[U-Boot] [PATCH] ARM: socfpga: Enable saveenv for SD/MMC
Enable the able to save the environment variables when SD/MMC is used.
Signed-off-by: Dinh Nguyen dinguyen@opensource.altera.com --- include/configs/socfpga_common.h | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/include/configs/socfpga_common.h b/include/configs/socfpga_common.h index 38ae763..f6a79ad 100644 --- a/include/configs/socfpga_common.h +++ b/include/configs/socfpga_common.h @@ -160,6 +160,9 @@ /* FIXME */ /* using smaller max blk cnt to avoid flooding the limited stack we have */ #define CONFIG_SYS_MMC_MAX_BLK_COUNT 256 /* FIXME -- SPL only? */ +#define CONFIG_ENV_IS_IN_MMC +#define CONFIG_SYS_MMC_ENV_DEV 0 /* device 0 */ +#define CONFIG_ENV_OFFSET 512 /* just after the MBR */ #endif
/* @@ -282,7 +285,9 @@ unsigned int cm_get_qspi_controller_clk_hz(void); #define CONFIG_SYS_CONSOLE_IS_IN_ENV #define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_SYS_CONSOLE_ENV_OVERWRITE +#if !defined CONFIG_ENV_IS_IN_MMC #define CONFIG_ENV_IS_NOWHERE +#endif #define CONFIG_ENV_SIZE 4096
On Tuesday, September 15, 2015 at 09:47:23 PM, dinguyen@opensource.altera.com wrote:
this should be done per-board, so I'd suggest the following: 1) Rename include/configs/socfpga_cyclone5.h to socfpga_cyclone5_socdk.h (to make it in-line with the naming in boards/altera/ , sorry, I forgot about this bit :( You'd also have to fix the MAINTAINERS file to match the adjusted filename). 2) Rename socfpga_arria5.h to socfpga_arria5_socdk.h 3) Enable this for both boards in socfpga_*_socdk.h
Can you do that please ?
Thanks!
Best regards, Marek Vasut
- Rename include/configs/socfpga_cyclone5.h to socfpga_cyclone5_socdk.h (to make it in-line with the naming in boards/altera/ , sorry, I forgot about this bit :( You'd also have to fix the MAINTAINERS file to match the adjusted filename).
- Rename socfpga_arria5.h to socfpga_arria5_socdk.h
- Enable this for both boards in socfpga_*_socdk.h
Yes, I can do that.
Dinh
Yes, I can do that.
Thanks!
btw when doing the rename of the files, use git format-patch -M -C , this will only mark the move in the patch, without doing the removal and insertion of a file, so the diff will be shorter while retaining all the information.
Why? MMC layout is same on all of them...
While you are changing that, bigger environment size would be welcome. 32K? Pavel
It doesn't have to be identical. And other boards might want to use e.g. SPI NOR as the environment storage device (I have such a custom board here). So this is definitely a board specific thing.
Yes.
Thanks, Stefan
participants (5)
dinguyenï¼ opensource.altera.com
Dinh Nguyen
Pavel Machek
Stefan Roese
