[U-Boot] [PATCH v2] sh: add support for sh7757lcr board
The R0P7757LC0030RL board has SH7757, 256MB DDR3-SDRAM, SPI ROM, Ethernet, and more.
This patch supports the following functions: - 256MB DDR3-SDRAM - SPI ROM - Ethernet
Signed-off-by: Yoshihiro Shimoda yoshihiro.shimoda.uh@renesas.com --- about v2: - remove unnecessary comment in config.mk - move CONFIG_SYS_TEXT_BASE to include/configs/sh7757lcr.h - replace local parse function with eth_parse_enetaddr() - add NULL checking for malloc. - update copyright in u-boot.lds
arch/sh/include/asm/cpu_sh4.h | 2 + arch/sh/include/asm/cpu_sh7757.h | 263 +++++++++++++++ board/renesas/sh7757lcr/Makefile | 42 +++ board/renesas/sh7757lcr/config.mk | 26 ++ board/renesas/sh7757lcr/lowlevel_init.S | 558 +++++++++++++++++++++++++++++++ board/renesas/sh7757lcr/sh7757lcr.c | 432 ++++++++++++++++++++++++ board/renesas/sh7757lcr/spi-boot.c | 111 ++++++ board/renesas/sh7757lcr/u-boot.lds | 101 ++++++ boards.cfg | 1 + doc/README.sh7757lcr | 64 ++++ include/configs/sh7757lcr.h | 145 ++++++++ 11 files changed, 1745 insertions(+), 0 deletions(-) create mode 100644 arch/sh/include/asm/cpu_sh7757.h create mode 100644 board/renesas/sh7757lcr/Makefile create mode 100644 board/renesas/sh7757lcr/config.mk create mode 100644 board/renesas/sh7757lcr/lowlevel_init.S create mode 100644 board/renesas/sh7757lcr/sh7757lcr.c create mode 100644 board/renesas/sh7757lcr/spi-boot.c create mode 100644 board/renesas/sh7757lcr/u-boot.lds create mode 100644 doc/README.sh7757lcr create mode 100644 include/configs/sh7757lcr.h
diff --git a/arch/sh/include/asm/cpu_sh4.h b/arch/sh/include/asm/cpu_sh4.h index fdcebd6..9b29d3a 100644 --- a/arch/sh/include/asm/cpu_sh4.h +++ b/arch/sh/include/asm/cpu_sh4.h @@ -44,6 +44,8 @@ # include <asm/cpu_sh7722.h> #elif defined (CONFIG_CPU_SH7723) # include <asm/cpu_sh7723.h> +#elif defined (CONFIG_CPU_SH7757) +# include <asm/cpu_sh7757.h> #elif defined (CONFIG_CPU_SH7763) # include <asm/cpu_sh7763.h> #elif defined (CONFIG_CPU_SH7780) diff --git a/arch/sh/include/asm/cpu_sh7757.h b/arch/sh/include/asm/cpu_sh7757.h new file mode 100644 index 0000000..eb9ff5b --- /dev/null +++ b/arch/sh/include/asm/cpu_sh7757.h @@ -0,0 +1,263 @@ +/* + * Copyright (C) 2009 Renesas Solutions Corp. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + * + */ + +#ifndef _ASM_CPU_SH7757_H_ +#define _ASM_CPU_SH7757_H_ + +#define CCR 0xFF00001C +#define WTCNT 0xFFCC0000 +#define CCR_CACHE_INIT 0x0000090b +#define CACHE_OC_NUM_WAYS 1 + +/* Exception */ +#define EXPEVT 0xff000024 +#define INTEVT 0xff000028 + +/* Watchdog */ +#define WTCSR0 0xffcc0002 +#define WRSTCSR_R 0xffcc0003 +#define WRSTCSR_W 0xffcc0002 +#define WTCSR_PREFIX 0xa500 +#define WRSTCSR_PREFIX 0x6900 +#define WRSTCSR_WOVF_PREFIX 0x9600 + + +/* SCIF */ +#define SCIF0_BASE 0xfe4b0000 /* The real name is SCIF2 */ +#define SCIF1_BASE 0xfe4c0000 /* The real name is SCIF3 */ +#define SCIF2_BASE 0xfe4d0000 /* The real name is SCIF4 */ + +/* SerMux */ +#define SMR0 0xfe470000 + +/* TMU0 */ +#define TSTR 0xFE430004 +#define TOCR 0xFE430000 +#define TSTR0 0xFE430004 +#define TCOR0 0xFE430008 +#define TCNT0 0xFE43000C +#define TCR0 0xFE430010 +#define TCOR1 0xFE430014 +#define TCNT1 0xFE430018 +#define TCR1 0xFE43001C +#define TCOR2 0xFE430020 +#define TCNT2 0xFE430024 +#define TCR2 0xFE430028 +#define TCPR2 0xFE43002C + +/* BSC */ +#define BCR 0xFE801000 +#define CS0BCR 0xFF802000 +#define CS0WCR 0xFF802008 +#define CS4BCR 0xFF802040 +#define CS4WCR 0xFF802048 +#define CS5BCR 0xFF802050 +#define CS5WCR 0xFF802058 +#define CS6BCR 0xFF802060 +#define CS6WCR 0xFF802068 + +/* DDR3IF */ +#define DDR3IF_BASE 0xfe800000 +#define DBSTATE0 (DDR3IF_BASE + 0x0008) +#define DBSTATE1 (DDR3IF_BASE + 0x000c) +#define DBACEN (DDR3IF_BASE + 0x0010) +#define DBRFEN (DDR3IF_BASE + 0x0014) +#define DBCMD (DDR3IF_BASE + 0x0018) +#define DBWAIT (DDR3IF_BASE + 0x001c) +#define DBKIND (DDR3IF_BASE + 0x0020) +#define DBCONF (DDR3IF_BASE + 0x0024) +#define DBTR0 (DDR3IF_BASE + 0x0040) +#define