[PATCH] xilinx: versal-net: Add support for timer and start it
Add support for starting timer by setting up time stamp generator registers. This is done only for EL3 i.e. mini U-Boot case. For other cases, it will be done TF-A.
Add COUNTER_FREQUENCY and IOU_SWITCH_DIVISOR0 to Kconfig so that they can be tuned as required.
Signed-off-by: Ashok Reddy Soma ashok.reddy.soma@amd.com Signed-off-by: Michal Simek michal.simek@amd.com ---
arch/arm/mach-versal-net/Kconfig | 12 ++++++ .../mach-versal-net/include/mach/hardware.h | 30 ++++++++++++++ board/xilinx/versal-net/board.c | 41 +++++++++++++++++++ configs/xilinx_versal_net_mini_defconfig | 1 + configs/xilinx_versal_net_virt_defconfig | 1 + 5 files changed, 85 insertions(+)
diff --git a/arch/arm/mach-versal-net/Kconfig b/arch/arm/mach-versal-net/Kconfig index 62825e189fe6..edff5b039e91 100644 --- a/arch/arm/mach-versal-net/Kconfig +++ b/arch/arm/mach-versal-net/Kconfig @@ -21,6 +21,18 @@ config SYS_CONFIG_NAME Based on this option include/configs/<CONFIG_SYS_CONFIG_NAME>.h header will be used for board configuration.
+config COUNTER_FREQUENCY + int "Timer clock frequency" + default 0 + help + Setup time clock frequency for certain platform + +config IOU_SWITCH_DIVISOR0 + hex "IOU switch divisor0" + default 0x20 + help + Setup time clock divisor for input clock. + config SYS_MEM_RSVD_FOR_MMU bool "Reserve memory for MMU Table" help diff --git a/arch/arm/mach-versal-net/include/mach/hardware.h b/arch/arm/mach-versal-net/include/mach/hardware.h index 808ce48fd148..c5e4e22040e2 100644 --- a/arch/arm/mach-versal-net/include/mach/hardware.h +++ b/arch/arm/mach-versal-net/include/mach/hardware.h @@ -8,6 +8,36 @@ #include <linux/bitops.h> #endif
+struct crlapb_regs { + u32 reserved0[67]; + u32 cpu_r5_ctrl; + u32 reserved; + u32 iou_switch_ctrl; /* 0x114 */ + u32 reserved1[13]; + u32 timestamp_ref_ctrl; /* 0x14c */ + u32 reserved3[108]; + u32 rst_cpu_r5; + u32 reserved2[17]; + u32 rst_timestamp; /* 0x348 */ +}; + +struct iou_scntrs_regs { + u32 counter_control_register; /* 0x0 */ + u32 reserved0[7]; + u32 base_frequency_id_register; /* 0x20 */ +}; + +#define VERSAL_NET_CRL_APB_BASEADDR 0xEB5E0000 +#define VERSAL_NET_IOU_SCNTR_SECURE 0xEC920000 + +#define CRL_APB_TIMESTAMP_REF_CTRL_CLKACT_BIT BIT(25) +#define IOU_SWITCH_CTRL_CLKACT_BIT BIT(25) +#define IOU_SWITCH_CTRL_DIVISOR0_SHIFT 8 +#define IOU_SCNTRS_CONTROL_EN 1 + +#define crlapb_base ((struct crlapb_regs *)VERSAL_NET_CRL_APB_BASEADDR) +#define iou_scntr_secure ((struct iou_scntrs_regs *)VERSAL_NET_IOU_SCNTR_SECURE) + #define PMC_TAP 0xF11A0000
#define PMC_TAP_IDCODE (PMC_TAP + 0) diff --git a/board/xilinx/versal-net/board.c b/board/xilinx/versal-net/board.c index 760031927f7c..5fb71107ddce 100644 --- a/board/xilinx/versal-net/board.c +++ b/board/xilinx/versal-net/board.c @@ -121,6 +121,47 @@ int board_early_init_f(void)
