[U-Boot] [PATCH 0/7] arm64: mvebu: Add support for A8K community board
This patch series adds initil support for A8K community board MACCHIATOBin manufactured by SolidRun. It should be applied on top of Stefan Roese patches adding support for SD/eMMC devices on Marvell A37x0/A80x0/A70x0 SoCs. The top level patch is called: "arm64: mvebu: Enable SDHCI/MMC support for the db-88f7040/8040" The default board DTS file is based on the original work of Rabeeh Khory from SolidRun.
Konstantin Porotchkin (6): arm64: mvebu: Update bubt command MMC block device access arm64: mvebu: gpio: Add GPIO nodes to A8K family devices arm64: mvebu: dts: Add i2c1 pin definitions to CPM mvebu: usb: xhci: Add support for VBUS controlled by GPIO mvebu: pcie: Add support for GPIO reset for PCIe device arm64: mvebu: Add default configuraton for MACCHIATOBin board
Rabeeh Khoury (1): arm64: mvebu: dts: Add DTS file for MACCHIATOBin board
arch/arm/dts/Makefile | 1 + arch/arm/dts/armada-7040.dtsi | 1 + arch/arm/dts/armada-8040-mcbin.dts | 253 ++++++++++++++++++++++ arch/arm/dts/armada-8040.dtsi | 1 + arch/arm/dts/armada-ap806.dtsi | 8 + arch/arm/dts/armada-cp110-master.dtsi | 22 ++ arch/arm/dts/armada-cp110-slave.dtsi | 18 ++ board/Marvell/mvebu_armada-8k/board.c | 54 ++++- board/Marvell/mvebu_db-88f3720/board.c | 2 +- cmd/mvebu/bubt.c | 17 +- configs/mvebu_mcbin-88f8040_defconfig | 65 ++++++ doc/device-tree-bindings/pci/armada8k-pcie.txt | 49 +++++ doc/device-tree-bindings/usb/marvell.xhci-usb.txt | 29 +++ drivers/pci/pcie_dw_mvebu.c | 11 + drivers/usb/host/xhci-mvebu.c | 5 +- 15 files changed, 518 insertions(+), 18 deletions(-) create mode 100644 arch/arm/dts/armada-8040-mcbin.dts create mode 100644 configs/mvebu_mcbin-88f8040_defconfig create mode 100644 doc/device-tree-bindings/pci/armada8k-pcie.txt create mode 100644 doc/device-tree-bindings/usb/marvell.xhci-usb.txt
Update the MMC block device access code in bubt command implementation according to the latest MMC driver changes
Change-Id: Ie852ceefa0b040ffe1362bdb7815fcea9b2d923b Signed-off-by: Konstantin Porotchkin kostap@marvell.com Cc: Stefan Roese sr@denx.de Cc: Nadav Haklai nadavh@marvell.com Cc: Neta Zur Hershkovits neta@marvell.com Cc: Omri Itach omrii@marvell.com Cc: Igal Liberman igall@marvell.com Cc: Haim Boot hayim@marvell.com Cc: Hanna Hawa hannah@marvell.com --- cmd/mvebu/bubt.c | 17 ++++++++++++----- 1 file changed, 12 insertions(+), 5 deletions(-)
diff --git a/cmd/mvebu/bubt.c b/cmd/mvebu/bubt.c index 1cbfcf0..0ac2e63 100644 --- a/cmd/mvebu/bubt.c +++ b/cmd/mvebu/bubt.c @@ -18,6 +18,7 @@ #include <usb.h> #include <fs.h> #include <mmc.h> +#include <blk.h> #include <u-boot/sha1.h> #include <u-boot/sha256.h>
@@ -111,6 +112,7 @@ static ulong get_load_addr(void) static int mmc_burn_image(size_t image_size) { struct mmc *mmc; + struct blk_desc *blk_desc; lbaint_t start_lba; lbaint_t blk_count; ulong blk_written; @@ -144,13 +146,18 @@ static int mmc_burn_image(size_t image_size) * MMC/eMMC boots from LBA-0 */ start_lba = IS_SD(mmc) ? 1 : 0; - blk_count = image_size / mmc->block_dev.blksz; - if (image_size % mmc->block_dev.blksz) + blk_count = image_size / mmc->write_bl_len; + if (image_size % mmc->write_bl_len) blk_count += 1;
- blk_written = mmc->block_dev.block_write(mmc_dev_num, - start_lba, blk_count, - (void *)get_load_addr()); + blk_desc = mmc_get_blk_desc(mmc); + if (!blk_desc) { + printf("Error - failed to obtain block descriptor\n"); + return -ENODEV; + } + blk_written = blk_dwrite(blk_desc, start_lba, blk_count, + (void *)get_load_addr()); + if (blk_written != blk_count) { printf("Error - written %#lx blocks\n", blk_written); return -ENOSPC;
Add GPIO nodes to AP-806 and CP-110-master DTSI files.
