[U-Boot-Users] [PATCH] MPC85xx: correct the procedure to change CCSRBAR.
The MPC8555E and MPC8548E reference manuals are quite specific about the formula required to change the value of CCSRBAR. This patch implements that formula. --- cpu/mpc85xx/cpu_init.c | 25 +++++++++++++++++++++++-- 1 files changed, 23 insertions(+), 2 deletions(-)
diff --git a/cpu/mpc85xx/cpu_init.c b/cpu/mpc85xx/cpu_init.c index 736aef1..2f256de 100644 --- a/cpu/mpc85xx/cpu_init.c +++ b/cpu/mpc85xx/cpu_init.c @@ -141,10 +141,31 @@ void cpu_init_early_f(void) MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, 1, 1, BOOKE_PAGESZ_4K, 0);
+ // Update CCSRBAR using the procedure described in + // the MPC8548E Reference Manual, section 4.3.1.1.1: + // -- Read the current value of CCSRBAR using a load word + // instruction followed by an isync. + // This forces all accesses to configuration space to + // complete. temp = in_be32((volatile u32 *)CFG_CCSRBAR_DEFAULT); - out_be32((volatile u32 *)CFG_CCSRBAR_DEFAULT, CFG_CCSRBAR_PHYS >> 12); - + asm volatile ("isync"); + + // -- Write the new value to CCSRBAR. + out_be32((volatile u32 *)CFG_CCSRBAR_DEFAULT, + CFG_CCSRBAR_PHYS >> 12); + + // -- Perform a load of an address that does not access + // configuration space or the on-chip SRAM, + // but has an address mapping already in effect + // (for example, boot ROM). + // Follow this load with an isync. + temp = *(volatile u32 *)0xfffff000; + asm volatile ("isync"); + + // -- Read the contents of CCSRBAR from its new location, + // followed by another isync. temp = in_be32((volatile u32 *)CFG_CCSRBAR); + asm volatile ("isync"); } #endif
Those manuals are not correct in their description of updating CCSRBAR.
The current code meets all the requirements excepting doing a load from some other address location.
So you really want:
temp = in_be32((volatile u32 *)CFG_CCSRBAR_DEFAULT); out_be32((volatile u32 *)CFG_CCSRBAR_DEFAULT, CFG_CCSRBAR_PHYS >> 12);
/* do a dummy load from somewhere else */ temp = in_be32((volatile u32 *)TEXT_BASE);
The in_be32/out_be32 cover the sync requirements that are needed.
- k
Just to be clear, I'm NACKing this for the reasons given by Kumar (also, don't use C++ comments for multi-line comments).
Andy
Andrew Klossner
Andy Fleming
Kumar Gala
