Pull request: u-boot-imx u-boot-imx-20220616
Hi Tom,
some fixes for 2022.07.
The following changes since commit c18e5fb055ab789f58434e3cb432582adee0134c:
dtoc: Update test_src_scan.py for new tegra compatibles (2022-06-14 13:59:23 -0400)
https://gitlab.denx.de/u-boot/custodians/u-boot-imx.git tags/u-boot-imx-20220616
for you to fetch changes up to 1a558fafbbdff80cb6a7c8e883addec7f02fe8e5:
spi: nxp_fspi: Fix clock imbalance (2022-06-15 11:34:38 +0200)
---------------------------------------------------------------- u-boot-imx-20220616 -------------------
Fixes for 2022.07 + Toradex apalis-imx8 (missed in last PR)
CI: https://source.denx.de/u-boot/custodians/u-boot-imx/-/pipelines/12322
---------------------------------------------------------------- Andrey Zhizhikin (2): clk: imx8mp: fix root clock names for ecspi clk: imx8mp: use usb_core_ref for usb_root_clk
Fabio Estevam (2): imx8mn_evk: Add the missing spl.bin entry imx8mn_evk: Add Ethernet support to the LPDDR4 variant
Gaurav Jain (1): secure boot: enable ARCH_MISC_INIT config.
Josua Mayer (4): phy: adin: add support for clock output ARM: dts: imx6qdl-sr-som: add support for alternate phy addresses mx6cuboxi: fixup dtb ethernet phy nodes before booting an OS mx6cuboxi: enable driver for adin1300 phy
Marek Vasut (1): spi: nxp_fspi: Fix clock imbalance
Nate Drude (1): phy: adin: fix broken support for adi, phy-mode-override
Philippe Schenker (3): toradex: tdx-cfg-block: add new 8gb apalis-imx8 board: apalis-imx8: add new 8gb product variant verdin-imx8mm, verdin-imx8mp: Fix default systemd console output
arch/arm/dts/imx6qdl-sr-som.dtsi | 17 +++++++++++++++-- arch/arm/dts/imx8mn-evk-u-boot.dtsi | 4 +++- board/freescale/common/Kconfig | 1 + board/solidrun/mx6cuboxi/mx6cuboxi.c | 78 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ board/toradex/apalis-imx8/apalis-imx8.c | 81 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++---- board/toradex/common/tdx-cfg-block.c | 18 ++++++++++++++++-- board/toradex/common/tdx-cfg-block.h | 1 + configs/imx8mn_evk_defconfig | 8 ++++++++ configs/mx6cuboxi_defconfig | 2 ++ drivers/clk/imx/clk-imx8mp.c | 8 ++++---- drivers/net/phy/adin.c | 64 +++++++++++++++++++++++++++++++++++++++++++++++++++++----------- drivers/spi/nxp_fspi.c | 3 --- include/configs/verdin-imx8mm.h | 4 ++-- include/configs/verdin-imx8mp.h | 2 +- 14 files changed, 261 insertions(+), 30 deletions(-)
Best regards, Stefano
On Thu, Jun 16, 2022 at 09:32:17AM +0200, Stefano Babic wrote:
Hi Tom,
Stefano Babic
