[U-Boot] BUG: fastmap and u-boot's ubi write command
[CC u-boot ML since it may not be a kernel only related bug(s)]
Hi Richard, Artem,
I'm still playing with fastmap and I ran into something. It's involving u-boot's "ubi write" command and fastmap. What I'm doing is: - Flashing a mtd partition with a userspace.ubi image via u-boot - Booting linux one or to times - Flashing the UBI volume rootfs with a rootfs.ubifs image via u-boot - Booting linux one or to times.
And, depending on fastmap not compiled/disable/auto I've got an ubi_assert that fails and a slowpath warning.
Here's the story: U-Boot 2013.07 Kernel 3.11.1 NAND: - 128KiB PEB - 2KiB page - 2048 PEB - no subpage mapping is: 0x000000000000-0x000000020000 : "dtb" (128KiB) 0x000000020000-0x000000a00000 : "Kernel" (9.875KiB) 0x000000a00000-0x00000ff80000 : "UBI" (245.5 KiB) 0x00000ff80000-0x000010000000 : "BBT" (512KiB)
1- With Fastmap NOT compiled - Flashing the UBI mtd partition under u-boot:
fatload usb 0 0x20008000 /userspace.ubi nand device ubi nand erase.part ubi
NAND erase.part: device 0 offset 0xa00000, size 0xf580000 OK
nand write.trimffs 0x20008000 ubi 35a0000
NAND write: device 0 offset 0xa00000, size 0x35a0000 56229888 bytes written: OK Booting a non-FASTMAP kernel: [...] [ 0.789062] UBI: attaching mtd2 to ubi0 [ 1.351562] UBI: scanning is finished [ 1.367187] UBI: attached mtd2 (name "UBI", size 245 MiB) to ubi0 [ 1.375000] UBI: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes [ 1.382812] UBI: min./max. I/O unit sizes: 2048/2048, sub-page size 2048 [ 1.390625] UBI: VID header offset: 2048 (aligned 2048), data offset: 4096 [ 1.398437] UBI: good PEBs: 1964, bad PEBs: 0, corrupted PEBs: 0 [ 1.398437] UBI: user volume: 3, internal volumes: 1, max. volumes count: 128 [ 1.406250] UBI: max/mean erase counter: 0/0, WL threshold: 4096, image sequence number: 891983656 [ 1.414062] UBI: available PEBs: 2, total reserved PEBs: 1962, PEBs reserved for bad PEB handling: 40 [ 1.421875] UBI: background thread "ubi_bgt0d" started, PID 354 [ 1.437500] UBIFS: background thread "ubifs_bgt0_0" started, PID 356 [ 1.523437] UBIFS: mounted UBI device 0, volume 0, name "rootfs" [ 1.523437] UBIFS: LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes [ 1.531250] UBIFS: FS size: 63614976 bytes (60 MiB, 501 LEBs), journal size 8634368 bytes (8 MiB, 68 LEBs) [ 1.539062] UBIFS: reserved for root: 0 bytes (0 KiB) [ 1.546875] UBIFS: media format: w4/r0 (latest is w4/r0), UUID 47FE5308-55FD-4F1C-BD13-C23AED232326, small LPT model
=> OK
Now, under u-boot, flashing only the ubi volume "rootfs":
fatload usb 0 0x20008000 /rootfs.ubifs
54218752 bytes read in 3259 ms (15.9 MiB/s)
ubi part ubi
UBI: attaching mtd1 to ubi0 UBI: physical eraseblock size: 131072 bytes (128 KiB) UBI: logical eraseblock size: 126976 bytes UBI: smallest flash I/O unit: 2048 UBI: VID header offset: 2048 (aligned 2048) UBI: data offset: 4096 UBI: attached mtd1 to ubi0 UBI: MTD device name: "mtd=2" UBI: MTD device size: 245 MiB UBI: number of good PEBs: 1964 UBI: number of bad PEBs: 0 UBI: max. allowed volumes: 128 UBI: wear-leveling threshold: 4096 UBI: number of internal volumes: 1 UBI: number of user volumes: 3 UBI: available PEBs: 23 UBI: total number of reserved PEBs: 1941 UBI: number of PEBs reserved for bad PEB handling: 19 UBI: max/mean erase counter: 2/0
ubi write 0x20008000 rootfs 33b5000
54218752 bytes written to volume rootfs
Booting the same kernel: [ 0.812500] UBI: attaching mtd2 to ubi0 [ 1.664062] UBI: scanning is finished [ 1.687500] UBI: attached mtd2 (name "UBI", size 245 MiB) to ubi0 [ 1.687500] UBI: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes [ 1.695312] UBI: min./max. I/O unit sizes: 2048/2048, sub-page size 2048 [ 1.703125] UBI: VID header offset: 2048 (aligned 2048), data offset: 4096 [ 1.710937] UBI: good PEBs: 1964, bad PEBs: 0, corrupted PEBs: 0 [ 1.718750] UBI: user volume: 3, internal volumes: 1, max. volumes count: 128 [ 1.718750] UBI: max/mean erase counter: 3/1, WL threshold: 4096, image sequence number: 891983656 [ 1.726562] UBI: available PEBs: 2, total reserved PEBs: 1962, PEBs reserved for bad PEB handling: 40 [ 1.734375] UBI: background thread "ubi_bgt0d" started, PID 354 [ 1.750000] UBIFS: background thread "ubifs_bgt0_0" started, PID 356 [ 1.789062] UBIFS: mounted UBI device 0, volume 0, name "rootfs" [ 1.796875] UBIFS: LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes [ 1.804687] UBIFS: FS size: 63614976 bytes (60 MiB, 501 LEBs), journal size 8634368 bytes (8 MiB, 68 LEBs) [ 1.812500] UBIFS: reserved for root: 0 bytes (0 KiB) [ 1.812500] UBIFS: media format: w4/r0 (latest is w4/r0), UUID 47FE5308-55FD-4F1C-BD13-C23AED232326, small LPT model