int board_early_init_r(void) { + u32 val; + + if (current_el() != 3) + return 0; + + debug("iou_switch ctrl div0 %x\n", + readl(&crlapb_base->iou_switch_ctrl)); + + writel(IOU_SWITCH_CTRL_CLKACT_BIT | + (CONFIG_IOU_SWITCH_DIVISOR0 << IOU_SWITCH_CTRL_DIVISOR0_SHIFT), + &crlapb_base->iou_switch_ctrl); + + /* Global timer init - Program time stamp reference clk */ + val = readl(&crlapb_base->timestamp_ref_ctrl); + val |= CRL_APB_TIMESTAMP_REF_CTRL_CLKACT_BIT; + writel(val, &crlapb_base->timestamp_ref_ctrl); + + debug("ref ctrl 0x%x\n", + readl(&crlapb_base->timestamp_ref_ctrl)); + + /* Clear reset of timestamp reg */ + writel(0, &crlapb_base->rst_timestamp); + + /* + * Program freq register in System counter and + * enable system counter. + */ + writel(CONFIG_COUNTER_FREQUENCY, + &iou_scntr_secure->base_frequency_id_register); + + debug("counter val 0x%x\n", + readl(&iou_scntr_secure->base_frequency_id_register)); + + writel(IOU_SCNTRS_CONTROL_EN, + &iou_scntr_secure->counter_control_register); + + debug("scntrs control 0x%x\n", + readl(&iou_scntr_secure->counter_control_register)); + debug("timer 0x%llx\n", get_ticks()); + debug("timer 0x%llx\n", get_ticks()); + return 0; }
diff --git a/configs/xilinx_versal_net_mini_defconfig b/configs/xilinx_versal_net_mini_defconfig index c5fa431a8c9d..5bad1791964f 100644 --- a/configs/xilinx_versal_net_mini_defconfig +++ b/configs/xilinx_versal_net_mini_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_SYS_CONFIG_NAME="xilinx_versal_net_mini" CONFIG_SYS_ICACHE_OFF=y # CONFIG_ARM64_CRC32 is not set +CONFIG_COUNTER_FREQUENCY=100000000 # CONFIG_ARM64_SUPPORT_AARCH32 is not set CONFIG_ARCH_VERSAL_NET=y CONFIG_TEXT_BASE=0xBBF10000 diff --git a/configs/xilinx_versal_net_virt_defconfig b/configs/xilinx_versal_net_virt_defconfig index 2fdf99f7cbbd..729c6ad4503b 100644 --- a/configs/xilinx_versal_net_virt_defconfig +++ b/configs/xilinx_versal_net_virt_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_COUNTER_FREQUENCY=100000000 CONFIG_POSITION_INDEPENDENT=y CONFIG_SYS_INIT_SP_BSS_OFFSET=1572864 CONFIG_ARCH_VERSAL_NET=y
- int "Timer clock frequency"
- default 0
- help
- hex "IOU switch divisor0"
- default 0x20
- help
- config SYS_MEM_RSVD_FOR_MMU bool "Reserve memory for MMU Table" help
- u32 reserved0[67];
- u32 cpu_r5_ctrl;
- u32 reserved;
- u32 iou_switch_ctrl; /* 0x114 */
- u32 reserved1[13];
- u32 timestamp_ref_ctrl; /* 0x14c */
- u32 reserved3[108];
- u32 rst_cpu_r5;
- u32 reserved2[17];
- u32 rst_timestamp; /* 0x348 */
- u32 counter_control_register; /* 0x0 */
- u32 reserved0[7];
- u32 base_frequency_id_register; /* 0x20 */
- u32 val;
- if (current_el() != 3)
- debug("iou_switch ctrl div0 %x\n",
- writel(IOU_SWITCH_CTRL_CLKACT_BIT |
- /* Global timer init - Program time stamp reference clk */
- val = readl(&crlapb_base->timestamp_ref_ctrl);
- val |= CRL_APB_TIMESTAMP_REF_CTRL_CLKACT_BIT;
- writel(val, &crlapb_base->timestamp_ref_ctrl);
- debug("ref ctrl 0x%x\n",
- /* Clear reset of timestamp reg */
- writel(0, &crlapb_base->rst_timestamp);
- writel(CONFIG_COUNTER_FREQUENCY,
- debug("counter val 0x%x\n",
- writel(IOU_SCNTRS_CONTROL_EN,
- debug("scntrs control 0x%x\n",
- debug("timer 0x%llx\n", get_ticks());
- return 0; }
applied. M
Michal Simek
