[U-Boot] test vs itest command confusion when using setexpr
I noticed a difference between the `test` and the `itest` command when using `setexpr`:
Running the test vs the itest command in the shell:
``` => setexpr i 0xf; while test ${i} -gt 0; do echo $i; setexpr i ${i} - 1; done => setexpr i 0xf; while itest ${i} -gt 0; do echo $i; setexpr i ${i} - 1; done f e d c b a 9 8 7 6 5 4 3 2 1 => ```
The difference between the test and the itest command is that the integer operations for the test command is done using the base of 10 while for the itest command the operations are done using a base of 16.
lib/test.c ``` simple_strtol(ap[0], NULL, 10) > simple_strtol(ap[2], NULL, 10); ```
lib/itest.c ``` simple_strtol(s, NULL, 16) > simple_strtol(t, NULL, 16); ```
As setexpr stores the variables as hex values, it becomes obvious why `itest` works, but `test` does not. Is this different behaviour intended?
Best regards Jörg Krause
Jörg Krause
