[PATCH] spl: ext: Use partition size for mount
Since commit 9905cae65e03 ("fs: ext4: check the minimal partition size to mount"), a valid size needs to be provided when mounting an ext filesystem. Fix the spl ext driver to use the parition size instead of 0 when mounting the filesystem.
Signed-off-by: Mayuresh Chitale mchitale@ventanamicro.com --- common/spl/spl_ext.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/common/spl/spl_ext.c b/common/spl/spl_ext.c index f117c630bf..2bf3434439 100644 --- a/common/spl/spl_ext.c +++ b/common/spl/spl_ext.c @@ -28,7 +28,7 @@ int spl_load_image_ext(struct spl_image_info *spl_image,
ext4fs_set_blk_dev(block_dev, &part_info);
- err = ext4fs_mount(0); + err = ext4fs_mount(part_info.size); if (!err) { #ifdef CONFIG_SPL_LIBCOMMON_SUPPORT printf("%s: ext4fs mount err - %d\n", __func__, err); @@ -82,7 +82,7 @@ int spl_load_image_ext_os(struct spl_image_info *spl_image,
Mayuresh Chitale
