot which you may be using for the same. Can you help me to get u-boot, the one you use if publicly available?
Regards, Subash
Chander Kashyap
