[U-Boot] [PATCH 1/2] net: gem: Allow to set the MAC from an EEPROM
Provide board specific option how to read MAC address from ROM. Do it in generic way to be reusable by differnet boards. If this is not enough board specific functions can be created.
Signed-off-by: Joe Hershberger joe.hershberger@gmail.com (driver part) Signed-off-by: Michal Simek monstr@monstr.eu ---
arch/arm/mach-zynq/include/mach/sys_proto.h | 2 ++ board/xilinx/zynq/board.c | 13 +++++++++++++ drivers/net/zynq_gem.c | 18 ++++++++++++++++++ 3 files changed, 33 insertions(+)
diff --git a/arch/arm/mach-zynq/include/mach/sys_proto.h b/arch/arm/mach-zynq/include/mach/sys_proto.h index 882beabe132f..44c9b50fe5b8 100644 --- a/arch/arm/mach-zynq/include/mach/sys_proto.h +++ b/arch/arm/mach-zynq/include/mach/sys_proto.h @@ -19,6 +19,8 @@ extern int zynq_slcr_get_mio_pin_status(const char *periph); extern void zynq_ddrc_init(void); extern unsigned int zynq_get_silicon_version(void);
+int zynq_board_read_rom_ethaddr(unsigned char *ethaddr); + /* Driver extern functions */ extern void ps7_init(void);
diff --git a/board/xilinx/zynq/board.c b/board/xilinx/zynq/board.c index 2f17e977a4b3..4c20450b6359 100644 --- a/board/xilinx/zynq/board.c +++ b/board/xilinx/zynq/board.c @@ -98,6 +98,19 @@ int checkboard(void) } #endif
+int zynq_board_read_rom_ethaddr(unsigned char *ethaddr) +{ +#if defined(CONFIG_ZYNQ_GEM_EEPROM_ADDR) && \ + defined(CONFIG_ZYNQ_GEM_I2C_MAC_OFFSET) + if (eeprom_read(CONFIG_ZYNQ_GEM_EEPROM_ADDR, + CONFIG_ZYNQ_GEM_I2C_MAC_OFFSET, + ethaddr, 6)) + printf("I2C EEPROM MAC address read failed\n"); +#endif + + return 0; +} + int dram_init(void) { int node; diff --git a/drivers/net/zynq_gem.c b/drivers/net/zynq_gem.c index b3821c31a91d..4cfc1fadbcad 100644 --- a/drivers/net/zynq_gem.c +++ b/drivers/net/zynq_gem.c @@ -561,6 +561,23 @@ static void zynq_gem_halt(struct udevice *dev) ZYNQ_GEM_NWCTRL_TXEN_MASK, 0); }
+__weak int zynq_board_read_rom_ethaddr(unsigned char *ethaddr) +{ + return -ENOSYS; +} + +static int zynq_gem_read_rom_mac(struct udevice *dev) +{ + int retval; + struct eth_pdata *pdata = dev_get_platdata(dev); + + retval = zynq_board_read_rom_ethaddr(pdata->enetaddr); + if (retval == -ENOSYS) + retval = 0; + + return retval; +} + static int zynq_gem_miiphy_read(struct mii_dev *bus, int addr, int devad, int reg) { @@ -634,6 +651,7 @@ static const struct eth_ops zynq_gem_ops = { .free_pkt = zynq_gem_free_pkt, .stop = zynq_gem_halt, .write_hwaddr = zynq_gem_setup_mac, + .read_rom_hwaddr = zynq_gem_read_rom_mac, };
static int zynq_gem_ofdata_to_platdata(struct udevice *dev)
Zybo has on board I2C EEPROM which contains preprogrammed MAC address.
include/configs/zynq_zybo.h | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/include/configs/zynq_zybo.h b/include/configs/zynq_zybo.h index 0882fe36bd82..637b1c5ffe91 100644 --- a/include/configs/zynq_zybo.h +++ b/include/configs/zynq_zybo.h @@ -17,6 +17,9 @@ #define CONFIG_ZYNQ_I2C0 #define CONFIG_ZYNQ_I2C1 #define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 +#define CONFIG_CMD_EEPROM +#define CONFIG_ZYNQ_GEM_EEPROM_ADDR 0x50 +#define CONFIG_ZYNQ_GEM_I2C_MAC_OFFSET 0xFA #define CONFIG_DISPLAY #define CONFIG_I2C_EDID
Michal Simek
