[PATCH v2] arm: exynos: Use proper PMIC device name
Since commit 4213609cc7 ("drivers: core: use strcmp when find device by name") one has to provide full name to get requested object. Fix the code used to detect enable power regulators on Odroid boards to use proper PMIC device device name then.
Signed-off-by: Marek Szyprowski m.szyprowski@samsung.com Reviewed-by: Anand Moon linux.amoon@gmail.com --- board/samsung/common/exynos5-dt-types.c | 2 +- board/samsung/common/exynos5-dt.c | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/board/samsung/common/exynos5-dt-types.c b/board/samsung/common/exynos5-dt-types.c index d51cc4eedc..31e23e8b07 100644 --- a/board/samsung/common/exynos5-dt-types.c +++ b/board/samsung/common/exynos5-dt-types.c @@ -129,7 +129,7 @@ static const char *odroid_get_type_str(void) if (gd->board_type != EXYNOS5_BOARD_ODROID_XU3_REV02) goto exit;
- ret = pmic_get("s2mps11", &dev); + ret = pmic_get("s2mps11_pmic@66", &dev); if (ret) goto exit;
diff --git a/board/samsung/common/exynos5-dt.c b/board/samsung/common/exynos5-dt.c index 87eb381345..c5e77480f5 100644 --- a/board/samsung/common/exynos5-dt.c +++ b/board/samsung/common/exynos5-dt.c @@ -64,7 +64,7 @@ int exynos_power_init(void) int ret;
#ifdef CONFIG_PMIC_S2MPS11 - ret = pmic_get("s2mps11_pmic", &dev); + ret = pmic_get("s2mps11_pmic@66", &dev); #else ret = pmic_get("max77686", &dev); if (!ret) {
On Wed, 15 Jan 2020 16:39:09 +0100 Marek Szyprowski m.szyprowski@samsung.com wrote:
- ret = pmic_get("s2mps11_pmic@66", &dev); if (ret) goto exit;
Reviewed-by: Lukasz Majewski lukma@denx.de
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-59 Fax: (+49)-8142-66989-80 Email: lukma@denx.de
Lukasz Majewski
Marek Szyprowski
