[PATCH 1/2] cmd: smccc: Print results in hex instead of dec
Printing return value in HEX instead of DEC. Return values are 64 bit values which impossible to decode in DEC. For example getting CHIP ID in dec is quite long.
Signed-off-by: Michal Simek michal.simek@amd.com ---
cmd/smccc.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/cmd/smccc.c b/cmd/smccc.c index 0539a42587e2..fb80431ad1d9 100644 --- a/cmd/smccc.c +++ b/cmd/smccc.c @@ -43,7 +43,7 @@ static int do_call(struct cmd_tbl *cmdtp, int flag, int argc, else arm_smccc_hvc(fid, a1, a2, a3, a4, a5, a6, a7, &res);
- printf("Res: %ld %ld %ld %ld\n", res.a0, res.a1, res.a2, res.a3); + printf("Res: 0x%lx 0x%lx 0x%lx 0x%lx\n", res.a0, res.a1, res.a2, res.a3);
return 0; }
SMC command is very useful for TF-A testing or issuing commands which are not covered by any driver. Strongly recommend to disable this command on any product unless it is required.
configs/xilinx_versal_net_virt_defconfig | 1 + configs/xilinx_versal_virt_defconfig | 1 + configs/xilinx_zynqmp_virt_defconfig | 1 + 3 files changed, 3 insertions(+)
diff --git a/configs/xilinx_versal_net_virt_defconfig b/configs/xilinx_versal_net_virt_defconfig index 729c6ad4503b..e3b0cb29c80d 100644 --- a/configs/xilinx_versal_net_virt_defconfig +++ b/configs/xilinx_versal_net_virt_defconfig @@ -47,6 +47,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_EFIDEBUG=y CONFIG_CMD_TIME=y CONFIG_CMD_TIMER=y +CONFIG_CMD_SMC=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_SQUASHFS=y CONFIG_CMD_MTDPARTS=y diff --git a/configs/xilinx_versal_virt_defconfig b/configs/xilinx_versal_virt_defconfig index 053af57b6b1c..451107479a85 100644 --- a/configs/xilinx_versal_virt_defconfig +++ b/configs/xilinx_versal_virt_defconfig @@ -51,6 +51,7 @@ CONFIG_CMD_EFIDEBUG=y CONFIG_CMD_TIME=y CONFIG_CMD_RNG=y CONFIG_CMD_TIMER=y +CONFIG_CMD_SMC=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_SQUASHFS=y CONFIG_CMD_MTDPARTS=y diff --git a/configs/xilinx_zynqmp_virt_defconfig b/configs/xilinx_zynqmp_virt_defconfig index c40490a9f801..f7364aae7099 100644 --- a/configs/xilinx_zynqmp_virt_defconfig +++ b/configs/xilinx_zynqmp_virt_defconfig @@ -91,6 +91,7 @@ CONFIG_CMD_TIME=y CONFIG_CMD_GETTIME=y CONFIG_CMD_TIMER=y CONFIG_CMD_REGULATOR=y +CONFIG_CMD_SMC=y CONFIG_CMD_TPM=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_SQUASHFS=y
return 0; }
Applied. M
Michal Simek
