[U-Boot] [PATCH] OMAP3: omap3logic: Fix DDR Pin Mux
The 512 MB DDR version of SOM's use CS0 and CS1. CS1 is not correctly setup in the pin muxing. This causes erratic behavior on suspend/resume
This fix has been tested on both 256 and 512 MB DDR versions.
Signed-off-by: Adam Ford aford173@gmail.com
diff --git a/board/logicpd/omap3som/omap3logic.c b/board/logicpd/omap3som/omap3logic.c index de6a060..af20339 100644 --- a/board/logicpd/omap3som/omap3logic.c +++ b/board/logicpd/omap3som/omap3logic.c @@ -335,7 +335,7 @@ void set_muxconf_regs(void) MUX_VAL(CP(SDRC_DQS2), (IEN | PTD | DIS | M0)); /*SDRC_DQS2*/ MUX_VAL(CP(SDRC_DQS3), (IEN | PTD | DIS | M0)); /*SDRC_DQS3*/ MUX_VAL(CP(SDRC_CKE0), (IDIS | PTU | EN | M0)); /*SDRC_CKE0*/ - MUX_VAL(CP(SDRC_CKE1), (IDIS | PTD | DIS | M7)); /*SDRC_CKE1*/ + MUX_VAL(CP(SDRC_CKE1), (IDIS | PTU | DIS | M0)); /*SDRC_CKE1*/
MUX_VAL(CP(GPMC_A1), (IDIS | PTU | EN | M0)); /*GPMC_A1*/ MUX_VAL(CP(GPMC_A2), (IDIS | PTU | EN | M0)); /*GPMC_A2*/
Adam Ford
