[PATCH 0/3] Allwinner sunxi USB gadget improvements
Hi list,
This patchset improves the musb-new variant used in sunxi for DM support and contains a couple of small fixes. Nothing too exciting here.
A note for Andre (as I suspect you'll be the one reviewing this): Could you update your R528/T113s series with: cpu_sunxi_ncat2.h: +#define SUNXI_SRAMC_BASE 0 Kconfig: + select PHY_SUN4I_USB ...as appropriate? Those are the only changes necessary to get this USB gadget driver working over there. :)
Many thanks, Sam
Sam Edwards (3): usb: musb-new: sunxi: do not attempt to access NULL SRAMC usb: musb-new: sunxi: fix error check usb: musb-new: sunxi: make compatible with UDC/DM gadget model
drivers/usb/musb-new/sunxi.c | 76 ++++++++++++++++++++++-------------- 1 file changed, 47 insertions(+), 29 deletions(-)
I believe that some sunxis (ncat2?) lack a SRAMC block, as accessing this region results in a data abort. Checking that it's non-null before accessing it allows this to be set to NULL for SoCs where it's not present.
Signed-off-by: Sam Edwards CFSworks@gmail.com --- drivers/usb/musb-new/sunxi.c | 16 +++++++++------- 1 file changed, 9 insertions(+), 7 deletions(-)
diff --git a/drivers/usb/musb-new/sunxi.c b/drivers/usb/musb-new/sunxi.c index dc4cfc2194..6e60dd47e0 100644 --- a/drivers/usb/musb-new/sunxi.c +++ b/drivers/usb/musb-new/sunxi.c @@ -174,13 +174,15 @@ static void USBC_ForceVbusValidToHigh(__iomem void *base)
static void USBC_ConfigFIFO_Base(void) { - u32 reg_value; - - /* config usb fifo, 8kb mode */ - reg_value = readl(SUNXI_SRAMC_BASE + 0x04); - reg_value &= ~(0x03 << 0); - reg_value |= BIT(0); - writel(reg_value, SUNXI_SRAMC_BASE + 0x04); + if (SUNXI_SRAMC_BASE) { + u32 reg_value; + + /* config usb fifo, 8kb mode */ + reg_value = readl(SUNXI_SRAMC_BASE + 0x04); + reg_value &= ~(0x03 << 0); + reg_value |= BIT(0); + writel(reg_value, SUNXI_SRAMC_BASE + 0x04); + } }
Could it be that the SRAMC clock need to be enabled instead ? (note that I don't know anything about sunxi stuff)
On Fri, 2 Jun 2023 15:49:56 -0600 Sam Edwards cfsworks@gmail.com wrote:
Hi Sam,
thanks for taking care and sending patched!
Ah, that's a good find, but I think it goes a bit deeper: Just to be clear, "SRAMC" stands for "SRAM controller", not "SRAM memory block C" (which other SoCs have, but indeed not the D1/T113s). However we (sort of) have an "SRAM controller", although the manual and DT call this IP block "syscon" these days. The address currently in ncat2.h is just plain wrong, it's actually 0x3000000.
Now looking at the Linux MUSB driver, only the older SoCs (A10, A20, F1C100s) need to switch some SRAM block to the OTG controller: https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/tree/driv...
So the code is already wrong, we should not touch SYSCON+0x04 for any newer SoCs, based on the compatible. We seem to be just lucky that newer syscons don't have any register at offset 0x4. And using SUNXI_SRAMC_BASE is somewhat dodgy to begin with, we should use the "allwinner,sram" property from the DT, although this is surely more complicated.
Do you have spare cycles to convert this over to look at the DT for this SRAM part? For now you might just change the SRAM address in ncat2.h to 0x03000000, to be inline with the other SoCs.
Cheers, Andre
- u32 reg_value;
- if (SUNXI_SRAMC_BASE) {
u32 reg_value;
Howdy Andre,
I did understand SRAMC to mean "SRAM controller," but what a funny coincidence that NCAT2 does away with SRAM 'C' at around the same time I sent in this patch! I did not know it's now the "syscon," I just deduced that it wasn't being used for anything important when I couldn't find any relevant code relying on it.
I spent longer than I thought I would looking into this! :)
Adding a `has_sram` field to the match table data was easy enough, but dynamic discovery of the syscon is, for sure, more complicated. The biggest problem is that the data model for representing these bits seems overengineered for what it is, and most of the logic is just for identifying *which bit* needs to be set. Linux's logic for the "syscon base" part of it is just: the first allwinner,*-system-control device to probe, registers itself globally -- that's it. Surely we could keep the "set the 1 bit" part of it hardcoded and just do the same thing (global registration) for the syscon, no need to chase the allwinner,sram phandle? That should suffice if the goal is to remove the SUNXI_SRAMC_BASE define, no?
