[PATCH v3 0/9] Restore USB and add UMS support for STiH407-B2260
This series is : _ restoring USB on STiH410-B2260 which hasn't been tested since a while. _ migrating STi DWC3 glue from proprietary driver to dwc3-generic driver. _ adding UMS support for STiH410-B2260.
Changes in v3: - Update comment by adding "Remove useless include files" - Replace debug() by dev_err() - check return value of syscon_regmap_lookup_by_phandle()
Changes in v2: - remove useless include files - add dwc3-sti.c DWC3 wrapper as done for dwc3-am62.c
Patrice Chotard (9): ARM: dts: sti: Add fixed clock for ehci and ohci nodes in stih410-b2260.dtsi configs: stih410-b2260: Enable DM_REGULATOR flag usb: dwc3-generic: Reorder include usb: dwc3-generic: Add STih407 support configs: stih410-b2260: Enable USB_DWC3_GENERIC and USB_DWC3_STI flags usb: dwc3: Remove dwc3 glue driver support for STi configs: stih410-b2260: Enable DM_USB_GADGET flag board: stih410-b2260: Remove board_usb_init/cleanup() configs: stih410-b2260: Enable CMD_USB_MASS_STORAGE flag
MAINTAINERS | 3 +- arch/arm/dts/stih410-b2260-u-boot.dtsi | 10 + board/st/stih410-b2260/board.c | 30 --- configs/stih410-b2260_defconfig | 5 + drivers/usb/dwc3/Kconfig | 6 + drivers/usb/dwc3/Makefile | 1 + drivers/usb/dwc3/dwc3-generic-sti.c | 132 +++++++++++++ drivers/usb/dwc3/dwc3-generic.c | 20 +- drivers/usb/host/Kconfig | 9 - drivers/usb/host/Makefile | 1 - drivers/usb/host/dwc3-sti-glue.c | 253 ------------------------- include/dwc3-sti-glue.h | 41 ---- 12 files changed, 159 insertions(+), 352 deletions(-) create mode 100644 drivers/usb/dwc3/dwc3-generic-sti.c delete mode 100644 drivers/usb/host/dwc3-sti-glue.c delete mode 100644 include/dwc3-sti-glue.h
On STi platforms, all clocks are enabled by BOOTROM, so CONFIG_CLK is not set as no clock driver for STI exists.
As ehci-generic and ohci-generic drivers are used on platforms where CONFIG_CLK is set, clk_get_bulk() returns-ENOSYS in case of stih410-b2260. To avoid this error, add fixed clocks for ehci and ohci nodes for stih410-b2260 to fix the following errors:
Bus usb@9a03c00: ohci_generic usb@9a03c00: Failed to get clocks (ret=-19) Port not available. Bus usb@9a03e00: ehci_generic usb@9a03e00: Failed to get clocks (ret=-19) Port not available. Bus usb@9a83c00: ohci_generic usb@9a83c00: Failed to get clocks (ret=-19) Port not available. Bus usb@9a83e00: ehci_generic usb@9a83e00: Failed to get clocks (ret=-19) Port not available. scanning bus dwc3@9900000 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found
Signed-off-by: Patrice Chotard patrice.chotard@foss.st.com Cc: Marek Vasut marex@denx.de ---
(no changes since v1)
arch/arm/dts/stih410-b2260-u-boot.dtsi | 10 ++++++++++ 1 file changed, 10 insertions(+)
diff --git a/arch/arm/dts/stih410-b2260-u-boot.dtsi b/arch/arm/dts/stih410-b2260-u-boot.dtsi index 3b080ac7a1b..e9d7ec92281 100644 --- a/arch/arm/dts/stih410-b2260-u-boot.dtsi +++ b/arch/arm/dts/stih410-b2260-u-boot.dtsi @@ -14,20 +14,30 @@ }; };
+ clk_usb: clk-usb { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <100000000>; + }; + ohci0: usb@9a03c00 { compatible = "generic-ohci"; + clocks = <&clk_usb>; };
ehci0: usb@9a03e00 { compatible = "generic-ehci"; + clocks = <&clk_usb>; };
ohci1: usb@9a83c00 { compatible = "generic-ohci"; + clocks = <&clk_usb>; };
ehci1: usb@9a83e00 { compatible = "generic-ehci"; + clocks = <&clk_usb>; }; }; };
Since commit 6aa8bde8786d ("usb: host: ehci-generic: Remove DM_REGULATOR flag") device_get_supply_regulator() returns -ENOSYS which is not handle by ehci_enable_vbus_supply() and thus, ehci_usb_probe() return an error.
By enabling DM_REGULATOR flag, device_get_supply_regulator() return -ENOENT which is handle and ehci_usb_probe() return 0.