Change-Id: I05958698d460cb721b7d8683d34f74a5ea32532c Signed-off-by: Konstantin Porotchkin kostap@marvell.com Cc: Stefan Roese sr@denx.de Cc: Nadav Haklai nadavh@marvell.com Cc: Neta Zur Hershkovits neta@marvell.com Cc: Omri Itach omrii@marvell.com Cc: Igal Liberman igall@marvell.com Cc: Haim Boot hayim@marvell.com Cc: Hanna Hawa hannah@marvell.com --- arch/arm/dts/armada-7040.dtsi | 1 + arch/arm/dts/armada-8040.dtsi | 1 + arch/arm/dts/armada-ap806.dtsi | 8 ++++++++ arch/arm/dts/armada-cp110-master.dtsi | 18 ++++++++++++++++++ arch/arm/dts/armada-cp110-slave.dtsi | 18 ++++++++++++++++++ 5 files changed, 46 insertions(+)
diff --git a/arch/arm/dts/armada-7040.dtsi b/arch/arm/dts/armada-7040.dtsi index 78d995d..b5be0c4 100644 --- a/arch/arm/dts/armada-7040.dtsi +++ b/arch/arm/dts/armada-7040.dtsi @@ -45,6 +45,7 @@ * one CP110. */
+#include <dt-bindings/gpio/gpio.h> #include "armada-ap806-quad.dtsi" #include "armada-cp110-master.dtsi"
diff --git a/arch/arm/dts/armada-8040.dtsi b/arch/arm/dts/armada-8040.dtsi index 9c1b28c..96cc112 100644 --- a/arch/arm/dts/armada-8040.dtsi +++ b/arch/arm/dts/armada-8040.dtsi @@ -45,6 +45,7 @@ * two CP110. */
+#include <dt-bindings/gpio/gpio.h> #include "armada-ap806-quad.dtsi" #include "armada-cp110-master.dtsi" #include "armada-cp110-slave.dtsi" diff --git a/arch/arm/dts/armada-ap806.dtsi b/arch/arm/dts/armada-ap806.dtsi index b6d31af..d86e5dd 100644 --- a/arch/arm/dts/armada-ap806.dtsi +++ b/arch/arm/dts/armada-ap806.dtsi @@ -158,6 +158,14 @@ }; };
+ ap_gpio0: gpio@6F5040 { + compatible = "marvell,orion-gpio"; + reg = <0x6F5040 0x40>; + ngpios = <20>; + gpio-controller; + #gpio-cells = <2>; + }; + xor@400000 { compatible = "marvell,mv-xor-v2"; reg = <0x400000 0x1000>, diff --git a/arch/arm/dts/armada-cp110-master.dtsi b/arch/arm/dts/armada-cp110-master.dtsi index d637867..a3e922d 100644 --- a/arch/arm/dts/armada-cp110-master.dtsi +++ b/arch/arm/dts/armada-cp110-master.dtsi @@ -113,6 +113,24 @@ }; };
+ cpm_gpio0: gpio@440100 { + compatible = "marvell,orion-gpio"; + reg = <0x440100 0x40>; + ngpios = <32>; + gpiobase = <20>; + gpio-controller; + #gpio-cells = <2>; + }; + + cpm_gpio1: gpio@440140 { + compatible = "marvell,orion-gpio"; + reg = <0x440140 0x40>; + ngpios = <31>; + gpiobase = <52>; + gpio-controller; + #gpio-cells = <2>; + }; + cpm_sata0: sata@540000 { compatible = "marvell,armada-8k-ahci"; reg = <0x540000 0x30000>; diff --git a/arch/arm/dts/armada-cp110-slave.dtsi b/arch/arm/dts/armada-cp110-slave.dtsi index 92ef55c..ff3fbed 100644 --- a/arch/arm/dts/armada-cp110-slave.dtsi +++ b/arch/arm/dts/armada-cp110-slave.dtsi @@ -100,6 +100,24 @@ }; };
+ cps_gpio0: gpio@440100 { + compatible = "marvell,orion-gpio"; + reg = <0x440100 0x40>; + ngpios = <32>; + gpiobase = <20>; + gpio-controller; + #gpio-cells = <2>; + }; + + cps_gpio1: gpio@440140 { + compatible = "marvell,orion-gpio"; + reg = <0x440140 0x40>; + ngpios = <31>; + gpiobase = <52>; + gpio-controller; + #gpio-cells = <2>; + }; + cps_sata0: sata@540000 { compatible = "marvell,armada-8k-ahci"; reg = <0x540000 0x30000>;
Add i2c-1 pin mappings to CP0(master) DTSI file