(By the way, apparently this facility in the SYSCON+0x4 register is only 1 bit wide -- not 2 as U-Boot believes. It also seems to be for switching ownership of SRAM block 'D' between the USB controller and CPU, and if so the "config usb fifo, 8kb mode" comment and USBC_ConfigFIFO_Base function name are both wrong. I am only judging by the Linux implementation of this logic, though.)
I'll do that latter part locally (can you take care of it in your series?) and send in a patch for the `has_sram` change that also clarifies the purpose of the syscon poke. The SUNXI_SRAMC_BASE removal I just now mentioned could be interesting, but not something I want to hold up NCAT2 support on.
Best regards, Sam
On Tue, 6 Jun 2023 23:39:24 -0600 Sam Edwards cfsworks@gmail.com wrote:
Hi Sam,
Yeah, I figured you would know, but just wanted to make this clear, also for the benefit of others, because it confused me in the past.
"syscon" really just means "a bunch of gates where AW didn't know where else to put them". In modern SoCs it prominently contains the version register and some EMAC control bits, partly, but not entirely, related to internal PHYs. And it's already the A10 manual that uses the term "system controller", maybe "SRAMC" comes from the original BSP source code. Definitely it somewhat evolved, because originally it was really just the SRAM control bits in there, but now has other functionality, and might not even control the SRAM muxing anymore.
I understand that it seems like boiling the ocean for just flipping a single bit somewhere, but at least for Linux there are good reasons to do it that way, see below. And to be honest, those problems stem more from AW's somewhat problematic design to use a generic "syscon" block, for *multiple* different things, in the first place.
Well, we indeed only seem to support one instance of syscon, but this is somewhat backed by its idea of some "catch-all" register collection. What's important for Linux is that only one device can claim a certain MMIO region. When other devices want to access even a single bit in there, they need to somehow talk to that other device. In Linux this is modelled via phandles and regmaps, and works somewhat nicely, if at the cost of having the boilerplate for a whole extra device. Now porting this over in its entirety to U-Boot is possible, but somewhat over-the-top for a bootloader, I believe. We have shortcuts, though, see sun8i_emac.c:sun8i_emac_eth_of_to_plat().
I think for that we could follow the sun8i-emac route: follow the phandle, and pick the "reg" property from the DTB. No need for an extra driver.
Yeah, it seems this way, though nobody knows for sure ;-) I believe this is code that came from the original Allwinner BSP, which tends to do, well, weird stuff at times ;-)
Yeah, so there are three steps, in increasing order of complexity: 1) Change SUNXI_SRAMC_BASE to 0x3000000. That's done already in my tree. 2) Introduce some has_sram property in U-Boot's MUSB driver and only poke the SRAM D bit for those SoCs that need it. 3) Follow the allwinner,sram phandle in the MUSB driver and fish out the syscon base address from the DTB, to avoid hardcoding it, at least for the MUSB driver. We need it elsewhere, to access the version register and print the SoC name.
Can you confirm that just changing the SUNXI_SRAMC_BASE to 0x3000000 avoids the crash you saw, and removes the immediate need for this very patch here?
And if I get this right, you already have 2) implemented? I would love to see it on the list, then.
3) doesn't really have priority, as we need SUNXI_SRAMC_BASE in cpu_info.c anyway. But looking at the sun8i_emac.c shortcut, it might not be too hard to do either.
Thanks, Andre
Hey Andre,
The good ol' "kitchen sink" register block, eh? Its lack of clear, definite purpose is even reflected in the name, because when you think about it, isn't *every* MMIO register for "system control"? :)
I've gone ahead and submitted a patch for rewording this in the driver source anyway. In the commit message, I've included a way we could verify this experimentally, though I don't have access to an early Allwinner SoC with which to try it.
- Change SUNXI_SRAMC_BASE to 0x3000000. That's done already in my tree.
I've done it over here as well.
- Introduce some has_sram property in U-Boot's MUSB driver and only poke
Done, a patch for that has been sent in.
- Follow the allwinner,sram phandle in the MUSB driver and fish out the
One of the patches I just sent in also adds a "TODO" comment to do this. I also kept the function separate specifically so someone coming along later wanting to add this has plenty of breathing room to do so.
Yes: I reverted enough changes to make the crash reappear, and then changed the base register. Updating SUNXI_SRAM_BASE to 0x03000000 resolves the crash with no side effects: it seems (BIT(0) of) 0x03000004 is RAZ/WI.
See Patchwork series #358672.
Thanks for your continued efforts, Sam
The `musb_register` function returns some ERR_PTR(...) on failure, not NULL, so update the check here appropriately.
