How u-boot can chain "grub" and booting a mainline kernel on my ARM Chromebook
Hello.
I would like to enable KVM virtualization on my old ARM Chromebook laptop,based on the Exynos5250 arm 32 bit cpu aka snow,model xe303c12. The first thing I did has been to dd the image below directly on the sd card :
https://github.com/hexdump0815/imagebuilder/releases/download/220619-01/chro...
and it worked like a charm,but kvm was disabled. So,I have started to look for a good documentation to understand how to enable kvm and I found this :
http://www.virtualopensystems.com/en/solutions/guides/kvm-on-chromebook/
I've followed all the instructions and it worked,but only with Ubuntu 13.04 and 14.04. More upgraded ubuntu versions give a lot of problems and they don't work.
So,I've thought about a fresh idea. What about to install the virtual open systems "non-verified u-boot" on the first partition like explained in the tutorial,and,instead of starting another u-boot after the original,can I chain grub with the kernel installed for example by the ubuntu jammy iso image created by "hexdump0815" ? To be honest I'm not sure if hexdump0815 used grub,but I will explain this later.
Anyway,I've got the idea by reading here :
https://unix.stackexchange.com/questions/599141/how-to-install-grub-bootload... So,now,I'm going to explain what's the content of the partitions on my Frankenstein sd card.
1) /dev/sdh1 = unknown = 16 MB. I've created this partition by doing :
$ sudo dd if=nv_uboot-snow.kpart of=/dev/sdh1
Where I've got the file nv_uboot-snow.kpart ? From here :
http://www.virtualopensystems.com/downloads/guides/kvm_on_chromebook/nv_u-bo...
2) /dev/sdh2 = unknown = 16 MB. This partition has been created by executing the following
script :
$ sudo ./scripts/sdcard.sh /dev/sdh
3) /dev/sdh3 = ext2 BOOT.
Inside the partition /dev/sdh3 I have copied the following files and folders (taken from the hexdump0815 "chromebook_snow-armv7l-jammy.img.gz" file :
a) dtb-5.18.1-stb-cbe+ = directory b) extlinux = directory c) extra = directory
d) config.5.18.1-stb-cbe+ : file e) initrd.img-5.18.1-stb-cbe+ : file f) System.map-5.18.1-stb-cbe+ : file g) vmlinux.kpart-5.18.1-stb-cbe+ : file h) zImage-5.18.1-stb.cbe+ : file
Inside the directory "dtb-5.18.1-stb-cbe+" there are the following files :
a) exynos5250-snow.dtb b) exynos5250-snow-rev5.dtb c) exynos5250-spring.dtb
Inside the directory "extlinux",there is the following file :
a) extlinux.conf : that has the following content :
TIMEOUT 30
DEFAULT linux-snow-rev4
MENU TITLE snow chromebook boot options
# rev4 snow chromebook LABEL linux-snow-rev4 MENU LABEL linux rev4 snow LINUX ../zImage-5.18.1-stb-cbe+ INITRD ../initrd.img-5.18.1-stb-cbe+ FDT ../dtb-5.18.1-stb-cbe+/exynos5250-snow.dtb APPEND console=tty1 root=LABEL=rootpart ro rootwait net.ifnames=0 ipv6.disable=1 fsck.repair=yes noresume
# rev5 snow chromebook LABEL linux-snow-rev5 MENU LABEL linux rev5 snow LINUX ../zImage-5.18.1-stb-cbe+ INITRD ../initrd.img-5.18.1-stb-cbe+ FDT ../dtb-5.18.1-stb-cbe+/exynos5250-snow-rev5.dtb APPEND console=tty1 root=LABEL=rootpart ro rootwait net.ifnames=0 ipv6.disable=1 fsck.repair=yes noresume
# spring chromebook - untested LABEL linux-spring MENU LABEL linux spring LINUX ../zImage-5.18.1-stb-cbe+ INITRD ../initrd.img-5.18.1-stb-cbe+ # rev4 snow chromebook FDT ../dtb-5.18.1-stb-cbe+/exynos5250-spring.dtb APPEND console=tty1 root=LABEL=rootpart ro rootwait net.ifnames=0 ipv6.disable=1 fsck.repair=yes noresume
Inside the extra directory there are the following files :
a) kernel-chromebook_snow-legacy.tar.gz b) uboot.kpart.cbe-snow c) uboot.kpart.cbe-snow-alternative d) uboot.kpart.cbe-spring
4) /dev/sdh4 : inside here I have copied all the files of the jammy userland prepared by hexdump0818.
