[PATCH] arm: dts: keystone: Move to OF_UPSTREAM
Enable OF_UPSTREAM for Keystone boards. Remove DT files that are now available in dts/upstream.
Signed-off-by: Andrew Davis afd@ti.com --- arch/arm/dts/Makefile | 7 - arch/arm/dts/keystone-clocks.dtsi | 411 ----------------- arch/arm/dts/keystone-k2e-clocks.dtsi | 74 --- arch/arm/dts/keystone-k2e-evm-u-boot.dtsi | 14 +- arch/arm/dts/keystone-k2e-evm.dts | 152 ------- arch/arm/dts/keystone-k2e-netcp.dtsi | 203 --------- arch/arm/dts/keystone-k2e.dtsi | 144 ------ arch/arm/dts/keystone-k2g-evm-u-boot.dtsi | 20 +- arch/arm/dts/keystone-k2g-evm.dts | 148 ------ arch/arm/dts/keystone-k2g-generic-u-boot.dtsi | 18 - arch/arm/dts/keystone-k2g-generic.dts | 27 -- arch/arm/dts/keystone-k2g-ice-u-boot.dtsi | 15 +- arch/arm/dts/keystone-k2g-ice.dts | 118 ----- arch/arm/dts/keystone-k2g-netcp.dtsi | 149 ------- arch/arm/dts/keystone-k2g.dtsi | 258 ----------- arch/arm/dts/keystone-k2hk-clocks.dtsi | 422 ------------------ arch/arm/dts/keystone-k2hk-evm-u-boot.dtsi | 26 +- arch/arm/dts/keystone-k2hk-evm.dts | 180 -------- arch/arm/dts/keystone-k2hk-netcp.dtsi | 207 --------- arch/arm/dts/keystone-k2hk.dtsi | 111 ----- arch/arm/dts/keystone-k2l-clocks.dtsi | 263 ----------- arch/arm/dts/keystone-k2l-evm-u-boot.dtsi | 28 +- arch/arm/dts/keystone-k2l-evm.dts | 129 ------ arch/arm/dts/keystone-k2l-netcp.dtsi | 187 -------- arch/arm/dts/keystone-k2l.dtsi | 105 ----- arch/arm/dts/keystone.dtsi | 330 -------------- configs/k2e_evm_defconfig | 3 +- configs/k2e_hs_evm_defconfig | 3 +- configs/k2g_evm_defconfig | 5 +- configs/k2g_hs_evm_defconfig | 5 +- configs/k2hk_evm_defconfig | 3 +- configs/k2hk_hs_evm_defconfig | 3 +- configs/k2l_evm_defconfig | 3 +- configs/k2l_hs_evm_defconfig | 3 +- 34 files changed, 98 insertions(+), 3676 deletions(-) delete mode 100644 arch/arm/dts/keystone-clocks.dtsi delete mode 100644 arch/arm/dts/keystone-k2e-clocks.dtsi delete mode 100644 arch/arm/dts/keystone-k2e-evm.dts delete mode 100644 arch/arm/dts/keystone-k2e-netcp.dtsi delete mode 100644 arch/arm/dts/keystone-k2e.dtsi delete mode 100644 arch/arm/dts/keystone-k2g-evm.dts delete mode 100644 arch/arm/dts/keystone-k2g-generic-u-boot.dtsi delete mode 100644 arch/arm/dts/keystone-k2g-generic.dts delete mode 100644 arch/arm/dts/keystone-k2g-ice.dts delete mode 100644 arch/arm/dts/keystone-k2g-netcp.dtsi delete mode 100644 arch/arm/dts/keystone-k2g.dtsi delete mode 100644 arch/arm/dts/keystone-k2hk-clocks.dtsi delete mode 100644 arch/arm/dts/keystone-k2hk-evm.dts delete mode 100644 arch/arm/dts/keystone-k2hk-netcp.dtsi delete mode 100644 arch/arm/dts/keystone-k2hk.dtsi delete mode 100644 arch/arm/dts/keystone-k2l-clocks.dtsi delete mode 100644 arch/arm/dts/keystone-k2l-evm.dts delete mode 100644 arch/arm/dts/keystone-k2l-netcp.dtsi delete mode 100644 arch/arm/dts/keystone-k2l.dtsi delete mode 100644 arch/arm/dts/keystone.dtsi
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 82d37adae3f..2c983b2224c 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -953,13 +953,6 @@ endif dtb-$(CONFIG_RZA1) += \ r7s72100-gr-peach.dtb
-dtb-$(CONFIG_ARCH_KEYSTONE) += keystone-k2hk-evm.dtb \ - keystone-k2l-evm.dtb \ - keystone-k2e-evm.dtb \ - keystone-k2g-evm.dtb \ - keystone-k2g-generic.dtb \ - keystone-k2g-ice.dtb - dtb-$(CONFIG_TARGET_AT91SAM9261EK) += at91sam9261ek.dtb
dtb-$(CONFIG_TARGET_PM9261) += at91sam9261ek.dtb diff --git a/arch/arm/dts/keystone-clocks.dtsi b/arch/arm/dts/keystone-clocks.dtsi deleted file mode 100644 index 33742d81971..00000000000 --- a/arch/arm/dts/keystone-clocks.dtsi +++ /dev/null @@ -1,411 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Device Tree Source for Keystone 2 clock tree - * - * Copyright (C) 2013-2017 Texas Instruments Incorporated - https://www.ti.com/ - */ - -clocks { - #address-cells = <1>; - #size-cells = <1>; - ranges; - - mainmuxclk: mainmuxclk@2310108 { - #clock-cells = <0>; - compatible = "ti,keystone,pll-mux-clock"; - clocks = <&mainpllclk>, <&refclksys>; - reg = <0x02310108 4>; - bit-shift = <23>; - bit-mask = <1>; - clock-output-names = "mainmuxclk"; - }; - - chipclk1: chipclk1 { - #clock-cells = <0>; - compatible = "fixed-factor-clock"; - clocks = <&mainmuxclk>; - clock-div = <1>; - clock-mult = <1>; - clock-output-names = "chipclk1"; - }; - - chipclk1rstiso: chipclk1rstiso { - #clock-cells = <0>; - compatible = "fixed-factor-clock"; - clocks = <&mainmuxclk>; - clock-div = <1>; - clock-mult = <1>; - clock-output-names = "chipclk1rstiso"; - }; - - gemtraceclk: gemtraceclk@2310120 { - #clock-cells = <0>; - compatible = "ti,keystone,pll-divider-clock"; - clocks = <&mainmuxclk>; - reg = <0x02310120 4>; - bit-shift = <0>; - bit-mask = <8>; - clock-output-names = "gemtraceclk"; - }; - - chipstmxptclk: chipstmxptclk@2310164 { - #clock-cells = <0>; - compatible = "ti,keystone,pll-divider-clock"; - clocks = <&mainmuxclk>; - reg = <0x02310164 4>; - bit-shift = <0>; - bit-mask = <8>; - clock-output-names = "chipstmxptclk"; - }; - - chipclk12: chipclk12 { - #clock-cells = <0>; - compatible = "fixed-factor-clock"; - clocks = <&chipclk1>; - clock-div = <2>; - clock-mult = <1>; - clock-output-names = "chipclk12"; - }; - - chipclk13: chipclk13 { - #clock-cells = <0>; - compatible = "fixed-factor-clock"; - clocks = <&chipclk1>; - clock-div = <3>; - clock-mult = <1>; - clock-output-names = "chipclk13"; - }; - - paclk13: paclk13 { - #clock-cells = <0>; - compatible = "fixed-factor-clock"; - clocks = <&papllclk>; - clock-div = <3>; - clock-mult = <1>; - clock-output-names = "paclk13"; - }; - - chipclk14: chipclk14 { - #clock-cells = <0>; - compatible = "fixed-factor-clock"; - clocks = <&chipclk1>; - clock-div = <4>; - clock-mult = <1>; - clock-output-names = "chipclk14"; - }; - - chipclk16: chipclk16 { - #clock-cells = <0>; - compatible = "fixed-factor-clock"; - clocks = <&chipclk1>; - clock-div = <6>; - clock-mult = <1>; - clock-output-names = "chipclk16"; - }; - - chipclk112: chipclk112 { - #clock-cells = <0>; - compatible = "fixed-factor-clock"; - clocks = <&chipclk1>; - clock-div = <12>; - clock-mult = <1>; - clock-output-names = "chipclk112"; - }; - - chipclk124: chipclk124 { - #clock-cells = <0>; - compatible = "fixed-factor-clock"; - clocks = <&chipclk1>; - clock-div = <24>; - clock-mult = <1>; - clock-output-names = "chipclk114"; - }; - - chipclk1rstiso13: chipclk1rstiso13 { - #clock-cells = <0>; - compatible = "fixed-factor-clock"; - clocks = <&chipclk1rstiso>; - clock-div = <3>; - clock-mult = <1>; - clock-output-names = "chipclk1rstiso13"; - }; - - chipclk1rstiso14: chipclk1rstiso14 { - #clock-cells = <0>; - compatible = "fixed-factor-clock"; - clocks = <&chipclk1rstiso>; - clock-div = <4>; - clock-mult = <1>; - clock-output-names = "chipclk1rstiso14"; - }; - - chipclk1rstiso16: chipclk1rstiso16 { - #clock-cells = <0>; - compatible = "fixed-factor-clock"; - clocks = <&chipclk1rstiso>; - clock-div = <6>; - clock-mult = <1>; - clock-output-names = "chipclk1rstiso16"; - }; - - chipclk1rstiso112: chipclk1rstiso112 { - #clock-cells = <0>; - compatible = "fixed-factor-clock"; - clocks = <&chipclk1rstiso>; - clock-div = <12>; - clock-mult = <1>; - clock-output-names = "chipclk1rstiso112"; - }; - - clkmodrst0: clkmodrst0@2350000 { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&chipclk16>; - clock-output-names = "modrst0"; - reg = <0x02350000 0xb00>, <0x02350000 0x400>; - reg-names = "control", "domain"; - domain-id = <0>; - }; - - - clkusb: clkusb@2350008 { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&chipclk16>; - clock-output-names = "usb"; - reg = <0x02350008 0xb00>, <0x02350000 0x400>; - reg-names = "control", "domain"; - domain-id = <0>; - }; - - clkaemifspi: clkaemifspi@235000c { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&chipclk16>; - clock-output-names = "aemif-spi"; - reg = <0x0235000c 0xb00>, <0x02350000 0x400>; - reg-names = "control", "domain"; - domain-id = <0>; - }; - - - clkdebugsstrc: clkdebugsstrc@2350014 { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&chipclk13>; - clock-output-names = "debugss-trc"; - reg = <0x02350014 0xb00>, <0x02350000 0x400>; - reg-names = "control", "domain"; - domain-id = <1>; - }; - - clktetbtrc: clktetbtrc@2350018 { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&chipclk13>; - clock-output-names = "tetb-trc"; - reg = <0x02350018 0xb00>, <0x02350004 0x400>; - reg-names = "control", "domain"; - domain-id = <1>; - }; - - clkpa: clkpa@235001c { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&paclk13>; - clock-output-names = "pa"; - reg = <0x0235001c 0xb00>, <0x02350008 0x400>; - reg-names = "control", "domain"; - domain-id = <2>; - }; - - clkcpgmac: clkcpgmac@2350020 { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&clkpa>; - clock-output-names = "cpgmac"; - reg = <0x02350020 0xb00>, <0x02350008 0x400>; - reg-names = "control", "domain"; - domain-id = <2>; - }; - - clksa: clksa@2350024 { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&clkpa>; - clock-output-names = "sa"; - reg = <0x02350024 0xb00>, <0x02350008 0x400>; - reg-names = "control", "domain"; - domain-id = <2>; - }; - - clkpcie: clkpcie@2350028 { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&chipclk12>; - clock-output-names = "pcie"; - reg = <0x02350028 0xb00>, <0x0235000c 0x400>; - reg-names = "control", "domain"; - domain-id = <3>; - }; - - clksr: clksr@2350034 { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&chipclk1rstiso112>; - clock-output-names = "sr"; - reg = <0x02350034 0xb00>, <0x02350018 0x400>; - reg-names = "control", "domain"; - domain-id = <6>; - }; - - clkgem0: clkgem0@235003c { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&chipclk1>; - clock-output-names = "gem0"; - reg = <0x0235003c 0xb00>, <0x02350020 0x400>; - reg-names = "control", "domain"; - domain-id = <8>; - }; - - clkddr30: clkddr30@235005c { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&chipclk12>; - clock-output-names = "ddr3-0"; - reg = <0x0235005c 0xb00>, <0x02350040 0x400>; - reg-names = "control", "domain"; - domain-id = <16>; - }; - - clkwdtimer0: clkwdtimer0@2350000 { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&clkmodrst0>; - clock-output-names = "timer0"; - reg = <0x02350000 0xb00>, <0x02350000 0x400>; - reg-names = "control", "domain"; - domain-id = <0>; - }; - - clkwdtimer1: clkwdtimer1@2350000 { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&clkmodrst0>; - clock-output-names = "timer1"; - reg = <0x02350000 0xb00>, <0x02350000 0x400>; - reg-names = "control", "domain"; - domain-id = <0>; - }; - - clkwdtimer2: clkwdtimer2@2350000 { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&clkmodrst0>; - clock-output-names = "timer2"; - reg = <0x02350000 0xb00>, <0x02350000 0x400>; - reg-names = "control", "domain"; - domain-id = <0>; - }; - - clkwdtimer3: clkwdtimer3@2350000 { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&clkmodrst0>; - clock-output-names = "timer3"; - reg = <0x02350000 0xb00>, <0x02350000 0x400>; - reg-names = "control", "domain"; - domain-id = <0>; - }; - - clktimer15: clktimer15@2350000 { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&clkmodrst0>; - clock-output-names = "timer15"; - reg = <0x02350000 0xb00>, <0x02350000 0x400>; - reg-names = "control", "domain"; - domain-id = <0>; - }; - - clkuart0: clkuart0@2350000 { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&clkmodrst0>; - clock-output-names = "uart0"; - reg = <0x02350000 0xb00>, <0x02350000 0x400>; - reg-names = "control", "domain"; - domain-id = <0>; - }; - - clkuart1: clkuart1@2350000 { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&clkmodrst0>; - clock-output-names = "uart1"; - reg = <0x02350000 0xb00>, <0x02350000 0x400>; - reg-names = "control", "domain"; - domain-id = <0>; - }; - - clkaemif: clkaemif@2350000 { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&clkaemifspi>; - clock-output-names = "aemif"; - reg = <0x02350000 0xb00>, <0x02350000 0x400>; - reg-names = "control", "domain"; - domain-id = <0>; - }; - - clkusim: clkusim@2350000 { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&clkmodrst0>; - clock-output-names = "usim"; - reg = <0x02350000 0xb00>, <0x02350000 0x400>; - reg-names = "control", "domain"; - domain-id = <0>; - }; - - clki2c: clki2c@2350000 { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&clkmodrst0>; - clock-output-names = "i2c"; - reg = <0x02350000 0xb00>, <0x02350000 0x400>; - reg-names = "control", "domain"; - domain-id = <0>; - }; - - clkspi: clkspi@2350000 { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&clkaemifspi>; - clock-output-names = "spi"; - reg = <0x02350000 0xb00>, <0x02350000 0x400>; - reg-names = "control", "domain"; - domain-id = <0>; - }; - - clkgpio: clkgpio@2350000 { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&clkmodrst0>; - clock-output-names = "gpio"; - reg = <0x02350000 0xb00>, <0x02350000 0x400>; - reg-names = "control", "domain"; - domain-id = <0>; - }; - - clkkeymgr: clkkeymgr@2350000 { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&clkmodrst0>; - clock-output-names = "keymgr"; - reg = <0x02350000 0xb00>, <0x02350000 0x400>; - reg-names = "control", "domain"; - domain-id = <0>; - }; -}; diff --git a/arch/arm/dts/keystone-k2e-clocks.dtsi b/arch/arm/dts/keystone-k2e-clocks.dtsi deleted file mode 100644 index 46f8ab3a11d..00000000000 --- a/arch/arm/dts/keystone-k2e-clocks.dtsi +++ /dev/null @@ -1,74 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Keystone 2 Edison SoC specific device tree - * - * Copyright (C) 2014-2017 Texas Instruments Incorporated - https://www.ti.com/ - */ - -clocks { - mainpllclk: mainpllclk@2310110 { - #clock-cells = <0>; - compatible = "ti,keystone,main-pll-clock"; - clocks = <&refclksys>; - reg = <0x02620350 4>, <0x02310110 4>, <0x02310108 4>; - reg-names = "control", "multiplier", "post-divider"; - }; - - papllclk: papllclk@2620358 { - #clock-cells = <0>; - compatible = "ti,keystone,pll-clock"; - clocks = <&refclkpass>; - clock-output-names = "papllclk"; - reg = <0x02620358 4>; - reg-names = "control"; - }; - - ddr3apllclk: ddr3apllclk@2620360 { - #clock-cells = <0>; - compatible = "ti,keystone,pll-clock"; - clocks = <&refclkddr3a>; - clock-output-names = "ddr-3a-pll-clk"; - reg = <0x02620360 4>; - reg-names = "control"; - }; - - clkusb1: clkusb1@2350004 { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&chipclk16>; - clock-output-names = "usb1"; - reg = <0x02350004 0xb00>, <0x02350000 0x400>; - reg-names = "control", "domain"; - domain-id = <0>; - }; - - clkhyperlink0: clkhyperlink0@2350030 { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&chipclk12>; - clock-output-names = "hyperlink-0"; - reg = <0x02350030 0xb00>, <0x02350014 0x400>; - reg-names = "control", "domain"; - domain-id = <5>; - }; - - clkpcie1: clkpcie1@235006c { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&chipclk12>; - clock-output-names = "pcie1"; - reg = <0x0235006c 0xb00>, <0x02350048 0x400>; - reg-names = "control", "domain"; - domain-id = <18>; - }; - - clkxge: clkxge@23500c8 { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&chipclk13>; - clock-output-names = "xge"; - reg = <0x023500c8 0xb00>, <0x02350074 0x400>; - reg-names = "control", "domain"; - domain-id = <29>; - }; -}; diff --git a/arch/arm/dts/keystone-k2e-evm-u-boot.dtsi b/arch/arm/dts/keystone-k2e-evm-u-boot.dtsi index 953c7502260..e77c53dbf7b 100644 --- a/arch/arm/dts/keystone-k2e-evm-u-boot.dtsi +++ b/arch/arm/dts/keystone-k2e-evm-u-boot.dtsi @@ -4,15 +4,23 @@ */
/{ - soc { - bootph-all; - }; aliases { usb0 = &usb; usb1 = &usb1; + i2c0 = &i2c0; + i2c1 = &i2c1; + i2c2 = &i2c2; + }; + + chosen { + stdout-path = &uart0; }; };
+&soc0 { + bootph-all; +}; + &i2c1 { bootph-all; }; diff --git a/arch/arm/dts/keystone-k2e-evm.dts b/arch/arm/dts/keystone-k2e-evm.dts deleted file mode 100644 index bf884442617..00000000000 --- a/arch/arm/dts/keystone-k2e-evm.dts +++ /dev/null @@ -1,152 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Keystone 2 Edison EVM device tree - * - * Copyright (C) 2013-2017 Texas Instruments Incorporated - https://www.ti.com/ - */ -/dts-v1/; - -#include "keystone.dtsi" -#include "keystone-k2e.dtsi" - -/ { - compatible = "ti,k2e-evm", "ti,k2e", "ti,keystone"; - model = "Texas Instruments Keystone 2 Edison EVM"; - - soc { - - clocks { - refclksys: refclksys { - #clock-cells = <0>; - compatible = "fixed-clock"; - clock-frequency = <100000000>; - clock-output-names = "refclk-sys"; - }; - - refclkpass: refclkpass { - #clock-cells = <0>; - compatible = "fixed-clock"; - clock-frequency = <100000000>; - clock-output-names = "refclk-pass"; - }; - - refclkddr3a: refclkddr3a { - #clock-cells = <0>; - compatible = "fixed-clock"; - clock-frequency = <100000000>; - clock-output-names = "refclk-ddr3a"; - }; - }; - }; -}; - -&usb_phy { - status = "okay"; -}; - -&usb { - status = "okay"; -}; - -&usb1_phy { - status = "okay"; -}; - -&usb1 { - status = "okay"; -}; - -&i2c0 { - dtt@50 { - compatible = "at,24c1024"; - reg = <0x50>; - }; -}; - -&aemif { - cs0 { - #address-cells = <2>; - #size-cells = <1>; - clock-ranges; - ranges; - - ti,cs-chipselect = <0>; - /* all timings in nanoseconds */ - ti,cs-min-turnaround-ns = <12>; - ti,cs-read-hold-ns = <6>; - ti,cs-read-strobe-ns = <23>; - ti,cs-read-setup-ns = <9>; - ti,cs-write-hold-ns = <8>; - ti,cs-write-strobe-ns = <23>; - ti,cs-write-setup-ns = <8>; - - nand@0,0 { - compatible = "ti,keystone-nand","ti,davinci-nand"; - #address-cells = <1>; - #size-cells = <1>; - reg = <0 0 0x4000000 - 1 0 0x0000100>; - - ti,davinci-chipselect = <0>; - ti,davinci-mask-ale = <0x2000>; - ti,davinci-mask-cle = <0x4000>; - ti,davinci-mask-chipsel = <0>; - nand-ecc-mode = "hw"; - ti,davinci-ecc-bits = <4>; - nand-on-flash-bbt; - - partition@0 { - label = "u-boot"; - reg = <0x0 0x100000>; - read-only; - }; - - partition@100000 { - label = "params"; - reg = <0x100000 0x80000>; - read-only; - }; - - partition@180000 { - label = "ubifs"; - reg = <0x180000 0x1FE80000>; - }; - }; - }; -}; - -&spi0 { - status = "okay"; - nor_flash: flash@0 { - #address-cells = <1>; - #size-cells = <1>; - compatible = "Micron,n25q128a11", "jedec,spi-nor"; - spi-max-frequency = <54000000>; - m25p,fast-read; - reg = <0>; - - partition@0 { - label = "u-boot-spl"; - reg = <0x0 0x80000>; - read-only; - }; - - partition@1 { - label = "misc"; - reg = <0x80000 0xf80000>; - }; - }; -}; - -&mdio { - status = "okay"; - ethphy0: ethernet-phy@0 { - compatible = "marvell,88E1514", "marvell,88E1510", "ethernet-phy-ieee802.3-c22"; - reg = <0>; - }; - - ethphy1: ethernet-phy@1 { - compatible = "marvell,88E1514", "marvell,88E1510", "ethernet-phy-ieee802.3-c22"; - reg = <1>; - }; -}; diff --git a/arch/arm/dts/keystone-k2e-netcp.dtsi b/arch/arm/dts/keystone-k2e-netcp.dtsi deleted file mode 100644 index dd61503db39..00000000000 --- a/arch/arm/dts/keystone-k2e-netcp.dtsi +++ /dev/null @@ -1,203 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Device Tree Source for Keystone 2 Edison Netcp driver - * - * Copyright (C) 2015-2017 Texas Instruments Incorporated - https://www.ti.com/ - */ - -qmss: qmss@2a40000 { - compatible = "ti,keystone-navigator-qmss"; - dma-coherent; - #address-cells = <1>; - #size-cells = <1>; - clocks = <&chipclk13>; - ranges; - queue-range = <0 0x2000>; - linkram0 = <0x100000 0x4000>; - linkram1 = <0 0x10000>; - - qmgrs { - #address-cells = <1>; - #size-cells = <1>; - ranges; - qmgr0 { - managed-queues = <0 0x2000>; - reg = <0x2a40000 0x20000>, - <0x2a06000 0x400>, - <0x2a02000 0x1000>, - <0x2a03000 0x1000>, - <0x23a80000 0x20000>, - <0x2a80000 0x20000>; - reg-names = "peek", "status", "config", - "region", "push", "pop"; - }; - }; - queue-pools { - qpend { - qpend-0 { - qrange = <658 8>; - interrupts =<0 40 0xf04 0 41 0xf04 0 42 0xf04 - 0 43 0xf04 0 44 0xf04 0 45 0xf04 - 0 46 0xf04 0 47 0xf04>; - }; - qpend-1 { - qrange = <528 16>; - interrupts = <0 48 0xf04 0 49 0xf04 0 50 0xf04 - 0 51 0xf04 0 52 0xf04 0 53 0xf04 - 0 54 0xf04 0 55 0xf04 0 56 0xf04 - 0 57 0xf04 0 58 0xf04 0 59 0xf04 - 0 60 0xf04 0 61 0xf04 0 62 0xf04 - 0 63 0xf04>; - qalloc-by-id; - }; - qpend-2 { - qrange = <544 16>; - interrupts = <0 64 0xf04 0 65 0xf04 0 66 0xf04 - 0 59 0xf04 0 68 0xf04 0 69 0xf04 - 0 70 0xf04 0 71 0xf04 0 72 0xf04 - 0 73 0xf04 0 74 0xf04 0 75 0xf04 - 0 76 0xf04 0 77 0xf04 0 78 0xf04 - 0 79 0xf04>; - }; - }; - general-purpose { - gp-0 { - qrange = <4000 64>; - }; - netcp-tx { - qrange = <896 128>; - qalloc-by-id; - }; - }; - }; - descriptor-regions { - #address-cells = <1>; - #size-cells = <1>; - ranges; - region-12 { - id = <12>; - region-spec = <8192 128>; /* num_desc desc_size */ - link-index = <0x4000>; - }; - }; -}; /* qmss */ - -knav_dmas: knav_dmas@0 { - compatible = "ti,keystone-navigator-dma"; - clocks = <&papllclk>; - #address-cells = <1>; - #size-cells = <1>; - ranges; - ti,navigator-cloud-address = <0x23a80000 0x23a90000 - 0x23a80000 0x23a90000>; - - dma_gbe: dma_gbe@0 { - reg = <0x24186000 0x100>, - <0x24187000 0x2a0>, - <0x24188000 0xb60>, - <0x24186100 0x80>, - <0x24189000 0x1000>; - reg-names = "global", "txchan", "rxchan", - "txsched", "rxflow"; - }; -}; - -netcp: netcp@24000000 { - reg = <0x2620110 0x8>; - reg-names = "efuse"; - compatible = "ti,netcp-1.0"; - #address-cells = <1>; - #size-cells = <1>; - - /* NetCP address range */ - ranges = <0 0x24000000 0x1000000>; - - clocks = <&papllclk>, <&clkcpgmac>, <&chipclk12>; - dma-coherent; - - ti,navigator-dmas = <&dma_gbe 0>, - <&dma_gbe 8>, - <&dma_gbe 0>; - ti,navigator-dma-names = "netrx0", "netrx1", "nettx"; - - netcp-devices { - #address-cells = <1>; - #size-cells = <1>; - ranges; - gbe@200000 { /* ETHSS */ - label = "netcp-gbe"; - compatible = "ti,netcp-gbe-9"; - reg = <0x200000 0x900>, <0x220000 0x20000>; - /* enable-ale; */ - tx-queue = <896>; - tx-channel = "nettx"; - - interfaces { - gbe0: interface-0 { - slave-port = <0>; - link-interface = <1>; - phy-handle = <ðphy0>; - }; - gbe1: interface-1 { - slave-port = <1>; - link-interface = <1>; - phy-handle = <ðphy1>; - }; - }; - - secondary-slave-ports { - port-2 { - slave-port = <2>; - link-interface = <2>; - }; - port-3 { - slave-port = <3>; - link-interface = <2>; - }; - port-4 { - slave-port = <4>; - link-interface = <2>; - }; - port-5 { - slave-port = <5>; - link-interface = <2>; - }; - port-6 { - slave-port = <6>; - link-interface = <2>; - }; - port-7 { - slave-port = <7>; - link-interface = <2>; - }; - }; - }; - }; - - netcp-interfaces { - interface-0 { - rx-channel = "netrx0"; - rx-pool = <1024 12>; - tx-pool = <1024 12>; - rx-queue-depth = <128 128 0 0>; - rx-buffer-size = <1518 4096 0 0>; - rx-queue = <528>; - tx-completion-queue = <530>; - efuse-mac = <1>; - netcp-gbe = <&gbe0>; - - }; - interface-1 { - rx-channel = "netrx1"; - rx-pool = <1024 12>; - tx-pool = <1024 12>; - rx-queue-depth = <128 128 0 0>; - rx-buffer-size = <1518 4096 0 0>; - rx-queue = <529>; - tx-completion-queue = <531>; - efuse-mac = <0>; - local-mac-address = [02 18 31 7e 3e 00]; - netcp-gbe = <&gbe1>; - }; - }; -}; diff --git a/arch/arm/dts/keystone-k2e.dtsi b/arch/arm/dts/keystone-k2e.dtsi deleted file mode 100644 index 449cddcb814..00000000000 --- a/arch/arm/dts/keystone-k2e.dtsi +++ /dev/null @@ -1,144 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Keystone 2 Edison soc device tree - * - * Copyright (C) 2013-2017 Texas Instruments Incorporated - https://www.ti.com/ - */ - -/ { - cpus { - #address-cells = <1>; - #size-cells = <0>; - - interrupt-parent = <&gic>; - - cpu@0 { - compatible = "arm,cortex-a15"; - device_type = "cpu"; - reg = <0>; - }; - - cpu@1 { - compatible = "arm,cortex-a15"; - device_type = "cpu"; - reg = <1>; - }; - - cpu@2 { - compatible = "arm,cortex-a15"; - device_type = "cpu"; - reg = <2>; - }; - - cpu@3 { - compatible = "arm,cortex-a15"; - device_type = "cpu"; - reg = <3>; - }; - }; - - soc { - /include/ "keystone-k2e-clocks.dtsi" - - usb: usb@2680000 { - interrupts = <GIC_SPI 152 IRQ_TYPE_EDGE_RISING>; - usb@2690000 { - interrupts = <GIC_SPI 152 IRQ_TYPE_EDGE_RISING>; - }; - }; - - usb1_phy: usb_phy@2620750 { - compatible = "ti,keystone-usbphy"; - #address-cells = <1>; - #size-cells = <1>; - reg = <0x2620750 24>; - status = "disabled"; - }; - - usb1: usb@25000000 { - compatible = "ti,keystone-dwc3"; - #address-cells = <1>; - #size-cells = <1>; - reg = <0x25000000 0x10000>; - clocks = <&clkusb1>; - clock-names = "usb"; - interrupts = <GIC_SPI 414 IRQ_TYPE_EDGE_RISING>; - ranges; - dma-coherent; - dma-ranges; - status = "disabled"; - - usb@25010000 { - compatible = "synopsys,dwc3"; - reg = <0x25010000 0x70000>; - interrupts = <GIC_SPI 414 IRQ_TYPE_EDGE_RISING>; - usb-phy = <&usb1_phy>, <&usb1_phy>; - }; - }; - - dspgpio0: keystone_dsp_gpio@02620240 { - compatible = "ti,keystone-dsp-gpio"; - gpio-controller; - #gpio-cells = <2>; - gpio,syscon-dev = <&devctrl 0x240>; - }; - - pcie1: pcie@21020000 { - compatible = "ti,keystone-pcie","snps,dw-pcie"; - clocks = <&clkpcie1>; - clock-names = "pcie"; - #address-cells = <3>; - #size-cells = <2>; - reg = <0x21021000 0x2000>, <0x21020000 0x1000>, <0x02620128 4>; - ranges = <0x81000000 0 0 0x23260000 0x4000 0x4000 - 0x82000000 0 0x60000000 0x60000000 0 0x10000000>; - - status = "disabled"; - device_type = "pci"; - num-lanes = <2>; - - #interrupt-cells = <1>; - interrupt-map-mask = <0 0 0 7>; - interrupt-map = <0 0 0 1 &pcie_intc1 0>, /* INT A */ - <0 0 0 2 &pcie_intc1 1>, /* INT B */ - <0 0 0 3 &pcie_intc1 2>, /* INT C */ - <0 0 0 4 &pcie_intc1 3>; /* INT D */ - - pcie_msi_intc1: msi-interrupt-controller { - interrupt-controller; - #interrupt-cells = <1>; - interrupt-parent = <&gic>; - interrupts = <GIC_SPI 377 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 378 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 379 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 380 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 381 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 382 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 383 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 384 IRQ_TYPE_EDGE_RISING>; - }; - - pcie_intc1: legacy-interrupt-controller { - interrupt-controller; - #interrupt-cells = <1>; - interrupt-parent = <&gic>; - interrupts = <GIC_SPI 373 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 374 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 375 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 376 IRQ_TYPE_EDGE_RISING>; - }; - }; - - mdio: mdio@24200f00 { - compatible = "ti,keystone_mdio", "ti,davinci_mdio"; - #address-cells = <1>; - #size-cells = <0>; - reg = <0x24200f00 0x100>; - status = "disabled"; - clocks = <&clkcpgmac>; - clock-names = "fck"; - bus_freq = <2500000>; - }; - /include/ "keystone-k2e-netcp.dtsi" - }; -}; diff --git a/arch/arm/dts/keystone-k2g-evm-u-boot.dtsi b/arch/arm/dts/keystone-k2g-evm-u-boot.dtsi index 72b67b232dd..19c78c97ae3 100644 --- a/arch/arm/dts/keystone-k2g-evm-u-boot.dtsi +++ b/arch/arm/dts/keystone-k2g-evm-u-boot.dtsi @@ -4,20 +4,34 @@ */
/{ - soc { - bootph-all; - }; aliases { usb0 = &usb0; usb1 = &usb1; }; + + chosen { + stdout-path = &uart0; + }; +}; + +&soc0 { + bootph-all; + + pmmc@2900000 { + bootph-all; + compatible = "ti,power-processor"; + reg = <0x02900000 0x40000>; + ti,lpsc_module = <1>; + }; };
&i2c0 { + status = "okay"; bootph-all; };
&i2c1 { + status = "okay"; bootph-all; };
diff --git a/arch/arm/dts/keystone-k2g-evm.dts b/arch/arm/dts/keystone-k2g-evm.dts deleted file mode 100644 index 491fdc4b046..00000000000 --- a/arch/arm/dts/keystone-k2g-evm.dts +++ /dev/null @@ -1,148 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Device Tree Source for K2G EVM - * - * Copyright (C) 2016-2017 Texas Instruments Incorporated - https://www.ti.com/ - */ -/dts-v1/; - -#include "keystone-k2g.dtsi" - -/ { - compatible = "ti,k2g-evm","ti,keystone"; - model = "Texas Instruments K2G General Purpose EVM"; - - chosen { - stdout-path = &uart0; - }; - - memory@80000000 { - device_type = "memory"; - reg = <0x80000000 0x80000000>; - }; -}; - -&mdio { - status = "okay"; - ethphy0: ethernet-phy@0 { - reg = <0>; - }; -}; - -&keystone_usb0 { - status = "okay"; -}; - -&usb0_phy { - status = "okay"; -}; - -&usb0 { - dr_mode = "host"; - status = "okay"; -}; - -&keystone_usb1 { - status = "okay"; -}; - -&usb1_phy { - status = "okay"; -}; - -&usb1 { - dr_mode = "peripheral"; - status = "okay"; -}; - -&gbe0 { - phy-handle = <ðphy0>; -}; - -&netcp { - status = "okay"; -}; - -&spi1 { - status = "okay"; - - spi_nor: flash@0 { - #address-cells = <1>; - #size-cells = <1>; - compatible = "jedec,spi-nor"; - spi-max-frequency = <50000000>; - m25p,fast-read; - reg = <0>; - - partition@0 { - label = "u-boot-spl"; - reg = <0x0 0x80000>; - read-only; - }; - - partition@1 { - label = "misc"; - reg = <0x80000 0xf80000>; - }; - }; -}; - -&qspi { - status = "okay"; - - flash0: flash@0 { - compatible = "s25fl512s", "jedec,spi-nor"; - reg = <0>; - spi-tx-bus-width = <1>; - spi-rx-bus-width = <4>; - spi-max-frequency = <96000000>; - #address-cells = <1>; - #size-cells = <1>; - cdns,tshsl-ns = <392>; - cdns,tsd2d-ns = <392>; - cdns,tchsh-ns = <100>; - cdns,tslch-ns = <100>; - block-size = <18>; - - partition@0 { - label = "QSPI.u-boot-spl-os"; - reg = <0x00000000 0x00100000>; - }; - partition@1 { - label = "QSPI.u-boot-env"; - reg = <0x00100000 0x00040000>; - }; - partition@2 { - label = "QSPI.skern"; - reg = <0x00140000 0x0040000>; - }; - partition@3 { - label = "QSPI.pmmc-firmware"; - reg = <0x00180000 0x0040000>; - }; - partition@4 { - label = "QSPI.kernel"; - reg = <0x001C0000 0x0800000>; - }; - partition@5 { - label = "QSPI.file-system"; - reg = <0x009C0000 0x3640000>; - }; - }; -}; - -&mmc0 { - status = "okay"; -}; - -&mmc1 { - status = "okay"; -}; - -&i2c0 { - status = "okay"; -}; - -&i2c1 { - status = "okay"; -}; diff --git a/arch/arm/dts/keystone-k2g-generic-u-boot.dtsi b/arch/arm/dts/keystone-k2g-generic-u-boot.dtsi deleted file mode 100644 index 3634ed7268c..00000000000 --- a/arch/arm/dts/keystone-k2g-generic-u-boot.dtsi +++ /dev/null @@ -1,18 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Copyright (C) 2017 Texas Instruments Incorporated - https://www.ti.com/ - */ - -/{ - soc { - bootph-all; - }; -}; - -&i2c0 { - bootph-all; -}; - -&i2c1 { - bootph-all; -}; diff --git a/arch/arm/dts/keystone-k2g-generic.dts b/arch/arm/dts/keystone-k2g-generic.dts deleted file mode 100644 index dc6c31a31b4..00000000000 --- a/arch/arm/dts/keystone-k2g-generic.dts +++ /dev/null @@ -1,27 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Device Tree Source for Generic 66AK2G0X EVM - * - * Copyright (C) 2017 Texas Instruments Incorporated - https://www.ti.com/ - */ - -/dts-v1/; - -#include "keystone-k2g.dtsi" - -/ { - compatible = "ti,k2g-generic", "ti,k2g", "ti,keystone"; - model = "Texas Instruments 66AK2G02 Generic"; - - chosen { - stdout-path = &uart0; - }; -}; - -&i2c0 { - status = "okay"; -}; - -&i2c1 { - status = "okay"; -}; diff --git a/arch/arm/dts/keystone-k2g-ice-u-boot.dtsi b/arch/arm/dts/keystone-k2g-ice-u-boot.dtsi index 3634ed7268c..152744686b5 100644 --- a/arch/arm/dts/keystone-k2g-ice-u-boot.dtsi +++ b/arch/arm/dts/keystone-k2g-ice-u-boot.dtsi @@ -4,15 +4,28 @@ */
/{ - soc { + chosen { + stdout-path = &uart0; + }; +}; + +&soc0 { + bootph-all; + + pmmc@2900000 { bootph-all; + compatible = "ti,power-processor"; + reg = <0x02900000 0x40000>; + ti,lpsc_module = <1>; }; };
&i2c1 { + status = "okay"; bootph-all; }; diff --git a/arch/arm/dts/keystone-k2g-ice.dts b/arch/arm/dts/keystone-k2g-ice.dts deleted file mode 100644 index b898ae668a9..00000000000 --- a/arch/arm/dts/keystone-k2g-ice.dts +++ /dev/null @@ -1,118 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Device Tree Source for K2G Industrial Communication Engine EVM - * - * Copyright (C) 2017 Texas Instruments Incorporated - https://www.ti.com/ - */ -/dts-v1/; - -#include "keystone-k2g.dtsi" -#include <dt-bindings/net/ti-dp83867.h> - -/ { - compatible = "ti,k2g-ice", "ti,k2g", "ti,keystone"; - model = "Texas Instruments K2G Industrial Communication EVM"; - - chosen { - stdout-path = &uart0; - }; - - memory@80000000 { - device_type = "memory"; - reg = <0x80000000 0x20000000>; - }; -}; - -&mmc1 { - status = "okay"; -}; - -&i2c0 { - status = "okay"; -}; - -&i2c1 { - status = "okay"; -}; - -&qspi { - status = "okay"; - - flash0: flash@0 { - compatible = "s25fl256s1", "jedec,spi-nor"; - reg = <0>; - spi-tx-bus-width = <1>; - spi-rx-bus-width = <4>; - spi-max-frequency = <96000000>; - #address-cells = <1>; - #size-cells = <1>; - cdns,read-delay = <5>; - cdns,tshsl-ns = <500>; - cdns,tsd2d-ns = <500>; - cdns,tchsh-ns = <119>; - cdns,tslch-ns = <119>; - - partition@0 { - label = "QSPI.u-boot"; - reg = <0x00000000 0x00100000>; - }; - partition@1 { - label = "QSPI.u-boot-env"; - reg = <0x00100000 0x00040000>; - }; - partition@2 { - label = "QSPI.skern"; - reg = <0x00140000 0x0040000>; - }; - partition@3 { - label = "QSPI.pmmc-firmware"; - reg = <0x00180000 0x0040000>; - }; - partition@4 { - label = "QSPI.kernel"; - reg = <0x001c0000 0x0800000>; - }; - partition@5 { - label = "QSPI.u-boot-spl-os"; - reg = <0x009c0000 0x0040000>; - }; - partition@6 { - label = "QSPI.file-system"; - reg = <0x00a00000 0x1600000>; - }; - }; -}; - -&qmss { - status = "okay"; -}; - -&knav_dmas { - status = "okay"; -}; - -&netcp { - pinctrl-names = "default"; - //pinctrl-0 = <&emac_pins>; - status = "okay"; -}; - -&mdio { - pinctrl-names = "default"; - //pinctrl-0 = <&mdio_pins>; - status = "okay"; - ethphy0: ethernet-phy@0 { - reg = <0>; - ti,rx-internal-delay = <DP83867_RGMIIDCTL_2_25_NS>; - ti,tx-internal-delay = <DP83867_RGMIIDCTL_250_PS>; - ti,fifo-depth = <DP83867_PHYCR_FIFO_DEPTH_8_B_NIB>; - ti,min-output-impedance; - ti,dp83867-rxctrl-strap-quirk; - }; -}; - -&gbe0 { - phy-handle = <ðphy0>; - phy-mode = "rgmii-id"; - status = "okay"; -}; diff --git a/arch/arm/dts/keystone-k2g-netcp.dtsi b/arch/arm/dts/keystone-k2g-netcp.dtsi deleted file mode 100644 index 2afb48823c1..00000000000 --- a/arch/arm/dts/keystone-k2g-netcp.dtsi +++ /dev/null @@ -1,149 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Device Tree Source for K2G Netcp driver - * - * Copyright (C) 2018 Texas Instruments Incorporated - https://www.ti.com/ - */ - -qmss: qmss@4020000 { - compatible = "ti,keystone-navigator-qmss-l"; - dma-coherent; - #address-cells = <1>; - #size-cells = <1>; - /* power-domains = <&k2g_pds K2G_DEV_NSS0>; */ - /* clocks = <&k2g_clks K2G_DEV_NSS0 K2G_DEV_NSS_VCLK>; */ - clock-names = "nss_vclk"; - ranges; - queue-range = <0 0x80>; - linkram0 = <0x4020000 0x7ff>; - - qmgrs { - #address-cells = <1>; - #size-cells = <1>; - ranges; - qmgr0 { - managed-queues = <0 0x80>; - reg = <0x4100000 0x800>, - <0x4040000 0x100>, - <0x4080000 0x800>, - <0x40c0000 0x800>; - reg-names = "peek", "config", - "region", "push"; - }; - - }; - queue-pools { - qpend { - qpend-0 { - qrange = <77 8>; - interrupts =<0 308 0xf04 0 309 0xf04 0 310 0xf04 - 0 311 0xf04 0 312 0xf04 0 313 0xf04 - 0 314 0xf04 0 315 0xf04>; - qalloc-by-id; - }; - }; - general-purpose { - gp-0 { - qrange = <112 8>; - }; - netcp-tx { - qrange = <5 8>; - qalloc-by-id; - }; - }; - }; - - descriptor-regions { - #address-cells = <1>; - #size-cells = <1>; - ranges; - region-12 { - id = <12>; - region-spec = <1023 128>; /* num_desc desc_size */ - link-index = <0x400>; - }; - }; -}; /* qmss */ - -knav_dmas: knav_dmas@0 { - compatible = "ti,keystone-navigator-dma"; - #address-cells = <1>; - #size-cells = <1>; - /* power-domains = <&k2g_pds K2G_DEV_NSS0>; */ - /* clocks = <&k2g_clks K2G_DEV_NSS0 K2G_DEV_NSS_VCLK>; */ - clock-names = "nss_vclk"; - ranges; - ti,navigator-cloud-address = <0x40c0000 0x40c0000 0x40c0000 0x40c0000>; - - dma_gbe: dma_gbe@0 { - reg = <0x4010000 0x100>, - <0x4011000 0x2a0>, /* 21 Tx channels */ - <0x4012000 0x400>, /* 32 Rx channels */ - <0x4010100 0x80>, - <0x4013000 0x400>; /* 32 Rx flows */ - reg-names = "global", "txchan", "rxchan", - "txsched", "rxflow"; - }; - -}; - -gbe_subsys: subsys@4200000 { - compatible = "syscon"; - reg = <0x4200000 0x100>; -}; - -netcp: netcp@4000000 { - reg = <0x2620110 0x8>; - reg-names = "efuse"; - compatible = "ti,netcp-1.0"; - #address-cells = <1>; - #size-cells = <1>; - status = "disabled"; - /* power-domains = <&k2g_pds K2G_DEV_NSS0>; */ - /* clocks = <&k2g_clks K2G_DEV_NSS0 K2G_DEV_NSS_ESW_CLK>; */ - clock-names = "ethss_clk"; - - /* NetCP address range */ - ranges = <0 0x4000000 0x1000000>; - - dma-coherent; - - ti,navigator-dmas = <&dma_gbe 0>, <&dma_gbe 5>; - ti,navigator-dma-names = "netrx0", "nettx"; - - netcp-devices { - #address-cells = <1>; - #size-cells = <1>; - ranges; - gbe@200000 { - label = "netcp-gbe"; - compatible = "ti,netcp-gbe-2"; - syscon-subsys = <&gbe_subsys>; - reg = <0x200100 0xe00>, <0x220000 0x20000>; - /* enable-ale; */ - tx-queue = <5>; - tx-channel = "nettx"; - - interfaces { - gbe0: interface-0 { - slave-port = <0>; - link-interface = <5>; - }; - }; - }; - }; - - netcp-interfaces { - interface-0 { - rx-channel = "netrx0"; - rx-pool = <512 12>; - tx-pool = <511 12>; - rx-queue-depth = <128 128 0 0>; - rx-buffer-size = <1518 4096 0 0>; - rx-queue = <77>; - tx-completion-queue = <78>; - efuse-mac = <1>; - netcp-gbe = <&gbe0>; - }; - }; -}; diff --git a/arch/arm/dts/keystone-k2g.dtsi