DBTR1 (DDR3IF_BASE + 0x0044) +#define DBTR2 (DDR3IF_BASE + 0x0048) +#define DBTR3 (DDR3IF_BASE + 0x0050) +#define DBTR4 (DDR3IF_BASE + 0x0054) +#define DBTR5 (DDR3IF_BASE + 0x0058) +#define DBTR6 (DDR3IF_BASE + 0x005c) +#define DBTR7 (DDR3IF_BASE + 0x0060) +#define DBTR8 (DDR3IF_BASE + 0x0064) +#define DBTR9 (DDR3IF_BASE + 0x0068) +#define DBTR10 (DDR3IF_BASE + 0x006c) +#define DBTR11 (DDR3IF_BASE + 0x0070) +#define DBTR12 (DDR3IF_BASE + 0x0074) +#define DBTR13 (DDR3IF_BASE + 0x0078) +#define DBTR14 (DDR3IF_BASE + 0x007c) +#define DBTR15 (DDR3IF_BASE + 0x0080) +#define DBTR16 (DDR3IF_BASE + 0x0084) +#define DBTR17 (DDR3IF_BASE + 0x0088) +#define DBTR18 (DDR3IF_BASE + 0x008c) +#define DBTR19 (DDR3IF_BASE + 0x0090) +#define DBADJ0 (DDR3IF_BASE + 0x00c0) +#define DBADJ1 (DDR3IF_BASE + 0x00c4) +#define DBADJ2 (DDR3IF_BASE + 0x00c8) +#define DBADJ3 (DDR3IF_BASE + 0x00cc) +#define DBRFCNF0 (DDR3IF_BASE + 0x00e0) +#define DBRFCNF1 (DDR3IF_BASE + 0x00e4) +#define DBRFCNF2 (DDR3IF_BASE + 0x00e8) +#define DBCALCNF (DDR3IF_BASE + 0x00f4) +#define DBRNK0 (DDR3IF_BASE + 0x0100) +#define DBPDCNT0 (DDR3IF_BASE + 0x0200) +#define DBPDCNT1 (DDR3IF_BASE + 0x0204) +#define DBPDCNT2 (DDR3IF_BASE + 0x0208) +#define DBPDCNT3 (DDR3IF_BASE + 0x020c) +#define DBPDLCK (DDR3IF_BASE + 0x0280) +#define DBPDRGA (DDR3IF_BASE + 0x0290) +#define DBPDRGD (DDR3IF_BASE + 0x02a0) +#define DBBS0CNT0 (DDR3IF_BASE + 0x0300) +#define DBBS0CNT1 (DDR3IF_BASE + 0x0304) + +/* DDR-ECC */ +#define ECD_ECDEN 0xffc1012c +#define ECD_MCR 0xfe900010 +#define ECD_SPACER 0xfe900018 +#define ECD_INTSR 0xfe900024 + +/* GPIO */ +#define GPIO_BASE 0xffec0000 +#define PACR (GPIO_BASE + 0x0000) +#define PBCR (GPIO_BASE + 0x0002) +#define PCCR (GPIO_BASE + 0x0004) +#define PDCR (GPIO_BASE + 0x0006) +#define PECR (GPIO_BASE + 0x0008) +#define PFCR (GPIO_BASE + 0x000a) +#define PGCR (GPIO_BASE + 0x000c) +#define PHCR (GPIO_BASE + 0x000e) +#define PICR (GPIO_BASE + 0x0010) +#define PJCR (GPIO_BASE + 0x0012) +#define PKCR (GPIO_BASE + 0x0014) +#define PLCR (GPIO_BASE + 0x0016) +#define PMCR (GPIO_BASE + 0x0018) +#define PNCR (GPIO_BASE + 0x001a) +#define POCR (GPIO_BASE + 0x001c) +#define PPCR (GPIO_BASE + 0x001e) +#define PQCR (GPIO_BASE + 0x0020) +#define PRCR (GPIO_BASE + 0x0022) +#define PSCR (GPIO_BASE + 0x0024) +#define PTCR (GPIO_BASE + 0x0026) +#define PUCR (GPIO_BASE + 0x0028) +#define PVCR (GPIO_BASE + 0x002a) +#define PWCR (GPIO_BASE + 0x002c) +#define PXCR (GPIO_BASE + 0x002e) +#define PYCR (GPIO_BASE + 0x0030) +#define PZCR (GPIO_BASE + 0x0032) +#define PADR (GPIO_BASE + 0x0034) +#define PBDR (GPIO_BASE + 0x0036) +#define PCDR (GPIO_BASE + 0x0038) +#define PDDR (GPIO_BASE + 0x003a) +#define PEDR (GPIO_BASE + 0x003c) +#define PFDR (GPIO_BASE + 0x003e) +#define PGDR (GPIO_BASE + 0x0040) +#define PHDR (GPIO_BASE + 0x0042) +#define PIDR (GPIO_BASE + 0x0044) +#define PJDR (GPIO_BASE + 0x0046) +#define PKDR (GPIO_BASE + 0x0048) +#define PLDR (GPIO_BASE + 0x004a) +#define PMDR (GPIO_BASE + 0x004c) +#define PNDR (GPIO_BASE + 0x004e) +#define PODR (GPIO_BASE + 0x0050) +#define PPDR (GPIO_BASE + 0x0052) +#define PQDR (GPIO_BASE + 0x0054) +#define PRDR (GPIO_BASE + 0x0056) +#define PSDR (GPIO_BASE + 0x0058) +#define PTDR (GPIO_BASE + 0x005a) +#define PUDR (GPIO_BASE + 0x005c) +#define PVDR (GPIO_BASE + 0x005e) +#define PWDR (GPIO_BASE + 0x0060) +#define PXDR (GPIO_BASE + 0x0062) +#define PYDR (GPIO_BASE + 0x0064) +#define PZDR (GPIO_BASE + 0x0066) +#define PSEL0 (GPIO_BASE + 0x0070) +#define PSEL1 (GPIO_BASE + 0x0072) +#define PSEL2 (GPIO_BASE + 0x0074) +#define PSEL3 (GPIO_BASE + 0x0076) +#define PSEL4 (GPIO_BASE + 0x0078) +#define PSEL5 (GPIO_BASE + 0x007a) +#define PSEL6 (GPIO_BASE + 0x007c) +#define PSEL7 (GPIO_BASE + 0x0082) +#define PSEL8 (GPIO_BASE + 0x0084) + +/* GETHER */ +#define GETHER_GBECONT 0xffc10100 +#define GBECONT_RMII1 0x00020000 +#define GBECONT_RMII0 0x00010000 + +/* USB1 */ +#define USB1_PORT1SEL 0xfe4f2000 +#define USB1_EHCIDATAC 0xfe4fe018 +#define USB1_OHCIDATAC 