This fixed the following issue: stih410-b2260 =>usb start starting USB... Bus dwc3@9900000: Register 2000240 NbrPorts 2 Starting the controller USB XHCI 1.00 Bus usb@9a03c00: USB OHCI 1.0 Bus usb@9a03e00: probe failed, error -38 Bus usb@9a83c00: USB OHCI 1.0 Bus usb@9a83e00: probe failed, error -38 scanning bus dwc3@9900000 for devices... 1 USB Device(s) found scanning bus usb@9a03c00 for devices... data abort pc : [<7df929b4>] lr : [<7df92918>] reloc pc : [<7d6409b4>] lr : [<7d640918>] sp : 7c73b848 ip : 9cf13c5c fp : 7c879d08 r10: 7c85d040 r9 : 7c74ded0 r8 : 09a03c00 r7 : 00000002 r6 : 7c85d080 r5 : 7c86a040 r4 : 00000000 r3 : 00000000 r2 : 00000000 r1 : 7c85d080 r0 : 7c85d040 Flags: nzCv IRQs off FIQs off Mode SVC_32 Code: 05853ae4 0affffe2 e59a2010 e59a300c (e5832010) Resetting CPU ...
configs/stih410-b2260_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/stih410-b2260_defconfig b/configs/stih410-b2260_defconfig index 815f7557d69..e312ca492d2 100644 --- a/configs/stih410-b2260_defconfig +++ b/configs/stih410-b2260_defconfig @@ -48,6 +48,7 @@ CONFIG_MMC_SDHCI_STI=y CONFIG_PHY=y CONFIG_STI_USB_PHY=y CONFIG_PINCTRL=y +CONFIG_DM_REGULATOR=y CONFIG_STI_RESET=y CONFIG_STI_ASC_SERIAL=y CONFIG_SYSRESET=y
Reorder include following rules available here : https://docs.u-boot.org/en/latest/develop/codingstyle.html#include-files
Remove useless include files.
drivers/usb/dwc3/dwc3-generic.c | 20 ++++---------------- 1 file changed, 4 insertions(+), 16 deletions(-)
diff --git a/drivers/usb/dwc3/dwc3-generic.c b/drivers/usb/dwc3/dwc3-generic.c index 2ab41cbae45..bc7d2d4234b 100644 --- a/drivers/usb/dwc3/dwc3-generic.c +++ b/drivers/usb/dwc3/dwc3-generic.c @@ -7,29 +7,17 @@ * Based on dwc3-omap.c. */
-#include <cpu_func.h> -#include <log.h> #include <dm.h> -#include <dm/device-internal.h> +#include <reset.h> +#include <asm/gpio.h> #include <dm/lists.h> -#include <dwc3-uboot.h> -#include <generic-phy.h> -#include <linux/bitops.h> #include <linux/delay.h> -#include <linux/printk.h> -#include <linux/usb/ch9.h> #include <linux/usb/gadget.h> -#include <malloc.h> #include <power/regulator.h> -#include <usb.h> -#include "core.h" -#include "gadget.h" -#include <reset.h> -#include <clk.h> #include <usb/xhci.h> -#include <asm/gpio.h> - +#include "core.h" #include "dwc3-generic.h" +#include "gadget.h"
struct dwc3_generic_plat { fdt_addr_t base;
Hi Patrice,
Thank you for the patch.
On lun., janv. 20, 2025 at 09:01, Patrice Chotard patrice.chotard@foss.st.com wrote:
Reviewed-by: Mattijs Korpershoek mkorpershoek@baylibre.com
Changes in v3:
Changes in v2:
- Based on dwc3-omap.c.
struct dwc3_generic_plat { fdt_addr_t base; -- 2.25.1
Add STi glue logic to manage the DWC3 HC on STiH407 SoC family. It configures the internal glue logic and syscfg registers.
Changes in v3: - Replace debug() by dev_err() - check return value of syscon_regmap_lookup_by_phandle()
Changes in v2: - add dwc3-sti.c DWC3 wrapper as done for dwc3-am62.c
MAINTAINERS | 1 + drivers/usb/dwc3/Kconfig | 6 ++ drivers/usb/dwc3/Makefile | 1 + drivers/usb/dwc3/dwc3-generic-sti.c | 132 ++++++++++++++++++++++++++++ 4 files changed, 140 insertions(+) create mode 100644 drivers/usb/dwc3/dwc3-generic-sti.c
diff --git a/MAINTAINERS b/MAINTAINERS index 8c6c0c2a4bc..5d7e251e601 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -656,6 +656,7 @@ F: drivers/mmc/sti_sdhci.c F: drivers/reset/sti-reset.c F: drivers/serial/serial_sti_asc.c F: drivers/sysreset/sysreset_sti.c +F: drivers/usb/host/dwc3-sti.c F: drivers/timer/arm_global_timer.c F: drivers/usb/host/dwc3-sti-glue.c F: include/dwc3-sti-glue.h diff --git a/drivers/usb/dwc3/Kconfig b/drivers/usb/dwc3/Kconfig index 0100723a68b..7d58ae65fb6 100644 --- a/drivers/usb/dwc3/Kconfig +++ b/drivers/usb/dwc3/Kconfig @@ -87,6 +87,12 @@ config USB_DWC3_LAYERSCAPE Host and Peripheral operation modes are supported. OTG is not supported.