=> all OK
2- With Fastmap compiled and ubi.fm_autoconvert=0 - Flashing the UBI mtd partition under u-boot:
NAND write: device 0 offset 0xa00000, size 0x35a0000 56229888 bytes written: OK Booting a FASTMAP kernel: [...] [ 0.812500] UBI: default fastmap pool size: 95 [ 0.820312] UBI: default fastmap WL pool size: 25 [ 0.820312] UBI: attaching mtd2 to ubi0 [ 1.289062] UBI: scanning is finished [ 1.304687] UBI: attached mtd2 (name "UBI", size 245 MiB) to ubi0 [ 1.312500] UBI: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes [ 1.320312] UBI: min./max. I/O unit sizes: 2048/2048, sub-page size 2048 [ 1.328125] UBI: VID header offset: 2048 (aligned 2048), data offset: 4096 [ 1.328125] UBI: good PEBs: 1964, bad PEBs: 0, corrupted PEBs: 0 [ 1.335937] UBI: user volume: 3, internal volumes: 1, max. volumes count: 128 [ 1.343750] UBI: max/mean erase counter: 0/0, WL threshold: 4096, image sequence number: 891983656 [ 1.351562] UBI: available PEBs: 0, total reserved PEBs: 1964, PEBs reserved for bad PEB handling: 40 [ 1.359375] UBI: background thread "ubi_bgt0d" started, PID 355 [ 1.453125] UBIFS: background thread "ubifs_bgt0_0" started, PID 357 [ 1.515625] UBIFS: mounted UBI device 0, volume 0, name "rootfs" [ 1.515625] UBIFS: LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes [ 1.523437] UBIFS: FS size: 63614976 bytes (60 MiB, 501 LEBs), journal size 8634368 bytes (8 MiB, 68 LEBs) [ 1.531250] UBIFS: reserved for root: 0 bytes (0 KiB) [ 1.539062] UBIFS: media format: w4/r0 (latest is w4/r0), UUID 47FE5308-55FD-4F1C-BD13-C23AED232326, small LPT model => OK
Rebooting: : [ 0.812500] UBI: default fastmap pool size: 95 [ 0.820312] UBI: default fastmap WL pool size: 25 [ 0.820312] UBI: attaching mtd2 to ubi0 [ 1.578125] UBI: scanning is finished [ 1.601562] UBI: attached mtd2 (name "UBI", size 245 MiB) to ubi0 [ 1.609375] UBI: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes [ 1.617187] UBI: min./max. I/O unit sizes: 2048/2048, sub-page size 2048 [ 1.617187] UBI: VID header offset: 2048 (aligned 2048), data offset: 4096 [ 1.625000] UBI: good PEBs: 1964, bad PEBs: 0, corrupted PEBs: 0 [ 1.632812] UBI: user volume: 3, internal volumes: 1, max. volumes count: 128 [ 1.640625] UBI: max/mean erase counter: 2/0, WL threshold: 4096, image sequence number: 891983656 [ 1.648437] UBI: available PEBs: 0, total reserved PEBs: 1964, PEBs reserved for bad PEB handling: 40 [ 1.656250] UBI: background thread "ubi_bgt0d" started, PID 355
Still ok.
ubi part ubi
Booting the same kernel: [ 0.804687] UBI: default fastmap pool size: 95 [ 0.812500] UBI: default fastmap WL pool size: 25 [ 0.812500] UBI: attaching mtd2 to ubi0 [ 1.570312] UBI: scanning is finished [ 1.593750] UBI: attached mtd2 (name "UBI", size 245 MiB) to ubi0 [ 1.601562] UBI: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes [ 1.609375] UBI: min./max. I/O unit sizes: 2048/2048, sub-page size 2048 [ 1.609375] UBI: VID header offset: 2048 (aligned 2048), data offset: 4096 [ 1.617187] UBI: good PEBs: 1964, bad PEBs: 0, corrupted PEBs: 0 [ 1.625000] UBI: user volume: 3, internal volumes: 1, max. volumes count: 128 [ 1.632812] UBI: max/mean erase counter: 3/1, WL threshold: 4096, image sequence number: 891983656 [ 1.640625] UBI: available PEBs: 0, total reserved PEBs: 1964, PEBs reserved for bad PEB handling: 40 [ 1.648437] UBI: background thread "ubi_bgt0d" started, PID 355 [ 1.664062] UBIFS: background thread "ubifs_bgt0_0" started, PID 357 [ 1.703125] UBIFS: mounted UBI device 0, volume 0, name "rootfs" [ 1.710937] UBIFS: LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes [ 1.718750] UBIFS: FS size: 63614976 bytes (60 MiB, 501 LEBs), journal size 8634368 bytes (8 MiB, 68 LEBs) [ 1.726562] UBIFS: reserved for root: 0 bytes (0 KiB) [ 1.734375] UBIFS: media format: w4/r0 (latest is w4/r0), UUID 47FE5308-55FD-4F1C-BD13-C23AED232326, small LPT model => All OK (I rebooted one or two times, no problem showing up)