0xfe4fe118 +#define USB0_PHY_RESET 0xfe5f0000 +#define USB0_PHY_PORTSEL 0xfe5f000a +#define USB0_SUSPMODE 0xfe450102 +#define USB1_SUSPMODE 0xfe4f0102 + +/* GCTRL */ +#define GCTRL_BASE 0xffc10000 +#define GCTRL_WPROTECT (GCTRL_BASE + 0x0000) +#define GCTRL_GPLLDIV (GCTRL_BASE + 0x0004) +#define GCTRL_GRACR3 (GCTRL_BASE + 0x000c) +#define GCTRL_FCNTCR1 (GCTRL_BASE + 0x0020) +#define GCTRL_FCNTCR2 (GCTRL_BASE + 0x0024) +#define GCTRL_MSTPCR2 (GCTRL_BASE + 0x0028) +#define GCTRL_GPLL1DIV (GCTRL_BASE + 0x0030) +#define GCTRL_VCOMPSEL (GCTRL_BASE + 0x0034) +#define GCTRL_SPIBOOTCAN (GCTRL_BASE + 0x1000) + +/* PCIe */ +#define PCIE_BASE 0xffca0000 +#define PCIE_PCICONF14 (PCIE_BASE + 0x003c) +#define PCIE_MSICAP0 (PCIE_BASE + 0x0050) +#define PCIE_LAD0 (PCIE_BASE + 0x1260) +#define PCIE_LADMSK0 (PCIE_BASE + 0x1264) +#define PCIE_LAD1 (PCIE_BASE + 0x1268) +#define PCIE_LADMSK1 (PCIE_BASE + 0x126c) +#define PCIE_LAD2 (PCIE_BASE + 0x1270) +#define PCIE_LADMSK2 (PCIE_BASE + 0x1274) +#define PCIE_LAD3 (PCIE_BASE + 0x1278) +#define PCIE_LADMSK3 (PCIE_BASE + 0x127c) +#define PCIE_LAD4 (PCIE_BASE + 0x1280) +#define PCIE_LADMSK4 (PCIE_BASE + 0x1284) +#define PCIE_LAD5 (PCIE_BASE + 0x1288) +#define PCIE_LADMSK5 (PCIE_BASE + 0x128c) +#define PCIE_BARMAP0 (PCIE_BASE + 0x1420) +#define PCIE_PBICTL3 (PCIE_BASE + 0x142C) +#define PCIE_PBICTL2 (PCIE_BASE + 0x1470) +#define PCIE_BSTCTL0 (PCIE_BASE + 0x1604) +#define PCIE_ENDICTL0 (PCIE_BASE + 0x160c) +#define PCIE_ENDICTL1 (PCIE_BASE + 0x1610) + +/* PCIe-Bridge */ +#define PCIEBRG_BASE 0xffd60000 +#define PCIEBRG_CTRL_H8S (PCIEBRG_BASE + 0x00) +#define PCIEBRG_CP_ADDR (PCIEBRG_BASE + 0x10) +#define PCIEBRG_CP_DATA (PCIEBRG_BASE + 0x14) +#define PCIEBRG_CP_CTRL (PCIEBRG_BASE + 0x18) + +/* CPU version */ +#define CCN_PRR 0xff000044 +#define prr_mask(_val) ((_val >> 4) & 0xff) +#define PRR_SH7757_B0 0x10 +#define PRR_SH7757_C0 0x11 + +#define is_sh7757_b0(_val) \ +({ \ + int __ret = prr_mask(__raw_readl(CCN_PRR)) == PRR_SH7757_B0; \ + __ret; \ +}) + +#endif /* _ASM_CPU_SH7757_H_ */ diff --git a/board/renesas/sh7757lcr/Makefile b/board/renesas/sh7757lcr/Makefile new file mode 100644 index 0000000..22106fd --- /dev/null +++ b/board/renesas/sh7757lcr/Makefile @@ -0,0 +1,42 @@ +# +# Copyright (C) 2011 Yoshihiro Shimoda shimoda.yoshihiro@renesas.com +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +COBJS := sh7757lcr.o spi-boot.o +SOBJS := lowlevel_init.o + +$(LIB): $(obj).depend $(COBJS) $(SOBJS) + $(call cmd_link_o_target, $(COBJS) $(SOBJS)) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak $(obj).depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/renesas/sh7757lcr/config.mk b/board/renesas/sh7757lcr/config.mk new file mode 100644 index 0000000..1037cc2 --- /dev/null +++ b/board/renesas/sh7757lcr/config.mk @@ -0,0 +1,26 @@ +# +# Copyright (C) 2007 +# Nobuhiro Iwamatsu iwamatsu@nigauri.org +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA + +# +# CONFIG_SYS_TEXT_BASE refers to image _after_ relocation. +# +# NOTE: Must match value used in u-boot.lds (in this directory). +# +LDSCRIPT = $(OBJTREE)/board/$(BOARDDIR)/u-boot.lds + diff --git a/board/renesas/sh7757lcr/lowlevel_init.S b/board/renesas/sh7757lcr/lowlevel_init.S new file mode 100644 index 0000000..3df2e0f --- /dev/null +++ b/board/renesas/sh7757lcr/lowlevel_init.S @@ -0,0 +1,558 @@ +/* + * Copyright (C) 2011 Renesas Solutions Corp. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <config.h> +#include <version.h> +#include <asm/processor.h> +#include <asm/macro.h> + +.macro or32, addr, data + mov.l \addr, r1 + mov.l \data, r0 + mov.l @r1, r2 + or r2, r0 + mov.l r0, @r1 +.endm + +.macro wait_DBCMD + mov.l DBWAIT_A, r0 + mov.l @r0, r1 +.endm + + .global lowlevel_init + .section .spiboot1.text + .align 2 + +lowlevel_init: + + /*------- GPIO -------*/ + write8 PGDR_A, PGDR_D /* eMMC power off */ + + write16 PACR_A, PACR_D + write16 PBCR_A, PBCR_D + write16 PCCR_A, PCCR_D + write16 PDCR_A, PDCR_D + write16 PECR_A, PECR_D + write16 