b/arch/arm/dts/keystone-k2g.dtsi deleted file mode 100644 index 5c3ff127218..00000000000 --- a/arch/arm/dts/keystone-k2g.dtsi +++ /dev/null @@ -1,258 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Device Tree Source for K2G SOC - * - * Copyright (C) 2016-2017 Texas Instruments Incorporated - https://www.ti.com/ - */ - -#include <dt-bindings/interrupt-controller/arm-gic.h> - -/ { - model = "Texas Instruments K2G SoC"; - #address-cells = <1>; - #size-cells = <1>; - interrupt-parent = <&gic>; - - chosen { }; - - aliases { - serial0 = &uart0; - spi0 = &spi0; - spi1 = &spi1; - spi2 = &spi2; - spi3 = &spi3; - spi4 = &qspi; - i2c0 = &i2c0; - i2c1 = &i2c1; - i2c2 = &i2c2; - }; - - cpus { - #address-cells = <1>; - #size-cells = <0>; - - interrupt-parent = <&gic>; - - cpu@0 { - compatible = "arm,cortex-a15"; - device_type = "cpu"; - reg = <0>; - }; - }; - - gic: interrupt-controller@2561000 { - compatible = "arm,cortex-a15-gic"; - #interrupt-cells = <3>; - interrupt-controller; - reg = <0x0 0x02561000 0x0 0x1000>, - <0x0 0x02562000 0x0 0x2000>, - <0x0 0x02564000 0x0 0x1000>, - <0x0 0x02566000 0x0 0x2000>; - interrupts = <GIC_PPI 9 (GIC_CPU_MASK_SIMPLE(4) | - IRQ_TYPE_LEVEL_HIGH)>; - }; - - soc { - #address-cells = <1>; - #size-cells = <1>; - compatible = "ti,keystone","simple-bus"; - interrupt-parent = <&gic>; - ranges; - - uart0: serial@02530c00 { - compatible = "ns16550a"; - current-speed = <115200>; - reg-shift = <2>; - reg-io-width = <4>; - reg = <0x02530c00 0x100>; - clock-names = "uart"; - interrupts = <GIC_SPI 164 IRQ_TYPE_EDGE_RISING>; - }; - - mdio: mdio@4200f00 { - compatible = "ti,keystone_mdio", "ti,davinci_mdio"; - #address-cells = <1>; - #size-cells = <0>; - /* power-domains = <&k2g_pds K2G_DEV_NSS0>; */ - /* clocks = <&k2g_clks K2G_DEV_NSS0 K2G_DEV_NSS_ESW_CLK>; */ - clock-names = "fck"; - reg = <0x04200f00 0x100>; - status = "disabled"; - bus_freq = <2500000>; - }; - - qspi: qspi@2940000 { - compatible = "cdns,qspi-nor"; - #address-cells = <1>; - #size-cells = <0>; - reg = <0x02940000 0x1000>, - <0x24000000 0x4000000>; - interrupts = <GIC_SPI 198 IRQ_TYPE_EDGE_RISING>; - num-cs = <4>; - cdns,fifo-depth = <256>; - cdns,fifo-width = <4>; - cdns,trigger-address = <0x24000000>; - status = "disabled"; - }; - - #include "keystone-k2g-netcp.dtsi" - - pmmc: pmmc@2900000 { - compatible = "ti,power-processor"; - reg = <0x02900000 0x40000>; - ti,lpsc_module = <1>; - }; - - spi0: spi@21805400 { - compatible = "ti,keystone-spi", "ti,dm6441-spi"; - reg = <0x21805400 0x200>; - num-cs = <4>; - ti,davinci-spi-intr-line = <0>; - interrupts = <GIC_SPI 64 IRQ_TYPE_EDGE_RISING>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - spi1: spi@21805800 { - compatible = "ti,keystone-spi", "ti,dm6441-spi"; - reg = <0x21805800 0x200>; - num-cs = <4>; - ti,davinci-spi-intr-line = <0>; - interrupts = <GIC_SPI 66 IRQ_TYPE_EDGE_RISING>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - spi2: spi@21805c00 { - compatible = "ti,keystone-spi", "ti,dm6441-spi"; - reg = <0x21805C00 0x200>; - num-cs = <4>; - ti,davinci-spi-intr-line = <0>; - interrupts = <GIC_SPI 68 IRQ_TYPE_EDGE_RISING>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - spi3: spi@21806000 { - compatible = "ti,keystone-spi", "ti,dm6441-spi"; - reg = <0x21806000 0x200>; - num-cs = <4>; - ti,davinci-spi-intr-line = <0>; - interrupts = <GIC_SPI 70 IRQ_TYPE_EDGE_RISING>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - i2c0: i2c@2530000 { - compatible = "ti,keystone-i2c"; - reg = <0x02530000 0x400>; - clock-frequency = <100000>; - interrupts = <GIC_SPI 88 IRQ_TYPE_EDGE_RISING>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - i2c1: i2c@2530400 { - compatible = "ti,keystone-i2c"; - reg = <0x02530400 0x400>; - clock-frequency = <100000>; - interrupts = <GIC_SPI 89 IRQ_TYPE_EDGE_RISING>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - i2c2: i2c@2530800 { - compatible = "ti,keystone-i2c"; - reg = <0x02530800 0x400>; - clock-frequency = <100000>; - interrupts = <GIC_SPI 90 IRQ_TYPE_EDGE_RISING>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - mmc0: mmc@23000000 { - compatible = "ti,omap4-hsmmc"; - reg = <0x23000000 0x400>; - interrupts = <GIC_SPI 96 IRQ_TYPE_EDGE_RISING>; - bus-width = <4>; - ti,needs-special-reset; - no-1-8-v; - max-frequency = <96000000>; - status = "disabled"; - }; - - mmc1: mmc@23100000 { - compatible = "ti,omap4-hsmmc"; - reg = <0x23100000 0x400>; - interrupts = <GIC_SPI 97 IRQ_TYPE_EDGE_RISING>; - bus-width = <8>; - ti,needs-special-reset; - ti,non-removable; - max-frequency = <96000000>; - status = "disabled"; - clock-names = "fck"; - }; - - usb0_phy: usb-phy@0 { - compatible = "usb-nop-xceiv"; - status = "disabled"; - }; - - keystone_usb0: keystone-dwc3@2680000 { - compatible = "ti,keystone-dwc3"; - #address-cells = <1>; - #size-cells = <1>; - reg = <0x2680000 0x10000>; - interrupts = <GIC_SPI 128 IRQ_TYPE_EDGE_RISING>; - ranges; - dma-coherent; - dma-ranges; - status = "disabled"; - /*power-domains = <&k2g_pds 0x0016>;*/ - - usb0: usb@2690000 { - compatible = "snps,dwc3"; - reg = <0x2690000 0x10000>; - interrupts = <GIC_SPI 128 IRQ_TYPE_EDGE_RISING>; - maximum-speed = "high-speed"; - dr_mode = "otg"; - /*usb-phy = <&usb0_phy>;*/ - status = "disabled"; - }; - }; - - usb1_phy: usb-phy@1 { - compatible = "usb-nop-xceiv"; - status = "disabled"; - }; - - keystone_usb1: keystone-dwc3@2580000 { - compatible = "ti,keystone-dwc3"; - #address-cells = <1>; - #size-cells = <1>; - reg = <0x2580000 0x10000>; - interrupts = <GIC_SPI 144 IRQ_TYPE_EDGE_RISING>; - ranges; - dma-coherent; - dma-ranges; - status = "disabled"; - /*power-domains = <&k2g_pds 0x0017>;*/ - - usb1: usb@2590000 { - compatible = "snps,dwc3"; - reg = <0x2590000 0x10000>; - interrupts = <GIC_SPI 144 IRQ_TYPE_EDGE_RISING>; - maximum-speed = "high-speed"; - dr_mode = "otg"; - /*usb-phy = <&usb1_phy>;*/ - status = "disabled"; - }; - }; - }; -}; diff --git a/arch/arm/dts/keystone-k2hk-clocks.dtsi b/arch/arm/dts/keystone-k2hk-clocks.dtsi deleted file mode 100644 index 3ca4722087c..00000000000 --- a/arch/arm/dts/keystone-k2hk-clocks.dtsi +++ /dev/null @@ -1,422 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Keystone 2 Kepler/Hawking SoC clock nodes - * - * Copyright (C) 2013-2017 Texas Instruments Incorporated - https://www.ti.com/ - */ - -clocks { - armpllclk: armpllclk@2620370 { - #clock-cells = <0>; - compatible = "ti,keystone,pll-clock"; - clocks = <&refclkarm>; - clock-output-names = "arm-pll-clk"; - reg = <0x02620370 4>; - reg-names = "control"; - }; - - mainpllclk: mainpllclk@2310110 { - #clock-cells = <0>; - compatible = "ti,keystone,main-pll-clock"; - clocks = <&refclksys>; - reg = <0x02620350 4>, <0x02310110 4>, <0x02310108 4>; - reg-names = "control", "multiplier", "post-divider"; - }; - - papllclk: papllclk@2620358 { - #clock-cells = <0>; - compatible = "ti,keystone,pll-clock"; - clocks = <&refclkpass>; - clock-output-names = "papllclk"; - reg = <0x02620358 4>; - reg-names = "control"; - }; - - ddr3apllclk: ddr3apllclk@2620360 { - #clock-cells = <0>; - compatible = "ti,keystone,pll-clock"; - clocks = <&refclkddr3a>; - clock-output-names = "ddr-3a-pll-clk"; - reg = <0x02620360 4>; - reg-names = "control"; - }; - - ddr3bpllclk: ddr3bpllclk@2620368 { - #clock-cells = <0>; - compatible = "ti,keystone,pll-clock"; - clocks = <&refclkddr3b>; - clock-output-names = "ddr-3b-pll-clk"; - reg = <0x02620368 4>; - reg-names = "control"; - }; - - clktsip: clktsip@2350000 { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&chipclk16>; - clock-output-names = "tsip"; - reg = <0x02350000 0xb00>, <0x02350000 0x400>; - reg-names = "control", "domain"; - domain-id = <0>; - }; - - clksrio: clksrio@235002c { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&chipclk1rstiso13>; - clock-output-names = "srio"; - reg = <0x0235002c 0xb00>, <0x02350010 0x400>; - reg-names = "control", "domain"; - domain-id = <4>; - }; - - clkhyperlink0: clkhyperlink0@2350030 { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&chipclk12>; - clock-output-names = "hyperlink-0"; - reg = <0x02350030 0xb00>, <0x02350014 0x400>; - reg-names = "control", "domain"; - domain-id = <5>; - }; - - clkgem1: clkgem1@2350040 { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&chipclk1>; - clock-output-names = "gem1"; - reg = <0x02350040 0xb00>, <0x02350024 0x400>; - reg-names = "control", "domain"; - domain-id = <9>; - }; - - clkgem2: clkgem2@2350044 { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&chipclk1>; - clock-output-names = "gem2"; - reg = <0x02350044 0xb00>, <0x02350028 0x400>; - reg-names = "control", "domain"; - domain-id = <10>; - }; - - clkgem3: clkgem3@2350048 { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&chipclk1>; - clock-output-names = "gem3"; - reg = <0x02350048 0xb00>, <0x0235002c 0x400>; - reg-names = "control", "domain"; - domain-id = <11>; - }; - - clkgem4: clkgem4@235004c { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&chipclk1>; - clock-output-names = "gem4"; - reg = <0x0235004c 0xb00>, <0x02350030 0x400>; - reg-names = "control", "domain"; - domain-id = <12>; - }; - - clkgem5: clkgem5@2350050 { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&chipclk1>; - clock-output-names = "gem5"; - reg = <0x02350050 0xb00>, <0x02350034 0x400>; - reg-names = "control", "domain"; - domain-id = <13>; - }; - - clkgem6: clkgem6@2350054 { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&chipclk1>; - clock-output-names = "gem6"; - reg = <0x02350054 0xb00>, <0x02350038 0x400>; - reg-names = "control", "domain"; - domain-id = <14>; - }; - - clkgem7: clkgem7@2350058 { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&chipclk1>; - clock-output-names = "gem7"; - reg = <0x02350058 0xb00>, <0x0235003c 0x400>; - reg-names = "control", "domain"; - domain-id = <15>; - }; - - clkddr31: clkddr31@2350060 { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&chipclk13>; - clock-output-names = "ddr3-1"; - reg = <0x02350060 0xb00>, <0x02350040 0x400>; - reg-names = "control", "domain"; - domain-id = <16>; - }; - - clktac: clktac@2350064 { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&chipclk13>; - clock-output-names = "tac"; - reg = <0x02350064 0xb00>, <0x02350044 0x400>; - reg-names = "control", "domain"; - domain-id = <17>; - }; - - clkrac01: clkrac01@2350068 { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&chipclk13>; - clock-output-names = "rac-01"; - reg = <0x02350068 0xb00>, <0x02350044 0x400>; - reg-names = "control", "domain"; - domain-id = <17>; - }; - - clkrac23: clkrac23@235006c { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&chipclk13>; - clock-output-names = "rac-23"; - reg = <0x0235006c 0xb00>, <0x02350048 0x400>; - reg-names = "control", "domain"; - domain-id = <18>; - }; - - clkfftc0: clkfftc0@2350070 { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&chipclk13>; - clock-output-names = "fftc-0"; - reg = <0x02350070 0xb00>, <0x0235004c 0x400>; - reg-names = "control", "domain"; - domain-id = <19>; - }; - - clkfftc1: clkfftc1@2350074 { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&chipclk13>; - clock-output-names = "fftc-1"; - reg = <0x02350074 0xb00>, <0x0235004c 0x400>; - reg-names = "control", "domain"; - domain-id = <19>; - }; - - clkfftc2: clkfftc2@2350078 { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&chipclk13>; - clock-output-names = "fftc-2"; - reg = <0x02350078 0xb00>, <0x02350050 0x400>; - reg-names = "control", "domain"; - domain-id = <20>; - }; - - clkfftc3: clkfftc3@235007c { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&chipclk13>; - clock-output-names = "fftc-3"; - reg = <0x0235007c 0xb00>, <0x02350050 0x400>; - reg-names = "control", "domain"; - domain-id = <20>; - }; - - clkfftc4: clkfftc4@2350080 { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&chipclk13>; - clock-output-names = "fftc-4"; - reg = <0x02350080 0xb00>, <0x02350050 0x400>; - reg-names = "control", "domain"; - domain-id = <20>; - }; - - clkfftc5: clkfftc5@2350084 { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&chipclk13>; - clock-output-names = "fftc-5"; - reg = <0x02350084 0xb00>, <0x02350050 0x400>; - reg-names = "control", "domain"; - domain-id = <20>; - }; - - clkaif: clkaif@2350088 { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&chipclk13>; - clock-output-names = "aif"; - reg = <0x02350088 0xb00>, <0x02350054 0x400>; - reg-names = "control", "domain"; - domain-id = <21>; - }; - - clktcp3d0: