[U-Boot] [PATCH 1/2 V2] afeb9260: fix macb device init
uses PA10, PA11 for ETX2 and ETX3.
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com --- cpu/arm926ejs/at91/at91sam9260_devices.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/cpu/arm926ejs/at91/at91sam9260_devices.c b/cpu/arm926ejs/at91/at91sam9260_devices.c index 6dc0acc..5309ba2 100644 --- a/cpu/arm926ejs/at91/at91sam9260_devices.c +++ b/cpu/arm926ejs/at91/at91sam9260_devices.c @@ -167,7 +167,7 @@ void at91_macb_hw_init(void) at91_set_B_periph(AT91_PIN_PA25, 0); /* ERX2 */ at91_set_B_periph(AT91_PIN_PA26, 0); /* ERX3 */ at91_set_B_periph(AT91_PIN_PA27, 0); /* ERXCK */ -#if defined(CONFIG_AT91SAM9260EK) +#if defined(CONFIG_AT91SAM9260EK) || defined(CONFIG_AFEB9260) /* * use PA10, PA11 for ETX2, ETX3. * PA23 and PA24 are for TWI EEPROM
all arm boards except a few use the same cpu linker script so move it to cpu/$(CPU)
that could be overwrite in following order SOC BOARD via the corresponding config.mk
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com --- V2: update commit message arm_config.mk | 2 + board/actux1/config.mk | 2 + board/actux2/config.mk | 2 + board/actux3/config.mk | 2 + board/actux4/u-boot.lds | 66 ---------------------- board/armadillo/u-boot.lds | 55 ------------------ board/armltd/integratorap/config.mk | 6 -- board/armltd/integratorap/split_by_variant.sh | 4 - board/armltd/integratorap/u-boot.lds.template | 53 ----------------- board/armltd/integratorcp/config.mk | 6 -- board/armltd/integratorcp/split_by_variant.sh | 4 - board/armltd/integratorcp/u-boot.lds.template | 53 ----------------- board/armltd/versatile/u-boot.lds | 51 ----------------- board/atmel/at91rm9200dk/u-boot.lds | 57 ------------------- board/atmel/at91rm9200ek/u-boot.lds | 56 ------------------ board/cerf250/u-boot.lds | 56 ------------------ board/cm4008/u-boot.lds | 56 ------------------ board/cm41xx/u-boot.lds | 56 ------------------ board/cmc_pu2/u-boot.lds | 57 ------------------- board/cradle/u-boot.lds | 56 ------------------ board/csb226/u-boot.lds | 56 ------------------ board/csb637/u-boot.lds | 56 ------------------ board/dave/B2/u-boot.lds | 58 ------------------- board/davedenx/qong/u-boot.lds | 58 ------------------- board/delta/u-boot.lds | 56 ------------------ board/dnp1110/u-boot.lds | 56 ------------------ board/ep7312/u-boot.lds | 56 ------------------ board/evb4510/u-boot.lds | 69 ----------------------- board/freescale/mx31ads/config.mk | 2 + board/gcplus/u-boot.lds | 58 ------------------- board/impa7/u-boot.lds | 56 ------------------ board/imx31_litekit/u-boot.lds | 59 ------------------- board/imx31_phycore/u-boot.lds | 59 ------------------- board/innokom/u-boot.lds | 56 ------------------ board/kb9202/u-boot.lds | 56 ------------------ board/lart/u-boot.lds | 56 ------------------ board/logodl/u-boot.lds | 56 ------------------ board/lpc2292sodimm/u-boot.lds | 55 ------------------ board/lubbock/u-boot.lds | 56 ------------------ board/m501sk/u-boot.lds | 55 ------------------ board/modnet50/u-boot.lds | 69 ----------------------- board/mp2usb/u-boot.lds | 56 ------------------ board/mpl/vcma9/u-boot.lds | 57 ------------------- board/mx1ads/u-boot.lds | 58 ------------------- board/netstar/u-boot.lds | 55 ------------------ board/ns9750dev/u-boot.lds | 59 ------------------- board/omap1510inn/u-boot.lds | 57 ------------------- board/omap1610inn/u-boot.lds | 52 ----------------- board/omap2420h4/u-boot.lds | 59 ------------------- board/pleb2/u-boot.lds | 56 ------------------ board/prodrive/pdnb3/u-boot.lds | 56 ------------------ board/samsung/smdk2400/u-boot.lds | 57 ------------------- board/samsung/smdk2410/u-boot.lds | 57 ------------------- board/samsung/smdk6400/config.mk | 2 + board/sbc2410x/u-boot.lds | 56 ------------------ board/shannon/u-boot.lds | 56 ------------------ board/siemens/SMN42/u-boot.lds | 55 ------------------ board/sx1/u-boot.lds | 57 ------------------- board/trab/config.mk | 2 + board/trizepsiv/u-boot.lds | 56 ------------------ board/voiceblue/u-boot.lds | 56 ------------------ board/wepep250/u-boot.lds | 56 ------------------ board/xaeniax/u-boot.lds | 56 ------------------ board/xsengine/u-boot.lds | 56 ------------------ board/zylonite/u-boot.lds | 56 ------------------ {board/apollon => cpu/arm1136}/u-boot.lds | 5 +- {board/omap5912osk => cpu/arm1176}/u-boot.lds | 10 ++- {board/scb9328 => cpu/arm720t}/u-boot.lds | 7 +- {board/xm250 => cpu/arm920t}/u-boot.lds | 14 ++++- {board/lpd7a40x => cpu/arm925t}/u-boot.lds | 10 ++- cpu/arm926ejs/at91/config.mk | 1 - cpu/arm926ejs/at91/u-boot.lds | 57 ------------------- cpu/arm926ejs/davinci/config.mk | 2 - {board/st/nmdk8815 => cpu/arm926ejs}/u-boot.lds | 11 +++- {board/omap730p2 => cpu/arm946es}/u-boot.lds | 10 ++- cpu/arm_cortexa8/omap3/config.mk | 2 - cpu/arm_cortexa8/{omap3 => }/u-boot.lds | 0 cpu/{arm926ejs/davinci => arm_intcm}/u-boot.lds | 10 ++- {board/ixdp425 => cpu/ixp}/u-boot.lds | 8 +- {board/st/nmdk8815 => cpu/lh7a40x}/u-boot.lds | 9 ++- {board/pxa255_idp => cpu/pxa}/u-boot.lds | 6 +- {board/mx1fs2 => cpu/s3c44b0}/u-boot.lds | 5 +- {board/assabet => cpu/sa1100}/u-boot.lds | 7 +- 83 files changed, 86 insertions(+), 3189 deletions(-) delete mode 100644 board/actux4/u-boot.lds delete mode 100644 board/armadillo/u-boot.lds delete mode 100644 board/armltd/integratorap/u-boot.lds.template delete mode 100644 board/armltd/integratorcp/u-boot.lds.template delete mode 100644 board/armltd/versatile/u-boot.lds delete mode 100644 board/atmel/at91rm9200dk/u-boot.lds delete mode 100644 board/atmel/at91rm9200ek/u-boot.lds delete mode 100644 board/cerf250/u-boot.lds delete mode 100644 board/cm4008/u-boot.lds delete mode 100644 board/cm41xx/u-boot.lds delete mode 100644 board/cmc_pu2/u-boot.lds delete mode 100644 board/cradle/u-boot.lds delete mode 100644 board/csb226/u-boot.lds delete mode 100644 board/csb637/u-boot.lds delete mode 100644 board/dave/B2/u-boot.lds delete mode 100644 board/davedenx/qong/u-boot.lds delete mode 100644 board/delta/u-boot.lds delete mode 100644 board/dnp1110/u-boot.lds delete mode 100644 board/ep7312/u-boot.lds delete mode 100644 board/evb4510/u-boot.lds delete mode 100644 board/gcplus/u-boot.lds delete mode 100644 board/impa7/u-boot.lds delete mode 100644 board/imx31_litekit/u-boot.lds delete mode 100644 board/imx31_phycore/u-boot.lds delete mode 100644 board/innokom/u-boot.lds delete mode 100644 board/kb9202/u-boot.lds delete mode 100644 board/lart/u-boot.lds delete mode 100644 board/logodl/u-boot.lds delete mode 100644 board/lpc2292sodimm/u-boot.lds delete mode 100644 board/lubbock/u-boot.lds delete mode 100644 board/m501sk/u-boot.lds delete mode 100644 board/modnet50/u-boot.lds delete mode 100644 board/mp2usb/u-boot.lds delete mode 100644 board/mpl/vcma9/u-boot.lds delete mode 100644 board/mx1ads/u-boot.lds delete mode 100644 board/netstar/u-boot.lds delete mode 100644 board/ns9750dev/u-boot.lds delete mode 100644 board/omap1510inn/u-boot.lds delete mode 100644 board/omap1610inn/u-boot.lds delete mode 100644 board/omap2420h4/u-boot.lds delete mode 100644 board/pleb2/u-boot.lds delete mode 100644 board/prodrive/pdnb3/u-boot.lds delete mode 100644 board/samsung/smdk2400/u-boot.lds delete mode 100644 board/samsung/smdk2410/u-boot.lds delete mode 100644 board/sbc2410x/u-boot.lds delete mode 100644 board/shannon/u-boot.lds delete mode 100644 board/siemens/SMN42/u-boot.lds delete mode 100644 board/sx1/u-boot.lds delete mode 100644 board/trizepsiv/u-boot.lds delete mode 100644 board/voiceblue/u-boot.lds delete mode 100644 board/wepep250/u-boot.lds delete mode 100644 board/xaeniax/u-boot.lds delete mode 100644 board/xsengine/u-boot.lds delete mode 100644 board/zylonite/u-boot.lds rename {board/apollon => cpu/arm1136}/u-boot.lds (94%) rename {board/omap5912osk => cpu/arm1176}/u-boot.lds (96%) rename {board/scb9328 => cpu/arm720t}/u-boot.lds (92%) rename {board/xm250 => cpu/arm920t}/u-boot.lds (84%) rename {board/lpd7a40x => cpu/arm925t}/u-boot.lds (91%) delete mode 100644 cpu/arm926ejs/at91/u-boot.lds copy {board/st/nmdk8815 => cpu/arm926ejs}/u-boot.lds (92%) rename {board/omap730p2 => cpu/arm946es}/u-boot.lds (96%) rename cpu/arm_cortexa8/{omap3 => }/u-boot.lds (100%) rename cpu/{arm926ejs/davinci => arm_intcm}/u-boot.lds (96%) rename {board/ixdp425 => cpu/ixp}/u-boot.lds (94%) rename {board/st/nmdk8815 => cpu/lh7a40x}/u-boot.lds (96%) rename {board/pxa255_idp => cpu/pxa}/u-boot.lds (96%) rename {board/mx1fs2 => cpu/s3c44b0}/u-boot.lds (96%) rename {board/assabet => cpu/sa1100}/u-boot.lds (95%)
Best Regards, J.
