[PATCH] arm64: zynqmp: Fix i2c addresses for zynqmp-p-a2197
After double checking some i2c addresses are not correct. It is visible from i2c dump
ZynqMP> i2c bus Bus 3: i2c@ff020000 74: i2c-mux@74, offset len 1, flags 0 Bus 5: i2c@ff020000->i2c-mux@74->i2c@0 Bus 6: i2c@ff020000->i2c-mux@74->i2c@2 Bus 7: i2c@ff020000->i2c-mux@74->i2c@1 Bus 8: i2c@ff020000->i2c-mux@74->i2c@3 Bus 4: i2c@ff030000 (active 4) 74: i2c-mux@74, offset len 1, flags 0 Bus 9: i2c@ff030000->i2c-mux@74->i2c@0 Bus 10: i2c@ff030000->i2c-mux@74->i2c@3 Bus 11: i2c@ff030000->i2c-mux@74->i2c@4 Bus 12: i2c@ff030000->i2c-mux@74->i2c@5 (active 12) 51: generic_51, offset len 1, flags 0 60: generic_60, offset len 1, flags 0 74: generic_74, offset len 1, flags 0 Bus 13: i2c@ff030000->i2c-mux@74->i2c@6 (active 13) 51: generic_51, offset len 1, flags 0 5d: generic_5d, offset len 1, flags 0 74: generic_74, offset len 1, flags 0 ZynqMP> i2c dev 4 Setting bus to 4 ZynqMP> i2c mw 74 0 18 ZynqMP> i2c probe Valid chip addresses: 18 36 37 50 51 60 74 ZynqMP> i2c mw 74 0 20 ZynqMP> i2c probe Valid chip addresses: 51 60 74
where it is clear that si570 (u5) is at 0x60 address and 8t49n240 (u39) is also at address 0x60 based on log above. i2c address 0x74 is i2c mux and 0x51 is eeprom.
arch/arm/dts/zynqmp-p-a2197-00-revA.dts | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/arch/arm/dts/zynqmp-p-a2197-00-revA.dts b/arch/arm/dts/zynqmp-p-a2197-00-revA.dts index 5d21795de9d0..b3fe42faeee8 100644 --- a/arch/arm/dts/zynqmp-p-a2197-00-revA.dts +++ b/arch/arm/dts/zynqmp-p-a2197-00-revA.dts @@ -511,10 +511,10 @@ #address-cells = <1>; #size-cells = <0>; reg = <6>; - si570_hsdp: clock-generator@5d { /* u5 */ + si570_hsdp: clock-generator@60 { /* u5 */ #clock-cells = <0>; compatible = "silabs,si570"; - reg = <0x5d>; /* 570JAC000900DG */ + reg = <0x60>; /* 570JAC000900DG */ temperature-stability = <50>; factory-fout = <156250000>; clock-frequency = <156250000>; @@ -528,10 +528,10 @@ /* u36 0xd8 or 0xde - pcie clk buf - 9ZML1241EKILF PCIe GEN 4 CLOCK BUFFER FIXME - no driver */ /* u37 0xd0 DNP - pcie clocking 1 - 9FGV1006BQ505LTGI - PCIe GEN 4 CLOCK GENERATOR FIXME - no linux driver */ /* u38 0xca - pcie clocking 2 - 9ZML1241EKILF PCIe GEN 4 CLOCK BUFFER FIXME - no driver */ - clock_8t49n287: clock-generator@d8 { /* u39 8T49N240 - pcie clocking 3 */ + clock_8t49n287: clock-generator@60 { /* u39 8T49N240 - pcie clocking 3 */ #clock-cells = <1>; /* author David Cater david.cater@idt.com*/ compatible = "idt,8t49n240", "idt,8t49n241"; /* FIXME no driver for 240 */ - reg = <0xd8>; + reg = <0x60>; /* Documentation/devicetree/bindings/clock/idt,idt8t49n24x.txt */ /* FIXME there input via J241 Samtec CLK1 and CLK0 from U38 - selection PIN */
po 7. 3. 2022 v 8:53 odesÃlatel Michal Simek michal.simek@xilinx.com napsal:
clock_8t49n287: clock-generator@60 { /* u39 8T49N240 - pcie clocking 3 */ #clock-cells = <1>; /* author David Cater <david.cater@idt.com>*/ compatible = "idt,8t49n240", "idt,8t49n241"; /* FIXME no driver for 240 */
reg = <0xd8>;
-- 2.35.1
Applied. M
Michal Simek
Michal Simek
