[PATCH 0/2] Mitigate warnings occurred during compilation
This patch series aims at mitigating warnings occurred during compilation by including required header files and using appropriate types for variables which are typecasted.
Nikhil M Jain (2): board: ti: am62x: evm: Include necessary header files common: splash_source: Fix type casting errors.
board/ti/am62x/evm.c | 1 + common/splash_source.c | 4 ++-- 2 files changed, 3 insertions(+), 2 deletions(-)
At the time of compilation evm.c gives below warning for implicit declaration of enable_caches, to mitigate this include cpu_func.h.
board/ti/am62x/evm.c: In function ‘spl_board_init’: board/ti/am62x/evm.c:90:9: warning: implicit declaration of function ‘enable_caches’ [-Wimplicit-function-declaration] 90 | enable_caches();
Signed-off-by: Nikhil M Jain n-jain1@ti.com --- board/ti/am62x/evm.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/board/ti/am62x/evm.c b/board/ti/am62x/evm.c index d3c1786cd9..ad93908840 100644 --- a/board/ti/am62x/evm.c +++ b/board/ti/am62x/evm.c @@ -12,6 +12,7 @@ #include <init.h> #include <video.h> #include <splash.h> +#include <cpu_func.h> #include <k3-ddrss.h> #include <fdt_support.h> #include <asm/io.h>
During compilation splash_source puts out below warning for type conversion in splash_load_fit for bmp_load_addr and fit_header, change their type to uintptr_t to mitigate the warnings.
common/splash_source.c: In function ‘splash_load_fit’: common/splash_source.c:366:22: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] 366 | img_header = (struct legacy_img_hdr *)bmp_load_addr; | ^ common/splash_source.c:376:49: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast] 376 | res = splash_storage_read_raw(location, (u32)fit_header, fit_size); | ^ common/splash_source.c:401:25: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] 401 | memmove((void *)bmp_load_addr, internal_splash_data, internal_splash_size);
Signed-off-by: Nikhil M Jain n-jain1@ti.com --- common/splash_source.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/common/splash_source.c b/common/splash_source.c index a260137619..53f2c7034b 100644 --- a/common/splash_source.c +++ b/common/splash_source.c @@ -343,7 +343,7 @@ static struct splash_location *select_splash_location( }
#ifdef CONFIG_FIT -static int splash_load_fit(struct splash_location *location, u32 bmp_load_addr) +static int splash_load_fit(struct splash_location *location, uintptr_t bmp_load_addr) { int res; int node_offset; @@ -373,7 +373,7 @@ static int splash_load_fit(struct splash_location *location, u32 bmp_load_addr)
/* Read in entire FIT */ fit_header = (const u32 *)(bmp_load_addr + header_size); - res = splash_storage_read_raw(location, (u32)fit_header, fit_size); + res = splash_storage_read_raw(location, (uintptr_t)fit_header, fit_size); if (res < 0) return res;
Hi Nikhil,
Below should be separate sentence. Also remove fullstop from subject line. change
s/mitigate/fix
In my opinion better to use uintptr_t for bmp_load_addr or for the matter any other address being used at all places in splash files.
Regards Devarsh
- res = splash_storage_read_raw(location, (uintptr_t)fit_header, fit_size); if (res < 0) return res;
What is this on top of, or what changes have been made to stock defconfigs to make these problems appear?
Hi Tom,
These errors appear when you enable CONFIG_SPLASH_SOURCE and CONFIG_FIT is enabled.
Thanks, Nikhil
Devarsh Thakkar
Nikhil M Jain