Now, booting with ubi.fm_autoconvert=1: [ 0.812500] UBI: default fastmap pool size: 95 [ 0.820312] UBI: default fastmap WL pool size: 25 [ 0.820312] UBI: attaching mtd2 to ubi0 [ 1.578125] UBI: scanning is finished [ 1.601562] UBI: attached mtd2 (name "UBI", size 245 MiB) to ubi0 [ 1.609375] UBI: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes [ 1.609375] UBI: min./max. I/O unit sizes: 2048/2048, sub-page size 2048 [ 1.617187] UBI: VID header offset: 2048 (aligned 2048), data offset: 4096 [ 1.625000] UBI: good PEBs: 1964, bad PEBs: 0, corrupted PEBs: 0 [ 1.632812] UBI: user volume: 3, internal volumes: 1, max. volumes count: 128 [ 1.640625] UBI: max/mean erase counter: 3/1, WL threshold: 4096, image sequence number: 891983656 [ 1.648437] UBI: available PEBs: 0, total reserved PEBs: 1964, PEBs reserved for bad PEB handling: 40 [ 1.656250] UBI: background thread "ubi_bgt0d" started, PID 355 [ 1.671875] UBIFS: background thread "ubifs_bgt0_0" started, PID 357 [ 1.710937] UBIFS: mounted UBI device 0, volume 0, name "rootfs" [ 1.718750] UBIFS: LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes [ 1.726562] UBIFS: FS size: 63614976 bytes (60 MiB, 501 LEBs), journal size 8634368 bytes (8 MiB, 68 LEBs) [ 1.734375] UBIFS: reserved for root: 0 bytes (0 KiB) [ 1.742187] UBIFS: media format: w4/r0 (latest is w4/r0), UUID 47FE5308-55FD-4F1C-BD13-C23AED232326, small LPT model => Still OK Rebooting again with ubi.fm_autoconvert=1: [ 0.812500] UBI: default fastmap pool size: 95 [ 0.820312] UBI: default fastmap WL pool size: 25 [ 0.820312] UBI: attaching mtd2 to ubi0 [ 0.851562] UBI error: ubi_scan_fastmap: Attach by fastmap failed, doing a full scan! [ 1.593750] UBI: scanning is finished [ 1.601562] UBI assert failed in ubi_wl_init at 1967 (pid 1) [ 1.609375] CPU: 0 PID: 1 Comm: swapper Not tainted 3.11.1 #5 [ 1.617187] [<c0012e20>] (unwind_backtrace+0x0/0xe0) from [<c0010bb8>] (show_stack+0x10/0x14) [ 1.625000] [<c0010bb8>] (show_stack+0x10/0x14) from [<c01a0704>] (ubi_wl_init+0x3d0/0x4b8) [ 1.632812] [<c01a0704>] (ubi_wl_init+0x3d0/0x4b8) from [<c01a2cd4>] (ubi_attach+0x270/0x34c) [ 1.640625] [<c01a2cd4>] (ubi_attach+0x270/0x34c) from [<c0197678>] (ubi_attach_mtd_dev+0x2b8/0x86c) [ 1.648437] [<c0197678>] (ubi_attach_mtd_dev+0x2b8/0x86c) from [<c0346630>] (ubi_init+0x1d8/0x29c) [ 1.656250] [<c0346630>] (ubi_init+0x1d8/0x29c) from [<c0008810>] (do_one_initcall+0x94/0x144) [ 1.664062] [<c0008810>] (do_one_initcall+0x94/0x144) from [<c0335a9c>] (kernel_init_freeable+0xe8/0x1ac) [ 1.671875] [<c0335a9c>] (kernel_init_freeable+0xe8/0x1ac) from [<c0251500>] (kernel_init+0x8/0xe4) [ 1.679687] [<c0251500>] (kernel_init+0x8/0xe4) from [<c000e590>] (ret_from_fork+0x14/0x24) [ 1.695312] UBI: attached mtd2 (name "UBI", size 245 MiB) to ubi0 [ 1.703125] UBI: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes [ 1.703125] UBI: min./max. I/O unit sizes: 2048/2048, sub-page size 2048 [ 1.710937] UBI: VID header offset: 2048 (aligned 2048), data offset: 4096 [ 1.718750] UBI: good PEBs: 1964, bad PEBs: 0, corrupted PEBs: 0 [ 1.726562] UBI: user volume: 3, internal volumes: 1, max. volumes count: 128 [ 1.726562] UBI: max/mean erase counter: 3/1, WL threshold: 4096, image sequence number: 891983656 [ 1.734375] UBI: available PEBs: 0, total reserved PEBs: 1964, PEBs reserved for bad PEB handling: 40 [ 1.742187] UBI: background thread "ubi_bgt0d" started, PID 355 [ 1.757812] UBIFS: background thread "ubifs_bgt0_0" started, PID 357 [ 1.796875] UBIFS: mounted UBI device 0, volume 0, name "rootfs" [ 1.804687] UBIFS: LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes [ 1.812500] UBIFS: FS size: 63614976 bytes (60 MiB, 501 LEBs), journal size 8634368 bytes (8 MiB, 68 LEBs) [ 1.820312] UBIFS: reserved for root: 0 bytes (0 KiB) [ 1.820312] UBIFS: media format: w4/r0 (latest is w4/r0), UUID 47FE5308-55FD-4F1C-BD13-C23AED232326, small LPT model [ 1.828125] VFS: Mounted root (ubifs filesystem) on device 0:11. [ 1.835937] devtmpfs: mounted [ 1.835937] Freeing unused kernel memory: 112K (c0335000 - c0351000) [ 2.187500] UBI error: ubi_update_fastmap: could not find any anchor PEB [ 2.195312] UBI warning: ubi_update_fastmap: Unable to write new fastmap, err=-28 => If I reboot again, I still have those error messages.
