[U-Boot] [PATCH] configs: Remove unused am335x_evm defconfigs
These defconfigs don't seem be actively used any more, and have not been moved to adapt DM or DT. Therefore delete them.
Signed-off-by: Vignesh R vigneshr@ti.com --- board/ti/am335x/MAINTAINERS | 3 -- configs/am335x_evm_nor_defconfig | 52 ---------------------------- configs/am335x_evm_norboot_defconfig | 49 -------------------------- configs/am335x_evm_spiboot_defconfig | 47 ------------------------- 4 files changed, 151 deletions(-) delete mode 100644 configs/am335x_evm_nor_defconfig delete mode 100644 configs/am335x_evm_norboot_defconfig delete mode 100644 configs/am335x_evm_spiboot_defconfig
diff --git a/board/ti/am335x/MAINTAINERS b/board/ti/am335x/MAINTAINERS index c99e06dc10bc..565f7055cdd3 100644 --- a/board/ti/am335x/MAINTAINERS +++ b/board/ti/am335x/MAINTAINERS @@ -6,7 +6,4 @@ F: include/configs/am335x_evm.h F: configs/am335x_boneblack_defconfig F: configs/am335x_boneblack_vboot_defconfig F: configs/am335x_evm_defconfig -F: configs/am335x_evm_nor_defconfig -F: configs/am335x_evm_norboot_defconfig -F: configs/am335x_evm_spiboot_defconfig F: configs/am335x_evm_usbspl_defconfig diff --git a/configs/am335x_evm_nor_defconfig b/configs/am335x_evm_nor_defconfig deleted file mode 100644 index e08234e9f8f0..000000000000 --- a/configs/am335x_evm_nor_defconfig +++ /dev/null @@ -1,52 +0,0 @@ -CONFIG_ARM=y -CONFIG_ARCH_OMAP2PLUS=y -CONFIG_TI_COMMON_CMD_OPTIONS=y -CONFIG_AM33XX=y -CONFIG_NOR=y -CONFIG_SPL=y -CONFIG_DISTRO_DEFAULTS=y -CONFIG_BOOTCOMMAND="if test ${boot_fit} -eq 1; then run update_to_fit; fi; run findfdt; run init_console; run envboot; run distro_bootcmd" -CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_VERSION_VARIABLE=y -CONFIG_ARCH_MISC_INIT=y -CONFIG_SPL_MTD_SUPPORT=y -CONFIG_SPL_MUSB_NEW_SUPPORT=y -CONFIG_SPL_OS_BOOT=y -CONFIG_CMD_SPL=y -CONFIG_CMD_SPL_NAND_OFS=0x00080000 -CONFIG_CMD_NAND=y -# CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_MTDPARTS=y -CONFIG_MTDIDS_DEFAULT="nand0=nand.0" -CONFIG_MTDPARTS_DEFAULT="mtdparts=nand.0:128k(NAND.SPL),128k(NAND.SPL.backup1),128k(NAND.SPL.backup2),128k(NAND.SPL.backup3),256k(NAND.u-boot-spl-os),1m(NAND.u-boot),128k(NAND.u-boot-env),128k(NAND.u-boot-env.backup1),8m(NAND.kernel),-(NAND.file-system)" -CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y -CONFIG_BOOTCOUNT_LIMIT=y -CONFIG_DFU_MMC=y -CONFIG_DFU_NAND=y -CONFIG_DFU_RAM=y -CONFIG_USB_FUNCTION_FASTBOOT=y -CONFIG_MMC_OMAP_HS=y -CONFIG_MTD_NOR_FLASH=y -CONFIG_FLASH_CFI_DRIVER=y -CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y -CONFIG_FLASH_CFI_MTD=y -CONFIG_SYS_FLASH_PROTECTION=y -CONFIG_SYS_FLASH_CFI=y -CONFIG_NAND=y -CONFIG_SPI_FLASH=y -CONFIG_SPI_FLASH_WINBOND=y -CONFIG_MII=y -CONFIG_DRIVER_TI_CPSW=y -CONFIG_SPI=y -CONFIG_OMAP3_SPI=y -CONFIG_USB=y -CONFIG_USB_MUSB_HOST=y -CONFIG_USB_MUSB_GADGET=y -CONFIG_USB_MUSB_DSPS=y -CONFIG_USB_GADGET=y -CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" -CONFIG_USB_GADGET_VENDOR_NUM=0x0451 -CONFIG_USB_GADGET_PRODUCT_NUM=0xd022 -CONFIG_USB_ETHER=y -CONFIG_LZO=y -CONFIG_OF_LIBFDT=y diff --git a/configs/am335x_evm_norboot_defconfig b/configs/am335x_evm_norboot_defconfig deleted file mode 100644 index 040384f3c7a0..000000000000 --- a/configs/am335x_evm_norboot_defconfig +++ /dev/null @@ -1,49 +0,0 @@ -CONFIG_ARM=y -# CONFIG_SYS_THUMB_BUILD