regression on Odroid U2: can't read from SD card
Dear maintainers,
As of commit 4a3ea75de4c5b3053eac326bf1c753ed65df8cb9 (somewhere between v2021.07 and v2021.10) U-Boot on my Odroid U2 can't read files from an SD card (despite being loaded from the SD card itself). During initialization loading the environment from the SD card fails (NOTE: the environment is zeroed):
U-Boot 2021.10-rc3-00055-g4a3ea75de4 (Jan 09 2023 - 10:29:52 +0100)
CPU: Exynos4412 @ 1 GHz Model: Odroid based on Exynos4412 Type: u3 DRAM: 2 GiB LDO20@VDDQ_EMMC_1.8V: set 1800000 uV; enabling LDO22@VDDQ_EMMC_2.8V: set 2800000 uV; enabling LDO21@TFLASH_2.8V: set 2800000 uV; enabling MMC: SAMSUNG SDHCI: 2, EXYNOS DWMMC: 0 Loading Environment from MMC... sdhci_send_command: Timeout for status update! mmc fail to send stop cmd *** Warning - !read failed, using default environment
Boot device: MMC(2) Net: No ethernet found. Hit any key to stop autoboot: 0
In the U-Boot shell, running `ls mmc` and `load mmc` fails:
Odroid # mmc list SAMSUNG SDHCI: 2 (SD) EXYNOS DWMMC: 0 Odroid # ls mmc 2:1 /boot sdhci_send_command: Timeout for status update! mmc fail to send stop cmd ** fs_devread read error - block Failed to mount ext2 filesystem... ** Unrecognized filesystem type ** Odroid # load mmc 2:1 0x41000000 /boot/vmlinuz-5.10.0-20-armmp sdhci_send_command: Timeout for status update! mmc fail to send stop cmd ** fs_devread read error - block Failed to mount ext2 filesystem... ** Unrecognized filesystem type ** Can't set block device
For reference, running the same commands using the parent of commit 4a3ea75d gives
U-Boot 2021.10-rc3-00054-g4412fd8ba2 (Jan 09 2023 - 12:22:54 +0100)
CPU: Exynos4412 @ 1 GHz Model: Odroid based on Exynos4412 Type: u3 DRAM: 2 GiB LDO20@VDDQ_EMMC_1.8V: set 1800000 uV; enabling LDO22@VDDQ_EMMC_2.8V: set 2800000 uV; enabling LDO21@TFLASH_2.8V: set 2800000 uV; enabling MMC: SAMSUNG SDHCI: 2, EXYNOS DWMMC: 0 Loading Environment from MMC... *** Warning - bad CRC, using default environment
Boot device: MMC(2) Net: No ethernet found. Hit any key to stop autoboot: 0 Odroid # mmc list SAMSUNG SDHCI: 2 (SD) EXYNOS DWMMC: 0 Odroid # ls mmc 2:1 /boot <DIR> 4096 . <DIR> 4096 .. 250461 config-5.10.0-20-armmp 4973056 vmlinuz-5.10.0-20-armmp <DIR> 4096 dtbs 83 System.map-5.10.0-20-armmp 22231585 initrd.img-5.10.0-20-armmp <SYM> 46 dtb-5.10.0-20-armmp <SYM> 46 dtb 3491 boot.scr Odroid # load mmc 2:1 0x41000000 /boot/vmlinuz-5.10.0-20-armmp 4973056 bytes read in 181 ms (26.2 MiB/s)
I'm building U-Boot using the default config for board `odroid` and boot the Odroid from an SD card with firmware (`bl1`, `bl2` and `tzsw`) from Hardkernel's clone of the u-boot repository [1]. There are no peripherals connected apart from the SD card and the serial console. Please let me know if you need more information.
Best, Joost
[1]: https://github.com/hardkernel/u-boot/tree/33e05ffb159141b640571e91470172d83a...
Joost van Zwieten