3- With Fastmap compiled and ubi.fm_autoconvert=1 - Flashing the UBI mtd partition under u-boot:
NAND write: device 0 offset 0xa00000, size 0x35a0000 56229888 bytes written: OK Booting a FASTMAP kernel with ubi.fm_autoconvert=1: [...] [ 0.812500] UBI: default fastmap pool size: 95 [ 0.820312] UBI: default fastmap WL pool size: 25 [ 0.820312] UBI: attaching mtd2 to ubi0 [ 1.289062] UBI: scanning is finished [ 1.304687] UBI: attached mtd2 (name "UBI", size 245 MiB) to ubi0 [ 1.312500] UBI: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes [ 1.320312] UBI: min./max. I/O unit sizes: 2048/2048, sub-page size 2048 [ 1.328125] UBI: VID header offset: 2048 (aligned 2048), data offset: 4096 [ 1.328125] UBI: good PEBs: 1964, bad PEBs: 0, corrupted PEBs: 0 [ 1.335937] UBI: user volume: 3, internal volumes: 1, max. volumes count: 128 [ 1.343750] UBI: max/mean erase counter: 0/0, WL threshold: 4096, image sequence number: 891983656 [ 1.351562] UBI: available PEBs: 0, total reserved PEBs: 1964, PEBs reserved for bad PEB handling: 40 [ 1.359375] UBI: background thread "ubi_bgt0d" started, PID 355 [ 1.437500] UBI error: ubi_update_fastmap: could not find any anchor PEB [ 1.445312] UBI warning: ubi_update_fastmap: Unable to write new fastmap, err=-28 =>OK
Rebooting 2 times to let FASTMAP show its power: [ 0.812500] UBI: default fastmap pool size: 95 [ 0.820312] UBI: default fastmap WL pool size: 25 [ 0.820312] UBI: attaching mtd2 to ubi0 [ 0.929687] UBI: attached by fastmap [ 0.937500] UBI: fastmap pool size: 95 [ 0.937500] UBI: fastmap WL pool size: 25 [ 0.960937] UBI: attached mtd2 (name "UBI", size 245 MiB) to ubi0 GREAT !
ubi part ubi
UBI: attaching mtd1 to ubi0 UBI: physical eraseblock size: 131072 bytes (128 KiB) UBI: logical eraseblock size: 126976 bytes UBI: smallest flash I/O unit: 2048 UBI: VID header offset: 2048 (aligned 2048) UBI: data offset: 4096 UBI: "delete" compatible internal volume 2147479552:0 found, remove it UBI: attached mtd1 to ubi0 UBI: MTD device name: "mtd=2" UBI: MTD device size: 245 MiB UBI: number of good PEBs: 1964 UBI: number of bad PEBs: 0 UBI: max. allowed volumes: 128 UBI: wear-leveling threshold: 4096 UBI: number of internal volumes: 1 UBI: number of user volumes: 3 UBI: available PEBs: 23 UBI: total number of reserved PEBs: 1941 UBI: number of PEBs reserved for bad PEB handling: 19 UBI: max/mean erase counter: 2/0
=>FASTMAP internal volume has been erased, which is the expected behaviour.
Booting the same kernel, still with ubi.fm_autoconvert=1: [...] [ 0.812500] UBI: default fastmap pool size: 95 [ 0.820312] UBI: default fastmap WL pool size: 25 [ 0.820312] UBI: attaching mtd2 to ubi0 [ 1.585937] UBI: scanning is finished [ 1.601562] UBI: attached mtd2 (name "UBI", size 245 MiB) to ubi0 [ 1.609375] UBI: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes [ 1.617187] UBI: min./max. I/O unit sizes: 2048/2048, sub-page size 2048 [ 1.625000] UBI: VID header offset: 2048 (aligned 2048), data offset: 4096 [ 1.625000] UBI: good PEBs: 1964, bad PEBs: 0, corrupted PEBs: 0 [ 1.632812] UBI: user volume: 3, internal volumes: 1, max. volumes count: 128 [ 1.640625] UBI: max/mean erase counter: 4/1, WL threshold: 4096, image sequence number: 891983656 [ 1.648437] UBI: available PEBs: 0, total reserved PEBs: 1964, PEBs reserved for bad PEB handling: 40 [ 1.656250] UBI: background thread "ubi_bgt0d" started, PID 355 [ 1.703125] UBIFS: background thread "ubifs_bgt0_0" started, PID 357 [ 1.734375] UBIFS: mounted UBI device 0, volume 0, name "rootfs" [ 1.742187] UBIFS: LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes [ 1.750000] UBIFS: FS size: 63614976 bytes (60 MiB, 501 LEBs), journal size 8634368 bytes (8 MiB, 68 LEBs) [ 1.757812] UBIFS: reserved for root: 0 bytes (0 KiB) [ 1.765625] UBIFS: media format: w4/r0 (latest is w4/r0), UUID 47FE5308-55FD-4F1C-BD13-C23AED232326, small LPT model =>OK this time, let's reboot:
[ 0.812500] UBI: default fastmap pool size: 95 [ 0.820312] UBI: default fastmap WL pool size: 25 [ 0.820312] UBI: attaching mtd2 to ubi0 [ 0.914062] UBI error: scan_pool: bad image seq: 0x0, expected: 0x352a9728 [ 0.921875] ------------[ cut here ]------------ [ 0.929687] WARNING: CPU: 0 PID: 1 at drivers/mtd/ubi/fastmap.c:829 ubi_attach_fastmap+0xd38/0xda0() [ 0.937500] Modules linked in: [ 0.937500] CPU: 0 PID: 1 Comm: swapper Not tainted 3.11.1 #5 [ 0.945312] [<c0012e20>] (unwind_backtrace+0x0/0xe0) from [<c0010bb8>] (show_stack+0x10/0x14) [ 0.953125] [<c0010bb8>] (show_stack+0x10/0x14) from [<c001ab2c>] (warn_slowpath_common+0x60/0x80) [ 0.960937] [<c001ab2c>] (warn_slowpath_common+0x60/0x80) from [<c001ab64>] (warn_slowpath_null+0x18/0x1c) [ 0.968750] [<c001ab64>] (warn_slowpath_null+0x18/0x1c) from [<c01a5c8c>] (ubi_attach_fastmap+0xd38/0xda0) [ 0.976562] [<c01a5c8c>] (ubi_attach_fastmap+0xd38/0xda0) from [<c01a62d4>] (ubi_scan_fastmap+0x5b4/0x7b8) [ 0.984375] [<c01a62d4>] (ubi_scan_fastmap+0x5b4/0x7b8) from [<c01a2c2c>] (ubi_attach+0x1c8/0x34c) [ 0.992187] [<c01a2c2c>] (ubi_attach+0x1c8/0x34c) from [<c0197678>] (ubi_attach_mtd_dev+0x2b8/0x86c) [ 1.000000] [<c0197678>] (ubi_attach_mtd_dev+0x2b8/0x86c) from [<c0346630>] (ubi_init+0x1d8/0x29c) [ 1.007812] [<c0346630>] (ubi_init+0x1d8/0x29c) from [<c0008810>] (do_one_initcall+0x94/0x144) [ 1.015625] [<c0008810>] (do_one_initcall+0x94/0x144) from [<c0335a9c>] (kernel_init_freeable+0xe8/0x1ac) [ 1.023437] [<c0335a9c>] (kernel_init_freeable+0xe8/0x1ac) from [<c0251500>] (kernel_init+0x8/0xe4) [ 1.031250] [<c0251500>] (kernel_init+0x8/0xe4) from [<c000e590>] (ret_from_fork+0x14/0x24) [ 1.039062] ---[ end trace 313a7957427257d8 ]--- [ 1.039062] UBI error: ubi_scan_fastmap: Attach by fastmap failed, doing a full scan! [ 1.781250] UBI: scanning is finished [ 1.796875] UBI assert failed in ubi_wl_init at 1967 (pid 1) [ 1.796875] CPU: 0 PID: 1 Comm: swapper Tainted: G W 3.11.1 #5 [ 1.804687] [<c0012e20>] (unwind_backtrace+0x0/0xe0) from [<c0010bb8>] (show_stack+0x10/0x14) [ 1.812500] [<c0010bb8>] (show_stack+0x10/0x14) from [<c01a0704>] (ubi_wl_init+0x3d0/0x4b8) [ 1.820312] [<c01a0704>] (ubi_wl_init+0x3d0/0x4b8) from [<c01a2cd4>] (ubi_attach+0x270/0x34c) [ 1.828125] [<c01a2cd4>] (ubi_attach+0x270/0x34c) from [<c0197678>] (ubi_attach_mtd_dev+0x2b8/0x86c) [ 1.835937] [<c0197678>] (ubi_attach_mtd_dev+0x2b8/0x86c) from [<c0346630>] (ubi_init+0x1d8/0x29c) [ 1.843750] [<c0346630>] (ubi_init+0x1d8/0x29c) from [<c0008810>] (do_one_initcall+0x94/0x144) [ 1.851562] [<c0008810>] (do_one_initcall+0x94/0x144) from [<c0335a9c>] (kernel_init_freeable+0xe8/0x1ac) [ 1.859375] [<c0335a9c>] (kernel_init_freeable+0xe8/0x1ac) from [<c0251500>] (kernel_init+0x8/0xe4) [ 1.867187] [<c0251500>] (kernel_init+0x8/0xe4) from [<c000e590>] (ret_from_fork+0x14/0x24) [ 1.882812] UBI: attached mtd2 (name "UBI", size 245 MiB) to ubi0 [ 1.890625] UBI: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes [ 1.898437] UBI: min./max. I/O unit sizes: 2048/2048, sub-page size 2048 [ 1.898437] UBI: VID header offset: 2048 (aligned 2048), data offset: 4096 [ 1.906250] UBI: good PEBs: 1964, bad PEBs: 0, corrupted PEBs: 0 [ 1.914062] UBI: user volume: 3, internal volumes: 1, max. volumes count: 128 [ 1.921875] UBI: max/mean erase counter: 4/1, WL threshold: 4096, image sequence number: 891983656 [ 1.929687] UBI: available PEBs: 0, total reserved PEBs: 1964, PEBs reserved for bad PEB handling: 40 [ 1.937500] UBI: background thread "ubi_bgt0d" started, PID 355 [ 1.953125] UBIFS: background thread "ubifs_bgt0_0" started, PID 357 [ 1.992187] UBIFS: mounted UBI device 0, volume 0, name "rootfs" [ 2.000000] UBIFS: LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes [ 2.007812] UBIFS: FS size: 63614976 bytes (60 MiB, 501 LEBs), journal size 8634368 bytes (8 MiB, 68 LEBs) [ 2.015625] UBIFS: reserved for root: 0 bytes (0 KiB) [ 2.023437] UBIFS: media format: w4/r0 (latest is w4/r0), UUID 47FE5308-55FD-4F1C-BD13-C23AED232326, small LPT model [ 2.031250] VFS: Mounted root (ubifs filesystem) on device 0:11. [ 2.039062] devtmpfs: mounted [ 2.046875] Freeing unused kernel memory: 112K (c0335000 - c0351000) [ 2.390625] UBI error: ubi_update_fastmap: could not find any anchor PEB [ 2.398437] UBI warning: ubi_update_fastmap: Unable to write new fastmap, err=-28
Richard.