Signed-off-by: Sam Edwards CFSworks@gmail.com --- drivers/usb/musb-new/sunxi.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/usb/musb-new/sunxi.c b/drivers/usb/musb-new/sunxi.c index 6e60dd47e0..65a528e229 100644 --- a/drivers/usb/musb-new/sunxi.c +++ b/drivers/usb/musb-new/sunxi.c @@ -488,7 +488,7 @@ static int musb_usb_probe(struct udevice *dev) #else pdata.mode = MUSB_PERIPHERAL; host->host = musb_register(&pdata, &glue->dev, base); - if (!host->host) + if (IS_ERR_OR_NULL(host->host)) return -EIO;
printf("Allwinner mUSB OTG (Peripheral)\n");
- if (!host->host)
Can you please send this one separately, so I can pick it for current release ?
Since many sunxi boards do not implement a `board_usb_init`, it's better if we just make the sunxi USB driver compatible with the DM gadget model, as many other musb-new variants already are.
This change has been verified working on a T113s.
Signed-off-by: Sam Edwards CFSworks@gmail.com --- drivers/usb/musb-new/sunxi.c | 60 +++++++++++++++++++++++------------- 1 file changed, 38 insertions(+), 22 deletions(-)
diff --git a/drivers/usb/musb-new/sunxi.c b/drivers/usb/musb-new/sunxi.c index 65a528e229..ac6d1a41bb 100644 --- a/drivers/usb/musb-new/sunxi.c +++ b/drivers/usb/musb-new/sunxi.c @@ -432,6 +432,16 @@ static struct musb_hdrc_config musb_config_h3 = { .ram_bits = SUNXI_MUSB_RAM_BITS, };
+#if CONFIG_IS_ENABLED(DM_USB_GADGET) +int dm_usb_gadget_handle_interrupts(struct udevice *dev) { + struct sunxi_glue *glue = dev_get_priv(dev); + struct musb_host_data *host = &glue->mdata; + + host->host->isr(0, host->host); + return 0; +} +#endif + static int musb_usb_probe(struct udevice *dev) { struct sunxi_glue *glue = dev_get_priv(dev); @@ -440,10 +450,6 @@ static int musb_usb_probe(struct udevice *dev) void *base = dev_read_addr_ptr(dev); int ret;
-#ifdef CONFIG_USB_MUSB_HOST - struct usb_bus_priv *priv = dev_get_uclass_priv(dev); -#endif - if (!base) return -EINVAL;
@@ -474,25 +480,35 @@ static int musb_usb_probe(struct udevice *dev) pdata.platform_ops = &sunxi_musb_ops; pdata.config = glue->cfg->config;
-#ifdef CONFIG_USB_MUSB_HOST - priv->desc_before_addr = true; - - pdata.mode = MUSB_HOST; - host->host = musb_init_controller(&pdata, &glue->dev, base); - if (!host->host) - return -EIO; - - ret = musb_lowlevel_init(host); - if (!ret) - printf("Allwinner mUSB OTG (Host)\n"); -#else - pdata.mode = MUSB_PERIPHERAL; - host->host = musb_register(&pdata, &glue->dev, base); - if (IS_ERR_OR_NULL(host->host)) - return -EIO; + if (IS_ENABLED(CONFIG_USB_MUSB_HOST)) { + struct usb_bus_priv *priv = dev_get_uclass_priv(dev); + priv->desc_before_addr = true; + + pdata.mode = MUSB_HOST; + host->host = musb_init_controller(&pdata, &glue->dev, base); + if (!host->host) + return -EIO; + + ret = musb_lowlevel_init(host); + if (!ret) + printf("Allwinner mUSB OTG (Host)\n"); + } else if (CONFIG_IS_ENABLED(DM_USB_GADGET)) { + pdata.mode = MUSB_PERIPHERAL; + host->host = musb_init_controller(&pdata, &glue->dev, base); + if (!host->host) + return -EIO; + + ret = usb_add_gadget_udc(&glue->dev, &host->host->g); + if (!ret) + printf("Allwinner mUSB OTG (Peripheral)\n"); + } else { + pdata.mode = MUSB_PERIPHERAL; + host->host = musb_register(&pdata, &glue->dev, base); + if (IS_ERR_OR_NULL(host->host)) + return -EIO;
- printf("Allwinner mUSB OTG (Peripheral)\n"); -#endif + printf("Allwinner mUSB OTG (Peripheral)\n"); + }
return ret; }
- struct sunxi_glue *glue = dev_get_priv(dev);
- struct musb_host_data *host = &glue->mdata;
- host->host->isr(0, host->host);
+} +#endif
- static int musb_usb_probe(struct udevice *dev) { struct sunxi_glue *glue = dev_get_priv(dev);
-#endif
- if (!host->host)
return -EIO;
- if (!ret)
-#else
return -EIO;
- if (IS_ENABLED(CONFIG_USB_MUSB_HOST)) {
if (!host->host)
return -EIO;
if (!ret)
Please just drop this print for DM (or in general).
Andre Przywara
Sam Edwards
