[PATCH u-boot-marvell v2] arm: mvebu: turris_omnia: Fixup SATA or PCIe nodes at runtime in DT blob
On of the MiniPCIe ports on Turris Omnia is also a mSATA port. Whether it works in SATA or PCIe mode is determined by a strapping pin, which value is read from the MCU.
We already determine which type of card is connected when configuring SerDeses.
But until now we left both SATA and PCIe port 0 nodes in device tree enabled, and so the SATA driver is probed in U-Boot / Linux even if we know there is no mSATA card, and similarly PCIe driver tries to link on port 0 even if we know there is mSATA card, not a PCIe card.
Fixup device tree blob to disable SATA node if mSATA card is not present, and to disable PCIe port 0 node if mSATA card is present.
Do this for U-Boot's DT blob before relocation and also for kernel DT blob before booting.
This ensures that software does not try to use SATA or PCIe HW when corresponding PHY is not configured.
Signed-off-by: Pali Rohár pali@kernel.org [ refactored and fixed some issues ] Signed-off-by: Marek Behún marek.behun@nic.cz --- Sorry about this, there is a bug in v1 which got there when I was testing this.
This depends on patch fdt_support: Add fdt_for_each_node_by_compatible() helper macro which I recently sent to mailing list: http://patchwork.ozlabs.org/project/uboot/patch/20220107101329.25836-1-kabel...
Stefan, the dependency touches DM stuff, so I added u-boot-dm tag, but it currently applies only to marvell/next. Could we sync with Simon and get both merged via marvell/next? Or do we wait till it gets merged there, then into master, then into marvell? --- board/CZ.NIC/turris_omnia/turris_omnia.c | 91 +++++++++++++++++++++++- configs/turris_omnia_defconfig | 1 + 2 files changed, 90 insertions(+), 2 deletions(-)
diff --git a/board/CZ.NIC/turris_omnia/turris_omnia.c b/board/CZ.NIC/turris_omnia/turris_omnia.c index ae24d14b76..80235e8b66 100644 --- a/board/CZ.NIC/turris_omnia/turris_omnia.c +++ b/board/CZ.NIC/turris_omnia/turris_omnia.c @@ -490,6 +490,86 @@ void spl_board_init(void) } }
+#if IS_ENABLED(CONFIG_OF_BOARD_FIXUP) || IS_ENABLED(CONFIG_OF_BOARD_SETUP) + +static void fixup_serdes_0_nodes(void *blob) +{ + bool mode_sata; + int node; + + /* + * Determine if SerDes 0 is configured to SATA mode. + * We do this instead of calling omnia_detect_sata() to avoid another + * call to the MCU. By this time the common PHYs are initialized (it is + * done in SPL), so we can read this common PHY register. + */ + mode_sata = (readl(MVEBU_REGISTER(0x183fc)) & GENMASK(3, 0)) == 2; + + /* + * We're either adding status = "disabled" property, or changing + * status = "okay" to status = "disabled". In both cases we'll need more + * space. Increase the size a little. + */ + if (fdt_increase_size(blob, 32) < 0) { + printf("Cannot increase FDT size!\n"); + return; + } + + /* If mSATA card is not present, disable SATA DT node */ + if (!mode_sata) { + fdt_for_each_node_by_compatible (node, blob, -1, + "marvell,armada-380-ahci") { + if (!fdtdec_get_is_enabled(blob, node)) + continue; + + if (fdt_status_disabled(blob, node) < 0) + printf("Cannot disable SATA DT node!\n"); + else + debug("Disabled SATA DT node\n"); + + break; + } + + return; + } + + /* Otherwise disable PCIe port 0 DT node (MiniPCIe / mSATA port) */ + fdt_for_each_node_by_compatible (node, blob, -1, + "marvell,armada-370-pcie") { + int port; + + if (!fdtdec_get_is_enabled(blob, node)) + continue; + + fdt_for_each_subnode (port, blob, node) { + if (!fdtdec_get_is_enabled(blob, port)) + continue; + + if (fdtdec_get_int(blob, port, "marvell,pcie-port", + -1) != 0) + continue; + + if (fdt_status_disabled(blob, port) < 0) + printf("Cannot disable PCIe port 0 DT node!\n"); + else + debug("Disabled PCIe port 0 DT node\n"); + + return; + } + } +} + +#endif + +#if IS_ENABLED(CONFIG_OF_BOARD_FIXUP) +int board_fix_fdt(void *blob) +{ + fixup_serdes_0_nodes(blob); + + return 0; +} +#endif + int board_init(void) { /* address of boot parameters */ @@ -694,7 +774,7 @@ static bool fixup_mtd_partitions(void *blob, int offset, struct mtd_info *mtd) return true; }