clktcp3d0@235008c { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&chipclk13>; - clock-output-names = "tcp3d-0"; - reg = <0x0235008c 0xb00>, <0x02350058 0x400>; - reg-names = "control", "domain"; - domain-id = <22>; - }; - - clktcp3d1: clktcp3d1@2350090 { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&chipclk13>; - clock-output-names = "tcp3d-1"; - reg = <0x02350090 0xb00>, <0x02350058 0x400>; - reg-names = "control", "domain"; - domain-id = <22>; - }; - - clktcp3d2: clktcp3d2@2350094 { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&chipclk13>; - clock-output-names = "tcp3d-2"; - reg = <0x02350094 0xb00>, <0x0235005c 0x400>; - reg-names = "control", "domain"; - domain-id = <23>; - }; - - clktcp3d3: clktcp3d3@2350098 { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&chipclk13>; - clock-output-names = "tcp3d-3"; - reg = <0x02350098 0xb00>, <0x0235005c 0x400>; - reg-names = "control", "domain"; - domain-id = <23>; - }; - - clkvcp0: clkvcp0@235009c { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&chipclk13>; - clock-output-names = "vcp-0"; - reg = <0x0235009c 0xb00>, <0x02350060 0x400>; - reg-names = "control", "domain"; - domain-id = <24>; - }; - - clkvcp1: clkvcp1@23500a0 { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&chipclk13>; - clock-output-names = "vcp-1"; - reg = <0x023500a0 0xb00>, <0x02350060 0x400>; - reg-names = "control", "domain"; - domain-id = <24>; - }; - - clkvcp2: clkvcp2@23500a4 { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&chipclk13>; - clock-output-names = "vcp-2"; - reg = <0x023500a4 0xb00>, <0x02350060 0x400>; - reg-names = "control", "domain"; - domain-id = <24>; - }; - - clkvcp3: clkvcp3@23500a8 { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&chipclk13>; - clock-output-names = "vcp-3"; - reg = <0x023500a8 0xb00>, <0x02350060 0x400>; - reg-names = "control", "domain"; - domain-id = <24>; - }; - - clkvcp4: clkvcp4@23500ac { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&chipclk13>; - clock-output-names = "vcp-4"; - reg = <0x023500ac 0xb00>, <0x02350064 0x400>; - reg-names = "control", "domain"; - domain-id = <25>; - }; - - clkvcp5: clkvcp5@23500b0 { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&chipclk13>; - clock-output-names = "vcp-5"; - reg = <0x023500b0 0xb00>, <0x02350064 0x400>; - reg-names = "control", "domain"; - domain-id = <25>; - }; - - clkvcp6: clkvcp6@23500b4 { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&chipclk13>; - clock-output-names = "vcp-6"; - reg = <0x023500b4 0xb00>, <0x02350064 0x400>; - reg-names = "control", "domain"; - domain-id = <25>; - }; - - clkvcp7: clkvcp7@23500b8 { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&chipclk13>; - clock-output-names = "vcp-7"; - reg = <0x023500b8 0xb00>, <0x02350064 0x400>; - reg-names = "control", "domain"; - domain-id = <25>; - }; - - clkbcp: clkbcp@23500bc { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&chipclk13>; - clock-output-names = "bcp"; - reg = <0x023500bc 0xb00>, <0x02350068 0x400>; - reg-names = "control", "domain"; - domain-id = <26>; - }; - - clkdxb: clkdxb@23500c0 { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&chipclk13>; - clock-output-names = "dxb"; - reg = <0x023500c0 0xb00>, <0x0235006c 0x400>; - reg-names = "control", "domain"; - domain-id = <27>; - }; - - clkhyperlink1: clkhyperlink1@23500c4 { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&chipclk12>; - clock-output-names = "hyperlink-1"; - reg = <0x023500c4 0xb00>, <0x02350070 0x400>; - reg-names = "control", "domain"; - domain-id = <28>; - }; - - clkxge: clkxge@23500c8 { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&chipclk13>; - clock-output-names = "xge"; - reg = <0x023500c8 0xb00>, <0x02350074 0x400>; - reg-names = "control", "domain"; - domain-id = <29>; - }; -}; diff --git a/arch/arm/dts/keystone-k2hk-evm-u-boot.dtsi b/arch/arm/dts/keystone-k2hk-evm-u-boot.dtsi index 3e38f228a6a..3b3d327562c 100644 --- a/arch/arm/dts/keystone-k2hk-evm-u-boot.dtsi +++ b/arch/arm/dts/keystone-k2hk-evm-u-boot.dtsi @@ -4,9 +4,19 @@ */
/{ - soc { - bootph-all; + aliases { + i2c0 = &i2c0; + i2c1 = &i2c1; + i2c2 = &i2c2; }; + + chosen { + stdout-path = &uart0; + }; +}; + +&soc0 { + bootph-all; };
&i2c1 { @@ -18,11 +28,9 @@ psc-domain = <2>; };
-&usb { - dwc3@2690000 { - phys = <&usb_phy>; - dr_mode = "host"; - snps,u2ss_inp3_quirk; - status = "okay"; - }; +&usb0 { + phys = <&usb_phy>; + dr_mode = "host"; + snps,u2ss_inp3_quirk; + status = "okay"; }; diff --git a/arch/arm/dts/keystone-k2hk-evm.dts b/arch/arm/dts/keystone-k2hk-evm.dts deleted file mode 100644 index 6222876f277..00000000000 --- a/arch/arm/dts/keystone-k2hk-evm.dts +++ /dev/null @@ -1,180 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Keystone 2 Kepler/Hawking EVM device tree - * - * Copyright (C) 2013-2017 Texas Instruments Incorporated - https://www.ti.com/ - */ -/dts-v1/; - -#include "keystone.dtsi" -#include "keystone-k2hk.dtsi" - -/ { - compatible = "ti,k2hk-evm","ti,keystone"; - model = "Texas Instruments Keystone 2 Kepler/Hawking EVM"; - - soc { - clocks { - refclksys: refclksys { - #clock-cells = <0>; - compatible = "fixed-clock"; - clock-frequency = <122880000>; - clock-output-names = "refclk-sys"; - }; - - refclkpass: refclkpass { - #clock-cells = <0>; - compatible = "fixed-clock"; - clock-frequency = <122880000>; - clock-output-names = "refclk-pass"; - }; - - refclkarm: refclkarm { - #clock-cells = <0>; - compatible = "fixed-clock"; - clock-frequency = <125000000>; - clock-output-names = "refclk-arm"; - }; - - refclkddr3a: refclkddr3a { - #clock-cells = <0>; - compatible = "fixed-clock"; - clock-frequency = <100000000>; - clock-output-names = "refclk-ddr3a"; - }; - - refclkddr3b: refclkddr3b { - #clock-cells = <0>; - compatible = "fixed-clock"; - clock-frequency = <100000000>; - clock-output-names = "refclk-ddr3b"; - }; - }; - }; - - leds { - compatible = "gpio-leds"; - led-debug-1-1 { - label = "keystone:green:debug1"; - gpios = <&gpio0 12 GPIO_ACTIVE_HIGH>; /* 12 */ - }; - - led-debug-1-2 { - label = "keystone:red:debug1"; - gpios = <&gpio0 13 GPIO_ACTIVE_HIGH>; /* 13 */ - }; - - led-debug-2 { - label = "keystone:blue:debug2"; - gpios = <&gpio0 14 GPIO_ACTIVE_HIGH>; /* 14 */ - }; - - led-debug-3 { - label = "keystone:blue:debug3"; - gpios = <&gpio0 15 GPIO_ACTIVE_HIGH>; /* 15 */ - }; - }; -}; - -&usb_phy { - status = "okay"; -}; - -&usb { - status = "okay"; -}; - -&aemif { - cs0 { - #address-cells = <2>; - #size-cells = <1>; - clock-ranges; - ranges; - - ti,cs-chipselect = <0>; - /* all timings in nanoseconds */ - ti,cs-min-turnaround-ns = <12>; - ti,cs-read-hold-ns = <6>; - ti,cs-read-strobe-ns = <23>; - ti,cs-read-setup-ns = <9>; - ti,cs-write-hold-ns = <8>; - ti,cs-write-strobe-ns = <23>; - ti,cs-write-setup-ns = <8>; - - nand@0,0 { - compatible = "ti,keystone-nand","ti,davinci-nand"; - #address-cells = <1>; - #size-cells = <1>; - reg = <0 0 0x4000000 - 1 0 0x0000100>; - - ti,davinci-chipselect = <0>; - ti,davinci-mask-ale = <0x2000>; - ti,davinci-mask-cle = <0x4000>; - ti,davinci-mask-chipsel = <0>; - nand-ecc-mode = "hw"; - ti,davinci-ecc-bits = <4>; - nand-on-flash-bbt; - - partition@0 { - label = "u-boot"; - reg = <0x0 0x100000>; - read-only; - }; - - partition@100000 { - label = "params"; - reg = <0x100000 0x80000>; - read-only; - }; - - partition@180000 { - label = "ubifs"; - reg = <0x180000 0x1fe80000>; - }; - }; - }; -}; - -&i2c0 { - dtt@50 { - compatible = "at,24c1024"; - reg = <0x50>; - }; -}; - -&spi0 { - status = "okay"; - nor_flash: flash@0 { - #address-cells = <1>; - #size-cells = <1>; - compatible = "Micron,n25q128a11", "jedec,spi-nor"; - spi-max-frequency = <54000000>; - m25p,fast-read; - reg = <0>; - - partition@0 { - label = "u-boot-spl"; - reg = <0x0 0x80000>; - read-only; - }; - - partition@1 { - label = "misc"; - reg = <0x80000 0xf80000>; - }; - }; -}; - -&mdio { - status = "okay"; - ethphy0: ethernet-phy@0 { - compatible = "marvell,88E1111", "ethernet-phy-ieee802.3-c22"; - reg = <0>; - }; - - ethphy1: ethernet-phy@1 { - compatible = "marvell,88E1111", "ethernet-phy-ieee802.3-c22"; - reg = <1>; - }; -}; diff --git a/arch/arm/dts/keystone-k2hk-netcp.dtsi b/arch/arm/dts/keystone-k2hk-netcp.dtsi deleted file mode 100644 index 3f8c4c263a2..00000000000 --- a/arch/arm/dts/keystone-k2hk-netcp.dtsi +++ /dev/null @@ -1,207 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Device Tree Source for Keystone 2 Hawking Netcp driver - * - * Copyright (C) 2015-2017 Texas Instruments Incorporated - https://www.ti.com/ - */ - -qmss: qmss@2a40000 { - compatible = "ti,keystone-navigator-qmss"; - dma-coherent; - #address-cells = <1>; - #size-cells = <1>; - clocks = <&chipclk13>; - ranges; - queue-range = <0 0x4000>; - linkram0 = <0x100000 0x8000>; - linkram1 = <0x0 0x10000>; - - qmgrs { - #address-cells = <1>; - #size-cells = <1>; - ranges; - qmgr0 { - managed-queues = <0 0x2000>; - reg = <0x2a40000 0x20000>, - <0x2a06000 0x400>, - <0x2a02000 0x1000>, - <0x2a03000 0x1000>, - <0x23a80000 0x20000>, - <0x2a80000 0x20000>; - reg-names = "peek", "status", "config", - "region", "push", "pop"; - }; - - qmgr1 { - managed-queues = <0x2000 0x2000>; - reg = <0x2a60000 0x20000>, - <0x2a06400 0x400>, - <0x2a04000 0x1000>, - <0x2a05000 0x1000>, - <0x23aa0000 0x20000>, - <0x2aa0000 0x20000>; - reg-names = "peek", "status", "config", - "region", "push", "pop"; - }; - }; - - queue-pools { - qpend { - qpend-0 { - qrange = <658 8>; - interrupts =<0 40 0xf04 0 41 0xf04 0 42 0xf04 - 0 43 0xf04 0 44 0xf04 0 45 0xf04 - 0 46 0xf04 0 47 0xf04>; - }; - qpend-1 { - qrange = <8704 16>; - interrupts = <0 48 0xf04 0 49 0xf04 0 50 0xf04 - 0 51 0xf04 0 52 0xf04 0 53 0xf04 - 0 54 0xf04 0 55 0xf04 0 56 0xf04 - 0 57 0xf04 0 58 0xf04 0 59 0xf04 - 0 60 0xf04 0 61 0xf04 0 62 0xf04 - 0 63 0xf04>; - qalloc-by-id; - }; - qpend-2 { - qrange = <8720 16>; - interrupts = <0 64 0xf04 0 65 0xf04 0 66 0xf04 - 0 59 0xf04 0 68 0xf04 0 69 0xf04 - 0 70 0xf04 0 71 0xf04 0 72 0xf04 - 0 73 0xf04 0 74 0xf04 0 75 0xf04 - 0 76 0xf04 0 77 0xf04 0 78 0xf04 - 0 79 0xf04>; - }; - }; - general-purpose { - gp-0 { - qrange = <4000 64>; - }; - netcp-tx { - qrange = <640 9>; - qalloc-by-id; - }; - netcpx-tx { - qrange = <8752 8>; - qalloc-by-id; - }; - }; - }; - - descriptor-regions { - #address-cells = <1>; - #size-cells = <1>; - ranges; - region-12 { - id = <12>; - region-spec = <8192 128>; /* num_desc desc_size */ - link-index = <0x4000>; - }; - }; -}; /* qmss */ - -knav_dmas: knav_dmas@0 { - compatible = "ti,keystone-navigator-dma"; - clocks = <&papllclk>; - #address-cells = <1>; - #size-cells = <1>; - ranges; - ti,navigator-cloud-address = <0x23a80000 0x23a90000 - 0x23aa0000 0x23ab0000>; - - dma_gbe: dma_gbe@0 { - reg = <0x2004000 0x100>, - <0x2004400 0x120>, - <0x2004800 0x300>, - <0x2004c00 0x120>, - <0x2005000 0x400>; - reg-names = "global", "txchan", "rxchan", - "txsched", "rxflow"; - }; -}; - -netcp: netcp@2000000 { - reg = <0x2620110 0x8>; - reg-names = "efuse"; - compatible = "ti,netcp-1.0"; - #address-cells = <1>; - #size-cells = <1>; - - /* NetCP address range */ - ranges = <0 0x2000000 0x100000>; - - clocks = <&papllclk>, <&clkcpgmac>, <&chipclk12>; - dma-coherent; - - ti,navigator-dmas = <&dma_gbe 22>, - <&dma_gbe 23>, - <&dma_gbe 8>; - ti,navigator-dma-names = "netrx0", "netrx1", "nettx"; - - netcp-devices { - ranges; - #address-cells = <1>; - #size-cells = <1>; - gbe@90000 { /* ETHSS */ - #address-cells = <1>; - #size-cells = <1>; - label = "netcp-gbe"; - compatible = "ti,netcp-gbe"; - reg = <0x90000 0x300>, <0x90400 0x400>, <0x90800 0x700>; - /* enable-ale; */ - tx-queue = <648>; - tx-channel = "nettx"; - - interfaces { - gbe0: interface-0 { - slave-port = <0>; - link-interface = <1>; - phy-handle = <ðphy0>; - }; - gbe1: interface-1 { - slave-port = <1>; - link-interface = <1>; - phy-handle = <ðphy1>; - }; - }; - - secondary-slave-ports { - port-2 { - slave-port = <2>; - link-interface = <2>; - }; - port-3 { - slave-port = <3>; - link-interface = <2>; - }; - }; - }; - }; - - netcp-interfaces { - interface-0 { - rx-channel = "netrx0"; - rx-pool = <1024 12>; - tx-pool = <1024 12>; - rx-queue-depth = <128 128 0 0>; - rx-buffer-size = <1518 4096 0 0>; - rx-queue = <8704>; - tx-completion-queue = <8706>; - efuse-mac = <1>; - netcp-gbe = <&gbe0>; - - }; - interface-1 { - rx-channel = "netrx1"; - rx-pool = <1024 12>; - tx-pool = <1024 12>; - rx-queue-depth = <128 128 0 