Change-Id: I0c6e6de8a557393f518f7df8e6daa6dfce1788b0 Signed-off-by: Konstantin Porotchkin kostap@marvell.com Cc: Stefan Roese sr@denx.de Cc: Nadav Haklai nadavh@marvell.com Cc: Neta Zur Hershkovits neta@marvell.com Cc: Omri Itach omrii@marvell.com Cc: Igal Liberman igall@marvell.com Cc: Haim Boot hayim@marvell.com Cc: Hanna Hawa hannah@marvell.com --- arch/arm/dts/armada-cp110-master.dtsi | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/arch/arm/dts/armada-cp110-master.dtsi b/arch/arm/dts/armada-cp110-master.dtsi index a3e922d..3776e4e 100644 --- a/arch/arm/dts/armada-cp110-master.dtsi +++ b/arch/arm/dts/armada-cp110-master.dtsi @@ -94,6 +94,10 @@ marvell,pins = < 37 38 >; marvell,function = <2>; }; + cpm_i2c1_pins: cpm-i2c-pins-1 { + marvell,pins = < 35 36 >; + marvell,function = <2>; + }; cpm_ge2_rgmii_pins: cpm-ge-rgmii-pins-0 { marvell,pins = < 44 45 46 47 48 49 50 51 52 53 54 55 >;
Add support for "marvell,vbus-gpio" property to mvebu XHCI board init function. This option is valid when CONFIG_DM_GPIO=y
Change-Id: I930b3ebe001e50ae8d5abe1f3c774bcdb1739e64 Signed-off-by: Konstantin Porotchkin kostap@marvell.com Cc: Stefan Roese sr@denx.de Cc: Nadav Haklai nadavh@marvell.com Cc: Neta Zur Hershkovits neta@marvell.com Cc: Omri Itach omrii@marvell.com Cc: Igal Liberman igall@marvell.com Cc: Haim Boot hayim@marvell.com Cc: Hanna Hawa hannah@marvell.com --- board/Marvell/mvebu_armada-8k/board.c | 32 ++++++++++++++++------- board/Marvell/mvebu_db-88f3720/board.c | 2 +- doc/device-tree-bindings/usb/marvell.xhci-usb.txt | 29 ++++++++++++++++++++ drivers/usb/host/xhci-mvebu.c | 5 ++-- 4 files changed, 55 insertions(+), 13 deletions(-) create mode 100644 doc/device-tree-bindings/usb/marvell.xhci-usb.txt
diff --git a/board/Marvell/mvebu_armada-8k/board.c b/board/Marvell/mvebu_armada-8k/board.c index 7d1b5d9..aa6a6d7 100644 --- a/board/Marvell/mvebu_armada-8k/board.c +++ b/board/Marvell/mvebu_armada-8k/board.c @@ -8,6 +8,7 @@ #include <dm.h> #include <i2c.h> #include <asm/io.h> +#include <asm/gpio.h> #include <asm/arch/cpu.h> #include <asm/arch/soc.h>
@@ -95,19 +96,23 @@ int board_xhci_config(void) return 0; }
-int board_xhci_enable(void) +int board_xhci_enable(struct udevice *usb_dev) { struct udevice *dev; +#ifdef CONFIG_DM_GPIO + struct gpio_desc vbus_gpio; +#endif int ret; u8 buf[8];
+ /* + * This function enables all USB ports simultaniously, + * it only needs to get called once + */ + if (usb_enabled) + return 0; + if (of_machine_is_compatible("marvell,armada7040-db")) { - /* - * This function enables all USB ports simultaniously, - * it only needs to get called once - */ - if (usb_enabled) - return 0;
/* Configure IO exander PCA9555: 7bit address 0x21 */ ret = i2c_get_chip_for_busnum(0, I2C_IO_EXP_ADDR, 1, &dev); @@ -131,10 +136,19 @@ int board_xhci_enable(void) return -EIO; }
- mdelay(500); /* required delay to let output value settle */ - usb_enabled = 1; }
+#ifdef CONFIG_DM_GPIO + gpio_request_by_name(usb_dev, "marvell,vbus-gpio", 0, + &vbus_gpio, GPIOD_IS_OUT); + + if (dm_gpio_is_valid(&vbus_gpio)) + dm_gpio_set_value(&vbus_gpio, 1); +#endif + + mdelay(500); /* required delay to let output value settle */ + usb_enabled = 1; + return 0; }
diff --git a/board/Marvell/mvebu_db-88f3720/board.c b/board/Marvell/mvebu_db-88f3720/board.c index edf88c7..75679ff 100644 --- a/board/Marvell/mvebu_db-88f3720/board.c +++ b/board/Marvell/mvebu_db-88f3720/board.c @@ -69,7 +69,7 @@ int board_ahci_enable(void) }