Hi!
Am 25.09.2013 12:59, schrieb Richard Genoud:
Hi Richard, Artem,
Before we waste time, please ensure that you have all recent UBI fixes applied. UBI: Fix PEB leak in wear_leveling_worker() (Merged into 3.12-rc1, on it's way to -stable) UBI: Fix invalidate_fastmap() (Merged into 3.12-rc1) UBI: Fix refill_wl_user_pool() (Pending, http://lkml.org/lkml/2013/8/26/121)
NAND:
- 128KiB PEB
- 2KiB page
- 2048 PEB
- no subpage
=> OK
ubi part ubi
=> all OK
Still ok.
ubi part ubi
This is not the top most error. Do you have to full log? Would be nice to know why fastmap has fallen back to a full scan.
ubi part ubi
This bug got most likely fixed by "UBI: Fix PEB leak in wear_leveling_worker()".
Thanks, //richard
On 25/09/2013 13:10, Richard Weinberger wrote:
Hi!
Hi Richard, Artem,
yes, I have them: git log --oneline v3.11.1..HEAD -- drivers/mtd/ubi/ 241bac5 UBI: fix refill_wl_user_pool() a5858cf UBI: Fix invalidate_fastmap() fd00289 UBI: Fix PEB leak in wear_leveling_worker()
NAND:
- 128KiB PEB
- 2KiB page
- 2048 PEB
- no subpage
=> OK
ubi part ubi
=> all OK
Still ok.
ubi part ubi
Here's the full log for this one: Uncompressing Linux... done, booting the kernel. [ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Linux version 3.11.1 (rgenoud@lnx-rg) (gcc version 4.7.3 (Buildroot 2013.05-00178-gd93036d-dirty) ) #5 Tue Sep 24 15:24:16 CEST 2013 [ 0.000000] CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177 [ 0.000000] CPU: VIVT data cache, VIVT instruction cache [ 0.000000] Machine: Atmel AT91SAM (Device Tree), model: Paratronic LNS [ 0.000000] Memory policy: ECC disabled, Data cache writeback [ 0.000000] AT91: Detected soc type: at91sam9x5 [ 0.000000] AT91: Detected soc subtype: at91sam9g35 [ 0.000000] AT91: sram at 0x300000 of 0x8000 mapped at 0xfef70000 [ 0.000000] On node 0 totalpages: 32768 [ 0.000000] free_area_init_node: node 0, pgdat c0374ccc, node_mem_map c03a6000 [ 0.000000] Normal zone: 256 pages used for memmap [ 0.000000] Normal zone: 0 pages reserved [ 0.000000] Normal zone: 32768 pages, LIFO batch:7 [ 0.000000] Clocks: CPU 400 MHz, master 133 MHz, main 12.000 MHz [ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768 [ 0.000000] pcpu-alloc: [0] 0 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512 [ 0.000000] Kernel command line: console=ttyS0,115200 loglevel=8 ubi.fm_autoconvert=1 rw root=ubi0:rootfs rootfstype=ubifs ubi.mtd=UBI [ 0.000000] PID hash table entries: 512 (order: -1, 2048 bytes) [ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes) [ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes) [ 0.000000] Memory: 126100K/131072K available (2474K kernel code, 140K rwdata, 776K rodata, 115K init, 194K bss, 4972K reserved) [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) [ 0.000000] vmalloc : 0xc8800000 - 0xff000000 ( 872 MB) [ 0.000000] lowmem : 0xc0000000 - 0xc8000000 ( 128 MB) [ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB) [ 0.000000] .text : 0xc0008000 - 0xc0334eec (3252 kB) [ 0.000000] .init : 0xc0335000 - 0xc0351f14 ( 116 kB) [ 0.000000] .data : 0xc0352000 - 0xc03753a0 ( 141 kB) [ 0.000000] .bss : 0xc03753a0 - 0xc03a5cf8 ( 195 kB) [ 0.000000] NR_IRQS:16 nr_irqs:16 16 [ 0.000000] sched_clock: 32 bits at 128 Hz, resolution 7812500ns, wraps every 3489660920ms [ 0.000000] Console: colour dummy device 80x30 [ 0.054687] Calibrating delay loop... 198.76 BogoMIPS (lpj=775168) [ 0.054687] pid_max: default: 32768 minimum: 301 [ 0.062500] Mount-cache hash table entries: 512 [ 0.070312] CPU: Testing write buffer coherency: ok [ 0.070312] Setting up static identity map for 0xc0257aa8 - 0xc0257ae4 [ 0.078125] devtmpfs: initialized [ 0.078125] pinctrl core: initialized pinctrl subsystem [ 0.078125] NET: Registered protocol family 16 [ 0.078125] DMA: preallocated 256 KiB pool for atomic coherent allocations [ 0.109375] gpio-at91 fffff400.gpio: at address fefff400 [ 0.109375] gpio-at91 fffff600.gpio: at address fefff600 [ 