+config USB_DWC3_STI + bool "STi USB wrapper" + depends on DM_USB && USB_DWC3_GENERIC && SYSCON + help + Select this for STi Platforms. + menu "PHY Subsystem"
config USB_DWC3_PHY_OMAP diff --git a/drivers/usb/dwc3/Makefile b/drivers/usb/dwc3/Makefile index a085c9d4628..985206eafe4 100644 --- a/drivers/usb/dwc3/Makefile +++ b/drivers/usb/dwc3/Makefile @@ -15,3 +15,4 @@ obj-$(CONFIG_USB_DWC3_UNIPHIER) += dwc3-uniphier.o obj-$(CONFIG_USB_DWC3_LAYERSCAPE) += dwc3-layerscape.o obj-$(CONFIG_USB_DWC3_PHY_OMAP) += ti_usb_phy.o obj-$(CONFIG_USB_DWC3_PHY_SAMSUNG) += samsung_usb_phy.o +obj-$(CONFIG_USB_DWC3_STI) += dwc3-generic-sti.o diff --git a/drivers/usb/dwc3/dwc3-generic-sti.c b/drivers/usb/dwc3/dwc3-generic-sti.c new file mode 100644 index 00000000000..2ff640cede4 --- /dev/null +++ b/drivers/usb/dwc3/dwc3-generic-sti.c @@ -0,0 +1,132 @@ +// SPDX-License-Identifier: GPL-2.0-or-later OR BSD-3-Clause +/* + * STi specific glue layer for DWC3 + * + * Copyright (C) 2025, STMicroelectronics - All Rights Reserved + */ + +#include <reset.h> +#include <regmap.h> +#include <syscon.h> +#include <asm/io.h> +#include <dm/device.h> +#include <dm/device_compat.h> +#include <dm/read.h> +#include <linux/usb/otg.h> +#include "dwc3-generic.h" + +/* glue registers */ +#define CLKRST_CTRL 0x00 +#define AUX_CLK_EN BIT(0) +#define SW_PIPEW_RESET_N BIT(4) +#define EXT_CFG_RESET_N BIT(8) + +#define XHCI_REVISION BIT(12) + +#define USB2_VBUS_MNGMNT_SEL1 0x2C +#define USB2_VBUS_UTMIOTG 0x1 + +#define SEL_OVERRIDE_VBUSVALID(n) ((n) << 0) +#define SEL_OVERRIDE_POWERPRESENT(n) ((n) << 4) +#define SEL_OVERRIDE_BVALID(n) ((n) << 8) + +/* Static DRD configuration */ +#define USB3_CONTROL_MASK 0xf77 + +#define USB3_DEVICE_NOT_HOST BIT(0) +#define USB3_FORCE_VBUSVALID BIT(1) +#define USB3_DELAY_VBUSVALID BIT(2) +#define USB3_SEL_FORCE_OPMODE BIT(4) +#define USB3_FORCE_OPMODE(n) ((n) << 5) +#define USB3_SEL_FORCE_DPPULLDOWN2 BIT(8) +#define USB3_FORCE_DPPULLDOWN2 BIT(9) +#define USB3_SEL_FORCE_DMPULLDOWN2 BIT(10) +#define USB3_FORCE_DMPULLDOWN2 BIT(11) + +static void dwc3_stih407_glue_configure(struct udevice *dev, int index, + enum usb_dr_mode mode) +{ + struct dwc3_glue_data *glue = dev_get_plat(dev); + struct regmap *regmap; + ulong syscfg_base; + ulong syscfg_offset; + ulong glue_base; + int ret; + + /* deassert both powerdown and softreset */ + ret = reset_deassert_bulk(&glue->resets); + if (ret) { + dev_err(dev, "reset_deassert_bulk error: %d\n", ret); + return; + } + + regmap = syscon_regmap_lookup_by_phandle(dev, "st,syscfg"); + if (IS_ERR(regmap)) { + dev_err(dev, "unable to get st,syscfg, dev %s\n", dev->name); + return; + } + + syscfg_base = regmap->ranges[0].start; + glue_base = dev_read_addr_index(dev, 0); + syscfg_offset = dev_read_addr_index(dev, 1); + + clrbits_le32(syscfg_base + syscfg_offset, USB3_CONTROL_MASK); + + /* glue drd init */ + switch (mode) { + case USB_DR_MODE_PERIPHERAL: + clrbits_le32(syscfg_base + syscfg_offset, + USB3_DELAY_VBUSVALID | USB3_SEL_FORCE_OPMODE | + USB3_FORCE_OPMODE(0x3) | USB3_SEL_FORCE_DPPULLDOWN2 | + USB3_FORCE_DPPULLDOWN2 | USB3_SEL_FORCE_DMPULLDOWN2 | + USB3_FORCE_DMPULLDOWN2); + + setbits_le32(syscfg_base + syscfg_offset, + USB3_DEVICE_NOT_HOST | USB3_FORCE_VBUSVALID); + break; + + case USB_DR_MODE_HOST: + clrbits_le32(syscfg_base + syscfg_offset, + USB3_DEVICE_NOT_HOST | USB3_FORCE_VBUSVALID | + USB3_SEL_FORCE_OPMODE | USB3_FORCE_OPMODE(0x3) | + USB3_SEL_FORCE_DPPULLDOWN2 | USB3_FORCE_DPPULLDOWN2 | + USB3_SEL_FORCE_DMPULLDOWN2 | USB3_FORCE_DMPULLDOWN2); + + setbits_le32(syscfg_base + syscfg_offset, USB3_DELAY_VBUSVALID); + break; + + default: + dev_err(dev, "Unsupported mode of operation %d\n", mode); + return; + } + + /* glue init */ + setbits_le32(glue_base + CLKRST_CTRL, AUX_CLK_EN | EXT_CFG_RESET_N | XHCI_REVISION); + clrbits_le32(glue_base + CLKRST_CTRL, SW_PIPEW_RESET_N); + + /* configure mux for vbus, powerpresent and bvalid signals */ + setbits_le32(glue_base + USB2_VBUS_MNGMNT_SEL1, + SEL_OVERRIDE_VBUSVALID(USB2_VBUS_UTMIOTG) | + SEL_OVERRIDE_POWERPRESENT(USB2_VBUS_UTMIOTG) | + SEL_OVERRIDE_BVALID(USB2_VBUS_UTMIOTG)); + setbits_le32(glue_base + CLKRST_CTRL, SW_PIPEW_RESET_N); +}; + +struct dwc3_glue_ops stih407_ops = { + .glue_configure = dwc3_stih407_glue_configure, +}; + +static const struct udevice_id dwc3_sti_match[] = { + { .compatible = "st,stih407-dwc3", .data = (ulong)&stih407_ops}, + { /* sentinel */ } +}; + +U_BOOT_DRIVER(dwc3_sti_wrapper) = { + .name = "dwc3-sti", + .id = UCLASS_SIMPLE_BUS, + .of_match = dwc3_sti_match, + .bind = dwc3_glue_bind, + .probe = dwc3_glue_probe, + .remove = dwc3_glue_remove, + .plat_auto = sizeof(struct dwc3_glue_data), +};
Hi Patrice,
Changes in v3:
Changes in v2:
- bool "STi USB wrapper"
- depends on DM_USB && USB_DWC3_GENERIC && SYSCON
- help
The improvements done in v3 based on the comments from v2 look good to me. However, checkpatch seems unhappy about this:
$ ./scripts/checkpatch.pl --git --u-boot --git master..HEAD
-------------------------------------------------------------- Commit 2a4d2432f669 ("usb: dwc3-generic: Add STih407 support") -------------------------------------------------------------- WARNING: please write a paragraph that describes the config symbol fully #42: FILE: drivers/usb/dwc3/Kconfig:90: +config USB_DWC3_STI
Can't we reuse the help description from 'config USB_XHCI_STI' ? I'm sorry I missed this before.
With that addressed, please add:
- STi specific glue layer for DWC3
- Copyright (C) 2025, STMicroelectronics - All Rights Reserved
- struct dwc3_glue_data *glue = dev_get_plat(dev);
- struct regmap *regmap;
- ulong syscfg_base;
- ulong syscfg_offset;
- ulong glue_base;
- int ret;
- /* deassert both powerdown and softreset */
- ret = reset_deassert_bulk(&glue->resets);
- if (ret) {
return;
- regmap = syscon_regmap_lookup_by_phandle(dev, "st,syscfg");
- if (IS_ERR(regmap)) {
return;
- syscfg_base = regmap->ranges[0].start;
- glue_base = dev_read_addr_index(dev, 0);
- syscfg_offset = dev_read_addr_index(dev, 1);
- clrbits_le32(syscfg_base + syscfg_offset, USB3_CONTROL_MASK);
- /* glue drd init */
- switch (mode) {
- case USB_DR_MODE_PERIPHERAL:
break;
- case USB_DR_MODE_HOST:
break;
- default:
return;
- /* glue init */
- setbits_le32(glue_base + CLKRST_CTRL, AUX_CLK_EN | EXT_CFG_RESET_N | XHCI_REVISION);
- clrbits_le32(glue_base + CLKRST_CTRL, SW_PIPEW_RESET_N);
- /* configure mux for vbus, powerpresent and bvalid signals */
- setbits_le32(glue_base + USB2_VBUS_MNGMNT_SEL1,
- setbits_le32(glue_base + CLKRST_CTRL, SW_PIPEW_RESET_N);
- .glue_configure = dwc3_stih407_glue_configure,
- { .compatible = "st,stih407-dwc3", .data = (ulong)&stih407_ops},
- { /* sentinel */ }
- .name = "dwc3-sti",
- .id = UCLASS_SIMPLE_BUS,
- .of_match = dwc3_sti_match,
- .bind = dwc3_glue_bind,
- .probe = dwc3_glue_probe,
- .remove = dwc3_glue_remove,
- .plat_auto = sizeof(struct dwc3_glue_data),
2.25.1
On 1/22/25 10:02, Mattijs Korpershoek wrote:
Hi Patrice,
Changes in v3:
Changes in v2:
- help
Ah yes, will update it
Patrice
- ulong glue_base;
- int ret;
- if (ret) {
return;
return;
- switch (mode) {
break;
break;
- default:
return;
- /* glue init */
2.25.1
Enable USB_DWC3_GENERIC and USB_DWC3_STI flags.