0>; - rx-buffer-size = <1518 4096 0 0>; - rx-queue = <8705>; - tx-completion-queue = <8707>; - efuse-mac = <0>; - local-mac-address = [02 18 31 7e 3e 6f]; - netcp-gbe = <&gbe1>; - }; - }; -}; diff --git a/arch/arm/dts/keystone-k2hk.dtsi b/arch/arm/dts/keystone-k2hk.dtsi deleted file mode 100644 index e5ab1fbb559..00000000000 --- a/arch/arm/dts/keystone-k2hk.dtsi +++ /dev/null @@ -1,111 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Keystone 2 Kepler/Hawking soc specific device tree - * - * Copyright (C) 2013-2017 Texas Instruments Incorporated - https://www.ti.com/ - */ - -/ { - cpus { - #address-cells = <1>; - #size-cells = <0>; - - interrupt-parent = <&gic>; - - cpu@0 { - compatible = "arm,cortex-a15"; - device_type = "cpu"; - reg = <0>; - }; - - cpu@1 { - compatible = "arm,cortex-a15"; - device_type = "cpu"; - reg = <1>; - }; - - cpu@2 { - compatible = "arm,cortex-a15"; - device_type = "cpu"; - reg = <2>; - }; - - cpu@3 { - compatible = "arm,cortex-a15"; - device_type = "cpu"; - reg = <3>; - }; - }; - - soc { - /include/ "keystone-k2hk-clocks.dtsi" - - dspgpio0: keystone_dsp_gpio@02620240 { - compatible = "ti,keystone-dsp-gpio"; - gpio-controller; - #gpio-cells = <2>; - gpio,syscon-dev = <&devctrl 0x240>; - }; - - dspgpio1: keystone_dsp_gpio@2620244 { - compatible = "ti,keystone-dsp-gpio"; - gpio-controller; - #gpio-cells = <2>; - gpio,syscon-dev = <&devctrl 0x244>; - }; - - dspgpio2: keystone_dsp_gpio@2620248 { - compatible = "ti,keystone-dsp-gpio"; - gpio-controller; - #gpio-cells = <2>; - gpio,syscon-dev = <&devctrl 0x248>; - }; - - dspgpio3: keystone_dsp_gpio@262024c { - compatible = "ti,keystone-dsp-gpio"; - gpio-controller; - #gpio-cells = <2>; - gpio,syscon-dev = <&devctrl 0x24c>; - }; - - dspgpio4: keystone_dsp_gpio@2620250 { - compatible = "ti,keystone-dsp-gpio"; - gpio-controller; - #gpio-cells = <2>; - gpio,syscon-dev = <&devctrl 0x250>; - }; - - dspgpio5: keystone_dsp_gpio@2620254 { - compatible = "ti,keystone-dsp-gpio"; - gpio-controller; - #gpio-cells = <2>; - gpio,syscon-dev = <&devctrl 0x254>; - }; - - dspgpio6: keystone_dsp_gpio@2620258 { - compatible = "ti,keystone-dsp-gpio"; - gpio-controller; - #gpio-cells = <2>; - gpio,syscon-dev = <&devctrl 0x258>; - }; - - dspgpio7: keystone_dsp_gpio@262025c { - compatible = "ti,keystone-dsp-gpio"; - gpio-controller; - #gpio-cells = <2>; - gpio,syscon-dev = <&devctrl 0x25c>; - }; - - mdio: mdio@02090300 { - compatible = "ti,keystone_mdio", "ti,davinci_mdio"; - #address-cells = <1>; - #size-cells = <0>; - reg = <0x02090300 0x100>; - status = "disabled"; - clocks = <&clkcpgmac>; - clock-names = "fck"; - bus_freq = <2500000>; - }; - /include/ "keystone-k2hk-netcp.dtsi" - }; -}; diff --git a/arch/arm/dts/keystone-k2l-clocks.dtsi b/arch/arm/dts/keystone-k2l-clocks.dtsi deleted file mode 100644 index fcfc2fb6cc2..00000000000 --- a/arch/arm/dts/keystone-k2l-clocks.dtsi +++ /dev/null @@ -1,263 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Keystone 2 lamarr SoC clock nodes - * - * Copyright (C) 2013-2017 Texas Instruments Incorporated - https://www.ti.com/ - */ - -clocks { - armpllclk: armpllclk@2620370 { - #clock-cells = <0>; - compatible = "ti,keystone,pll-clock"; - clocks = <&refclksys>; - clock-output-names = "arm-pll-clk"; - reg = <0x02620370 4>; - reg-names = "control"; - }; - - mainpllclk: mainpllclk@2310110 { - #clock-cells = <0>; - compatible = "ti,keystone,main-pll-clock"; - clocks = <&refclksys>; - reg = <0x02620350 4>, <0x02310110 4>, <0x02310108 4>; - reg-names = "control", "multiplier", "post-divider"; - }; - - papllclk: papllclk@2620358 { - #clock-cells = <0>; - compatible = "ti,keystone,pll-clock"; - clocks = <&refclksys>; - clock-output-names = "papllclk"; - reg = <0x02620358 4>; - reg-names = "control"; - }; - - ddr3apllclk: ddr3apllclk@2620360 { - #clock-cells = <0>; - compatible = "ti,keystone,pll-clock"; - clocks = <&refclksys>; - clock-output-names = "ddr-3a-pll-clk"; - reg = <0x02620360 4>; - reg-names = "control"; - }; - - clkdfeiqnsys: clkdfeiqnsys@2350004 { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&chipclk12>; - clock-output-names = "dfe"; - reg-names = "control", "domain"; - reg = <0x02350004 0xb00>, <0x02350000 0x400>; - domain-id = <0>; - }; - - clkpcie1: clkpcie1@235002c { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&chipclk12>; - clock-output-names = "pcie"; - reg = <0x0235002c 0xb00>, <0x02350000 0x400>; - reg-names = "control", "domain"; - domain-id = <4>; - }; - - clkgem1: clkgem1@2350040 { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&chipclk1>; - clock-output-names = "gem1"; - reg = <0x02350040 0xb00>, <0x02350024 0x400>; - reg-names = "control", "domain"; - domain-id = <9>; - }; - - clkgem2: clkgem2@2350044 { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&chipclk1>; - clock-output-names = "gem2"; - reg = <0x02350044 0xb00>, <0x02350028 0x400>; - reg-names = "control", "domain"; - domain-id = <10>; - }; - - clkgem3: clkgem3@2350048 { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&chipclk1>; - clock-output-names = "gem3"; - reg = <0x02350048 0xb00>, <0x0235002c 0x400>; - reg-names = "control", "domain"; - domain-id = <11>; - }; - - clktac: clktac@2350064 { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&chipclk13>; - clock-output-names = "tac"; - reg = <0x02350064 0xb00>, <0x02350044 0x400>; - reg-names = "control", "domain"; - domain-id = <17>; - }; - - clkrac: clkrac@2350068 { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&chipclk13>; - clock-output-names = "rac"; - reg = <0x02350068 0xb00>, <0x02350044 0x400>; - reg-names = "control", "domain"; - domain-id = <17>; - }; - - clkdfepd0: clkdfepd0@235006c { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&chipclk13>; - clock-output-names = "dfe-pd0"; - reg = <0x0235006c 0xb00>, <0x02350044 0x400>; - reg-names = "control", "domain"; - domain-id = <18>; - }; - - clkfftc0: clkfftc0@2350070 { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&chipclk13>; - clock-output-names = "fftc-0"; - reg = <0x02350070 0xb00>, <0x0235004c 0x400>; - reg-names = "control", "domain"; - domain-id = <19>; - }; - - clkosr: clkosr@2350088 { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&chipclk13>; - clock-output-names = "osr"; - reg = <0x02350088 0xb00>, <0x0235004c 0x400>; - reg-names = "control", "domain"; - domain-id = <21>; - }; - - clktcp3d0: clktcp3d0@235008c { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&chipclk13>; - clock-output-names = "tcp3d-0"; - reg = <0x0235008c 0xb00>, <0x02350058 0x400>; - reg-names = "control", "domain"; - domain-id = <22>; - }; - - clktcp3d1: clktcp3d1@2350094 { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&chipclk13>; - clock-output-names = "tcp3d-1"; - reg = <0x02350094 0xb00>, <0x02350058 0x400>; - reg-names = "control", "domain"; - domain-id = <23>; - }; - - clkvcp0: clkvcp0@235009c { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&chipclk13>; - clock-output-names = "vcp-0"; - reg = <0x0235009c 0xb00>, <0x02350060 0x400>; - reg-names = "control", "domain"; - domain-id = <24>; - }; - - clkvcp1: clkvcp1@23500a0 { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&chipclk13>; - clock-output-names = "vcp-1"; - reg = <0x023500a0 0xb00>, <0x02350060 0x400>; - reg-names = "control", "domain"; - domain-id = <24>; - }; - - clkvcp2: clkvcp2@23500a4 { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&chipclk13>; - clock-output-names = "vcp-2"; - reg = <0x023500a4 0xb00>, <0x02350060 0x400>; - reg-names = "control", "domain"; - domain-id = <24>; - }; - - clkvcp3: clkvcp3@23500a8 { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&chipclk13>; - clock-output-names = "vcp-3"; - reg = <0x023500a8 0xb00>, <0x02350060 0x400>; - reg-names = "control", "domain"; - domain-id = <24>; - }; - - clkbcp: clkbcp@23500bc { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&chipclk13>; - clock-output-names = "bcp"; - reg = <0x023500bc 0xb00>, <0x02350068 0x400>; - reg-names = "control", "domain"; - domain-id = <26>; - }; - - clkdfepd1: clkdfepd1@23500c0 { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&chipclk13>; - clock-output-names = "dfe-pd1"; - reg = <0x023500c0 0xb00>, <0x02350044 0x400>; - reg-names = "control", "domain"; - domain-id = <27>; - }; - - clkfftc1: clkfftc1@23500c4 { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&chipclk13>; - clock-output-names = "fftc-1"; - reg = <0x023500c4 0xb00>, <0x023504c0 0x400>; - reg-names = "control", "domain"; - domain-id = <28>; - }; - - clkiqnail: clkiqnail@23500c8 { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&chipclk13>; - clock-output-names = "iqn-ail"; - reg = <0x023500c8 0xb00>, <0x0235004c 0x400>; - reg-names = "control", "domain"; - domain-id = <29>; - }; - - clkuart2: clkuart2@2350000 { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&clkmodrst0>; - clock-output-names = "uart2"; - reg = <0x02350000 0xb00>, <0x02350000 0x400>; - reg-names = "control", "domain"; - domain-id = <0>; - }; - - clkuart3: clkuart3@2350000 { - #clock-cells = <0>; - compatible = "ti,keystone,psc-clock"; - clocks = <&clkmodrst0>; - clock-output-names = "uart3"; - reg = <0x02350000 0xb00>, <0x02350000 0x400>; - reg-names = "control", "domain"; - domain-id = <0>; - }; -}; diff --git a/arch/arm/dts/keystone-k2l-evm-u-boot.dtsi b/arch/arm/dts/keystone-k2l-evm-u-boot.dtsi index f1aed14b0b5..d9dee805ebe 100644 --- a/arch/arm/dts/keystone-k2l-evm-u-boot.dtsi +++ b/arch/arm/dts/keystone-k2l-evm-u-boot.dtsi @@ -3,16 +3,30 @@ * Copyright (C) 2019 Texas Instruments Incorporated - https://www.ti.com/ */
+/{ + aliases { + i2c0 = &i2c0; + i2c1 = &i2c1; + i2c2 = &i2c2; + }; + + chosen { + stdout-path = &uart0; + }; +}; + +&soc0 { + bootph-all; +}; + &usb_phy { #phy-cells = <0>; psc-domain = <2>; };
-&usb { - dwc3@2690000 { - phys = <&usb_phy>; - dr_mode = "host"; - snps,u2ss_inp3_quirk; - status = "okay"; - }; +&usb0 { + phys = <&usb_phy>; + dr_mode = "host"; + snps,u2ss_inp3_quirk; + status = "okay"; }; diff --git a/arch/arm/dts/keystone-k2l-evm.dts b/arch/arm/dts/keystone-k2l-evm.dts deleted file mode 100644 index 9d2b4542e81..00000000000 --- a/arch/arm/dts/keystone-k2l-evm.dts +++ /dev/null @@ -1,129 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Keystone 2 Lamarr EVM device tree - * - * Copyright (C) 2014-2017 Texas Instruments Incorporated - https://www.ti.com/ - */ -/dts-v1/; - -#include "keystone.dtsi" -#include "keystone-k2l.dtsi" - -/ { - compatible = "ti,k2l-evm","ti,keystone"; - model = "Texas Instruments Keystone 2 Lamarr EVM"; - - soc { - clocks { - refclksys: refclksys { - #clock-cells = <0>; - compatible = "fixed-clock"; - clock-frequency = <122880000>; - clock-output-names = "refclk-sys"; - }; - }; - }; -}; - -&usb_phy { - status = "okay"; -}; - -&usb { - status = "okay"; -}; - -&i2c0 { - dtt@50 { - compatible = "at,24c1024"; - reg = <0x50>; - }; -}; - -&aemif { - cs0 { - #address-cells = <2>; - #size-cells = <1>; - clock-ranges; - ranges; - - ti,cs-chipselect = <0>; - /* all timings in nanoseconds */ - ti,cs-min-turnaround-ns = <12>; - ti,cs-read-hold-ns = <6>; - ti,cs-read-strobe-ns = <23>; - ti,cs-read-setup-ns = <9>; - ti,cs-write-hold-ns = <8>; - ti,cs-write-strobe-ns = <23>; - ti,cs-write-setup-ns = <8>; - - nand@0,0 { - compatible = "ti,keystone-nand","ti,davinci-nand"; - #address-cells = <1>; - #size-cells = <1>; - reg = <0 0 0x4000000 - 1 0 0x0000100>; - - ti,davinci-chipselect = <0>; - ti,davinci-mask-ale = <0x2000>; - ti,davinci-mask-cle = <0x4000>; - ti,davinci-mask-chipsel = <0>; - nand-ecc-mode = "hw"; - ti,davinci-ecc-bits = <4>; - nand-on-flash-bbt; - - partition@0 { - label = "u-boot"; - reg = <0x0 0x100000>; - read-only; - }; - - partition@100000 { - label = "params"; - reg = <0x100000 0x80000>; - read-only; - }; - - partition@180000 { - label = "ubifs"; - reg = <0x180000 0x7FE80000>; - }; - }; - }; -}; - -&spi0 { - status ="okay"; - nor_flash: flash@0 { - #address-cells = <1>; - #size-cells = <1>; - compatible = "Micron,n25q128a11", "jedec,spi-nor"; - spi-max-frequency = <54000000>; - m25p,fast-read; - reg = <0>; - - partition@0 { - label = "u-boot-spl"; - reg = <0x0 0x80000>; - read-only; - }; - - partition@1 { - label = "misc"; - reg = <0x80000 0xf80000>; - }; - }; -}; - -&mdio { - status = "okay"; - ethphy0: ethernet-phy@0 { - compatible = "marvell,88E1514", "marvell,88E1510", "ethernet-phy-ieee802.3-c22"; - reg = <0>; - }; - - ethphy1: ethernet-phy@1 { - compatible = "marvell,88E1514", "marvell,88E1510", "ethernet-phy-ieee802.3-c22"; - reg = <1>; - }; -}; diff --git a/arch/arm/dts/keystone-k2l-netcp.dtsi b/arch/arm/dts/keystone-k2l-netcp.dtsi deleted file mode 100644 index 2caa0583fc8..00000000000 --- a/arch/arm/dts/keystone-k2l-netcp.dtsi +++ /dev/null @@ -1,187 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Device Tree Source for Keystone 2 Lamarr Netcp driver - * - * Copyright (C) 2015-2017 Texas Instruments Incorporated - https://www.ti.com/ - */ - -qmss: qmss@2a40000 { - compatible = "ti,keystone-navigator-qmss"; - dma-coherent; - #address-cells = <1>; - #size-cells = <1>; - clocks = <&chipclk13>; - ranges; - queue-range = <0 0x2000>; - linkram0 = <0x100000 0x4000>; - linkram1 = <0x70000000 0x10000>; /* 1MB OSR mem */ - - qmgrs { - #address-cells = <1>; - #size-cells = <1>; - ranges; - qmgr0 { - managed-queues = <0 0x2000>; - reg = <0x2a40000 0x20000>, - <0x2a06000 0x400>, - <0x2a02000 0x1000>, - <0x2a03000 0x1000>, - <0x23a80000 0x20000>, - <0x2a80000 0x20000>; - reg-names = "peek", "status", "config", - "region", "push", "pop"; - }; - }; - queue-pools { - qpend { - qpend-0 { - qrange = <658 8>; - interrupts =<0 40 0xf04 0 41 0xf04 0 42 0xf04 - 0 43 0xf04 0 44 0xf04 0 45 0xf04 - 0 46 0xf04 0 47 0xf04>; - }; - qpend-1 { - qrange = <528 16>; - interrupts = <0 48 0xf04 0 49 0xf04 0 50 0xf04 - 0 51 0xf04 0 52 0xf04 0 53 0xf04 - 0 54 0xf04 0 55 0xf04 0 56 0xf04 - 0 57 0xf04 0 58 0xf04 0 59 0xf04 - 0 60 0xf04 0 61 0xf04 0 62 0xf04 - 0 63 0xf04>; - qalloc-by-id; - }; - qpend-2 { - qrange = <544 16>; - interrupts = <0 64 0xf04 0 65 0xf04 0 66 0xf04 - 0 59 0xf04 0 68 0xf04 0 69 0xf04 - 0 70 0xf04 0 71 0xf04 0 72 0xf04 - 0 73 0xf04 0 74 0xf04 0 75 0xf04 - 0 76 0xf04 0 77 0xf04 0 78 0xf04 - 0 79 0xf04>; - }; - }; - general-purpose { - gp-0 { - qrange = <4000 64>; - }; - netcp-tx { - qrange = <896 128>; - qalloc-by-id; - }; - }; - }; - - descriptor-regions { - #address-cells = <1>; - #size-cells = <1>; - ranges; - region-12 { - id = <12>; - region-spec = <8192 128>; /* num_desc desc_size */ - link-index = <0x4000>; - }; - }; -}; /* qmss */ - -knav_dmas: knav_dmas@0 { - compatible = "ti,keystone-navigator-dma"; - clocks = <&papllclk>; - #address-cells = <1>; - #size-cells = <1>; - ranges; - ti,navigator-cloud-address = <0x23a80000 0x23a90000>; - - dma_gbe: dma_gbe@0 { - reg = <0x26186000 0x100>, - <0x26187000 0x2a0>, - <0x26188000 0xb60>, - <0x26186100 0x80>, - <0x26189000 0x1000>; - reg-names = "global", "txchan", "rxchan", - "txsched", "rxflow"; - }; -}; - -netcp: netcp@26000000 { - reg = <0x2620110 0x8>; - reg-names = "efuse"; - compatible = "ti,netcp-1.0"; - #address-cells = <1>; - #size-cells = <1>; - - /* NetCP address range */ - ranges = <0 0x26000000 0x1000000>; - - clocks = <&papllclk>, <&clkcpgmac>, <&chipclk12>; - dma-coherent; - - ti,navigator-dmas = <&dma_gbe 0>, - <&dma_gbe 8>, - <&dma_gbe 0>; - ti,navigator-dma-names = "netrx0", "netrx1", "nettx"; - - netcp-devices { - #address-cells = <1>; - #size-cells = <1>; - ranges; - gbe@200000 { /* ETHSS */ - label = "netcp-gbe"; - compatible = "ti,netcp-gbe-5"; - reg = <0x200000 0x900>, <0x220000 0x20000>; - /* enable-ale; */ - tx-queue = <896>; - tx-channel = "nettx"; - - interfaces { - gbe0: interface-0 { - slave-port = <0>; - link-interface = <1>; - phy-handle = <ðphy0>; - }; - gbe1: interface-1 { - slave-port = <1>; - link-interface = <1>; - phy-handle = <ðphy1>; - }; - }; - - secondary-slave-ports { - port-2 { - slave-port = <2>; - link-interface = <2>; - }; - port-3 { - slave-port = <3>; - link-interface = <2>; - }; - }; - }; - }; - - netcp-interfaces { - interface-0 { - rx-channel = "netrx0"; - rx-pool = <1024 12>; - tx-pool = <1024 12>; - rx-queue-depth = <128 128 0 0>; - rx-buffer-size = <1518 4096 0 0>; - rx-queue = <528>; - tx-completion-queue = <530>; - efuse-mac = <1>; - netcp-gbe = <&gbe0>; - - }; - interface-1 { - rx-channel = "netrx1"; - rx-pool = <1024 12>; - tx-pool = <1024 12>; - rx-queue-depth = <128 128 0 0>; - rx-buffer-size = <1518 4096 0 0>; - rx-queue = <529>; - tx-completion-queue = <531>; - efuse-mac = <0>; - local-mac-address = [02 18 31 7e 3e 7f]; - netcp-gbe = <&gbe1>; - }; - }; -}; diff --git a/arch/arm/dts/keystone-k2l.dtsi b/arch/arm/dts/keystone-k2l.dtsi deleted file mode 100644 index c8893e284f2..00000000000 --- a/arch/arm/dts/keystone-k2l.dtsi +++ /dev/null @@ -1,105 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Keystone 2 Lamarr SoC specific device tree - * - * Copyright (C) 2014-2017 Texas Instruments Incorporated - https://www.ti.com/ - */ - -/ { - cpus { - #address-cells = <1>; - #size-cells = <0>; - - interrupt-parent = <&gic>; - - cpu@0 { - compatible = "arm,cortex-a15"; - device_type = "cpu"; - reg = <0>; - }; - - cpu@1 { - compatible = "arm,cortex-a15"; - device_type = "cpu"; - reg = <1>; - }; - }; - - soc { - /include/ "keystone-k2l-clocks.dtsi" - - uart2: serial@2348400 { - compatible = "ns16550a"; - current-speed = <115200>; - reg-shift = <2>; - reg-io-width = <4>; - reg = <0x02348400 0x100>; - clocks = <&clkuart2>; - interrupts = <GIC_SPI 432 IRQ_TYPE_EDGE_RISING>; - }; - - uart3: serial@2348800 { - compatible = "ns16550a"; - current-speed = <115200>; - reg-shift = <2>; - reg-io-width = <4>; - reg = <0x02348800 0x100>; - clocks = <&clkuart3>; - interrupts = <GIC_SPI 435 IRQ_TYPE_EDGE_RISING>; - }; - - dspgpio0: keystone_dsp_gpio@02620240 { - compatible = "ti,keystone-dsp-gpio"; - gpio-controller; - #gpio-cells = <2>; - gpio,syscon-dev = <&devctrl 0x240>; - }; - - dspgpio1: keystone_dsp_gpio@2620244 { - compatible = "ti,keystone-dsp-gpio"; - gpio-controller; - #gpio-cells = <2>; - gpio,syscon-dev = <&devctrl 0x244>; - }; - - dspgpio2: keystone_dsp_gpio@2620248 { - compatible = "ti,keystone-dsp-gpio"; - gpio-controller; - #gpio-cells = <2>; - gpio,syscon-dev = <&devctrl 0x248>; - }; - - dspgpio3: keystone_dsp_gpio@262024c { - compatible = "ti,keystone-dsp-gpio"; - gpio-controller; - #gpio-cells = <2>; - gpio,syscon-dev = <&devctrl 0x24c>; - }; - - mdio: mdio@26200f00 { - compatible = "ti,keystone_mdio", "ti,davinci_mdio"; - #address-cells = <1>; - #size-cells = <0>; - reg = <0x26200f00 0x100>; - status = "disabled"; - clocks = <&clkcpgmac>; - clock-names = "fck"; - bus_freq = <2500000>; - }; - /include/ "keystone-k2l-netcp.dtsi" - }; -}; - -&spi0 { - ti,davinci-spi-num-cs = <5>; -}; - -&spi1 { - ti,davinci-spi-num-cs = <3>; -}; - -&spi2 { - ti,davinci-spi-num-cs = <5>; - /* Pin muxed. Enabled and configured by Bootloader */ - status = "disabled"; -}; diff --git a/arch/arm/dts/keystone.dtsi b/arch/arm/dts/keystone.dtsi deleted file mode 100644 index 1538ccef81a..00000000000 --- a/arch/arm/dts/keystone.dtsi +++ /dev/null @@ -1,330 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Copyright (C) 2013-2017 Texas Instruments Incorporated - https://www.ti.com/ - */ - -#include <dt-bindings/interrupt-controller/arm-gic.h> -#include <dt-bindings/gpio/gpio.h> - -#include "skeleton.dtsi" - -/ { - model = "Texas Instruments Keystone 2 SoC"; - #address-cells = <1>; - #size-cells = <1>; - interrupt-parent = <&gic>; - - aliases { - serial0 = &uart0; - spi0 = &spi0; - spi1 = &spi1; - spi2 = &spi2; - i2c0 = &i2c0; - i2c1 = &i2c1; - i2c2 = &i2c2; - }; - - chosen { - stdout-path = &uart0; - }; - - memory { - reg = <0x80000000 0x40000000>; - }; - - gic: interrupt-controller { - compatible = "arm,cortex-a15-gic"; - #interrupt-cells = <3>; - interrupt-controller; - reg = <0x02561000 0x1000>, - <0x02562000 0x2000>, - <0x02564000 0x1000>, - <0x02566000 0x2000>; - interrupts = <GIC_PPI 9 (GIC_CPU_MASK_SIMPLE(4) | - IRQ_TYPE_LEVEL_HIGH)>; - }; - - timer { - compatible = "arm,armv7-timer"; - interrupts = - <GIC_PPI 13 - (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, - <GIC_PPI 14 - (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, - <GIC_PPI 11 - (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, - <GIC_PPI 10 - (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>; - }; - - pmu { - compatible = "arm,cortex-a15-pmu"; - interrupts = <GIC_SPI 20 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 21 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 22 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 23 IRQ_TYPE_EDGE_RISING>; - }; - - soc { - #address-cells = <1>; - #size-cells = <1>; - compatible = "ti,keystone","simple-bus"; - interrupt-parent = <&gic>; - ranges; - - pllctrl: pll-controller@02310000 { - compatible = "ti,keystone-pllctrl", "syscon"; - reg = <0x02310000 0x200>; - }; - - devctrl: device-state-control@02620000 { - compatible = "ti,keystone-devctrl", "syscon"; - reg = <0x02620000 0x1000>; - }; - - rstctrl: reset-controller { - compatible = "ti,keystone-reset"; - ti,syscon-pll = <&pllctrl 0xe4>; - ti,syscon-dev = <&devctrl 0x328>; - ti,wdt-list = <0>; - }; - - /include/ "keystone-clocks.dtsi" - - uart0: serial@2530c00 { - compatible = "ns16550a"; - current-speed = <115200>; - reg-shift = <2>; - reg-io-width = <4>; - reg = <0x02530c00 0x100>; - clocks = <&clkuart0>; - interrupts = <GIC_SPI 277 IRQ_TYPE_EDGE_RISING>; - }; - - uart1: serial@2531000 { - compatible = "ns16550a"; - current-speed = <115200>; - reg-shift = <2>; - reg-io-width = <4>; - reg = <0x02531000 0x100>; - clocks = <&clkuart1>; - interrupts = <GIC_SPI 280 IRQ_TYPE_EDGE_RISING>; - }; - - i2c0: i2c@2530000 { - compatible = "ti,davinci-i2c"; - reg = <0x02530000 0x400>; - clock-frequency = <100000>; - clocks = <&clki2c>; - interrupts = <GIC_SPI 283 IRQ_TYPE_EDGE_RISING>; - #address-cells = <1>; - #size-cells = <0>; - }; - - i2c1: i2c@2530400 { - compatible = "ti,davinci-i2c"; - reg = <0x02530400 0x400>; - clock-frequency = <100000>; - clocks = <&clki2c>; - interrupts = <GIC_SPI 286 IRQ_TYPE_EDGE_RISING>; - #address-cells = <1>; - #size-cells = <0>; - }; - - i2c2: i2c@2530800 { - compatible = "ti,davinci-i2c"; - reg = <0x02530800 0x400>; - clock-frequency = <100000>; - clocks = <&clki2c>; - interrupts = <GIC_SPI 289 IRQ_TYPE_EDGE_RISING>; - #address-cells = <1>; - #size-cells = <0>; - }; - - spi0: spi@21000400 { - compatible = "ti,dm6441-spi"; - reg = <0x21000400 0x200>; - num-cs = <4>; - ti,davinci-spi-intr-line = <0>; - interrupts = <GIC_SPI 292 IRQ_TYPE_EDGE_RISING>; - clocks = <&clkspi>; - #address-cells = <1>; - #size-cells = <0>; - }; - - spi1: spi@21000600 { - compatible = "ti,dm6441-spi"; - reg = <0x21000600 0x200>; - num-cs = <4>; - ti,davinci-spi-intr-line = <0>; - interrupts = <GIC_SPI 296 IRQ_TYPE_EDGE_RISING>; - clocks = <&clkspi>; - #address-cells = <1>; - #size-cells = <0>; - }; - - spi2: spi@21000800 { - compatible = "ti,dm6441-spi"; - reg = <0x21000800 0x200>; - num-cs = <4>; - ti,davinci-spi-intr-line = <0>; - interrupts = <GIC_SPI 300 IRQ_TYPE_EDGE_RISING>; - clocks = <&clkspi>; - #address-cells = <1>; - #size-cells = <0>; - }; - - usb_phy: usb_phy@2620738 { - compatible = "ti,keystone-usbphy"; - #address-cells = <1>; - #size-cells = <1>; - reg = <0x2620738 24>; - status = "disabled"; - }; - - usb: usb@2680000 { - compatible = "ti,keystone-dwc3"; - #address-cells = <1>; - #size-cells = <1>; - reg = <0x2680000 0x10000>; - clocks = <&clkusb>; - clock-names = "usb"; - interrupts = <GIC_SPI 393 IRQ_TYPE_EDGE_RISING>; - ranges; - dma-coherent; - dma-ranges; - status = "disabled"; - - usb@2690000 { - compatible = "synopsys,dwc3"; - reg = <0x2690000 0x70000>; - interrupts = <GIC_SPI 393 IRQ_TYPE_EDGE_RISING>; - usb-phy = <&usb_phy>, <&usb_phy>; - }; - }; - - wdt: wdt@22f0080 { - compatible = "ti,keystone-wdt","ti,davinci-wdt"; - reg = <0x022f0080 0x80>; - clocks = <&clkwdtimer0>; - }; - - clock_event: timer@22f0000 { - compatible = "ti,keystone-timer"; - reg = <0x022f0000 0x80>; - interrupts = <GIC_SPI 110 IRQ_TYPE_EDGE_RISING>; - clocks = <&clktimer15>; - }; - - gpio0: gpio@260bf00 { - compatible = "ti,keystone-gpio"; - reg = <0x0260bf00 0x100>; - gpio-controller; - #gpio-cells = <2>; - /* HW Interrupts mapped to GPIO pins */ - interrupts = <GIC_SPI 120 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 121 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 122 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 123 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 124 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 125 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 126 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 127 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 