PFCR_A, PFCR_D + write16 PGCR_A, PGCR_D + write16 PHCR_A, PHCR_D + write16 PICR_A, PICR_D + write16 PJCR_A, PJCR_D + write16 PKCR_A, PKCR_D + write16 PLCR_A, PLCR_D + write16 PMCR_A, PMCR_D + write16 PNCR_A, PNCR_D + write16 POCR_A, POCR_D + write16 PQCR_A, PQCR_D + write16 PRCR_A, PRCR_D + write16 PSCR_A, PSCR_D + write16 PTCR_A, PTCR_D + write16 PUCR_A, PUCR_D + write16 PVCR_A, PVCR_D + write16 PWCR_A, PWCR_D + write16 PXCR_A, PXCR_D + write16 PYCR_A, PYCR_D + write16 PZCR_A, PZCR_D + write16 PSEL0_A, PSEL0_D + write16 PSEL1_A, PSEL1_D + write16 PSEL2_A, PSEL2_D + write16 PSEL3_A, PSEL3_D + write16 PSEL4_A, PSEL4_D + write16 PSEL5_A, PSEL5_D + write16 PSEL6_A, PSEL6_D + write16 PSEL7_A, PSEL7_D + write16 PSEL8_A, PSEL8_D + + bra exit_gpio + nop + + .align 4 + +/*------- GPIO -------*/ +PGDR_A: .long PGDR +PACR_A: .long PACR +PBCR_A: .long PBCR +PCCR_A: .long PCCR +PDCR_A: .long PDCR +PECR_A: .long PECR +PFCR_A: .long PFCR +PGCR_A: .long PGCR +PHCR_A: .long PHCR +PICR_A: .long PICR +PJCR_A: .long PJCR +PKCR_A: .long PKCR +PLCR_A: .long PLCR +PMCR_A: .long PMCR +PNCR_A: .long PNCR +POCR_A: .long POCR +PQCR_A: .long PQCR +PRCR_A: .long PRCR +PSCR_A: .long PSCR +PTCR_A: .long PTCR +PUCR_A: .long PUCR +PVCR_A: .long PVCR +PWCR_A: .long PWCR +PXCR_A: .long PXCR +PYCR_A: .long PYCR +PZCR_A: .long PZCR +PSEL0_A: .long PSEL0 +PSEL1_A: .long PSEL1 +PSEL2_A: .long PSEL2 +PSEL3_A: .long PSEL3 +PSEL4_A: .long PSEL4 +PSEL5_A: .long PSEL5 +PSEL6_A: .long PSEL6 +PSEL7_A: .long PSEL7 +PSEL8_A: .long PSEL8 + +PGDR_D: .long 0x80 +PACR_D: .long 0x0000 +PBCR_D: .long 0x0001 +PCCR_D: .long 0x0000 +PDCR_D: .long 0x0000 +PECR_D: .long 0x0000 +PFCR_D: .long 0x0000 +PGCR_D: .long 0x0000 +PHCR_D: .long 0x0000 +PICR_D: .long 0x0000 +PJCR_D: .long 0x0000 +PKCR_D: .long 0x0003 +PLCR_D: .long 0x0000 +PMCR_D: .long 0x0000 +PNCR_D: .long 0x0000 +POCR_D: .long 0x0000 +PQCR_D: .long 0xc000 +PRCR_D: .long 0x0000 +PSCR_D: .long 0x0000 +PTCR_D: .long 0x0000 +#if defined(CONFIG_SH7757_OFFSET_SPI) +PUCR_D: .long 0x0055 +#else +PUCR_D: .long 0x0000 +#endif +PVCR_D: .long 0x0000 +PWCR_D: .long 0x0000 +PXCR_D: .long 0x0000 +PYCR_D: .long 0x0000 +PZCR_D: .long 0x0000 +PSEL0_D: .long 0xfe00 +PSEL1_D: .long 0x0000 +PSEL2_D: .long 0x3000 +PSEL3_D: .long 0xff00 +PSEL4_D: .long 0x771f +PSEL5_D: .long 0x0ffc +PSEL6_D: .long 0x00ff +PSEL7_D: .long 0xfc00 +PSEL8_D: .long 0x0000 + + .align 2 + +exit_gpio: + mov #0, r14 + mova 2f, r0 + mov.l PC_MASK, r1 + tst r0, r1 + bf 2f + + bra exit_pmb + nop + + .align 2 + +/* If CPU runs on SDRAM, PC is 0x8???????. */ +PC_MASK: .long 0x20000000 + +2: + mov #1, r14 + + mov.l EXPEVT_A, r0 + mov.l @r0, r0 + mov.l EXPEVT_POWER_ON_RESET, r1 + cmp/eq r0, r1 + bt 1f + + /* + * If EXPEVT value is manual reset or tlb multipul-hit, + * initialization of DDR3IF is not necessary. + */ + bra exit_ddr + nop + +1: + /* For Core Reset */ + mov.l DBACEN_A, r0 + mov.l @r0, r0 + cmp/eq #0, r0 + bt 3f + + /* + * If DBACEN == 1(DBSC was already enabled), we have to avoid the + * initialization of DDR3-SDRAM. + */ + bra exit_ddr + nop + +3: + /*------- DDR3IF -------*/ + /* oscillation stabilization time */ + wait_timer WAIT_OSC_TIME + + /* step 3 */ + write32 DBCMD_A, DBCMD_RSTL_VAL + wait_timer WAIT_30US + + /* step 4 */ + write32 DBCMD_A, DBCMD_PDEN_VAL + + /* step 5 */ + write32 DBKIND_A, DBKIND_D + + /* step 6 */ + write32 DBCONF_A, DBCONF_D + write32 DBTR0_A, DBTR0_D + write32 DBTR1_A, DBTR1_D + write32 DBTR2_A, DBTR2_D + write32 DBTR3_A, DBTR3_D + write32 DBTR4_A, DBTR4_D + write32 DBTR5_A, DBTR5_D + write32 DBTR6_A, DBTR6_D + write32 DBTR7_A, DBTR7_D + write32 DBTR8_A, DBTR8_D + write32 DBTR9_A, DBTR9_D + write32 DBTR10_A, DBTR10_D + write32 DBTR11_A, DBTR11_D + write32 DBTR12_A, DBTR12_D + write32 DBTR13_A, DBTR13_D + write32 DBTR14_A, DBTR14_D + write32 DBTR15_A, DBTR15_D + write32 DBTR16_A, DBTR16_D + write32 DBTR17_A, DBTR17_D + write32 DBTR18_A, DBTR18_D + write32 DBTR19_A, DBTR19_D + write32 DBRNK0_A, DBRNK0_D + + /* step 7 */ + write32 