[U-Boot] [PATCH] Add assert() for debug assertions
assert() is like BUG_ON() but compiles to nothing unless DEBUG is defined. This is useful when a condition is an error but a board reset is unlikely to fix it, so it is better to soldier on in hope. Assertion failures should be caught during development/test.
It turns out that assert() is defined separately in a few places in U-Boot with various meanings. This patch cleans up some of these.
Build errors exposed by this change (and defining DEBUG) are also fixed in this patch.
Signed-off-by: Simon Glass sjg@chromium.org --- common/dlmalloc.c | 7 ------- include/common.h | 13 +++++++++++++ include/malloc.h | 8 -------- lib/qsort.c | 5 ----- 4 files changed, 13 insertions(+), 20 deletions(-)
diff --git a/common/dlmalloc.c b/common/dlmalloc.c index e9bab09..f2080c6 100644 --- a/common/dlmalloc.c +++ b/common/dlmalloc.c @@ -286,13 +286,6 @@ extern "C" {
-#ifdef DEBUG -#include <assert.h> -#else -#define assert(x) ((void)0) -#endif - - /* INTERNAL_SIZE_T is the word-size used for internal bookkeeping of chunk sizes. On a 64-bit machine, you can reduce malloc diff --git a/include/common.h b/include/common.h index 1e21b7a..f2f1326 100644 --- a/include/common.h +++ b/include/common.h @@ -119,9 +119,22 @@ typedef volatile unsigned char vu_char; #ifdef DEBUG #define debug(fmt,args...) printf (fmt ,##args) #define debugX(level,fmt,args...) if (DEBUG>=level) printf(fmt,##args); + +/* + * An assertion is run-time check done in debug mode only. If DEBUG is not + * defined then it is skipped. It does not BUG or halt U-Boot, but tries to + * continue execution in any case. It is hoped that all failing assertions + * are found before release, and after release it is hoped that they don't + * matter. But in any case these failing assertions cannot be fixed with a + * BUG-type reset (which may just do the same assertion again). + */ +#define assert(x) \ + ({ if (!(x)) printf("Assertion failure '%s' %s line %d\n", \ + #x, __FILE__, __LINE__); }) #else #define debug(fmt,args...) #define debugX(level,fmt,args...) +#define assert(x) #endif /* DEBUG */
#define error(fmt, args...) do { \ diff --git a/include/malloc.h b/include/malloc.h index 3e145ad..ecf3c67 100644 --- a/include/malloc.h +++ b/include/malloc.h @@ -285,14 +285,6 @@ extern "C" {
-#ifdef DEBUG -/* #include <assert.h> */ -#define assert(x) ((void)0) -#else -#define assert(x) ((void)0) -#endif - - /* INTERNAL_SIZE_T is the word-size used for internal bookkeeping of chunk sizes. On a 64-bit machine, you can reduce malloc diff --git a/lib/qsort.c b/lib/qsort.c index 1cc0d31..86c392c 100644 --- a/lib/qsort.c +++ b/lib/qsort.c @@ -17,11 +17,6 @@
#include <linux/types.h> #include <exports.h> -#if 0 -#include <assert.h> -#else -#define assert(arg) -#endif
void qsort(void *base, size_t nel,
On Wednesday, June 22, 2011 17:04:49 Simon Glass wrote:
- An assertion is run-time check done in debug mode only. If DEBUG is not
- defined then it is skipped. It does not BUG or halt U-Boot, but tries
- ({ if (!(x)) printf("Assertion failure '%s' %s line %d\n", \
the trouble with ifdef magic like this is that errors/warnings can be introduced when DEBUG isnt defined, and then only noticed when DEBUG is defined. so how about:
#ifdef DEBUG # define _DEBUG 1 #else # define _DEBUG 2 #endif #define assert(x) \ do { \ if ((x) && _DEBUG) \ printf("%s:%s():%i: assertion failure: %s\n", \ __FILE__, __func__, __LINE__, #x); \ } while (0)
(and yes, i know debug() and debugX() are also broken this way) -mike
Dear Mike Frysinger,
In message 201106221723.27679.vapier@gentoo.org you wrote:
the trouble with ifdef magic like this is that errors/warnings can be=20 introduced when DEBUG isnt defined, and then only noticed when DEBUG is=20 defined. so how about:
1 and 2? You don't happen to mean 1 and 0 ?
This way the code will _always_ be compiled in.
err, of course. i had something semi-related on my mind as i banged that out. -mike
Hi Mike & Wolfgang,
That sounds better thanks, I will send a new patch. It would be good to have it compile the same code in and out of DEBUG mode.
-mike
- #x, __FILE__, __LINE__); })
Symbian OS, that had an array of defensive programming features, had two ASSERT macros:
Something like ASSERT_DEBUG(x) and ASSERT_ALWAYS(x).
ASSERT_DEBUG(x) could be used more liberally because it is compiled out in production image and ASSERT_ALWAYS(x) could be used in more critical run-time errors.
My rule of thumb for using these two was this:
1. ASSERT_DEBUG(x) was used for invariant checking, that's for catching errors that could arise out of programming errors. This was used more liberally in the code. 2. ASSERT_ALWAYS(x) was used to catch erros due to invalid run-time parameters that one may not be able to catch during testing.
best regards, Aneesh
Hi Aneesh,
Symbian OS can live on in U-Boot!
- ASSERT_DEBUG(x) was used for invariant checking, that's for catching errors
With this patch we have:
- assert: compiled out for production code, used for debug, like your ASSERT_DEBUG I think - BUG_ON: halt/reset even in production code, used for production code and critical faults where continued execution is certainly pointless or counterproductive. Like your ASSERT_ALWAYS I think.
best regards, Aneesh _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
if we're going to go this route, then we should just take the API linux already has. that means WARN/WARN_ON/BUG/BUG_ON. we've got more in common with linux than we'll ever have with symbian. -mike
Mike Frysinger
V, Aneesh