configs/stih410-b2260_defconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/configs/stih410-b2260_defconfig b/configs/stih410-b2260_defconfig index e312ca492d2..4fcbf75548b 100644 --- a/configs/stih410-b2260_defconfig +++ b/configs/stih410-b2260_defconfig @@ -61,6 +61,8 @@ CONFIG_USB_EHCI_GENERIC=y CONFIG_USB_OHCI_HCD=y CONFIG_USB_OHCI_GENERIC=y CONFIG_USB_DWC3=y +CONFIG_USB_DWC3_GENERIC=y +CONFIG_USB_DWC3_STI=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETHER_MCS7830=y
STi is now using the dwc3-generic driver, dwc3-sti-glue driver can be removed.
Signed-off-by: Patrice Chotard patrice.chotard@foss.st.com Cc: Marek Vasut marex@denx.de Reviewed-by: Mattijs Korpershoek mkorpershoek@baylibre.com
Changes in v3: - add RB Mattijs Korpershoek
MAINTAINERS | 2 - board/st/stih410-b2260/board.c | 1 - drivers/usb/host/Kconfig | 9 -- drivers/usb/host/Makefile | 1 - drivers/usb/host/dwc3-sti-glue.c | 253 ------------------------------- include/dwc3-sti-glue.h | 41 ----- 6 files changed, 307 deletions(-) delete mode 100644 drivers/usb/host/dwc3-sti-glue.c delete mode 100644 include/dwc3-sti-glue.h
diff --git a/MAINTAINERS b/MAINTAINERS index 5d7e251e601..0982dfa3fe0 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -658,8 +658,6 @@ F: drivers/serial/serial_sti_asc.c F: drivers/sysreset/sysreset_sti.c F: drivers/usb/host/dwc3-sti.c F: drivers/timer/arm_global_timer.c -F: drivers/usb/host/dwc3-sti-glue.c -F: include/dwc3-sti-glue.h F: include/dt-bindings/clock/stih407-clks.h F: include/dt-bindings/clock/stih410-clks.h F: include/dt-bindings/reset/stih407-resets.h diff --git a/board/st/stih410-b2260/board.c b/board/st/stih410-b2260/board.c index a912712c9dd..3a495eb5089 100644 --- a/board/st/stih410-b2260/board.c +++ b/board/st/stih410-b2260/board.c @@ -9,7 +9,6 @@ #include <asm/cache.h> #include <asm/global_data.h> #include <linux/usb/otg.h> -#include <dwc3-sti-glue.h> #include <dwc3-uboot.h> #include <usb.h>
diff --git a/drivers/usb/host/Kconfig b/drivers/usb/host/Kconfig index 24786a2bc91..cd1c03f10d7 100644 --- a/drivers/usb/host/Kconfig +++ b/drivers/usb/host/Kconfig @@ -110,15 +110,6 @@ config USB_XHCI_RCAR Choose this option to add support for USB 3.0 driver on Renesas R-Car Gen3 SoCs.
