Please pull u-boot-marvell/master
Hi Tom,
please pull this first batch of Marvell related patches:
---------------------------------------------------------------- - dns325: Enable 2nd harddrive (Peter & Stefan) - marvell: cn9310-crb: Misc fixes to SPI / pincntrl in DTS (Chris) - kirkwood: Add support for ZyXEL NSA325 board (Tony) - sata_mv: Add bootstd hook to enable sata_bootdev (Tony) - x240/AC5/AC5X: Disable SMBIOS (Chris) - Revert "arm: mvebu: x240: Use i2c-gpio instead of built in controller" (Chris) - DS116/N2350: Enable bootstd (Tony) - clearfog: Support multiple DDR sizes (Josua) ----------------------------------------------------------------
Here the Azure build, without any issues:
https://dev.azure.com/sr0718/u-boot/_build/results?buildId=317&view=resu...
Thanks, Stefan
The following changes since commit 3c3f1626919cd93cbe6c56e3849937de5be18dbb:
Merge tag 'dm-pull-13oct23' of https://source.denx.de/u-boot/custodians/u-boot-dm (2023-10-14 10:50:20 -0400)
git@source.denx.de:u-boot/custodians/u-boot-marvell.git
for you to fetch changes up to d2387c6227715eee8fd07466ed4eeffdcc9f86d2:
arm: mvebu: AC5/AC5X: Disable SMBIOS (2023-10-16 14:00:45 +0200)
---------------------------------------------------------------- Chris Packham (5): ARM64: dts: marvell: cn9310: Use appropriate label for spi1 pins ARM64: dts: marvell: cn9310-crb: Remove duplicate pinctrl arm: mvebu: x240: Disable SMBIOS Revert "arm: mvebu: x240: Use i2c-gpio instead of built in controller" arm: mvebu: AC5/AC5X: Disable SMBIOS
Josua Mayer (2): arm: mvebu: clearfog: read number of ddr channels from tlv data arm: mvebu: clearfog: support 512MB memory size from tlv eeprom
Stefan Roese (1): kirkwood: dns325: Enable 2nd harddrive
Tony Dinh (4): arm: kirkwood: Add support for ZyXEL NSA325 board arm: mvebu: sata_mv: Add bootstd hook to enable sata_bootdev arm: mvebu: Enable bootstd for Synology DS116 board arm: mvebu: Enable bootstd for Thecus N2350 board
arch/arm/dts/Makefile | 1 + arch/arm/dts/ac5-98dx35xx-atl-x240.dts | 30 +--- arch/arm/dts/cn9130-crb.dtsi | 7 +- arch/arm/dts/cn9130-db.dtsi | 2 +- arch/arm/dts/cn9130.dtsi | 2 +- arch/arm/dts/kirkwood-6282.dtsi | 161 +++++++++++++++++++++ arch/arm/dts/kirkwood-nsa325.dts | 231 +++++++++++++++++++++++++++++++ arch/arm/dts/kirkwood-nsa3x0-common.dtsi | 157 +++++++++++++++++++++ arch/arm/mach-kirkwood/Kconfig | 7 + board/d-link/dns325/dns325.c | 1 + board/solidrun/clearfog/clearfog.c | 17 ++- board/solidrun/common/tlv_data.c | 7 +- board/solidrun/common/tlv_data.h | 1 + board/zyxel/nsa325/Kconfig | 12 ++ board/zyxel/nsa325/MAINTAINERS | 9 ++ board/zyxel/nsa325/Makefile | 11 ++ board/zyxel/nsa325/kwbimage.cfg | 55 ++++++++ board/zyxel/nsa325/nsa325.c | 196 ++++++++++++++++++++++++++ configs/ds116_defconfig | 3 +- configs/mvebu_ac5_rd_defconfig | 1 + configs/n2350_defconfig | 3 +- configs/nsa325_defconfig | 81 +++++++++++ configs/x240_defconfig | 2 +- drivers/ata/sata_mv.c | 8 +- include/configs/ds116.h | 12 +- include/configs/n2350.h | 12 +- include/configs/nsa325.h | 37 +++++ 27 files changed, 1007 insertions(+), 59 deletions(-) create mode 100644 arch/arm/dts/kirkwood-6282.dtsi create mode 100644 arch/arm/dts/kirkwood-nsa325.dts create mode 100644 arch/arm/dts/kirkwood-nsa3x0-common.dtsi create mode 100644 board/zyxel/nsa325/Kconfig create mode 100644 board/zyxel/nsa325/MAINTAINERS create mode 100644 board/zyxel/nsa325/Makefile create mode 100644 board/zyxel/nsa325/kwbimage.cfg create mode 100644 board/zyxel/nsa325/nsa325.c create mode 100644 configs/nsa325_defconfig create mode 100644 include/configs/nsa325.h
Stefan Roese
