[PATCH] imx8m*_venice_defconfig: fix default bootcmd
commit 970bf8603b87 ("Convert CONFIG_USE_BOOTCOMMAND et al to Kconfig") had an unintended side effect of resulting in a bootcmd env var change for boards like venice that did not have CONFIG_USE_BOOTCOMMAND defined and relied on it being defaulted in include/config_distro_bootcmd.h. Following that patch it instead got defaulted in tools/env/fw_env_private.h
Fix this by enabling CONFIG_USE_BOOTCOMMAND for venice.
Fixes: commit 970bf8603b87 ("Convert CONFIG_USE_BOOTCOMMAND et al to Kconfig") Signed-off-by: Tim Harvey tharvey@gateworks.com --- configs/imx8mm_venice_defconfig | 1 - configs/imx8mn_venice_defconfig | 1 - configs/imx8mp_venice_defconfig | 1 - 3 files changed, 3 deletions(-)
diff --git a/configs/imx8mm_venice_defconfig b/configs/imx8mm_venice_defconfig index a2bd27ab5729..a72b9033d8a9 100644 --- a/configs/imx8mm_venice_defconfig +++ b/configs/imx8mm_venice_defconfig @@ -28,7 +28,6 @@ CONFIG_SPL_LOAD_FIT=y # CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_SYSTEM_SETUP=y -# CONFIG_USE_BOOTCOMMAND is not set CONFIG_USE_PREBOOT=y CONFIG_PREBOOT="gsc wd-disable" CONFIG_BOARD_LATE_INIT=y diff --git a/configs/imx8mn_venice_defconfig b/configs/imx8mn_venice_defconfig index a4e54ff50cf1..821252ad600c 100644 --- a/configs/imx8mn_venice_defconfig +++ b/configs/imx8mn_venice_defconfig @@ -29,7 +29,6 @@ CONFIG_SPL_LOAD_FIT=y # CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_SYSTEM_SETUP=y -# CONFIG_USE_BOOTCOMMAND is not set CONFIG_USE_PREBOOT=y CONFIG_PREBOOT="gsc wd-disable" CONFIG_BOARD_LATE_INIT=y diff --git a/configs/imx8mp_venice_defconfig b/configs/imx8mp_venice_defconfig index d1a1bfa82acf..339e740349d4 100644 --- a/configs/imx8mp_venice_defconfig +++ b/configs/imx8mp_venice_defconfig @@ -29,7 +29,6 @@ CONFIG_SPL_LOAD_FIT=y # CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_SYSTEM_SETUP=y -# CONFIG_USE_BOOTCOMMAND is not set CONFIG_USE_PREBOOT=y CONFIG_PREBOOT="gsc wd-disable" CONFIG_BOARD_LATE_INIT=y
diff --git a/configs/imx8mm_venice_defconfig b/configs/imx8mm_venice_defconfig index a2bd27ab5729..a72b9033d8a9 100644 --- a/configs/imx8mm_venice_defconfig +++ b/configs/imx8mm_venice_defconfig @@ -28,7 +28,6 @@ CONFIG_SPL_LOAD_FIT=y # CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_SYSTEM_SETUP=y -# CONFIG_USE_BOOTCOMMAND is not set CONFIG_USE_PREBOOT=y CONFIG_PREBOOT="gsc wd-disable" CONFIG_BOARD_LATE_INIT=y diff --git a/configs/imx8mn_venice_defconfig b/configs/imx8mn_venice_defconfig index a4e54ff50cf1..821252ad600c 100644 --- a/configs/imx8mn_venice_defconfig +++ b/configs/imx8mn_venice_defconfig @@ -29,7 +29,6 @@ CONFIG_SPL_LOAD_FIT=y # CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_SYSTEM_SETUP=y -# CONFIG_USE_BOOTCOMMAND is not set CONFIG_USE_PREBOOT=y CONFIG_PREBOOT="gsc wd-disable" CONFIG_BOARD_LATE_INIT=y diff --git a/configs/imx8mp_venice_defconfig b/configs/imx8mp_venice_defconfig index d1a1bfa82acf..339e740349d4 100644 --- a/configs/imx8mp_venice_defconfig +++ b/configs/imx8mp_venice_defconfig @@ -29,7 +29,6 @@ CONFIG_SPL_LOAD_FIT=y # CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_SYSTEM_SETUP=y -# CONFIG_USE_BOOTCOMMAND is not set CONFIG_USE_PREBOOT=y CONFIG_PREBOOT="gsc wd-disable" CONFIG_BOARD_LATE_INIT=y -- 2.25.1
Stefano,
I probably needed to send this one to you as it is for imx8m board defconfigs and has a Fixes tag that fixes a regression. With a pending release in a few weeks, it would be nice to get fixes merged. I'm not sure if this must go through your tree or could instead go through Tom's tree.
Best Regards,
Tim
Stefano,
As this applies cleanly on top of the current imx PR, and is a Fixes, I'll take this directly.
Tim Harvey