128 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 129 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 130 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 131 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 132 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 133 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 134 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 135 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 136 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 137 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 138 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 139 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 140 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 141 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 142 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 143 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 144 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 145 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 146 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 147 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 148 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 149 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 150 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 151 IRQ_TYPE_EDGE_RISING>; - clocks = <&clkgpio>; - clock-names = "gpio"; - ti,ngpio = <32>; - ti,davinci-gpio-unbanked = <32>; - }; - - aemif: aemif@21000A00 { - compatible = "ti,keystone-aemif", "ti,davinci-aemif"; - #address-cells = <2>; - #size-cells = <1>; - clocks = <&clkaemif>; - clock-names = "aemif"; - clock-ranges; - - reg = <0x21000A00 0x00000100>; - ranges = <0 0 0x30000000 0x10000000 - 1 0 0x21000A00 0x00000100>; - }; - - kirq0: keystone_irq@26202a0 { - compatible = "ti,keystone-irq"; - interrupts = <GIC_SPI 4 IRQ_TYPE_EDGE_RISING>; - interrupt-controller; - #interrupt-cells = <1>; - ti,syscon-dev = <&devctrl 0x2a0>; - }; - - pcie0: pcie@21800000 { - compatible = "ti,keystone-pcie", "snps,dw-pcie"; - clocks = <&clkpcie>; - clock-names = "pcie"; - #address-cells = <3>; - #size-cells = <2>; - reg = <0x21801000 0x2000>, <0x21800000 0x1000>, <0x02620128 4>; - ranges = <0x81000000 0 0 0x23250000 0 0x4000 - 0x82000000 0 0x50000000 0x50000000 0 0x10000000>; - - status = "disabled"; - device_type = "pci"; - num-lanes = <2>; - - #interrupt-cells = <1>; - interrupt-map-mask = <0 0 0 7>; - interrupt-map = <0 0 0 1 &pcie_intc0 0>, /* INT A */ - <0 0 0 2 &pcie_intc0 1>, /* INT B */ - <0 0 0 3 &pcie_intc0 2>, /* INT C */ - <0 0 0 4 &pcie_intc0 3>; /* INT D */ - - pcie_msi_intc0: msi-interrupt-controller { - interrupt-controller; - #interrupt-cells = <1>; - interrupt-parent = <&gic>; - interrupts = <GIC_SPI 30 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 31 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 32 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 33 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 34 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 35 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 36 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 37 IRQ_TYPE_EDGE_RISING>; - }; - - pcie_intc0: legacy-interrupt-controller { - interrupt-controller; - #interrupt-cells = <1>; - interrupt-parent = <&gic>; - interrupts = <GIC_SPI 26 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 27 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 28 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 29 IRQ_TYPE_EDGE_RISING>; - }; - }; - }; -}; diff --git a/configs/k2e_evm_defconfig b/configs/k2e_evm_defconfig index 8d6cb240446..f201a175727 100644 --- a/configs/k2e_evm_defconfig +++ b/configs/k2e_evm_defconfig @@ -18,7 +18,7 @@ CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_ENV_SIZE=0x40000 CONFIG_ENV_OFFSET=0x100000 CONFIG_SPL_DM_SPI=y -CONFIG_DEFAULT_DEVICE_TREE="keystone-k2e-evm" +CONFIG_DEFAULT_DEVICE_TREE="ti/keystone/keystone-k2e-evm" CONFIG_SPL_TEXT_BASE=0xC100000 CONFIG_SPL_SERIAL=y CONFIG_SPL_STACK=0xc1223f4 @@ -99,3 +99,4 @@ CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_DWC3=y CONFIG_USB_DWC3_GENERIC=y +CONFIG_OF_UPSTREAM=y diff --git a/configs/k2e_hs_evm_defconfig b/configs/k2e_hs_evm_defconfig index e3c0ae15071..46501d59e09 100644 --- a/configs/k2e_hs_evm_defconfig +++ b/configs/k2e_hs_evm_defconfig @@ -15,7 +15,7 @@ CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0xc0fff10 CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_ENV_SIZE=0x40000 CONFIG_ENV_OFFSET=0x100000 -CONFIG_DEFAULT_DEVICE_TREE="keystone-k2e-evm" +CONFIG_DEFAULT_DEVICE_TREE="ti/keystone/keystone-k2e-evm" CONFIG_TIMESTAMP=y CONFIG_DISTRO_DEFAULTS=y CONFIG_OF_BOARD_SETUP=y @@ -73,3 +73,4 @@ CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_DWC3=y CONFIG_USB_DWC3_GENERIC=y +CONFIG_OF_UPSTREAM=y diff --git a/configs/k2g_evm_defconfig b/configs/k2g_evm_defconfig index 5d54d75f974..57a3d362a1b 100644 --- a/configs/k2g_evm_defconfig +++ b/configs/k2g_evm_defconfig @@ -17,7 +17,7 @@ CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0xc09ff10 CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_ENV_SIZE=0x40000 CONFIG_SPL_DM_SPI=y -CONFIG_DEFAULT_DEVICE_TREE="keystone-k2g-evm" +CONFIG_DEFAULT_DEVICE_TREE="ti/keystone/keystone-k2g-evm" CONFIG_SPL_TEXT_BASE=0xC0A0000 CONFIG_SPL_SERIAL=y CONFIG_SPL_STACK=0xc0c23f4 @@ -57,7 +57,7 @@ CONFIG_MTDIDS_DEFAULT="nand0=davinci_nand.0" CONFIG_CMD_UBI=y CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y -CONFIG_OF_LIST="keystone-k2g-generic keystone-k2g-evm keystone-k2g-ice" +CONFIG_OF_LIST="ti/keystone/keystone-k2g-evm ti/keystone/keystone-k2g-ice" CONFIG_DTB_RESELECT=y CONFIG_MULTI_DTB_FIT=y CONFIG_ENV_OVERWRITE=y @@ -109,3 +109,4 @@ CONFIG_USB_DWC3_GENERIC=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_USB_FUNCTION_SDP=y +CONFIG_OF_UPSTREAM=y diff --git a/configs/k2g_hs_evm_defconfig b/configs/k2g_hs_evm_defconfig index 9adab3af305..392ec5b2a05 100644 --- a/configs/k2g_hs_evm_defconfig +++ b/configs/k2g_hs_evm_defconfig @@ -14,7 +14,7 @@ CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0xc09ff10 CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_ENV_SIZE=0x40000 -CONFIG_DEFAULT_DEVICE_TREE="keystone-k2g-evm" +CONFIG_DEFAULT_DEVICE_TREE="ti/keystone/keystone-k2g-evm" CONFIG_TIMESTAMP=y CONFIG_DISTRO_DEFAULTS=y CONFIG_OF_BOARD_SETUP=y @@ -33,7 +33,7 @@ CONFIG_BOOTP_DNS2=y CONFIG_MTDIDS_DEFAULT="nand0=davinci_nand.0" CONFIG_CMD_UBI=y CONFIG_OF_CONTROL=y -CONFIG_OF_LIST="keystone-k2g-generic keystone-k2g-evm keystone-k2g-ice" +CONFIG_OF_LIST="ti/keystone/keystone-k2g-evm ti/keystone/keystone-k2g-ice" CONFIG_DTB_RESELECT=y CONFIG_MULTI_DTB_FIT=y CONFIG_ENV_OVERWRITE=y @@ -84,3 +84,4 @@ CONFIG_USB_DWC3_GENERIC=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_USB_FUNCTION_SDP=y +CONFIG_OF_UPSTREAM=y diff --git a/configs/k2hk_evm_defconfig b/configs/k2hk_evm_defconfig index 4da75d1ca76..2e29b2f2aeb 100644 --- a/configs/k2hk_evm_defconfig +++ b/configs/k2hk_evm_defconfig @@ -18,7 +18,7 @@ CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_ENV_SIZE=0x40000 CONFIG_ENV_OFFSET=0x100000 CONFIG_SPL_DM_SPI=y -CONFIG_DEFAULT_DEVICE_TREE="keystone-k2hk-evm" +CONFIG_DEFAULT_DEVICE_TREE="ti/keystone/keystone-k2hk-evm" CONFIG_SPL_TEXT_BASE=0xC200000 CONFIG_SPL_SERIAL=y CONFIG_SPL_STACK=0xc2223f4 @@ -100,3 +100,4 @@ CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_DWC3=y CONFIG_USB_DWC3_GENERIC=y +CONFIG_OF_UPSTREAM=y diff --git a/configs/k2hk_hs_evm_defconfig b/configs/k2hk_hs_evm_defconfig index 1a24d7142b8..cf299f2457c 100644 --- a/configs/k2hk_hs_evm_defconfig +++ b/configs/k2hk_hs_evm_defconfig @@ -15,7 +15,7 @@ CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0xc1fff10 CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_ENV_SIZE=0x40000 CONFIG_ENV_OFFSET=0x100000 -CONFIG_DEFAULT_DEVICE_TREE="keystone-k2hk-evm" +CONFIG_DEFAULT_DEVICE_TREE="ti/keystone/keystone-k2hk-evm" CONFIG_TIMESTAMP=y CONFIG_DISTRO_DEFAULTS=y CONFIG_OF_BOARD_SETUP=y @@ -74,3 +74,4 @@ CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_DWC3=y CONFIG_USB_DWC3_GENERIC=y +CONFIG_OF_UPSTREAM=y diff --git a/configs/k2l_evm_defconfig b/configs/k2l_evm_defconfig index c4534f033ac..0cadece4b02 100644 --- a/configs/k2l_evm_defconfig +++ b/configs/k2l_evm_defconfig @@ -18,7 +18,7 @@ CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_ENV_SIZE=0x40000 CONFIG_ENV_OFFSET=0x100000 CONFIG_SPL_DM_SPI=y -CONFIG_DEFAULT_DEVICE_TREE="keystone-k2l-evm" +CONFIG_DEFAULT_DEVICE_TREE="ti/keystone/keystone-k2l-evm" CONFIG_SPL_TEXT_BASE=0xC100000 CONFIG_SPL_SERIAL=y CONFIG_SPL_STACK=0xc1223f4 @@ -100,3 +100,4 @@ CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_DWC3=y CONFIG_USB_DWC3_GENERIC=y +CONFIG_OF_UPSTREAM=y diff --git a/configs/k2l_hs_evm_defconfig b/configs/k2l_hs_evm_defconfig index c874349e942..5496049d3a3 100644 --- a/configs/k2l_hs_evm_defconfig +++ b/configs/k2l_hs_evm_defconfig @@ -15,7 +15,7 @@ CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0xc0fff10 CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_ENV_SIZE=0x40000 CONFIG_ENV_OFFSET=0x100000 -CONFIG_DEFAULT_DEVICE_TREE="keystone-k2l-evm" +CONFIG_DEFAULT_DEVICE_TREE="ti/keystone/keystone-k2l-evm" CONFIG_TIMESTAMP=y CONFIG_OF_BOARD_SETUP=y CONFIG_USE_BOOTCOMMAND=y @@ -78,3 +78,4 @@ CONFIG_USB_XHCI_DWC3=y CONFIG_USB_DWC3=y CONFIG_USB_DWC3_GENERIC=y CONFIG_USB_STORAGE=y +CONFIG_OF_UPSTREAM=y
Hi Andrew
On 07/08/24 20:26, Andrew Davis wrote:
Enable OF_UPSTREAM for Keystone boards. Remove DT files that are now available in dts/upstream.
Signed-off-by: Andrew Davis afd@ti.com
arch/arm/dts/Makefile | 7 - arch/arm/dts/keystone-clocks.dtsi | 411 ----------------- arch/arm/dts/keystone-k2e-clocks.dtsi | 74 --- arch/arm/dts/keystone-k2e-evm-u-boot.dtsi | 14 +- arch/arm/dts/keystone-k2e-evm.dts | 152 ------- arch/arm/dts/keystone-k2e-netcp.dtsi | 203 --------- arch/arm/dts/keystone-k2e.dtsi | 144 ------ arch/arm/dts/keystone-k2g-evm-u-boot.dtsi | 20 +- arch/arm/dts/keystone-k2g-evm.dts | 148 ------ arch/arm/dts/keystone-k2g-generic-u-boot.dtsi | 18 - arch/arm/dts/keystone-k2g-generic.dts | 27 -- arch/arm/dts/keystone-k2g-ice-u-boot.dtsi | 15 +- arch/arm/dts/keystone-k2g-ice.dts | 118 ----- arch/arm/dts/keystone-k2g-netcp.dtsi | 149 ------- arch/arm/dts/keystone-k2g.dtsi | 258 ----------- arch/arm/dts/keystone-k2hk-clocks.dtsi | 422 ------------------ arch/arm/dts/keystone-k2hk-evm-u-boot.dtsi | 26 +- arch/arm/dts/keystone-k2hk-evm.dts | 180 -------- arch/arm/dts/keystone-k2hk-netcp.dtsi | 207 --------- arch/arm/dts/keystone-k2hk.dtsi | 111 ----- arch/arm/dts/keystone-k2l-clocks.dtsi | 263 ----------- arch/arm/dts/keystone-k2l-evm-u-boot.dtsi | 28 +- arch/arm/dts/keystone-k2l-evm.dts | 129 ------ arch/arm/dts/keystone-k2l-netcp.dtsi | 187 -------- arch/arm/dts/keystone-k2l.dtsi | 105 ----- arch/arm/dts/keystone.dtsi | 330 -------------- configs/k2e_evm_defconfig | 3 +- configs/k2e_hs_evm_defconfig | 3 +- configs/k2g_evm_defconfig | 5 +- configs/k2g_hs_evm_defconfig | 5 +- configs/k2hk_evm_defconfig | 3 +- configs/k2hk_hs_evm_defconfig | 3 +- configs/k2l_evm_defconfig | 3 +- configs/k2l_hs_evm_defconfig | 3 +- 34 files changed, 98 insertions(+), 3676 deletions(-) delete mode 100644 arch/arm/dts/keystone-clocks.dtsi delete mode 100644 arch/arm/dts/keystone-k2e-clocks.dtsi delete mode 100644 arch/arm/dts/keystone-k2e-evm.dts delete mode 100644 arch/arm/dts/keystone-k2e-netcp.dtsi delete mode 100644 arch/arm/dts/keystone-k2e.dtsi delete mode 100644 arch/arm/dts/keystone-k2g-evm.dts delete mode 100644 arch/arm/dts/keystone-k2g-generic-u-boot.dtsi delete mode 100644 arch/arm/dts/keystone-k2g-generic.dts delete mode 100644 arch/arm/dts/keystone-k2g-ice.dts delete mode 100644 arch/arm/dts/keystone-k2g-netcp.dtsi delete mode 100644 arch/arm/dts/keystone-k2g.dtsi delete mode 100644 arch/arm/dts/keystone-k2hk-clocks.dtsi delete mode 100644 arch/arm/dts/keystone-k2hk-evm.dts delete mode 100644 arch/arm/dts/keystone-k2hk-netcp.dtsi delete mode 100644 arch/arm/dts/keystone-k2hk.dtsi delete mode 100644 arch/arm/dts/keystone-k2l-clocks.dtsi delete mode 100644 arch/arm/dts/keystone-k2l-evm.dts delete mode 100644 arch/arm/dts/keystone-k2l-netcp.dtsi delete mode 100644 arch/arm/dts/keystone-k2l.dtsi delete mode 100644 arch/arm/dts/keystone.dtsi
Acked-by: Neha Malcom Francis n-francis@ti.com
Andrew Davis
Neha Malcom Francis