is not set -CONFIG_ARCH_OMAP2PLUS=y -CONFIG_SYS_TEXT_BASE=0x08000000 -CONFIG_TI_COMMON_CMD_OPTIONS=y -CONFIG_AM33XX=y -CONFIG_NOR=y -CONFIG_DISTRO_DEFAULTS=y -CONFIG_NOR_BOOT=y -CONFIG_BOOTCOMMAND="if test ${boot_fit} -eq 1; then run update_to_fit; fi; run findfdt; run init_console; run envboot; run distro_bootcmd" -CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_VERSION_VARIABLE=y -CONFIG_ARCH_MISC_INIT=y -CONFIG_BOARD_EARLY_INIT_F=y -# CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_MTDPARTS=y -CONFIG_MTDIDS_DEFAULT="nor0=physmap-flash.0" -CONFIG_MTDPARTS_DEFAULT="mtdparts=physmap-flash.0:512k(u-boot),128k(u-boot-env1),128k(u-boot-env2),4m(kernel),-(rootfs)" -CONFIG_ENV_IS_IN_FLASH=y -CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y -CONFIG_DFU_MMC=y -CONFIG_DFU_RAM=y -CONFIG_USB_FUNCTION_FASTBOOT=y -CONFIG_MMC_OMAP_HS=y -CONFIG_MTD_NOR_FLASH=y -CONFIG_MTD_DEVICE=y -CONFIG_FLASH_CFI_DRIVER=y -CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y -CONFIG_FLASH_CFI_MTD=y -CONFIG_SYS_FLASH_PROTECTION=y -CONFIG_SYS_FLASH_CFI=y -CONFIG_SPI_FLASH=y -CONFIG_SPI_FLASH_WINBOND=y -CONFIG_MII=y -CONFIG_DRIVER_TI_CPSW=y -CONFIG_SPI=y -CONFIG_OMAP3_SPI=y -CONFIG_USB=y -CONFIG_USB_MUSB_HOST=y -CONFIG_USB_MUSB_GADGET=y -CONFIG_USB_MUSB_DSPS=y -CONFIG_USB_GADGET=y -CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" -CONFIG_USB_GADGET_VENDOR_NUM=0x0451 -CONFIG_USB_GADGET_PRODUCT_NUM=0xd022 -CONFIG_USB_ETHER=y -CONFIG_USBNET_HOST_ADDR="de:ad:be:af:00:00" -CONFIG_LZO=y -CONFIG_OF_LIBFDT=y diff --git a/configs/am335x_evm_spiboot_defconfig b/configs/am335x_evm_spiboot_defconfig deleted file mode 100644 index 1f430ad416a5..000000000000 --- a/configs/am335x_evm_spiboot_defconfig +++ /dev/null @@ -1,47 +0,0 @@ -CONFIG_ARM=y -CONFIG_ARCH_OMAP2PLUS=y -CONFIG_TI_COMMON_CMD_OPTIONS=y -CONFIG_AM33XX=y -CONFIG_SPL=y -CONFIG_SPL_SPI_FLASH_SUPPORT=y -CONFIG_SPL_SPI_SUPPORT=y -CONFIG_DISTRO_DEFAULTS=y -CONFIG_SYS_EXTRA_OPTIONS="SPI_BOOT" -CONFIG_SPI_BOOT=y -CONFIG_BOOTCOMMAND="if test ${boot_fit} -eq 1; then run update_to_fit; fi; run findfdt; run init_console; run envboot; run distro_bootcmd" -CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_VERSION_VARIABLE=y -CONFIG_ARCH_MISC_INIT=y -CONFIG_SPL_MUSB_NEW_SUPPORT=y -# CONFIG_SPL_NAND_SUPPORT is not set -CONFIG_SPL_SPI_LOAD=y -# CONFIG_CMD_FLASH is not set -# CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_MTDPARTS=y -CONFIG_MTDIDS_DEFAULT="nor0=m25p80-flash.0" -CONFIG_MTDPARTS_DEFAULT="mtdparts=m25p80-flash.0:128k(SPL),512k(u-boot),128k(u-boot-env1),128k(u-boot-env2),3464k(kernel),-(rootfs)" -CONFIG_ENV_IS_IN_SPI_FLASH=y -CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y -CONFIG_BOOTCOUNT_LIMIT=y -CONFIG_DFU_MMC=y -CONFIG_DFU_RAM=y -CONFIG_USB_FUNCTION_FASTBOOT=y -CONFIG_MMC_OMAP_HS=y -CONFIG_MTD_DEVICE=y -CONFIG_SPI_FLASH=y -CONFIG_SPI_FLASH_WINBOND=y -CONFIG_MII=y -CONFIG_DRIVER_TI_CPSW=y -CONFIG_SPI=y -CONFIG_OMAP3_SPI=y -CONFIG_USB=y -CONFIG_USB_MUSB_HOST=y -CONFIG_USB_MUSB_GADGET=y -CONFIG_USB_MUSB_DSPS=y -CONFIG_USB_GADGET=y -CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" -CONFIG_USB_GADGET_VENDOR_NUM=0x0451 -CONFIG_USB_GADGET_PRODUCT_NUM=0xd022 -CONFIG_USB_ETHER=y -CONFIG_LZO=y -CONFIG_OF_LIBFDT=y
Signed-off-by: Vignesh R vigneshr@ti.com Reviewed-by: Tom Rini trini@konsulko.com
Vignesh R
