[PULL] u-boot-riscv/master
Hi Tom,
The following changes since commit 8e21064cb3452950b09301baec06d86e37342471:
Merge tag 'efi-2023-07-rc7' of https://source.denx.de/u-boot/custodians/u-boot-efi (2023-07-11 13:27:32 -0400)
https://source.denx.de/u-boot/custodians/u-boot-riscv.git master
for you to fetch changes up to 478fedfda42ea2a444991de1696fa0adc8bb16d4:
doc: t-head: lpi4a: document Lichee PI 4A board (2023-07-12 13:21:41 +0800)
CI result shows no issue: https://source.denx.de/u-boot/custodians/u-boot-riscv/-/pipelines/16856
- Add ethernet driver for StarFive JH7110 SoC - Add ACLINT mtimer and mswi devices support - Add Lichee PI 4A board
---------------------------------------------------------------- Bin Meng (3): riscv: timer: Update the sifive clint timer driver to support aclint riscv: clint: Update the sifive clint ipi driver to support aclint riscv: Rename SiFive CLINT to RISC-V ALINT
Yanhong Wang (11): net: phy: Add driver for Motorcomm yt8531 gigabit ethernet phy net: dwc_eth_qos: Add StarFive ethernet driver glue layer riscv: dts: jh7110: Add ethernet device tree nodes riscv: dts: jh7110: Combine the board device tree files of 1.2A and 1.3B doc: board: starfive: Reword the make defconfig information configs: starfive: Enable ethernet configuration for StarFive VisionFive2 eeprom: starfive: Enable ID EEPROM configuration riscv: dts: starfive: Add support eeprom device tree node configs: starfive: Enable ID EEPROM configuration ram: starfive: Read memory size information from EEPROM board: starfive: Dynamic configuration of DT for 1.2A and 1.3B
Yixun Lan (4): riscv: t-head: licheepi4a: initial support added riscv: dts: t-head: Add basic device tree for Sipeed Lichee PI 4A board configs: th1520_lpi4a_defconfig: Add initial config doc: t-head: lpi4a: document Lichee PI 4A board
MAINTAINERS | 2 +- arch/riscv/Kconfig | 17 +++-- arch/riscv/cpu/fu540/Kconfig | 2 +- arch/riscv/cpu/fu740/Kconfig | 2 +- arch/riscv/cpu/generic/Kconfig | 4 +- arch/riscv/cpu/jh7110/Kconfig | 2 +- arch/riscv/cpu/jh7110/spl.c | 32 ++++++++- arch/riscv/dts/Makefile | 4 +- arch/riscv/dts/{jh7110-starfive-visionfive-2-v1.2a-u-boot.dtsi => jh7110-starfive-visionfive-2-u-boot.dtsi} | 39 ++++++++++- arch/riscv/dts/jh7110-starfive-visionfive-2-v1.2a.dts | 12 ---- arch/riscv/dts/jh7110-starfive-visionfive-2-v1.3b-u-boot.dtsi | 69 ------------------- arch/riscv/dts/{jh7110-starfive-visionfive-2-v1.3b.dts => jh7110-starfive-visionfive-2.dts} | 3 +- arch/riscv/dts/jh7110-starfive-visionfive-2.dtsi | 40 +++++++++++ arch/riscv/dts/jh7110.dtsi | 69 +++++++++++++++++++ arch/riscv/dts/th1520-lichee-module-4a.dtsi | 34 +++++++++ arch/riscv/dts/th1520-lichee-pi-4a.dts | 32 +++++++++ arch/riscv/dts/th1520.dtsi | 406 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ arch/riscv/include/asm/arch-jh7110/eeprom.h | 13 ++++ arch/riscv/include/asm/global_data.h | 4 +- arch/riscv/include/asm/syscon.h | 2 +- arch/riscv/lib/Makefile | 2 +- arch/riscv/lib/{sifive_clint.c => aclint_ipi.c} | 31 +++++++-- board/openpiton/riscv64/Kconfig | 2 +- board/sipeed/maix/Kconfig | 2 +- board/starfive/visionfive2/Makefile | 1 + board/starfive/visionfive2/spl.c | 157 ++++++++++++++++++++++++++++++++++++++++++ board/starfive/visionfive2/starfive_visionfive2.c | 13 ++++ board/starfive/visionfive2/visionfive2-i2c-eeprom.c | 561 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ board/thead/th1520_lpi4a/Kconfig | 42 ++++++++++++ board/thead/th1520_lpi4a/MAINTAINERS | 7 ++ board/thead/th1520_lpi4a/Makefile | 5 ++ board/thead/th1520_lpi4a/board.c | 15 ++++ configs/starfive_visionfive2_defconfig | 32 ++++++++- configs/th1520_lpi4a_defconfig | 82 ++++++++++++++++++++++ doc/board/index.rst | 1 + doc/board/starfive/visionfive2.rst | 6 +- doc/board/thead/index.rst | 9 +++ doc/board/thead/lpi4a.rst | 129 +++++++++++++++++++++++++++++++++++ drivers/net/Kconfig | 7 ++ drivers/net/Makefile | 1 + drivers/net/dwc_eth_qos.c | 6 ++ drivers/net/dwc_eth_qos.h | 1 + drivers/net/dwc_eth_qos_starfive.c | 249 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ drivers/net/phy/Kconfig | 6 ++ drivers/net/phy/Makefile | 1 + drivers/net/phy/motorcomm.c | 437 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ drivers/ram/starfive/starfive_ddr.c | 2 - drivers/timer/Makefile | 2 +- drivers/timer/riscv_aclint_timer.c | 74 ++++++++++++++++++++ drivers/timer/sifive_clint_timer.c | 68 ------------------ include/configs/qemu-riscv.h | 2 +- include/configs/sifive-unleashed.h | 2 +- include/configs/starfive-visionfive2.h | 1 + include/configs/th1520_lpi4a.h | 22 ++++++ 54 files changed, 2578 insertions(+), 188 deletions(-) rename arch/riscv/dts/{jh7110-starfive-visionfive-2-v1.2a-u-boot.dtsi => jh7110-starfive-visionfive-2-u-boot.dtsi} (58%) delete mode 100644 arch/riscv/dts/jh7110-starfive-visionfive-2-v1.2a.dts delete mode 100644 arch/riscv/dts/jh7110-starfive-visionfive-2-v1.3b-u-boot.dtsi rename arch/riscv/dts/{jh7110-starfive-visionfive-2-v1.3b.dts => jh7110-starfive-visionfive-2.dts} (65%) create mode 100644 arch/riscv/dts/th1520-lichee-module-4a.dtsi create mode 100644 arch/riscv/dts/th1520-lichee-pi-4a.dts create mode 100644 arch/riscv/dts/th1520.dtsi create mode 100644 arch/riscv/include/asm/arch-jh7110/eeprom.h rename arch/riscv/lib/{sifive_clint.c => aclint_ipi.c} (53%) create mode 100644 board/starfive/visionfive2/visionfive2-i2c-eeprom.c create mode 100644 board/thead/th1520_lpi4a/Kconfig create mode 100644 board/thead/th1520_lpi4a/MAINTAINERS create mode 100644 board/thead/th1520_lpi4a/Makefile create mode 100644 board/thead/th1520_lpi4a/board.c create mode 100644 configs/th1520_lpi4a_defconfig create mode 100644 doc/board/thead/index.rst create mode 100644 doc/board/thead/lpi4a.rst create mode 100644 drivers/net/dwc_eth_qos_starfive.c create mode 100644 drivers/net/phy/motorcomm.c create mode 100644 drivers/timer/riscv_aclint_timer.c delete mode 100644 drivers/timer/sifive_clint_timer.c create mode 100644 include/configs/th1520_lpi4a.h
Best regards, Leo
On Wed, Jul 12, 2023 at 06:58:21AM +0000, Leo Liang wrote:
Hi Tom,
Leo Liang
