[PATCH v2] ARM: stm32: Add IWDG handling into PSCI suspend code
In case the IWDG is enabled by either U-Boot or Linux, the IWDG can never be disabled again. That includes low power states, which means that if the IWDG is enabled, the SoC would reset itself after a while in suspend via the IWDG. This is not desired behavior.
It is possible to enable IWDG pre-timeout IRQ which is routed into the EXTI, and use that IRQ to wake the CPU up before the IWDG timeout is reached and reset is triggered. This pre-timeout IRQ can be used to reload the WDT and then suspend the CPU again every once in a while.
Implement this functionality for both IWDG1 and IWDG2 by reading out all the unmasked IRQs, comparing the list with currently pending IRQs in GICv3: - If any IRQ is pending and it is NOT IWDG1 or IWDG2 pre-timeout IRQ, wake up and let OS handle the IRQs - If IWDG1 or IWDG2 IRQ is pending and no other IRQ is pending, ping the respective IWDG and suspend again
This does not seem to have any adverse impact on power consumption in suspend.
Signed-off-by: Marek Vasut marex@denx.de --- Cc: Ilias Apalodimas ilias.apalodimas@linaro.org Cc: Marek Vasut marex@denx.de Cc: Patrice Chotard patrice.chotard@foss.st.com Cc: Patrick Delaunay patrick.delaunay@foss.st.com Cc: Sughosh Ganu sughosh.ganu@linaro.org Cc: u-boot@lists.denx.de Cc: uboot-stm32@st-md-mailman.stormreply.com --- V2: Ping the IWDG before entering WFI to assure they would not reset the SoC --- arch/arm/mach-stm32mp/include/mach/stm32.h | 2 + arch/arm/mach-stm32mp/psci.c | 73 ++++++++++++++++++++-- 2 files changed, 70 insertions(+), 5 deletions(-)
diff --git a/arch/arm/mach-stm32mp/include/mach/stm32.h b/arch/arm/mach-stm32mp/include/mach/stm32.h index c85ae6a34ee..1cdc5e3b186 100644 --- a/arch/arm/mach-stm32mp/include/mach/stm32.h +++ b/arch/arm/mach-stm32mp/include/mach/stm32.h @@ -21,8 +21,10 @@ #define STM32_DBGMCU_BASE 0x50081000 #endif #define STM32_FMC2_BASE 0x58002000 +#define STM32_IWDG2_BASE 0x5A002000 #define STM32_DDRCTRL_BASE 0x5A003000 #define STM32_DDRPHYC_BASE 0x5A004000 +#define STM32_IWDG1_BASE 0x5C003000 #define STM32_TZC_BASE 0x5C006000 #define STM32_ETZPC_BASE 0x5C007000 #define STM32_STGEN_BASE 0x5C008000 diff --git a/arch/arm/mach-stm32mp/psci.c b/arch/arm/mach-stm32mp/psci.c index 1e69673e88b..39b5200949a 100644 --- a/arch/arm/mach-stm32mp/psci.c +++ b/arch/arm/mach-stm32mp/psci.c @@ -161,6 +161,12 @@ #define RCC_MP_GRSTCSETR_MPUP0RST BIT(4) #define RCC_MP_GRSTCSETR_MPUP1RST BIT(5)
+/* IWDG */ +#define IWDG_KR 0x00 +#define IWDG_KR_RELOAD_KEY 0xaaaa +#define IWDG_EWCR 0x14 +#define IWDG_EWCR_EWIC BIT(14) + #define STM32MP1_PSCI_NR_CPUS 2 #if STM32MP1_PSCI_NR_CPUS > CONFIG_ARMV7_PSCI_NR_CPUS #error "invalid value for CONFIG_ARMV7_PSCI_NR_CPUS" @@ -696,7 +702,18 @@ void __secure psci_system_suspend(u32 __always_unused function_id, u32 ep, u32 context_id) { u32 saved_mcudivr, saved_pll3cr, saved_pll4cr, saved_mssckselr; + u32 gicd_addr = stm32mp_get_gicd_base_address(); + bool iwdg1_wake = false; + bool iwdg2_wake = false; + bool other_wake = false; u32 saved_pwrctl, reg; + u32 gic_enabled[8]; + u32 irqs; + int i; + + /* Cache enable mask of all 256 SPI */ + for (i = 0; i < ARRAY_SIZE(gic_enabled); i++) + gic_enabled[i] = readl(gicd_addr + GICD_ISENABLERn + 0x4 + 4 * i);
/* Disable IO compensation */
@@ -725,11 +742,57 @@ void __secure psci_system_suspend(u32 __always_unused function_id, setbits_le32(STM32_PWR_BASE + PWR_CR3, PWR_CR3_DDRSREN); writel(0x3, STM32_RCC_BASE + RCC_MP_SREQSETR);
- /* Zzz, enter stop mode */ - asm volatile( - "isb\n" - "dsb\n" - "wfi\n"); + /* Ping the IWDG before entering suspend */ + iwdg1_wake = !!(gic_enabled[4] & BIT(22)); /* SPI 150 */ + iwdg2_wake = !!(gic_enabled[4] & BIT(23)); /* SPI 151 */ + + for (;;) { + /* Ping IWDG1 and ACK pretimer IRQ */ + if (iwdg1_wake) { + writel(IWDG_KR_RELOAD_KEY, STM32_IWDG1_BASE + IWDG_KR); + writel(IWDG_EWCR_EWIC, STM32_IWDG1_BASE + IWDG_EWCR); + } + + /* Ping IWDG2 and ACK pretimer IRQ */ + if (iwdg2_wake) { + writel(IWDG_KR_RELOAD_KEY, STM32_IWDG2_BASE + IWDG_KR); + writel(IWDG_EWCR_EWIC, STM32_IWDG2_BASE + IWDG_EWCR); + } + + iwdg1_wake = false; + iwdg2_wake = false; + + /* Zzz, enter stop mode */ + asm volatile( + "isb\n" + "dsb\n" + "wfi\n"); + + /* Determine the wake up source */ + for (i = 0; i < ARRAY_SIZE(gic_enabled); i++) { + irqs = readl(gicd_addr + GICR_IGROUPMODRn + 0x4 + 4 * i); + irqs &= gic_enabled[i]; + if (!irqs) + continue; + + /* Test whether IWDG pretimeout triggered the wake up. */ + if (i == 4) { /* SPI Num 128..159 */ + iwdg1_wake = !!(irqs & BIT(22)); /* SPI 150 */ + iwdg2_wake = !!(irqs & BIT(23)); /* SPI 151 */ + irqs &= ~(BIT(22) | BIT(23)); + } + + /* Test whether there is any other wake up trigger. */ + if (irqs) { + other_wake = true; + break; + } + } + + /* Other wake up triggers pending, let OS deal with all of it. */ + if (other_wake) + break; + }
writel(0x3, STM32_RCC_BASE + RCC_MP_SREQCLRR); ddr_sw_self_refresh_exit();
Reviewed-by: Patrick Delaunay patrick.delaunay@foss.st.com
Thanks Patrick
u32 gic_enabled[8];
u32 irqs;
int i;
- asm volatile(
"isb\n"
"dsb\n"
"wfi\n");
for (;;) {
if (iwdg1_wake) {
if (iwdg2_wake) {
iwdg1_wake = false;
iwdg2_wake = false;
asm volatile(
"isb\n"
"dsb\n"
"wfi\n");
if (!irqs)
continue;
if (irqs) {
other_wake = true;
break;
if (other_wake)
break;
Applied to u-boot-stm/next
Thanks Patrice
Patrice CHOTARD
Patrick DELAUNAY
