[U-Boot] [PATCH] ARM: rmobile: Enable HS200 mode on RCar Gen3
Enable the HS200 on RCar Gen3 platforms, since the SDHI core supports it.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Nobuhiro Iwamatsu iwamatsu@nigauri.org --- configs/r8a7795_salvator-x_defconfig | 3 +++ configs/r8a7795_ulcb_defconfig | 3 +++ configs/r8a7796_salvator-x_defconfig | 3 +++ configs/r8a7796_ulcb_defconfig | 3 +++ configs/r8a77970_eagle_defconfig | 3 +++ configs/r8a77995_draak_defconfig | 3 +++ 6 files changed, 18 insertions(+)
diff --git a/configs/r8a7795_salvator-x_defconfig b/configs/r8a7795_salvator-x_defconfig index 5a09473efa..8c9399c87d 100644 --- a/configs/r8a7795_salvator-x_defconfig +++ b/configs/r8a7795_salvator-x_defconfig @@ -35,6 +35,9 @@ CONFIG_RCAR_GPIO=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_RCAR_IIC=y CONFIG_DM_MMC=y +CONFIG_MMC_IO_VOLTAGE=y +CONFIG_MMC_UHS_SUPPORT=y +CONFIG_MMC_HS200_SUPPORT=y CONFIG_MMC_UNIPHIER=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y diff --git a/configs/r8a7795_ulcb_defconfig b/configs/r8a7795_ulcb_defconfig index 0959bb44c9..1828043023 100644 --- a/configs/r8a7795_ulcb_defconfig +++ b/configs/r8a7795_ulcb_defconfig @@ -35,6 +35,9 @@ CONFIG_RCAR_GPIO=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_RCAR_IIC=y CONFIG_DM_MMC=y +CONFIG_MMC_IO_VOLTAGE=y +CONFIG_MMC_UHS_SUPPORT=y +CONFIG_MMC_HS200_SUPPORT=y CONFIG_MMC_UNIPHIER=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y diff --git a/configs/r8a7796_salvator-x_defconfig b/configs/r8a7796_salvator-x_defconfig index 9055c291bb..34a85dde67 100644 --- a/configs/r8a7796_salvator-x_defconfig +++ b/configs/r8a7796_salvator-x_defconfig @@ -36,6 +36,9 @@ CONFIG_RCAR_GPIO=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_RCAR_IIC=y CONFIG_DM_MMC=y +CONFIG_MMC_IO_VOLTAGE=y +CONFIG_MMC_UHS_SUPPORT=y +CONFIG_MMC_HS200_SUPPORT=y CONFIG_MMC_UNIPHIER=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y diff --git a/configs/r8a7796_ulcb_defconfig b/configs/r8a7796_ulcb_defconfig index fe0b4fc93d..47308a43fd 100644 --- a/configs/r8a7796_ulcb_defconfig +++ b/configs/r8a7796_ulcb_defconfig @@ -36,6 +36,9 @@ CONFIG_RCAR_GPIO=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_RCAR_IIC=y CONFIG_DM_MMC=y +CONFIG_MMC_IO_VOLTAGE=y +CONFIG_MMC_UHS_SUPPORT=y +CONFIG_MMC_HS200_SUPPORT=y CONFIG_MMC_UNIPHIER=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y diff --git a/configs/r8a77970_eagle_defconfig b/configs/r8a77970_eagle_defconfig index 621ac1f49a..543074393a 100644 --- a/configs/r8a77970_eagle_defconfig +++ b/configs/r8a77970_eagle_defconfig @@ -35,6 +35,9 @@ CONFIG_RCAR_GPIO=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_RCAR_IIC=y CONFIG_DM_MMC=y +CONFIG_MMC_IO_VOLTAGE=y +CONFIG_MMC_UHS_SUPPORT=y +CONFIG_MMC_HS200_SUPPORT=y CONFIG_MMC_UNIPHIER=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y diff --git a/configs/r8a77995_draak_defconfig b/configs/r8a77995_draak_defconfig index 3fd3caf106..7d14d19784 100644 --- a/configs/r8a77995_draak_defconfig +++ b/configs/r8a77995_draak_defconfig @@ -36,6 +36,9 @@ CONFIG_RCAR_GPIO=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_RCAR_IIC=y CONFIG_DM_MMC=y +CONFIG_MMC_IO_VOLTAGE=y +CONFIG_MMC_UHS_SUPPORT=y +CONFIG_MMC_HS200_SUPPORT=y CONFIG_MMC_UNIPHIER=y CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y