/* Board specific xHCI enable code */ -int board_xhci_enable(void) +int board_xhci_enable(struct udevice *usb_dev) { struct udevice *dev; int ret; diff --git a/doc/device-tree-bindings/usb/marvell.xhci-usb.txt b/doc/device-tree-bindings/usb/marvell.xhci-usb.txt new file mode 100644 index 0000000..b0a53ad --- /dev/null +++ b/doc/device-tree-bindings/usb/marvell.xhci-usb.txt @@ -0,0 +1,29 @@ +Marvell SOC USB controllers + +This controller is integrated in Armada 3700/8K. +It uses the same properties as a generic XHCI host controller + +Required properties : + - compatible: should be one or more of: + - "marvell,armada3700-xhci", "generic-xhci" for Armada 37xx SoCs + - "marvell,armada-8k-xhci", "generic-xhci" for Armada A8K SoCs + - reg: should contain address and length of the standard XHCI + register set for the device. + - interrupts: one XHCI interrupt should be described here. + +Optional properties: + - clocks: reference to a clock + - marvell,vbus-gpio : If present, specifies a gpio that needs to be + activated for the bus to be powered. + +Example: + cpm_usb3_0: usb3@500000 { + compatible = "marvell,armada-8k-xhci", + "generic-xhci"; + reg = <0x500000 0x4000>; + interrupts = <GIC_SPI 62 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpm_syscon0 1 22>; + marvell,vbus-gpio = <&cpm_gpio1 15 GPIO_ACTIVE_HIGH>; + status = "disabled"; + }; + diff --git a/drivers/usb/host/xhci-mvebu.c b/drivers/usb/host/xhci-mvebu.c index 46eb937..843a51b 100644 --- a/drivers/usb/host/xhci-mvebu.c +++ b/drivers/usb/host/xhci-mvebu.c @@ -10,7 +10,6 @@ #include <dm.h> #include <fdtdec.h> #include <usb.h> -#include <asm/gpio.h>
#include "xhci.h"
@@ -34,7 +33,7 @@ struct mvebu_xhci { * Dummy implementation that can be overwritten by a board * specific function */ -__weak int board_xhci_enable(void) +__weak int board_xhci_enable(struct udevice *usb_dev) { return 0; } @@ -51,7 +50,7 @@ static int xhci_usb_probe(struct udevice *dev) hcor = (struct xhci_hcor *)((uintptr_t)ctx->hcd + len);
/* Enable USB xHCI (VBUS, reset etc) in board specific code */ - board_xhci_enable(); + board_xhci_enable(dev);
return xhci_register(dev, ctx->hcd, hcor); }
Add board init hook to mvebu DW PCIe device driver. Add support for "marvell,reset-gpio" property to A8K board init function. This option is valid when CONFIG_DM_GPIO=y
Change-Id: Ic17c500449050c2fbb700731f1a9ca8b83298986 Signed-off-by: Konstantin Porotchkin kostap@marvell.com Signed-off-by: Rabeeh Khoury rabeeh@solid-run.com Cc: Stefan Roese sr@denx.de Cc: Nadav Haklai nadavh@marvell.com Cc: Neta Zur Hershkovits neta@marvell.com Cc: Omri Itach omrii@marvell.com Cc: Igal Liberman igall@marvell.com Cc: Haim Boot hayim@marvell.com Cc: Hanna Hawa hannah@marvell.com --- board/Marvell/mvebu_armada-8k/board.c | 22 ++++++++++++ doc/device-tree-bindings/pci/armada8k-pcie.txt | 49 ++++++++++++++++++++++++++ drivers/pci/pcie_dw_mvebu.c | 11 ++++++ 3 files changed, 82 insertions(+) create mode 100644 doc/device-tree-bindings/pci/armada8k-pcie.txt
diff --git a/board/Marvell/mvebu_armada-8k/board.c b/board/Marvell/mvebu_armada-8k/board.c index aa6a6d7..7fca8ed 100644 --- a/board/Marvell/mvebu_armada-8k/board.c +++ b/board/Marvell/mvebu_armada-8k/board.c @@ -152,6 +152,28 @@ int board_xhci_enable(struct udevice *usb_dev) return 0; }
+int board_pcie_init(struct udevice *pcie_dev) +{ +#ifdef CONFIG_DM_GPIO + struct gpio_desc reset_gpio; + + gpio_request_by_name(pcie_dev, "marvell,reset-gpio", 0, + &reset_gpio, GPIOD_IS_OUT); + /* + * Issue reset to add-in card trough the dedicated GPIO. + * Some boards are connecting the card reset pin to common + * system reset wire and others are using separate GPIO port. + * In the last case we have to release a reset of the addon + * card using this GPIO. + */ + if (dm_gpio_is_valid(&reset_gpio)) { + dm_gpio_set_value(&reset_gpio, 1); + mdelay(100); + } +#endif /* CONFIG_DM_GPIO */ + return 0; +} + int