-int ft_board_setup(void *blob, struct bd_info *bd) +static void fixup_spi_nor_partitions(void *blob) { struct mtd_info *mtd; int node; @@ -711,12 +791,19 @@ int ft_board_setup(void *blob, struct bd_info *bd) goto fail;
put_mtd_device(mtd); - return 0; + return;
fail: printf("Failed fixing SPI NOR partitions!\n"); if (!IS_ERR_OR_NULL(mtd)) put_mtd_device(mtd); +} + +int ft_board_setup(void *blob, struct bd_info *bd) +{ + fixup_spi_nor_partitions(blob); + fixup_serdes_0_nodes(blob); + return 0; } #endif diff --git a/configs/turris_omnia_defconfig b/configs/turris_omnia_defconfig index e6f901ea77..6b1081c9bd 100644 --- a/configs/turris_omnia_defconfig +++ b/configs/turris_omnia_defconfig @@ -23,6 +23,7 @@ CONFIG_DEBUG_UART_BASE=0xd0012000 CONFIG_DEBUG_UART_CLOCK=250000000 CONFIG_DEBUG_UART=y CONFIG_AHCI=y +CONFIG_OF_BOARD_FIXUP=y CONFIG_DISTRO_DEFAULTS=y CONFIG_SYS_LOAD_ADDR=0x800000 CONFIG_FIT=y
A few minor comments below...
- bool mode_sata;
- int node;
- mode_sata = (readl(MVEBU_REGISTER(0x183fc)) & GENMASK(3, 0)) == 2;
- if (fdt_increase_size(blob, 32) < 0) {
return;
- /* If mSATA card is not present, disable SATA DT node */
- if (!mode_sata) {
Why are adding the space before the "(" here? This does not seem the common and preferred coding style AFAICT.
continue;
else
break;
return;
- /* Otherwise disable PCIe port 0 DT node (MiniPCIe / mSATA port) */
- fdt_for_each_node_by_compatible (node, blob, -1,
Same here.
int port;
continue;
continue;
-1) != 0)
continue;
else
return;
- fixup_serdes_0_nodes(blob);
+} +#endif
- int board_init(void) { /* address of boot parameters */
return;
- fixup_spi_nor_partitions(blob);
- return 0; } #endif
Viele Grüße, Stefan Roese
- if (!mode_sata) {
Hello Stefan! Just to note that I'm adding this space too when writing for-loops. E.g.:
for (i = 0; i < 10; i++) { ... }
or:
fdt_for_each_node_by_compatible (node, blob, -1, compatible) { ... }
continue;
else
break;
return;
- if (!mode_sata) {
or:
Right. But we already have multiple of these for () helpers in U-Boot and Linux. And AFACIT all are used without this space:
[stefan@ryzen u-boot (master)]$ git grep for_each drivers/ drivers/block/blkcache.c: list_for_each_entry(node, &block_cache, lh) drivers/block/blkcache.c: list_for_each_safe(entry, n, &block_cache) { drivers/button/button-adc.c: dev_for_each_subnode(node, dev->parent) { drivers/button/button-adc.c: dev_for_each_subnode(node, parent) { drivers/button/button-gpio.c: dev_for_each_subnode(node, parent) { drivers/clk/clk-uclass.c: list_for_each_entry(child_dev, &clk->dev->child_head, sibling_node) { drivers/clk/clk_stm32mp1.c: ofnode_for_each_subnode(subnode, node) { drivers/core/device-remove.c: list_for_each_entry_safe(pos, n, &dev->child_head, sibling_node) { drivers/core/device-remove.c: list_for_each_entry_safe(pos, n, &dev->child_head, sibling_node) { drivers/core/device.c: list_for_each_entry_safe(pos, n, &dev->parent->child_head, drivers/core/device.c: list_for_each_entry(uc, gd->uclass_root, sibling_node) {
So I would prefer to also use this new helper without the extra space as well.
Thanks, Stefan
Marek Behún
Pali Rohár
Stefan Roese