That's all. What I want to do is if and how can I chainload the "non-verified u-boot" that is installed on the partition /dev/sdh1 with grub or whatever mechanism it is able to boot the hexdump0815 jammy iso image.
As I repeat,the "non-verified u-boot" is produced by the script called "build.sh",that's stored inside the u-boot/scripts directory. And if what I want to do is impossible,can you explain to me how I can enable kvm on my chromebook arm,using the most recent kernel possible ? I already know that the support for kvm on arm 32 has been dropped on kernel 5.7,but for me to use a lower kernel than 5.7 is ok. I've been working on this project for a lot of months. I would like to see some progress. Thanks.
On Sat, Jul 1, 2023 at 1:25 PM Mario Marietto marietto2008@gmail.com wrote:
Hello.
Upstream Linux kernel dropped support for running virt on 32 bit hosts (you can still run a 32 bit guest on a 64 bit host) in the upstream linux kernel with the 5.7 release (May 31st, 2020) so you'll probably have to run a 5.4.x LTS kernel rather than 5.18.x (not sure why you chose that one) at the very least.
- /dev/sdh1 = unknown = 16 MB. I've created this partition by doing :
- /dev/sdh2 = unknown = 16 MB. This partition has been created by
script :
- /dev/sdh3 = ext2 BOOT.
TIMEOUT 30
- /dev/sdh4 : inside here I have copied all the files of the jammy
-- Mario.
Excuse me. The problem is not the kernel version that I'm running,but how to use the unverified u-boot created by virtual open systems to chainload the kernel of whatever used to boot one recent ISO image created by hexdump0815. Because it contains the code to put the chromebook in hypervisor mode. Without that special u-boot version,I can for sure install one ISO image of hexdump0815 (I've chosen jammy as an example,but hexdump0815 created some more updated isos),but KVM will not be enabled.
Hello.
look
this :
13.04
open
the
script :
TIMEOUT 30
what I
that
to
a
-- Mario.
You'll note I didn't comment on the U-Boot piece, but my point still remains, that KVM for a 32 bit Arm host was removed in the 5.7 kernel upstream, so even when you sort out the other problem you still won't have virt due to the kernel.
Hello.
script :
TIMEOUT 30
-- Mario.
-- Mario.
Some days ago I successfully compiled the kernel version. 5.4.244 with all the kvm flags enabled and the exynos 5250-snow.dtb file.
wrote:
Hello.
sd
card :
look
this :
13.04
they
don't work.
open
in the
original,can I
iso
hexdump0815
script :
files :
TIMEOUT 30
net.ifnames=0
net.ifnames=0
net.ifnames=0
what I
on my
that
me to
for a
-- Mario.
-- Mario.
ok. Can we come back to the main problem,please ? Is there a method to do what I want ? Is there some kind of technique ? Very thanks.
wrote:
Hello.
xe303c12.
sd
card :
to look
this :
Ubuntu 13.04
they
don't work.
virtual open
in the
original,can I
iso
hexdump0815
my
script :
files :
TIMEOUT 30
net.ifnames=0
net.ifnames=0
net.ifnames=0
called
what I
on my
know that
me to
for a
-- Mario.
-- Mario.
-- Mario.
Hello.
I've been able to understand what was the X variable,the component that allows the hexdump0815 ubuntu iso images to boot correctly : it is syslinux. So,now I know what I should do : to try to chainload the u-boot installed on the first partition with syslinux,installed on the 4 partition I think,I don't know. I would like to understand if this task can be accomplished or not.
wrote:
Hello.
xe303c12.
the sd
card :
to look
found this :
Ubuntu 13.04
they
don't work.
virtual open
in the
original,can I
jammy iso
hexdump0815
my
doing :
script :
files :
TIMEOUT 30
net.ifnames=0
net.ifnames=0
net.ifnames=0
called
if what I
on my
know that
for me to
project for a
-- Mario.
-- Mario.
-- Mario.
-- Mario.
Mario Marietto
Peter Robinson