DBPDCNT3_A, DBPDCNT3_D + + /* step 8 */ + write32 DBPDCNT1_A, DBPDCNT1_D + write32 DBPDCNT2_A, DBPDCNT2_D + write32 DBPDLCK_A, DBPDLCK_D + write32 DBPDRGA_A, DBPDRGA_D + write32 DBPDRGD_A, DBPDRGD_D + + /* step 9 */ + wait_timer WAIT_30US + + /* step 10 */ + write32 DBPDCNT0_A, DBPDCNT0_D + + /* step 11 */ + wait_timer WAIT_30US + wait_timer WAIT_30US + + /* step 12 */ + write32 DBCMD_A, DBCMD_WAIT_VAL + wait_DBCMD + + /* step 13 */ + write32 DBCMD_A, DBCMD_RSTH_VAL + wait_DBCMD + + /* step 14 */ + write32 DBCMD_A, DBCMD_WAIT_VAL + write32 DBCMD_A, DBCMD_WAIT_VAL + write32 DBCMD_A, DBCMD_WAIT_VAL + write32 DBCMD_A, DBCMD_WAIT_VAL + + /* step 15 */ + write32 DBCMD_A, DBCMD_PDXT_VAL + + /* step 16 */ + write32 DBCMD_A, DBCMD_MRS2_VAL + + /* step 17 */ + write32 DBCMD_A, DBCMD_MRS3_VAL + + /* step 18 */ + write32 DBCMD_A, DBCMD_MRS1_VAL + + /* step 19 */ + write32 DBCMD_A, DBCMD_MRS0_VAL + + /* step 20 */ + write32 DBCMD_A, DBCMD_ZQCL_VAL + + write32 DBCMD_A, DBCMD_REF_VAL + write32 DBCMD_A, DBCMD_REF_VAL + wait_DBCMD + + /* step 21 */ + write32 DBADJ0_A, DBADJ0_D + write32 DBADJ1_A, DBADJ1_D + write32 DBADJ2_A, DBADJ2_D + + /* step 22 */ + write32 DBRFCNF0_A, DBRFCNF0_D + write32 DBRFCNF1_A, DBRFCNF1_D + write32 DBRFCNF2_A, DBRFCNF2_D + + /* step 23 */ + write32 DBCALCNF_A, DBCALCNF_D + + /* step 24 */ + write32 DBRFEN_A, DBRFEN_D + write32 DBCMD_A, DBCMD_SRXT_VAL + + /* step 25 */ + write32 DBACEN_A, DBACEN_D + + /* step 26 */ + wait_DBCMD + + /* enable DDR-ECC */ + write32 ECD_ECDEN_A, ECD_ECDEN_D + write32 ECD_INTSR_A, ECD_INTSR_D + write32 ECD_SPACER_A, ECD_SPACER_D + write32 ECD_MCR_A, ECD_MCR_D + + bra exit_ddr + nop + + .align 4 + +EXPEVT_A: .long EXPEVT +EXPEVT_POWER_ON_RESET: .long 0x00000000 + +/*------- DDR3IF -------*/ +DBCMD_A: .long DBCMD +DBKIND_A: .long DBKIND +DBCONF_A: .long DBCONF +DBTR0_A: .long DBTR0 +DBTR1_A: .long DBTR1 +DBTR2_A: .long DBTR2 +DBTR3_A: .long DBTR3 +DBTR4_A: .long DBTR4 +DBTR5_A: .long DBTR5 +DBTR6_A: .long DBTR6 +DBTR7_A: .long DBTR7 +DBTR8_A: .long DBTR8 +DBTR9_A: .long DBTR9 +DBTR10_A: .long DBTR10 +DBTR11_A: .long DBTR11 +DBTR12_A: .long DBTR12 +DBTR13_A: .long DBTR13 +DBTR14_A: .long DBTR14 +DBTR15_A: .long DBTR15 +DBTR16_A: .long DBTR16 +DBTR17_A: .long DBTR17 +DBTR18_A: .long DBTR18 +DBTR19_A: .long DBTR19 +DBRNK0_A: .long DBRNK0 +DBPDCNT0_A: .long DBPDCNT0 +DBPDCNT1_A: .long DBPDCNT1 +DBPDCNT2_A: .long DBPDCNT2 +DBPDCNT3_A: .long DBPDCNT3 +DBPDLCK_A: .long DBPDLCK +DBPDRGA_A: .long DBPDRGA +DBPDRGD_A: .long DBPDRGD +DBADJ0_A: .long DBADJ0 +DBADJ1_A: .long DBADJ1 +DBADJ2_A: .long DBADJ2 +DBRFCNF0_A: .long DBRFCNF0 +DBRFCNF1_A: .long DBRFCNF1 +DBRFCNF2_A: .long DBRFCNF2 +DBCALCNF_A: .long DBCALCNF +DBRFEN_A: .long DBRFEN +DBACEN_A: .long DBACEN +DBWAIT_A: .long DBWAIT + +WAIT_OSC_TIME: .long 6000 +WAIT_30US: .long 13333 + +DBCMD_RSTL_VAL: .long 0x20000000 +DBCMD_PDEN_VAL: .long 0x1000d73c +DBCMD_WAIT_VAL: .long 0x0000d73c +DBCMD_RSTH_VAL: .long 0x2100d73c +DBCMD_PDXT_VAL: .long 0x110000c8 +DBCMD_MRS0_VAL: .long 0x28000930 +DBCMD_MRS1_VAL: .long 0x29000004 +DBCMD_MRS2_VAL: .long 0x2a000008 +DBCMD_MRS3_VAL: .long 0x2b000000 +DBCMD_ZQCL_VAL: .long 0x03000200 +DBCMD_REF_VAL: .long 0x0c000000 +DBCMD_SRXT_VAL: .long 0x19000000 +DBKIND_D: .long 0x00000007 +DBCONF_D: .long 0x0f030a01 +DBTR0_D: .long 0x00000007 +DBTR1_D: .long 0x00000006 +DBTR2_D: .long 0x00000000 +DBTR3_D: .long 0x00000007 +DBTR4_D: .long 0x00070007 +DBTR5_D: .long 0x0000001b +DBTR6_D: .long 0x00000014 +DBTR7_D: .long 0x00000005 +DBTR8_D: .long 0x00000015 +DBTR9_D: .long 0x00000006 +DBTR10_D: .long 0x00000008 +DBTR11_D: .long 0x00000007 +DBTR12_D: .long 0x0000000e +DBTR13_D: .long 0x00000056 +DBTR14_D: .long 0x00000006 +DBTR15_D: .long 0x00000004 +DBTR16_D: .long 0x00150002 +DBTR17_D: .long 0x000c0017 +DBTR18_D: .long 0x00000200 +DBTR19_D: .long 0x00000040 +DBRNK0_D: .long 0x00000001 +DBPDCNT0_D: .long 0x00000001 +DBPDCNT1_D: .long 0x00000001 +DBPDCNT2_D: .long 0x00000000 +DBPDCNT3_D: .long 0x00004010 +DBPDLCK_D: .long 0x0000a55a +DBPDRGA_D: .long 0x00000028 +DBPDRGD_D: .long 0x00017100 + +DBADJ0_D: .long 0x00000000 +DBADJ1_D: .long 0x00000000 +DBADJ2_D: .long 0x18061806 +DBRFCNF0_D: .long 0x000001ff +DBRFCNF1_D: .long 0x08001000 +DBRFCNF2_D: .long 0x00000000 +DBCALCNF_D: .long 0x0000ffff +DBRFEN_D: .long 0x00000001 +DBACEN_D: .long 0x00000001 + +/*------- DDR-ECC -------*/ +ECD_ECDEN_A: .long ECD_ECDEN +ECD_ECDEN_D: .long 0x00000001 +ECD_INTSR_A: .long ECD_INTSR +ECD_INTSR_D: .long 0xffffffff +ECD_SPACER_A: .long ECD_SPACER +ECD_SPACER_D: .long SH7757LCR_SDRAM_ECC_SETTING +ECD_MCR_A: .long ECD_MCR +ECD_MCR_D: .long 0x00000001 + + .align 2 +exit_ddr: + +#if defined(CONFIG_SH_32BIT) + /*------- set PMB -------*/ + write32 PASCR_A, PASCR_29BIT_D + write32 MMUCR_A, MMUCR_D + + /***************************************************************** + * ent virt phys v sz c wt + * 0 0xa0000000 0x00000000 1 128M 0 1 + * 1 0xa8000000 0x48000000 1 128M 0 1 + * 5 0x88000000 0x48000000 1 128M 1 1 + */ + write32 PMB_ADDR_SPIBOOT_A, PMB_ADDR_SPIBOOT_D + write32 PMB_DATA_SPIBOOT_A, PMB_DATA_SPIBOOT_D + write32 PMB_ADDR_DDR_C1_A, PMB_ADDR_DDR_C1_D + write32 PMB_DATA_DDR_C1_A, PMB_DATA_DDR_C1_D + write32 PMB_ADDR_DDR_N1_A, PMB_ADDR_DDR_N1_D + write32 PMB_DATA_DDR_N1_A, PMB_DATA_DDR_N1_D + + write32 PMB_ADDR_ENTRY2, PMB_ADDR_NOT_USE_D + write32 PMB_ADDR_ENTRY3, PMB_ADDR_NOT_USE_D + write32 PMB_ADDR_ENTRY4, PMB_ADDR_NOT_USE_D + write32 PMB_ADDR_ENTRY6, PMB_ADDR_NOT_USE_D + write32 PMB_ADDR_ENTRY7, PMB_ADDR_NOT_USE_D + write32 PMB_ADDR_ENTRY8, PMB_ADDR_NOT_USE_D + write32 PMB_ADDR_ENTRY9, PMB_ADDR_NOT_USE_D + write32 PMB_ADDR_ENTRY10, PMB_ADDR_NOT_USE_D + write32 PMB_ADDR_ENTRY11, PMB_ADDR_NOT_USE_D + write32 PMB_ADDR_ENTRY12, PMB_ADDR_NOT_USE_D + write32 PMB_ADDR_ENTRY13, PMB_ADDR_NOT_USE_D + write32 PMB_ADDR_ENTRY14, PMB_ADDR_NOT_USE_D + write32 PMB_ADDR_ENTRY15, PMB_ADDR_NOT_USE_D + + write32 PASCR_A, PASCR_INIT + mov.l DUMMY_ADDR, r0 + icbi @r0 +#endif /* if defined(CONFIG_SH_32BIT) */ + +exit_pmb: + /* CPU is running on ILRAM? */ + mov r14, r0 + tst #1, r0 + bt 1f + + mov.l _bss_start, r15 + mov.l _spiboot_main, r0 +100: bsrf r0 + nop + + .align 2 +_spiboot_main: .long (spiboot_main - (100b + 4)) +_bss_start: .long bss_start + +1: + + write32 CCR_A, CCR_D + + rts + nop + + .align 4 + +#if defined(CONFIG_SH_32BIT) +/*------- set PMB -------*/ +PMB_ADDR_SPIBOOT_A: .long PMB_ADDR_BASE(0) +PMB_ADDR_DDR_N1_A: .long PMB_ADDR_BASE(1) +PMB_ADDR_DDR_C1_A: .long PMB_ADDR_BASE(5) +PMB_ADDR_ENTRY2: .long PMB_ADDR_BASE(2) +PMB_ADDR_ENTRY3: .long PMB_ADDR_BASE(3) +PMB_ADDR_ENTRY4: .long PMB_ADDR_BASE(4) +PMB_ADDR_ENTRY6: .long PMB_ADDR_BASE(6) +PMB_ADDR_ENTRY7: .long PMB_ADDR_BASE(7) +PMB_ADDR_ENTRY8: .long PMB_ADDR_BASE(8) +PMB_ADDR_ENTRY9: .long PMB_ADDR_BASE(9) +PMB_ADDR_ENTRY10: .long PMB_ADDR_BASE(10) +PMB_ADDR_ENTRY11: .long PMB_ADDR_BASE(11) +PMB_ADDR_ENTRY12: .long PMB_ADDR_BASE(12) +PMB_ADDR_ENTRY13: .long PMB_ADDR_BASE(13) +PMB_ADDR_ENTRY14: .long PMB_ADDR_BASE(14) +PMB_ADDR_ENTRY15: .long PMB_ADDR_BASE(15) + +PMB_ADDR_SPIBOOT_D: .long mk_pmb_addr_val(0xa0) +PMB_ADDR_DDR_C1_D: .long mk_pmb_addr_val(0x88) +PMB_ADDR_DDR_N1_D: .long mk_pmb_addr_val(0xa8) +PMB_ADDR_NOT_USE_D: .long 0x00000000 + +PMB_DATA_SPIBOOT_A: .long PMB_DATA_BASE(0) +PMB_DATA_DDR_N1_A: .long PMB_DATA_BASE(1) +PMB_DATA_DDR_C1_A: .long PMB_DATA_BASE(5) + +/* ppn ub v s1 s0 c wt */ +PMB_DATA_SPIBOOT_D: .long mk_pmb_data_val(0x00, 0, 1, 1, 0, 0, 1) +PMB_DATA_DDR_C1_D: .long mk_pmb_data_val(0x48, 0, 1, 1, 0, 1, 1) +PMB_DATA_DDR_N1_D: .long mk_pmb_data_val(0x48, 1, 1, 1, 0, 0, 1) + +PASCR_A: .long 0xff000070 +DUMMY_ADDR: .long 0xa0000000 +PASCR_29BIT_D: .long 0x00000000 +PASCR_INIT: .long 0x80000080 +MMUCR_A: .long 0xff000010 +MMUCR_D: .long 0x00000004 /* clear ITLB */ +#endif /* CONFIG_SH_32BIT */ + +CCR_A: .long CCR +CCR_D: .long CCR_CACHE_INIT diff --git a/board/renesas/sh7757lcr/sh7757lcr.c b/board/renesas/sh7757lcr/sh7757lcr.c new file mode 100644 index 0000000..d4f54e5 --- /dev/null +++ b/board/renesas/sh7757lcr/sh7757lcr.c @@ -0,0 +1,432 @@ +/* + * Copyright (C) 2011 Renesas Solutions Corp. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <malloc.h> +#include <asm/processor.h> +#include <asm/io.h> +#include <spi_flash.h> + +int checkboard(void) +{ + puts("BOARD: R0P7757LC0030RL board\n"); + + return 0; +} + +static void init_gctrl(void) +{ + unsigned long graofst; + + graofst = (SH7757LCR_SDRAM_PHYS_TOP + SH7757LCR_GRA_OFFSET) >> 24; + writel(graofst | 0x20000f00, GCTRL_GRACR3); +} + +static int init_pcie_bridge_from_spi(void *buf, size_t size) +{ + struct spi_flash *spi; + int ret; + unsigned long pcie_addr; + + spi = spi_flash_probe(0, 0, 1000000, SPI_MODE_3); + if (!spi) { + printf("%s: spi_flash probe error.\n", __func__); + return 1; + } + + if (is_sh7757_b0()) + pcie_addr = SH7757LCR_PCIEBRG_ADDR_B0; + else + pcie_addr = SH7757LCR_PCIEBRG_ADDR; + + ret = spi_flash_read(spi, pcie_addr, size, buf); + if (ret) { + printf("%s: spi_flash read error.\n", __func__); + spi_flash_free(spi); + return 1; + } + spi_flash_free(spi); + + return 0; +} + +static void init_pcie_bridge(void) +{ + int i; + unsigned char *data; + unsigned short tmp; + unsigned long pcie_size; + + if (!(readw(PCIEBRG_CTRL_H8S) & 0x0001)) + return; + + if (is_sh7757_b0()) + pcie_size = SH7757LCR_PCIEBRG_SIZE_B0; + else + pcie_size = SH7757LCR_PCIEBRG_SIZE; + + data = malloc(pcie_size); + if (!data) { + printf("%s: malloc error.\n", __func__); + return; + } + if (init_pcie_bridge_from_spi(data, pcie_size)) { + free(data); + return; + } + + if (data[0] == 0xff && data[1] == 0xff && data[2] == 0xff && + data[3] == 0xff) { + free(data); + printf("%s: skipped initialization\n", __func__); + return; + } + + writew(0xa501, PCIEBRG_CTRL_H8S); /* reset */ + writew(0x0000, PCIEBRG_CP_CTRL); + writew(0x0000, PCIEBRG_CP_ADDR); + + for (i = 0; i < pcie_size; i += 2) { + tmp = (data[i] << 8) | data[i + 1]; + writew(tmp, PCIEBRG_CP_DATA); + } + + writew(0xa500, PCIEBRG_CTRL_H8S); /* start */ + if (!is_sh7757_b0()) + writel(0x00000001, PCIE_PBICTL3); + + free(data); +} + +static void init_usb_phy(void) +{ + writew(0x0100, USB0_PHY_RESET); /* set reset */ + /* port0 = USB0, port1 = USB1 */ + writew(0x0002, USB0_PHY_PORTSEL); + writel(0x0001, USB1_PORT1SEL); /* port1 = Host */ + writew(0x0111, USB0_PHY_RESET); /* clear reset */ + + writew(0x4000, USB0_SUSPMODE); + writew(0x4000, USB1_SUSPMODE); + +#if defined(__LITTLE_ENDIAN) + writel(0x00000000, USB1_EHCIDATAC); + writel(0x00000000, USB1_OHCIDATAC); +#endif +} + +static void set_mac_to_sh_eth_register(int channel, char *mac_string) +{ +#define SH_ETH_BASE 0xfef00000 +#define MALR(port) (SH_ETH_BASE + 0x800 * (port) + 0x01c8) +#define MAHR(port) (SH_ETH_BASE + 0x800 * (port) + 0x01c0) + unsigned char mac[6]; + unsigned long val; + + eth_parse_enetaddr(mac_string, mac); + + val = (mac[0] << 24) | (mac[1] << 16) | (mac[2] << 8) | mac[3]; + writel(val, MAHR(channel)); + val = (mac[4] << 8) | mac[5]; + writel(val, MALR(channel)); +} + +static void set_mac_to_sh_giga_eth_register(int channel, char *mac_string) +{ +#define SH_GIGA_ETH_BASE 0xfee00000 +#define GIGA_MALR(port) (SH_GIGA_ETH_BASE + 0x800 * (port) + 0x05c8) +#define GIGA_MAHR(port) (SH_GIGA_ETH_BASE + 0x800 * (port) + 0x05c0) + + unsigned char mac[6]; + unsigned long val; + + eth_parse_enetaddr(mac_string, mac); + + val = (mac[0] << 24) | (mac[1] << 16) | (mac[2] << 8) | mac[3]; + writel(val, GIGA_MAHR(channel)); + val = (mac[4] << 8) | mac[5]; + writel(val, GIGA_MALR(channel)); +} + +/***************************************************************** + * This PMB must be set on this timing. The lowlevel_init is run on + * Area 0(phys 0x00000000), so we have to map it. + * + * The new PMB table is following: + * ent virt phys v sz c wt + * 0 0xa0000000 0x40000000 1 128M 0 1 + * 1 0xa8000000 0x48000000 1 128M 0 1 + * 2 0xb0000000 0x50000000 1 128M 0 1 + * 3 0xb8000000 0x58000000 1 128M 0 1 + * 4 0x80000000 0x40000000 1 128M 1 1 + * 5 0x88000000 0x48000000 1 128M 1 1 + * 6 0x90000000 