-config USB_XHCI_STI - bool "Support for STMicroelectronics STiH407 family on-chip xHCI USB controller" - depends on ARCH_STI - default y - help - Enables support for the on-chip xHCI controller on STMicroelectronics - STiH407 family SoCs. This is a driver for the dwc3 to provide the glue logic - to configure the controller. - config USB_XHCI_DRA7XX_INDEX int "DRA7XX xHCI USB index" range 0 1 diff --git a/drivers/usb/host/Makefile b/drivers/usb/host/Makefile index 301bb9fdee1..902d68d0378 100644 --- a/drivers/usb/host/Makefile +++ b/drivers/usb/host/Makefile @@ -54,7 +54,6 @@ obj-$(CONFIG_USB_XHCI_GENERIC) += xhci-generic.o obj-$(CONFIG_USB_XHCI_OMAP) += xhci-omap.o obj-$(CONFIG_USB_XHCI_PCI) += xhci-pci.o obj-$(CONFIG_USB_XHCI_RCAR) += xhci-rcar.o -obj-$(CONFIG_USB_XHCI_STI) += dwc3-sti-glue.o obj-$(CONFIG_USB_XHCI_OCTEON) += dwc3-octeon-glue.o
# designware diff --git a/drivers/usb/host/dwc3-sti-glue.c b/drivers/usb/host/dwc3-sti-glue.c deleted file mode 100644 index 3e6834e38e3..00000000000 --- a/drivers/usb/host/dwc3-sti-glue.c +++ /dev/null @@ -1,253 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * STiH407 family DWC3 specific Glue layer - * - * Copyright (C) 2017, STMicroelectronics - All Rights Reserved - * Author(s): Patrice Chotard, patrice.chotard@foss.st.com for STMicroelectronics. - */ - -#include <log.h> -#include <asm/global_data.h> -#include <asm/io.h> -#include <dm.h> -#include <errno.h> -#include <dm/lists.h> -#include <regmap.h> -#include <reset-uclass.h> -#include <syscon.h> -#include <usb.h> -#include <linux/printk.h> - -#include <linux/usb/dwc3.h> -#include <linux/usb/otg.h> -#include <dwc3-sti-glue.h> - -DECLARE_GLOBAL_DATA_PTR; - -/* - * struct sti_dwc3_glue_plat - dwc3 STi glue driver private structure - * @syscfg_base: addr for the glue syscfg - * @glue_base: addr for the glue registers - * @syscfg_offset: usb syscfg control offset - * @powerdown_ctl: rest controller for powerdown signal - * @softreset_ctl: reset controller for softreset signal - * @mode: drd static host/device config - */ -struct sti_dwc3_glue_plat { - phys_addr_t syscfg_base; - phys_addr_t glue_base; - phys_addr_t syscfg_offset; - struct reset_ctl powerdown_ctl; - struct reset_ctl softreset_ctl; - enum usb_dr_mode mode; -}; - -static int sti_dwc3_glue_drd_init(struct sti_dwc3_glue_plat *plat) -{ - unsigned long val; - - val = readl(plat->syscfg_base + plat->syscfg_offset); - - val &= USB3_CONTROL_MASK; - - switch (plat->mode) { - case USB_DR_MODE_PERIPHERAL: - val &= ~(USB3_DELAY_VBUSVALID - | USB3_SEL_FORCE_OPMODE | USB3_FORCE_OPMODE(0x3) - | USB3_SEL_FORCE_DPPULLDOWN2 | USB3_FORCE_DPPULLDOWN2 - | USB3_SEL_FORCE_DMPULLDOWN2 | USB3_FORCE_DMPULLDOWN2); - - val |= USB3_DEVICE_NOT_HOST | USB3_FORCE_VBUSVALID; - break; - - case USB_DR_MODE_HOST: - val &= ~(USB3_DEVICE_NOT_HOST | USB3_FORCE_VBUSVALID - | USB3_SEL_FORCE_OPMODE | USB3_FORCE_OPMODE(0x3) - | USB3_SEL_FORCE_DPPULLDOWN2 | USB3_FORCE_DPPULLDOWN2 - | USB3_SEL_FORCE_DMPULLDOWN2 | USB3_FORCE_DMPULLDOWN2); - - val |= USB3_DELAY_VBUSVALID; - break; - - default: - pr_err("Unsupported mode of operation %d\n", plat->mode); - return -EINVAL; - } - writel(val, plat->syscfg_base + plat->syscfg_offset); - - return 0; -} - -static void sti_dwc3_glue_init(struct sti_dwc3_glue_plat *plat) -{ - unsigned long reg; - - reg = readl(plat->glue_base + CLKRST_CTRL); - - reg |= AUX_CLK_EN | EXT_CFG_RESET_N | XHCI_REVISION; - reg &= ~SW_PIPEW_RESET_N; - - writel(reg, plat->glue_base + CLKRST_CTRL); - - /* configure mux for vbus, powerpresent and bvalid signals */ - reg = readl(plat->glue_base + USB2_VBUS_MNGMNT_SEL1); - - reg |= SEL_OVERRIDE_VBUSVALID(USB2_VBUS_UTMIOTG) | - SEL_OVERRIDE_POWERPRESENT(USB2_VBUS_UTMIOTG) | - SEL_OVERRIDE_BVALID(USB2_VBUS_UTMIOTG); - - writel(reg, plat->glue_base + USB2_VBUS_MNGMNT_SEL1); - - setbits_le32(plat->glue_base + CLKRST_CTRL, SW_PIPEW_RESET_N); -} - -static int sti_dwc3_glue_of_to_plat(struct udevice *dev) -{ - struct sti_dwc3_glue_plat *plat = dev_get_plat(dev); - struct udevice *syscon; - struct regmap *regmap; - int ret; - u32 reg[4]; - - ret = ofnode_read_u32_array(dev_ofnode(dev), "reg", reg, - ARRAY_SIZE(reg)); - if (ret) { - pr_err("unable to find st,stih407-dwc3 reg property(%d)\n", ret); - return ret; - } - - plat->glue_base = reg[0]; - plat->syscfg_offset = reg[2]; - - /* get corresponding syscon phandle */ - ret = uclass_get_device_by_phandle(UCLASS_SYSCON, dev, "st,syscfg", - &syscon); - if (ret) { - pr_err("unable to find syscon device (%d)\n", ret); - return ret; - } - - /* get syscfg-reg base address */ - regmap = syscon_get_regmap(syscon); - if (!regmap) { - pr_err("unable to find regmap\n"); - return -ENODEV; - } - plat->syscfg_base = regmap->ranges[0].start; - - /* get powerdown reset */ - ret = reset_get_by_name(dev, "powerdown", &plat->powerdown_ctl); - if (ret) { - pr_err("can't get powerdown reset for %s (%d)", dev->name, ret); - return ret; - } - - /* get softreset reset */ - ret = reset_get_by_name(dev, "softreset", &plat->softreset_ctl); - if (ret) - pr_err("can't get soft reset for %s (%d)", dev->name, ret); - - return ret; -}; - -static int sti_dwc3_glue_bind(struct udevice *dev) -{ - struct sti_dwc3_glue_plat *plat = dev_get_plat(dev); - ofnode node, dwc3_node; - - /* Find snps,dwc3 node from subnode */ - ofnode_for_each_subnode(node, dev_ofnode(dev)) { - if (ofnode_device_is_compatible(node, "snps,dwc3")) - dwc3_node = node; - } - - if (!ofnode_valid(dwc3_node)) { - pr_err("Can't find dwc3 subnode for %s\n", dev->name); - return -ENODEV; - } - - /* retrieve the DWC3 dual role mode */ - plat->mode = usb_get_dr_mode(dwc3_node); - if (plat->mode == USB_DR_MODE_UNKNOWN) - /* by default set dual role mode to HOST */ - plat->mode = USB_DR_MODE_HOST; - - return dm_scan_fdt_dev(dev); -} - -static int sti_dwc3_glue_probe(struct udevice *dev) -{ - struct sti_dwc3_glue_plat *plat = dev_get_plat(dev); - int ret; - - /* deassert both powerdown and softreset */ - ret = reset_deassert(&plat->powerdown_ctl); - if (ret < 0) { - pr_err("DWC3 powerdown reset deassert failed: %d", ret); - return ret; - } - - ret = reset_deassert(&plat->softreset_ctl); - if (ret < 0) { - pr_err("DWC3 soft reset deassert failed: %d", ret); - goto softreset_err; - } - - ret = sti_dwc3_glue_drd_init(plat); - if (ret) - goto init_err; - - sti_dwc3_glue_init(plat); - - return 0; - -init_err: - ret = reset_assert(&plat->softreset_ctl); - if (ret < 0) { - pr_err("DWC3 soft reset deassert failed: %d", ret); - return ret; - } - -softreset_err: - ret = reset_assert(&plat->powerdown_ctl); - if (ret < 0) - pr_err("DWC3 powerdown reset deassert failed: %d", ret); - - return ret; -} - -static int sti_dwc3_glue_remove(struct udevice *dev) -{ - struct sti_dwc3_glue_plat *plat = dev_get_plat(dev); - int ret; - - /* assert both powerdown and softreset */ - ret = reset_assert(&plat->powerdown_ctl); - if (ret < 0) { - pr_err("DWC3 powerdown reset deassert failed: %d", ret); - return ret; - } - - ret = reset_assert(&plat->softreset_ctl); - if (ret < 0) - pr_err("DWC3 soft reset deassert failed: %d", ret); - - return ret; -} - -static const struct udevice_id sti_dwc3_glue_ids[] = { - { .compatible = "st,stih407-dwc3" }, - { } -}; - -U_BOOT_DRIVER(dwc3_sti_glue) = { - .name = "dwc3_sti_glue", - .id = UCLASS_NOP, - .of_match = sti_dwc3_glue_ids, - .of_to_plat = sti_dwc3_glue_of_to_plat, - .probe = sti_dwc3_glue_probe, - .remove = sti_dwc3_glue_remove, - .bind = sti_dwc3_glue_bind, - .plat_auto = sizeof(struct sti_dwc3_glue_plat), - .flags = DM_FLAG_ALLOC_PRIV_DMA, -}; diff --git a/include/dwc3-sti-glue.h b/include/dwc3-sti-glue.h deleted file mode 100644 index 546ffbaf7b4..00000000000 --- a/include/dwc3-sti-glue.h +++ /dev/null @@ -1,41 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Copyright (C) 2017, STMicroelectronics - All Rights Reserved - * Author(s): Patrice Chotard, patrice.chotard@foss.st.com for STMicroelectronics. - */ - -#ifndef __DWC3_STI_UBOOT_H_ -#define __DWC3_STI_UBOOT_H_ - -/* glue registers */ -#include <linux/bitops.h> -#define CLKRST_CTRL 0x00 -#define AUX_CLK_EN BIT(0) -#define SW_PIPEW_RESET_N BIT(4) -#define EXT_CFG_RESET_N BIT(8) - -#define XHCI_REVISION BIT(12) - -#define USB2_VBUS_MNGMNT_SEL1 0x2C -#define USB2_VBUS_UTMIOTG 0x1 - -#define SEL_OVERRIDE_VBUSVALID(n) ((n) << 0) -#define SEL_OVERRIDE_POWERPRESENT(n) ((n) << 4) -#define SEL_OVERRIDE_BVALID(n) ((n) << 8) - -/* Static DRD configuration */ -#define USB3_CONTROL_MASK 0xf77 - -#define USB3_DEVICE_NOT_HOST BIT(0) -#define USB3_FORCE_VBUSVALID BIT(1) -#define USB3_DELAY_VBUSVALID BIT(2) -#define USB3_SEL_FORCE_OPMODE BIT(4) -#define USB3_FORCE_OPMODE(n) ((n) << 5) -#define USB3_SEL_FORCE_DPPULLDOWN2 BIT(8) -#define USB3_FORCE_DPPULLDOWN2 BIT(9) -#define USB3_SEL_FORCE_DMPULLDOWN2 BIT(10) -#define USB3_FORCE_DMPULLDOWN2 BIT(11) - -int sti_dwc3_init(enum usb_dr_mode mode); - -#endif /* __DWC3_STI_UBOOT_H_ */
Enable DM_USB_GADGET flag.
diff --git a/configs/stih410-b2260_defconfig b/configs/stih410-b2260_defconfig index 4fcbf75548b..5641fd1d8d7 100644 --- a/configs/stih410-b2260_defconfig +++ b/configs/stih410-b2260_defconfig @@ -54,6 +54,7 @@ CONFIG_STI_ASC_SERIAL=y CONFIG_SYSRESET=y CONFIG_TIMER=y CONFIG_USB=y +CONFIG_DM_USB_GADGET=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_EHCI_HCD=y
Since DM_USB_GADGET is enable for this board, board_usb_init() and board_usb_cleanup() can be removed.
Signed-off-by: Patrice Chotard patrice.chotard@foss.st.com Reviewed-by: Mattijs Korpershoek mkorpershoek@baylibre.com
board/st/stih410-b2260/board.c | 29 ----------------------------- 1 file changed, 29 deletions(-)
diff --git a/board/st/stih410-b2260/board.c b/board/st/stih410-b2260/board.c index 3a495eb5089..8ad593cccdd 100644 --- a/board/st/stih410-b2260/board.c +++ b/board/st/stih410-b2260/board.c @@ -7,10 +7,6 @@ #include <cpu_func.h> #include <init.h> #include <asm/cache.h> -#include <asm/global_data.h> -#include <linux/usb/otg.h> -#include <dwc3-uboot.h> -#include <usb.h>
@@ -42,31 +38,6 @@ int board_init(void) }
#ifdef CONFIG_USB_DWC3 -static struct dwc3_device dwc3_device_data = { - .maximum_speed = USB_SPEED_HIGH, - .dr_mode = USB_DR_MODE_PERIPHERAL, - .index = 0, -}; - -int board_usb_init(int index, enum usb_init_type init) -{ - int node; - const void *blob = gd->fdt_blob; - - /* find the snps,dwc3 node */ - node = fdt_node_offset_by_compatible(blob, -1, "snps,dwc3"); - - dwc3_device_data.base = fdtdec_get_addr(blob, node, "reg"); - - return dwc3_uboot_init(&dwc3_device_data); -} - -int board_usb_cleanup(int index, enum usb_init_type init) -{ - dwc3_uboot_exit(index); - return 0; -} - int g_dnl_board_usb_cable_connected(void) { return 1;
Enable CMD_USB_MASS_STORAGE flag.
diff --git a/configs/stih410-b2260_defconfig b/configs/stih410-b2260_defconfig index 5641fd1d8d7..1e5190dc828 100644 --- a/configs/stih410-b2260_defconfig +++ b/configs/stih410-b2260_defconfig @@ -25,6 +25,7 @@ CONFIG_CMD_ASKENV=y CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y CONFIG_CMD_USB=y +CONFIG_CMD_USB_MASS_STORAGE=y CONFIG_CMD_TIME=y CONFIG_CMD_TIMER=y CONFIG_CMD_EXT4_WRITE=y
Mattijs Korpershoek
Patrice CHOTARD
Patrice Chotard
