ARM: socfpga: gen5: release reset before using USB as device with ums
The command "ums 0 mmc 0" does not work because the USB port is still in reset. Releasing it in board_usb_init() fixes the problem. This issue has been observed and fixed on the Aries MCVEVP board.
Signed-off-by: Wolfgang Grandegger wg@aries-embedded.de --- arch/arm/dts/socfpga_cyclone5_mcvevk.dts | 1 + arch/arm/mach-socfpga/board.c | 8 ++++++++ arch/arm/mach-socfpga/include/mach/reset_manager_gen5.h | 2 ++ 3 files changed, 11 insertions(+)
diff --git a/arch/arm/dts/socfpga_cyclone5_mcvevk.dts b/arch/arm/dts/socfpga_cyclone5_mcvevk.dts index ceaec29770..a673837f25 100644 --- a/arch/arm/dts/socfpga_cyclone5_mcvevk.dts +++ b/arch/arm/dts/socfpga_cyclone5_mcvevk.dts @@ -12,6 +12,7 @@ aliases { ethernet0 = &gmac0; stmpe-i2c0 = &stmpe1; + udc0 = &usb1; };
chosen { diff --git a/arch/arm/mach-socfpga/board.c b/arch/arm/mach-socfpga/board.c index 7267163222..a2eed73fe9 100644 --- a/arch/arm/mach-socfpga/board.c +++ b/arch/arm/mach-socfpga/board.c @@ -83,6 +83,14 @@ int board_usb_init(int index, enum usb_init_type init) /* Patch the address from OF into the controller pdata. */ socfpga_otg_data.regs_otg = addr;
+#ifdef CONFIG_TARGET_SOCFPGA_GEN5 + /* First release reset of the USB port */ + if (addr == SOCFPGA_USB0_ADDRESS) + socfpga_per_reset(SOCFPGA_RESET(USB0), 0); + else if (addr == SOCFPGA_USB1_ADDRESS) + socfpga_per_reset(SOCFPGA_RESET(USB1), 0); +#endif + return dwc2_udc_probe(&socfpga_otg_data); }
diff --git a/arch/arm/mach-socfpga/include/mach/reset_manager_gen5.h b/arch/arm/mach-socfpga/include/mach/reset_manager_gen5.h index d108eac1e2..611403cf00 100644 --- a/arch/arm/mach-socfpga/include/mach/reset_manager_gen5.h +++ b/arch/arm/mach-socfpga/include/mach/reset_manager_gen5.h @@ -31,6 +31,8 @@ void socfpga_bridges_reset(int enable); */ #define RSTMGR_EMAC0 RSTMGR_DEFINE(1, 0) #define RSTMGR_EMAC1 RSTMGR_DEFINE(1, 1) +#define RSTMGR_USB0 RSTMGR_DEFINE(1, 2) +#define RSTMGR_USB1 RSTMGR_DEFINE(1, 3) #define RSTMGR_NAND RSTMGR_DEFINE(1, 4) #define RSTMGR_QSPI RSTMGR_DEFINE(1, 5) #define RSTMGR_L4WD0 RSTMGR_DEFINE(1, 6)
udc0 = &usb1;
chosen {
- /* First release reset of the USB port */
- if (addr == SOCFPGA_USB0_ADDRESS)
- else if (addr == SOCFPGA_USB1_ADDRESS)
Is this really needed at all ?
There is drivers/reset/reset-socfpga.c which should handle the reset of the DWC2 USB IP.
Hello Marek,
Am 28.02.22 um 15:51 schrieb Marek Vasut:
diff --git a/arch/arm/dts/socfpga_cyclone5_mcvevk.dts b/arch/arm/dts/socfpga_cyclone5_mcvevk.dts index ceaec29770..a673837f25 100644 --- a/arch/arm/dts/socfpga_cyclone5_mcvevk.dts +++ b/arch/arm/dts/socfpga_cyclone5_mcvevk.dts @@ -12,6 +12,7 @@ aliases { ethernet0 = &gmac0; stmpe-i2c0 = &stmpe1; + udc0 = &usb1; }; chosen { diff --git a/arch/arm/mach-socfpga/board.c b/arch/arm/mach-socfpga/board.c index 7267163222..a2eed73fe9 100644 --- a/arch/arm/mach-socfpga/board.c +++ b/arch/arm/mach-socfpga/board.c @@ -83,6 +83,14 @@ int board_usb_init(int index, enum usb_init_type init) /* Patch the address from OF into the controller pdata. */ socfpga_otg_data.regs_otg = addr; +#ifdef CONFIG_TARGET_SOCFPGA_GEN5 + /* First release reset of the USB port */ + if (addr == SOCFPGA_USB0_ADDRESS) + socfpga_per_reset(SOCFPGA_RESET(USB0), 0); + else if (addr == SOCFPGA_USB1_ADDRESS) + socfpga_per_reset(SOCFPGA_RESET(USB1), 0); +#endif
Yes, it's needed, otherwise "ums 0 mmc 0" does not work. It was working some time ago but commit 430b42f76a4e50ffef7cc2b3c195ff645a438433 did remove the ad-hoc reset code. I realize the issue an on Aries MCVEVP board, but I'm quite sure that it's present on all Cyclone5 boards.
See above!
Wolfgang
Can you investigate why the reset-socfpga.c does not release the USB from reset instead ? That would be the right approach.
Hello,
Am 28.02.22 um 16:22 schrieb Marek Vasut:
The attached patch works. It enables CONFIG_DM_USB_GADGET and adds "dr_mode = otg" to the USB device tree node. "ums 0 mmc 0" deasserts the reset for USB1 and re-assert it when done. All ok with that!
But then "usb start" is broken:
=> usb start starting USB... USB: drv id 110 name usb USB: drv id 90 name serial USB: drv id 101 name sysreset USB: drv id 85 name reset USB: drv id 22 name blk USB: drv id 59 name mmc USB: drv id 99 name syscon USB: drv id 25 name cache USB: drv id 43 name i2c USB: drv id 40 name gpio USB: drv id 36 name ethernet USB: drv id 91 name simple_bus USB: drv id 0 name root No working controllers found
The function "uclass_find()" does no longer find the USB host device (UCLASS_USB). The debug ouput is with:
diff --git a/drivers/core/uclass.c b/drivers/core/uclass.c index 2578803b7a..b59a5dcdad 100644 --- a/drivers/core/uclass.c +++ b/drivers/core/uclass.c @@ -35,6 +35,9 @@ struct uclass *uclass_find(enum uclass_id key) * id to node. */ list_for_each_entry(uc, gd->uclass_root, sibling_node) { + if (key == UCLASS_USB) + printf("USB: drv id %d name %s\n", + uc->uc_drv->id, uc->uc_drv->name); if (uc->uc_drv->id == key) return uc; }
Id 110 is UCLASS_USB_GADGET_GENERIC, but UCLASS_USB is gone. There is some magic with usb device scanning. Any idea what could cause that problem?
Wolfgang
On 3/14/22 11:57, Wolfgang Grandegger wrote:
Hello,
+CC Simon
Wolfgang Grandegger