0.109375] gpio-at91 fffff800.gpio: at address fefff800 [ 0.117187] gpio-at91 fffffa00.gpio: at address fefffa00 [ 0.117187] pinctrl-at91 pinctrl.2: initialized AT91 pinctrl driver [ 0.117187] tcb_clksrc: tc0 at 16.166 MHz [ 0.148437] bio: create slab <bio-0> at 0 [ 0.148437] at_hdmac ffffec00.dma-controller: Atmel AHB DMA Controller ( cpy slave ), 8 channels [ 0.156250] at_hdmac ffffee00.dma-controller: Atmel AHB DMA Controller ( cpy slave ), 8 channels [ 0.164062] Switched to clocksource tcb_clksrc [ 0.218750] NET: Registered protocol family 2 [ 0.218750] TCP established hash table entries: 1024 (order: 1, 8192 bytes) [ 0.218750] TCP bind hash table entries: 1024 (order: 0, 4096 bytes) [ 0.218750] TCP: Hash tables configured (established 1024 bind 1024) [ 0.218750] TCP: reno registered [ 0.218750] UDP hash table entries: 256 (order: 0, 4096 bytes) [ 0.218750] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) [ 0.218750] NET: Registered protocol family 1 [ 0.218750] RPC: Registered named UNIX socket transport module. [ 0.218750] RPC: Registered udp transport module. [ 0.218750] RPC: Registered tcp transport module. [ 0.218750] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.226562] NetWinder Floating Point Emulator V0.97 (double precision) [ 0.226562] msgmni has been set to 246 [ 0.234375] NET: Registered protocol family 38 [ 0.234375] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253) [ 0.234375] io scheduler noop registered (default) [ 0.242187] gpio-export gpio_export.5: 16 gpio(s) exported [ 0.242187] fffff200.serial: ttyS0 at MMIO 0xfffff200 (irq = 16) is a ATMEL_SERIAL [ 0.593750] console [ttyS0] enabled [ 0.601562] f801c000.serial: ttyS1 at MMIO 0xf801c000 (irq = 23) is a ATMEL_SERIAL [ 0.609375] f8020000.serial: ttyS2 at MMIO 0xf8020000 (irq = 24) is a ATMEL_SERIAL [ 0.625000] brd: module loaded [ 0.640625] loop: module loaded [ 0.656250] atmel_nand: Use On Flash BBT [ 0.656250] atmel_nand 40000000.nand: Using dma0chan0 for DMA transfers. [ 0.664062] ONFI param page 0 valid [ 0.671875] ONFI flash detected [ 0.671875] NAND device: Manufacturer ID: 0x2c, Chip ID: 0xda (Micron MT29F2G08ABAEAWP), 256MiB, page size: 2048, OOB size: 64 [ 0.679687] atmel_nand 40000000.nand: ONFI params, minimum required ECC: 4 bits in 512 bytes [ 0.687500] atmel_nand 40000000.nand: Initialize PMECC params, cap: 4, sector: 512 [ 0.695312] Bad block table found at page 131008, version 0x01 [ 0.703125] Bad block table found at page 130944, version 0x01 [ 0.710937] 4 ofpart partitions found on MTD device atmel_nand [ 0.710937] Creating 4 MTD partitions on "atmel_nand": [ 0.718750] 0x000000000000-0x000000020000 : "dtb" [ 0.726562] 0x000000020000-0x000000a00000 : "Kernel" [ 0.734375] 0x000000a00000-0x00000ff80000 : "UBI" [ 0.742187] 0x00000ff80000-0x000010000000 : "BBT" [ 0.757812] libphy: MACB_mii_bus: probed [ 0.765625] macb f802c000.ethernet eth0: Cadence MACB at 0xf802c000 irq 25 (00:04:a3:91:c4:e3) [ 0.773437] macb f802c000.ethernet eth0: attached PHY driver [Davicom DM9161A] (mii_bus:phy_addr=f802c000.etherne:00, irq=-1) [ 0.781250] at91sam9_wdt: sorry, watchdog is disabled [ 0.789062] at91_wdt: probe of fffffe40.wdt failed with error -5 [ 0.796875] TCP: cubic registered [ 0.804687] NET: Registered protocol family 17 [ 0.804687] Key type dns_resolver registered [ 0.812500] UBI: default fastmap pool size: 95 [ 0.820312] UBI: default fastmap WL pool size: 25 [ 0.820312] UBI: attaching mtd2 to ubi0 [ 0.851562] UBI error: ubi_scan_fastmap: Attach by fastmap failed, doing a full scan! [ 1.593750] UBI: scanning is finished [ 1.601562] UBI assert failed in ubi_wl_init at 1967 (pid 1) [ 1.609375] CPU: 0 PID: 1 Comm: swapper Not tainted 3.11.1 #5 [ 1.617187] [<c0012e20>] (unwind_backtrace+0x0/0xe0) from [<c0010bb8>] (show_stack+0x10/0x14) [ 1.625000] [<c0010bb8>] (show_stack+0x10/0x14) from [<c01a0704>] (ubi_wl_init+0x3d0/0x4b8) [ 1.632812] [<c01a0704>] (ubi_wl_init+0x3d0/0x4b8) from [<c01a2cd4>] (ubi_attach+0x270/0x34c) [ 1.640625] [<c01a2cd4>] (ubi_attach+0x270/0x34c) from [<c0197678>] (ubi_attach_mtd_dev+0x2b8/0x86c) [ 1.648437] [<c0197678>] (ubi_attach_mtd_dev+0x2b8/0x86c) from [<c0346630>] (ubi_init+0x1d8/0x29c) [ 1.656250] [<c0346630>] (ubi_init+0x1d8/0x29c) from [<c0008810>] (do_one_initcall+0x94/0x144) [ 1.664062] [<c0008810>] (do_one_initcall+0x94/0x144) from [<c0335a9c>] (kernel_init_freeable+0xe8/0x1ac) [ 1.671875] [<c0335a9c>] (kernel_init_freeable+0xe8/0x1ac) from [<c0251500>] (kernel_init+0x8/0xe4) [ 1.679687] [<c0251500>] (kernel_init+0x8/0xe4) from [<c000e590>] (ret_from_fork+0x14/0x24) [ 1.695312] UBI: attached mtd2 (name "UBI", size 245 MiB) to ubi0 [ 1.703125] UBI: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes [ 1.703125] UBI: min./max. I/O unit sizes: 2048/2048, sub-page size 2048 [ 1.710937] UBI: VID header offset: 2048 (aligned 2048), data offset: 4096 [ 1.718750] UBI: good PEBs: 1964, bad PEBs: 0, corrupted PEBs: 0 [ 1.726562] UBI: user volume: 3, internal volumes: 1, max. volumes count: 128 [ 1.726562] UBI: max/mean erase counter: 3/1, WL threshold: 4096, image sequence number: 891983656 [ 1.734375] UBI: available PEBs: 0, total reserved PEBs: 1964, PEBs reserved for bad PEB handling: 40 [ 1.742187] UBI: background thread "ubi_bgt0d" started, PID 355 [ 1.757812] UBIFS: background thread "ubifs_bgt0_0" started, PID 357 [ 1.796875] UBIFS: mounted UBI device 0, volume 0, name "rootfs" [ 1.804687] UBIFS: LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes [ 1.812500] UBIFS: FS size: 63614976 bytes (60 MiB, 501 LEBs), journal size 8634368 bytes (8 MiB, 68 LEBs) [ 1.820312] UBIFS: reserved for root: 0 bytes (0 KiB) [ 1.820312] UBIFS: media format: w4/r0 (latest is w4/r0), UUID 47FE5308-55FD-4F1C-BD13-C23AED232326, small LPT model [ 1.828125] VFS: Mounted root (ubifs filesystem) on device 0:11. [ 1.835937] devtmpfs: mounted [ 1.835937] Freeing unused kernel memory: 112K (c0335000 - c0351000) [ 2.187500] UBI error: ubi_update_fastmap: could not find any anchor PEB [ 2.195312] UBI warning: ubi_update_fastmap: Unable to write new fastmap, err=-28
ubi part ubi
Well, I'm afraid it's not. But I'm going to redo those tests with UBI debug enabled to be really really sure.
Thanks, //richard
Thanks !
Am 25.09.2013 14:13, schrieb Richard Genoud:
Oh, this makes me sad. ;-)
Okay, you hit a code path which does not call ubi_err() and just terminates the attach function. These paths are mostly fatal errors like OOM or major problems with the fastmap disk-layout. So, we need a debug-patch. By end of the week I'll send one.
What is line wl.c:1967 in your tree?
Is it ubi_assert(ubi->good_peb_count == found_pebs + ubi->fm->used_blocks); or ubi_assert(ubi->good_peb_count == found_pebs);
Please enable UBI Debugging to see the debug statement above: dbg_wl("found %i PEBs", found_pebs);. I really wonder what found_pebs contains in that case. Or just turn it into a ubi_err().
ubi part ubi
Okay, this is really interesting. The fastmap pool contains invalid data and therefore attaching by fastmap aborts.
Okay, found at least one bug which explains the WARN_ON(). The error path on scan_pool() is wrong. --> Patch is on the way.
That said, so far it looks to me that the fastmap get's sometimes only half written. As conseqeunce of this UBI falls back to scanning mode. But sadly there seem to be some problems with the fallback code.
Thanks, //richard
2013/9/25 Richard Weinberger richard@nod.at:
it's ubi_assert(ubi->good_peb_count == found_pebs); (in the debug log I sent you, it's line 1968 because I added a quick "#define DEBUG" at the top)
ubi part ubi
Thanks, //richard
Am 25.09.2013 15:39, schrieb Richard Genoud:
Okay. The assert() not correct. It does not honor the case where we have a fastmap found (thus some PEBs are used for the fastmap) but the fastmap has be treated as invalid.
Thanks, //richard
Richard Genoud
Richard Weinberger
