[U-Boot] [BUG] x86: invalid size calculations in interrupts.c with newer GCC
On latest master (commit 0ff27d), when using the stock qemu-x86_defconfig, it is possible to build an invalid U-Boot. I traced the issue to arch/x86/cpu/interrupts.c. The problem is that cpu_init_interrupts() assumes that each IRQ entry consumes the same number of bytes. Depending upon the compiler used, this assumption is incorrect.
Commit 564a9984 added this hunk:
+void irq_0(void); +void irq_1(void);
int cpu_init_interrupts(void) { int i;
+ int irq_entry_size = irq_1 - irq_0; + void *irq_entry = (void *)irq_0;
When I used a Buildroot derived compiler, I got this assembly code for arch/x86/cpu/interrupts.o:
$ /home/tang/buildroot-x86/output/host/usr/bin/x86_64-linux-gcc --version x86_64-linux-gcc.br_real (Buildroot 2016.11.1) 5.4.0 $ objdump -d interrupts.o <snip> 00000207 <irq_18>: 207: 6a 12 push $0x12 209: eb 85 jmp 190 <irq_common_entry>
0000020b <irq_19>: 20b: 6a 13 push $0x13 20d: eb 81 jmp 190 <irq_common_entry>
0000020f <irq_20>: 20f: 6a 14 push $0x14 211: e9 7a ff ff ff jmp 190 <irq_common_entry>
00000216 <irq_21>: 216: 6a 15 push $0x15 218: e9 73 ff ff ff jmp 190 <irq_common_entry>
Based upon the offset difference, the newer GCC optimizer will use a shorter jmp opcode instruction. This results in varying size IRQ entries. As a comparison, a stock Debian compiler produced this assembly:
$ gcc --version gcc (Debian 4.9.2-10) 4.9.2 $ objdump -d interrupts.o <snip> 00000240 <irq_18>: 240: 6a 12 push $0x12 242: e9 fc ff ff ff jmp 243 <irq_18+0x3>
00000247 <irq_19>: 247: 6a 13 push $0x13 249: e9 fc ff ff ff jmp 24a <irq_19+0x3>
0000024e <irq_20>: 24e: 6a 14 push $0x14 250: e9 fc ff ff ff jmp 251 <irq_20+0x3>
00000255 <irq_21>: 255: 6a 15 push $0x15 257: e9 fc ff ff ff jmp 258 <irq_21+0x3>
I got around this temporarily by having directly referencing all 256 IRQ symbols, rather than compute the next IRQ address relative to the previous. Hopefully someone can come up with a more elegant solution.
+Simon,
Thanks for reporting this!
I do not have a GCC5 toolchain to test this. I suspect this is only exposed with GCC5, or GCC 5.4? Is there any parameter to control the behavior?
Regards, Bin
On 2017-02-06, at 01:35, Bin Meng bmeng.cn@gmail.com wrote:
+Simon,
I observed a similar behavior with GCC 5.3.
As an experiment, I disabled CONFIG_CC_OPTIMIZE_FOR_SIZE. This did not change the sizes; the handler for IRQs 0 through 19 were still 4 bytes while the rest were 7 bytes.
Although I am not an expert x86 assembly writer, I was able to force the assembler to generate 32-bit jumps with the following:
diff --git a/arch/x86/cpu/interrupts.c b/arch/x86/cpu/interrupts.c index 5f6cdd3..9917d09 100644 --- a/arch/x86/cpu/interrupts.c +++ b/arch/x86/cpu/interrupts.c @@ -32,7 +32,7 @@ DECLARE_GLOBAL_DATA_PTR; ".type irq_"#x", @function\n" \ "irq_"#x":\n" \ "pushl $"#x"\n" \ - "jmp irq_common_entry\n" + "jmp.d32 irq_common_entry\n"
static char *exceptions[] = { "Divide Error",
This worked for both GCC 5.4 and 4.9.
+Simon,
Looks good. Can you prepare a patch?
Regards, Bin
Bin Meng
J. Tang
