[U-Boot] [PATCH] doc: Document for generic firmware loader
This is initial draft document about generic firmware loader. The intention of this patch is open for discussion, and final version will be included together with next version release of generic firmware loader patchset. Current V3 generic firmware loader patchset can be reviewed from https://www.mail-archive.com/u-boot@lists.denx.de/msg272028.html
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com --- doc/README.firmware_loader | 77 ++++++++++++++++++++++++++++++++++++++++++++ 1 files changed, 77 insertions(+), 0 deletions(-) create mode 100644 doc/README.firmware_loader
diff --git a/doc/README.firmware_loader b/doc/README.firmware_loader new file mode 100644 index 0000000..d250723 --- /dev/null +++ b/doc/README.firmware_loader @@ -0,0 +1,77 @@ +/* + * Copyright (C) 2017 Intel Corporation <www.intel.com> + * + * SPDX-License-Identifier: GPL-2.0 + */ + +Introduction +------------ +This is firmware loader for U-Boot framework, which has very close to some Linux +Firmware API. For the details of Linux Firmware API, you can refer to +https://01.org/linuxgraphics/gfx-docs/drm/driver-api/firmware/index.html. + +Firmware loader can be used to load whatever(firmware, image, and binary) from +the flash in file system format into target location such as memory, then +consumer driver such as FPGA driver can program FPGA image from the target +location into FPGA. + +Firmware Loader API core features +--------------------------------- +=> Firmware storage device partition search + ---------------------------------------- + => Default storage device partition search set for mmc, usb and sata + as shown in below: + static struct device_location default_locations[] = { + { + .name = "mmc", + .devpart = "0:1", + }, + { + .name = "usb", + .devpart = "0:1", + }, + { + .name = "sata", + .devpart = "0:1", + }, + }; + + However, the default storage device .devpart value can be overwritten + with value which is defined in the environment variable "FW_DEV_PART". + For example: env_set("FW_DEV_PART", "0:2"); + +Firmware Loader API +------------------- +=> int request_firmware_into_buf(struct firmware **firmware_p, + const char *name, + struct device_location *location, + void *buf, size_t size, u32 offset) + -------------------------------------------------------------- + => Load firmware into a previously allocated buffer + + Parameters: + struct firmware **firmware_p + pointer to firmware image + + const char *name + name of firmware file + + struct device_location *location + an array of supported firmware location + + void *buf + address of buffer to load firmware into + + size_t size + size of buffer + + u32 offset + offset of a file for start reading into buffer + + return: size of total read + -ve when error + + Description: + The firmware is loaded directly into the buffer pointed to by buf and + the @firmware_p data member is pointed at buf. +
Hi Tien,
- Copyright (C) 2017 Intel Corporation <www.intel.com>
- SPDX-License-Identifier: GPL-2.0
- +Firmware loader can be used to load whatever(firmware, image, and
^^^^^^^^^^^^^^ I suppose that you mean - load binary image from file system put on flash?
- => Default storage device partition search set for mmc,
usb and sata
- as shown in below:
- static struct device_location default_locations[] = {
.name = "mmc",
.devpart = "0:1",
.name = "usb",
.devpart = "0:1",
.name = "sata",
.devpart = "0:1",
- However, the default storage device .devpart value can be
overwritten
- with value which is defined in the environment variable
"FW_DEV_PART".
- For example: env_set("FW_DEV_PART", "0:2");
^^^^^^^^^^ - u-boot normally uses lower case for env variable naming.
const char *name,
- => Load firmware into a previously allocated buffer
- Parameters:
- struct firmware **firmware_p
- const char *name
- struct device_location *location
- void *buf
- size_t size
size of buffer
- u32 offset
- return: size of total read
-ve when error
- Description:
- The firmware is loaded directly into the buffer pointed to
by buf and
- the @firmware_p data member is pointed at buf.
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de
On Isn, 2017-12-18 at 10:28 +0100, Lukasz Majewski wrote:
Hi Tien,
+Introduction +------------ +This is firmware loader for U-Boot framework, which has very close to some Linux +Firmware API. For the details of Linux Firmware API, you can refer to +https://01.org/linuxgraphics/gfx-docs/drm/driver-api/firmware/inde x.html.
Yes, you are right.
.name = "mmc",
.devpart = "0:1",
.name = "usb",
.devpart = "0:1",
.name = "sata",
.devpart = "0:1",
overwritten
"FW_DEV_PART".
okay, i will switch to lower case.
const char *name,
- Parameters:
- const char *name
- void *buf
- size_t size
size of buffer
- u32 offset
- -ve when error
- Description:
Lukasz Majewski
Chee, Tien Fong
Lukasz Majewski