board_early_init_f(void) { /* Nothing to do (yet), perhaps later some pin-muxing etc */ diff --git a/doc/device-tree-bindings/pci/armada8k-pcie.txt b/doc/device-tree-bindings/pci/armada8k-pcie.txt new file mode 100644 index 0000000..7230f10 --- /dev/null +++ b/doc/device-tree-bindings/pci/armada8k-pcie.txt @@ -0,0 +1,49 @@ +Armada-8K PCIe DT details: +========================== + +Armada-8k uses synopsis designware PCIe controller. + +Required properties: +- compatible : should be "marvell,armada8k-pcie", "snps,dw-pcie". +- reg: base addresses and lengths of the pcie control and global control registers. + "ctrl" registers points to the global control registers, while the "config" space + points to the pcie configuration registers as mentioned in dw-pcie dt bindings in the link below. +- interrupt-map-mask and interrupt-map, standard PCI properties to + define the mapping of the PCIe interface to interrupt numbers. +- All other definitions as per generic PCI bindings +See Linux kernel documentation: +"Documentation/devicetree/bindings/pci/designware-pcie.txt" + +Optional properties: +PHY support is still not supported for armada-8k, once it will, the following parameters can be used: +- phys : phandle to phy node associated with pcie controller. +- phy-names : must be "pcie-phy" +- marvell,reset-gpio : specifies a gpio that needs to be activated for plug-in + card reset signal release. +Example: + +cpm_pcie0: pcie@f2600000 { + compatible = "marvell,armada8k-pcie", "snps,dw-pcie"; + reg = <0 0xf2600000 0 0x10000>, + <0 0xf6f00000 0 0x80000>; + reg-names = "ctrl", "config"; + #address-cells = <3>; + #size-cells = <2>; + #interrupt-cells = <1>; + device_type = "pci"; + dma-coherent; + + bus-range = <0 0xff>; + ranges = + /* downstream I/O */ + <0x81000000 0 0xf9000000 0 0xf9000000 0 0x10000 + /* non-prefetchable memory */ + 0x82000000 0 0xf6000000 0 0xf6000000 0 0xf00000>; + interrupt-map-mask = <0 0 0 0>; + interrupt-map = <0 0 0 0 &gic 0 GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>; + interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>; + num-lanes = <1>; + clocks = <&cpm_syscon0 1 13>; + marvell,reset-gpio = <&cpm_gpio1 20 GPIO_ACTIVE_HIGH>; + status = "disabled"; +}; diff --git a/drivers/pci/pcie_dw_mvebu.c b/drivers/pci/pcie_dw_mvebu.c index 17fa024..26451b8 100644 --- a/drivers/pci/pcie_dw_mvebu.c +++ b/drivers/pci/pcie_dw_mvebu.c @@ -112,6 +112,15 @@ struct pcie_dw_mvebu { int first_busno; };
+/* + * Dummy implementation that can be overwritten by a board + * specific function + */ +__weak int board_pcie_init(struct udevice *pcie_dev) +{ + return 0; +} + static int pcie_dw_get_link_speed(const void *regs_base) { return (readl(regs_base + PCIE_LINK_STATUS_REG) & @@ -464,6 +473,8 @@ static int pcie_dw_mvebu_probe(struct udevice *dev)
pcie->first_busno = dev->seq;
+ board_pcie_init(dev); + /* Don't register host if link is down */ if (!pcie_dw_mvebu_pcie_link_up(pcie->ctrl_base, LINK_SPEED_GEN_3)) { printf("PCIE-%d: Link down\n", dev->seq);
Added A8040 dts file for community board MACCHIATIBin. The patch includes the following features: AP - eMMC, Serial console (connected to onboard FTDI usb to serial) CP0 - PCIe x4, SATA, I2C and 10G KR (connected to Marvell 3310 10G copper / SFP+ phy) CP1 - Boot SPI, USB3 host, 2xSATA, 10G KR (connected to Marvell 3310 10G copper / SFP+ phy), SGMII connected to onboard 1512 1Gbps copper phy, and additional SGMII connected to SFP (default 1Gbps can be configured to 2.5Gbps).
