[U-Boot] [PATCH] test: call lmb tests vi 'ut lib'
The unit tests in test/lib/lmb.c are not related to the device tree. So they should be executed via `ut lib` and not via `ut dm`.
Signed-off-by: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com ---
test/lib/lmb.c | 23 +++++++++++------------ 1 file changed, 11 insertions(+), 12 deletions(-)
diff --git a/test/lib/lmb.c b/test/lib/lmb.c index ec68227bb6..88764293b9 100644 --- a/test/lib/lmb.c +++ b/test/lib/lmb.c @@ -5,7 +5,8 @@
#include <common.h> #include <lmb.h> -#include <dm/test.h> +#include <test/lib.h> +#include <test/test.h> #include <test/ut.h>
static int check_lmb(struct unit_test_state *uts, struct lmb *lmb, @@ -197,7 +198,7 @@ static int lib_test_lmb_simple(struct unit_test_state *uts) return test_multi_alloc_512mb(uts, 0xE0000000); }
-DM_TEST(lib_test_lmb_simple, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT); +LIB_TEST(lib_test_lmb_simple, 0);
/* Create two memory regions with one reserved region and allocate */ static int lib_test_lmb_simple_x2(struct unit_test_state *uts) @@ -213,7 +214,7 @@ static int lib_test_lmb_simple_x2(struct unit_test_state *uts) return test_multi_alloc_512mb_x2(uts, 0xE0000000, 0x40000000); }
-DM_TEST(lib_test_lmb_simple_x2, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT); +LIB_TEST(lib_test_lmb_simple_x2, 0);
/* Simulate 512 MiB RAM, allocate some blocks that fit/don't fit */ static int test_bigblock(struct unit_test_state *uts, const phys_addr_t ram) @@ -280,7 +281,7 @@ static int lib_test_lmb_big(struct unit_test_state *uts) return test_bigblock(uts, 0xE0000000); }
-DM_TEST(lib_test_lmb_big, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT); +LIB_TEST(lib_test_lmb_big, 0);
/* Simulate 512 MiB RAM, allocate a block without previous reservation */ static int test_noreserved(struct unit_test_state *uts, const phys_addr_t ram, @@ -355,7 +356,7 @@ static int lib_test_lmb_noreserved(struct unit_test_state *uts) return test_noreserved(uts, 0xE0000000, 4, 1); }
-DM_TEST(lib_test_lmb_noreserved, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT); +LIB_TEST(lib_test_lmb_noreserved, 0);
static int lib_test_lmb_unaligned_size(struct unit_test_state *uts) { @@ -370,7 +371,7 @@ static int lib_test_lmb_unaligned_size(struct unit_test_state *uts) return test_noreserved(uts, 0xE0000000, 5, 8); }
-DM_TEST(lib_test_lmb_unaligned_size, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT); +LIB_TEST(lib_test_lmb_unaligned_size, 0); /* * Simulate a RAM that starts at 0 and allocate down to address 0, which must * fail as '0' means failure for the lmb_alloc functions. @@ -413,7 +414,7 @@ static int lib_test_lmb_at_0(struct unit_test_state *uts) return 0; }
-DM_TEST(lib_test_lmb_at_0, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT); +LIB_TEST(lib_test_lmb_at_0, 0);
/* Check that calling lmb_reserve with overlapping regions fails. */ static int lib_test_lmb_overlapping_reserve(struct unit_test_state *uts) @@ -451,8 +452,7 @@ static int lib_test_lmb_overlapping_reserve(struct unit_test_state *uts) return 0; }
-DM_TEST(lib_test_lmb_overlapping_reserve, - DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT); +LIB_TEST(lib_test_lmb_overlapping_reserve, 0);
/* * Simulate 512 MiB RAM, reserve 3 blocks, allocate addresses in between. @@ -582,7 +582,7 @@ static int lib_test_lmb_alloc_addr(struct unit_test_state *uts) return test_alloc_addr(uts, 0xE0000000); }
-DM_TEST(lib_test_lmb_alloc_addr, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT); +LIB_TEST(lib_test_lmb_alloc_addr, 0);
/* Simulate 512 MiB RAM, reserve 3 blocks, check addresses in between */ static int test_get_unreserved_size(struct unit_test_state *uts, @@ -653,5 +653,4 @@ static int lib_test_lmb_get_free_size(struct unit_test_state *uts) return test_get_unreserved_size(uts, 0xE0000000); }
-DM_TEST(lib_test_lmb_get_free_size, - DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT); +LIB_TEST(lib_test_lmb_get_free_size, 0);
With sandbox_defconfig:
./u-boot -D => ut lib Running 12 lib tests Test: lib_memcpy Test: lib_memmove Test: lib_memset Test: lib_test_lmb_alloc_addr ERROR: Failed to allocate 0x1 bytes below 0x0. ERROR: Failed to allocate 0x1 bytes below 0x0. Test: lib_test_lmb_at_0 ERROR: Failed to allocate 0x4 bytes below 0x0. Test: lib_test_lmb_big ERROR: Failed to allocate 0x10000000 bytes below 0x0. ERROR: Failed to allocate 0x20000000 bytes below 0x0. ERROR: Failed to allocate 0x10000000 bytes below 0x0. ERROR: Failed to allocate 0x20000000 bytes below 0x0. Test: lib_test_lmb_get_free_size Test: lib_test_lmb_noreserved Test: lib_test_lmb_overlapping_reserve Test: lib_test_lmb_simple Test: lib_test_lmb_simple_x2 Test: lib_test_lmb_unaligned_size Failures: 0 =>
Without your patch
=> ut dm
simply hangs. So I cannot judge if these are new errors.
Best regards
Heinrich
- Simulate a RAM that starts at 0 and allocate down to address 0, which must
- fail as '0' means failure for the lmb_alloc functions.
- Simulate 512 MiB RAM, reserve 3 blocks, allocate addresses in between.
Am Mo., 11. Feb. 2019, 22:27 hat Heinrich Schuchardt xypron.glpk@gmx.de geschrieben:
Well, these are not test errors but output of the functions the test calls. That could be improved...
Without your patch
=> ut dm
Hmm, I have no idea what's wrong when it hangs. I ran 'ut dm' about a week or two ago and it worked for me...
Simon Goldschmidt
