[PATCHv2 1/2] i2c: stm32f7: fix clearing the control register
Bits should be set to 0, not 1.
Signed-off-by: Jorge Ramirez-Ortiz jorge@foundries.io --- drivers/i2c/stm32f7_i2c.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/i2c/stm32f7_i2c.c b/drivers/i2c/stm32f7_i2c.c index bf2a6c9b4b..3a727e68ac 100644 --- a/drivers/i2c/stm32f7_i2c.c +++ b/drivers/i2c/stm32f7_i2c.c @@ -413,7 +413,7 @@ static int stm32_i2c_check_end_of_message(struct stm32_i2c_priv *i2c_priv) setbits_le32(®s->icr, STM32_I2C_ICR_STOPCF);
/* Clear control register 2 */ - setbits_le32(®s->cr2, STM32_I2C_CR2_RESET_MASK); + clrbits_le32(®s->cr2, STM32_I2C_CR2_RESET_MASK); }
return ret;
Sending the stop condition without waiting for transfer complete has been found to lock the bus (BUSY) when NACKF is raised.
Tested accessing the NXP SE05X I2C device. https://www.nxp.com/docs/en/application-note/AN12399.pdf
Signed-off-by: Jorge Ramirez-Ortiz jorge@foundries.io Reviewed-by: Oleksandr Suvorov oleksandr.suvorov@foundries.io --- drivers/i2c/stm32f7_i2c.c | 8 +++++--- 1 file changed, 5 insertions(+), 3 deletions(-)
diff --git a/drivers/i2c/stm32f7_i2c.c b/drivers/i2c/stm32f7_i2c.c index 3a727e68ac..14827e5cec 100644 --- a/drivers/i2c/stm32f7_i2c.c +++ b/drivers/i2c/stm32f7_i2c.c @@ -485,9 +485,11 @@ static int stm32_i2c_message_xfer(struct stm32_i2c_priv *i2c_priv, } }
- /* End of transfer, send stop condition */ - mask = STM32_I2C_CR2_STOP; - setbits_le32(®s->cr2, mask); + if (!ret) { + /* End of transfer, send stop condition */ + mask = STM32_I2C_CR2_STOP; + setbits_le32(®s->cr2, mask); + }
return stm32_i2c_check_end_of_message(i2c_priv); }
+Alain
Alain, can you have a look a this patch and give your feedback on it.
On my side i tested it on stm32mp157c-ev1 and stm32mp157c-dk2, i didn't see any regression but i prefer to get expert feedback ;-)
Thanks Patrice
if (!ret) {
+Alain (with the correct email address ;-))
Thanks Patrice
if (!ret) {
I confirm that a fix is necessary regarding this setting of the stop condition. As a matter of fact, the controller is already sending the stop condition in case of NACK so there is no need to send the stop condition. However, this fix is not enough since the nack could be detected few lines above
if (status & (STM32_I2C_ISR_NACKF | STM32_I2C_ISR_ERRORS)) break;
and in this case the current check would not catch it.
I propose to set the STOP condition upon handling of the transfer complete.
I've put this fix within a small 3 patches series that I'm going to send, could you check it to confirm this fixes the issue ?
Regards, Alain
Thanks Patrice
if (!ret) {
Regards, Alain
Thanks Patrice
For reference, this patch is superseded by Alain Volmat patch:
[v2,1/3] i2c: stm32: fix comment and remove unused AUTOEND bit
http://patchwork.ozlabs.org/project/uboot/patch/20220908105934.1764482-2-ala...
in the serie "i2c: stm32: cleanup & stop handling fix"
http://patchwork.ozlabs.org/project/uboot/list/?series=317443&state=*
Regards
Patrick
Hi Jorge
return ret;
Reviewed-by: Patrice Chotard patrice.chotard@foss.st.com Thanks Patrice
return ret;
Reviewed-by: Patrick Delaunay patrick.delaunay@foss.st.com
Thanks Patrick
return ret;
Applied to u-boot-stm/master, thanks!
Regards Patrick
Alain Volmat
Jorge Ramirez-Ortiz
Patrice CHOTARD
Patrick DELAUNAY