Network interface naming - egiga0 - CP0 KR egiga1 - CP1 KR egiga2 - CP1 RJ45 1Gbps connector (recommended for TFTP boot) egiga3 - CP1 SFP default 1Gbps and can be modified to 2.5Gbps
Change-Id: Icb844eff9a8f07cd76ca8f86ffb01fe297bde836 Signed-off-by: Konstantin Porotchkin kostap@marvell.com Signed-off-by: Rabeeh Khoury rabeeh@solid-run.com Cc: Stefan Roese sr@denx.de Cc: Nadav Haklai nadavh@marvell.com Cc: Omri Itach omrii@marvell.com Cc: Igal Liberman igall@marvell.com Cc: Haim Boot hayim@marvell.com Cc: Hanna Hawa hannah@marvell.com --- arch/arm/dts/Makefile | 1 + arch/arm/dts/armada-8040-mcbin.dts | 253 +++++++++++++++++++++++++++++++++++++ 2 files changed, 254 insertions(+) create mode 100644 arch/arm/dts/armada-8040-mcbin.dts
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index ff78385..10e0536 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -76,6 +76,7 @@ dtb-$(CONFIG_ARCH_MVEBU) += \ armada-385-amc.dtb \ armada-7040-db.dtb \ armada-8040-db.dtb \ + armada-8040-mcbin.dtb \ armada-xp-gp.dtb \ armada-xp-maxbcm.dtb \ armada-xp-synology-ds414.dtb \ diff --git a/arch/arm/dts/armada-8040-mcbin.dts b/arch/arm/dts/armada-8040-mcbin.dts new file mode 100644 index 0000000..682e6f7 --- /dev/null +++ b/arch/arm/dts/armada-8040-mcbin.dts @@ -0,0 +1,253 @@ +/* + * Copyright (C) 2016 Marvell International Ltd. + * + * SPDX-License-Identifier: GPL-2.0 + * https://spdx.org/licenses + */ + +#include "armada-8040.dtsi" /* include SoC device tree */ + +/ { + model = "MACCHIATOBin-8040"; + compatible = "marvell,armada8040-mcbin", + "marvell,armada8040"; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + aliases { + i2c0 = &cpm_i2c0; + i2c1 = &cpm_i2c1; + spi0 = &cps_spi1; + gpio0 = &ap_gpio0; + gpio1 = &cpm_gpio0; + gpio2 = &cpm_gpio1; + }; + + memory@00000000 { + device_type = "memory"; + reg = <0x0 0x0 0x0 0x80000000>; + }; +}; + +/* Accessible over the mini-USB CON9 connector on the main board */ +&uart0 { + status = "okay"; +}; + +&ap_pinctl { + /* + * MPP Bus: + * eMMC [0-10] + * UART0 [11,19] + */ + /* 0 1 2 3 4 5 6 7 8 9 */ + pin-func = < 1 1 1 1 1 1 1 1 1 1 + 1 3 0 0 0 0 0 0 0 3 >; +}; + +/* on-board eMMC */ +&sdhci0 { + pinctrl-names = "default"; + pinctrl-0 = <&ap_emmc_pins>; + bus-width= <8>; + status = "okay"; +}; + +&cpm_pinctl { + /* + * MPP Bus: + * [0-31] = 0xff: Keep default CP0_shared_pins: + * [11] CLKOUT_MPP_11 (out) + * [23] LINK_RD_IN_CP2CP (in) + * [25] CLKOUT_MPP_25 (out) + * [29] AVS_FB_IN_CP2CP (in) + * [32,34] SMI + * [33] MSS power down + * [35-38] CP0 I2C1 and I2C0 + * [39] MSS CKE Enable + * [40,41] CP0 UART1 TX/RX + * [42,43] XSMI (controls two 10G phys) + * [47] USB VBUS EN + * [48] FAN PWM + * [49] 10G port 1 interrupt + * [50] 10G port 0 interrupt + * [51] 2.5G SFP TX fault + * [52] PCIe reset out + * [53] 2.5G SFP mode + * [54] 2.5G SFP LOS + * [55] Micro SD card detect + * [56-61] Micro SD + * [62] CP1 KR SFP FAULT + */ + /* 0 1 2 3 4 5 6 7 8 9 */ + pin-func = < 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff + 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff + 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff + 0xff 0 7 0xa 7 2 2 2 2 0xa + 7 7 8 8 0 0 0 0 0 0 + 0 0 9 0 0 0 0xe 0xe 0xe 0xe + 0xe 0xe 0 >; +}; + +/* PCIe x4 */ +&cpm_pcie0 { + num-lanes = <4>; + marvell,reset-gpio = <&cpm_gpio1 20 GPIO_ACTIVE_HIGH>; /* GPIO[52] */ + status = "okay"; +}; + +&cpm_i2c0 { + pinctrl-names = "default"; + pinctrl-0 = <&cpm_i2c0_pins>; + status = "okay"; + clock-frequency = <100000>; +}; + +&cpm_i2c1 { + pinctrl-names = "default"; + pinctrl-0 = <&cpm_i2c1_pins>; + status = "okay"; + clock-frequency = <100000>; +}; + +&cpm_sata0 { + status = "okay"; +}; + +&cpm_comphy { + /* + * CP0 Serdes Configuration: + * Lane 0: PCIe0 (x4) + * Lane 1: PCIe0 (x4) + * Lane 2: PCIe0 (x4) + * Lane 3: PCIe0 (x4) + * Lane 4: KR (10G) + * Lane 5: SATA1 + */ + phy0 { + phy-type = <PHY_TYPE_PEX0>; + }; + phy1 { + phy-type = <PHY_TYPE_PEX0>; + }; + phy2 { + phy-type = <PHY_TYPE_PEX0>; + }; + phy3 { + phy-type = <PHY_TYPE_PEX0>; + }; + phy4 { + phy-type = <PHY_TYPE_KR>; + }; + phy5 { + phy-type = <PHY_TYPE_SATA1>; + }; +}; + +&cps_sata0 { + status = "okay"; +}; + +&cps_usb3_0 { + status = "okay"; + marvell,vbus-gpio = <&cpm_gpio1 15 GPIO_ACTIVE_HIGH>; /* GPIO[47] */ +}; + +&cps_utmi0 { + status = "okay"; +}; + +&cps_pinctl { + /* + * MPP Bus: + * [0-5] TDM + * [6,7] CP1_UART 0 + * [8] CP1 10G SFP LOS + * [9] CP1 10G PHY RESET + * [10] CP1 10G SFP TX Disable + * [11] CP1 10G SFP Mode + * [12] SPI1 CS1n + * [13] SPI1 MISO (TDM and SPI ROM shared) + * [14] SPI1 CS0n + * [15] SPI1 MOSI (TDM and SPI ROM shared) + * [16] SPI1 CLK (TDM and SPI ROM shared) + * [24] CP1 2.5G SFP TX Disable + * [26] CP0 10G SFP TX Fault + * [27] CP0 10G SFP Mode + * [28] CP0 10G SFP LOS + * [29] CP0 10G SFP TX Disable + * [30] USB Over current indication + * [31] 10G Port 0 phy reset + * [32-62] = 0xff: Keep default CP1_shared_pins: + */ + /* 0 1 2 3 4 5 6 7 8 9 */ + pin-func = < 0x4 0x4 0x4 0x4 0x4 0x4 0x8 0x8 0x0 0x0 + 0x0 0x0 0x3 0x3 0x3 0x3 0x3 0xff 0xff 0xff + 0xff 0xff 0xff 0xff 0x0 0xff 0x0 0x0 0x0 0x0 + 0x0 0x0 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff + 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff + 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff + 0xff 0xff 0xff>; +}; + +&cps_spi1 { + pinctrl-names = "default"; + pinctrl-0 = <&cps_spi1_pins>; + status = "okay"; + + spi-flash@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "jedec,spi-nor"; + reg = <0>; + spi-max-frequency = <10000000>; + + partitions { + compatible = "fixed-partitions"; + #address-cells = <1>; + #size-cells = <1>; + + partition@0 { + label = "U-Boot"; + reg = <0 0x200000>; + }; + partition@400000 { + label = "Filesystem"; + reg = <0x200000 0xce0000>; + }; + }; + }; +}; + +&cps_comphy { + /* + * CP1 Serdes Configuration: + * Lane 0: SGMII2 + * Lane 1: SATA 0 + * Lane 2: USB HOST 0 + * Lane 3: SATA1 + * Lane 4: KR (10G) + * Lane 5: SGMII3 + */ + phy0 { + phy-type = <PHY_TYPE_SGMII2>; + phy-speed = <PHY_SPEED_1_25G>; + }; + phy1 { + phy-type = <PHY_TYPE_SATA0>; + }; + phy2 { + phy-type = <PHY_TYPE_USB3_HOST0>; + }; + phy3 { + phy-type = <PHY_TYPE_SATA1>; + }; + phy4 { + phy-type = <PHY_TYPE_KR>; + }; + phy5 { + phy-type = <PHY_TYPE_SGMII3>; + }; +};
Add default configuration for MACHHIATOBin community board based on Aramda-8040 SoC.
Change-Id: I60efcca5b31060340ad0a948561f082646f6556c Signed-off-by: Konstantin Porotchkin kostap@marvell.com Cc: Stefan Roese sr@denx.de Cc: Nadav Haklai nadavh@marvell.com Cc: Neta Zur Hershkovits neta@marvell.com Cc: Omri Itach omrii@marvell.com Cc: Igal Liberman igall@marvell.com Cc: Haim Boot hayim@marvell.com Cc: Hanna Hawa hannah@marvell.com --- configs/mvebu_mcbin-88f8040_defconfig | 65 +++++++++++++++++++++++++++++++++++ 1 file changed, 65 insertions(+) create mode 100644 configs/mvebu_mcbin-88f8040_defconfig
diff --git a/configs/mvebu_mcbin-88f8040_defconfig b/configs/mvebu_mcbin-88f8040_defconfig new file mode 100644 index 0000000..ed6e9db --- /dev/null +++ b/configs/mvebu_mcbin-88f8040_defconfig @@ -0,0 +1,65 @@ +CONFIG_ARM=y +CONFIG_ARCH_MVEBU=y +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_TARGET_MVEBU_ARMADA_8K=y +CONFIG_DEFAULT_DEVICE_TREE="armada-8040-mcbin" +CONFIG_SMBIOS_PRODUCT_NAME="" +CONFIG_AHCI=y +# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SYS_CONSOLE_INFO_QUIET=y +# CONFIG_DISPLAY_CPUINFO is not set +# CONFIG_DISPLAY_BOARDINFO is not set +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +# CONFIG_CMD_FPGA is not set +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_TFTPPUT=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_TIME=y +CONFIG_CMD_MMC=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_CMD_MVEBU_BUBT=y +CONFIG_BLOCK_CACHE=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_MVTWSI=y +CONFIG_DM_GPIO=y +CONFIG_MVEBU_GPIO=y +CONFIG_MISC=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_WINBOND=y +CONFIG_PHYLIB=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_PCIE_DW_MVEBU=y +CONFIG_MVEBU_COMPHY_SUPPORT=y +# CONFIG_SPL_SERIAL_PRESENT is not set +CONFIG_DEBUG_UART=y +CONFIG_DEBUG_UART_BASE=0xf0512000 +CONFIG_DEBUG_UART_CLOCK=200000000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_DEBUG_UART_ANNOUNCE=y +CONFIG_SYS_NS16550=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_STORAGE=y +CONFIG_DM_MMC=y +CONFIG_XENON_SDHCI=y +CONFIG_SMBIOS_MANUFACTURER="" +CONFIG_PINCTRL=y +CONFIG_HUSH_PARSER=y
kostap@marvell.com