0x50000000 1 128M 1 1 + * 7 0x98000000 0x58000000 1 128M 1 1 + */ +static void set_pmb_on_board_init(void) +{ + /* clear ITLB */ + writel(0x00000004, 0xff000010); + + /* delete PMB for SPIBOOT */ + writel(0, PMB_ADDR_BASE(0)); + writel(0, PMB_DATA_BASE(0)); + + /* add PMB for SDRAM(0x40000000 - 0x47ffffff) */ + /* ppn ub v s1 s0 c wt */ + writel(mk_pmb_addr_val(0xa0), PMB_ADDR_BASE(0)); + writel(mk_pmb_data_val(0x40, 1, 1, 1, 0, 0, 1), PMB_DATA_BASE(0)); + writel(mk_pmb_addr_val(0xb0), PMB_ADDR_BASE(2)); + writel(mk_pmb_data_val(0x50, 1, 1, 1, 0, 0, 1), PMB_DATA_BASE(2)); + writel(mk_pmb_addr_val(0xb8), PMB_ADDR_BASE(3)); + writel(mk_pmb_data_val(0x58, 1, 1, 1, 0, 0, 1), PMB_DATA_BASE(3)); + writel(mk_pmb_addr_val(0x80), PMB_ADDR_BASE(4)); + writel(mk_pmb_data_val(0x40, 0, 1, 1, 0, 1, 1), PMB_DATA_BASE(4)); + writel(mk_pmb_addr_val(0x90), PMB_ADDR_BASE(6)); + writel(mk_pmb_data_val(0x50, 0, 1, 1, 0, 1, 1), PMB_DATA_BASE(6)); + writel(mk_pmb_addr_val(0x98), PMB_ADDR_BASE(7)); + writel(mk_pmb_data_val(0x58, 0, 1, 1, 0, 1, 1), PMB_DATA_BASE(7)); +} + +int board_init(void) +{ + set_pmb_on_board_init(); + + /* enable RMII's MDIO (disable GRMII's MDIO) */ + writel(0x00030000, GETHER_GBECONT); + + init_gctrl(); + init_usb_phy(); + + return 0; +} + +int dram_init(void) +{ + DECLARE_GLOBAL_DATA_PTR; + + gd->bd->bi_memstart = CONFIG_SYS_SDRAM_BASE; + gd->bd->bi_memsize = CONFIG_SYS_SDRAM_SIZE; + printf("DRAM: %dMB\n", CONFIG_SYS_SDRAM_SIZE / (1024 * 1024)); + printf(" Physical address\n"); + printf(" 0x%08x - 0x%08x : Accessible Space as ECC Area\n", + SH7757LCR_SDRAM_PHYS_TOP, + SH7757LCR_SDRAM_PHYS_TOP + SH7757LCR_SDRAM_SIZE - 1); + printf(" 0x%08x - 0x%08x : No Access Area\n", + SH7757LCR_SDRAM_PHYS_TOP + SH7757LCR_SDRAM_SIZE, + SH7757LCR_SDRAM_PHYS_TOP + SH7757LCR_SDRAM_SIZE * 2 - 1); + printf(" 0x%08x - 0x%08x : Non-ECC Area for DVC/AVC\n", + SH7757LCR_SDRAM_PHYS_TOP + SH7757LCR_SDRAM_ECC_SETTING * 2, + SH7757LCR_SDRAM_PHYS_TOP + SH7757LCR_SDRAM_ECC_SETTING * 2 + + SH7757LCR_SDRAM_DVC_SIZE - 1); + printf(" 0x%08x - 0x%08x : Non-ECC Area for G200eR2\n", + SH7757LCR_SDRAM_PHYS_TOP + SH7757LCR_GRA_OFFSET, + SH7757LCR_SDRAM_PHYS_TOP + SH7757LCR_GRA_OFFSET + 0x00ffffff); + + return 0; +} + +static int get_sh_eth_mac_raw(unsigned char *buf, int size) +{ + struct spi_flash *spi; + int ret; + + spi = spi_flash_probe(0, 0, 1000000, SPI_MODE_3); + if (spi == NULL) { + printf("%s: spi_flash probe error.\n", __func__); + return 1; + } + + ret = spi_flash_read(spi, SH7757LCR_ETHERNET_MAC_BASE, size, buf); + if (ret) { + printf("%s: spi_flash read error.\n", __func__); + spi_flash_free(spi); + return 1; + } + spi_flash_free(spi); +} + +static int get_sh_eth_mac(int channel, char *mac_string, unsigned char *buf) +{ + struct spi_flash *spi; + int ret; + + memcpy(mac_string, &buf[channel * (SH7757LCR_ETHERNET_MAC_SIZE + 1)], + SH7757LCR_ETHERNET_MAC_SIZE); + mac_string[SH7757LCR_ETHERNET_MAC_SIZE] = 0x00; /* terminate */ + + return 0; +} + +static void init_ethernet_mac(void) +{ + char mac_string[64]; + char env_string[64]; + int i; + unsigned char *buf; + + buf = malloc(256); + if (!buf) { + printf("%s: malloc error.\n", __func__); + return; + } + get_sh_eth_mac_raw(buf, 256); + + /* Fast Ethernet */ + for (i = 0; i < SH7757LCR_ETHERNET_NUM_CH; i++) { + get_sh_eth_mac(i, mac_string, buf); + if (i == 0) + setenv("ethaddr", mac_string); + else { + sprintf(env_string, "eth%daddr", i); + setenv(env_string, mac_string); + } + + set_mac_to_sh_eth_register(i, mac_string); + } + + /* Gigabit Ethernet */ + for (i = 0; i < SH7757LCR_GIGA_ETHERNET_NUM_CH; i++) { + get_sh_eth_mac(i + SH7757LCR_ETHERNET_NUM_CH, mac_string, buf); + sprintf(env_string, "eth%daddr", i + SH7757LCR_ETHERNET_NUM_CH); + setenv(env_string, mac_string); + + set_mac_to_sh_giga_eth_register(i, mac_string); + } + + free(buf); +} + +static void init_pcie(void) +{ + writel(0x00000ff2, PCIE_LADMSK0); + writel(0x00000001, PCIE_BARMAP0); + writel(0xffcaa000, PCIE_LAD0); + writel(0x00030000, PCIE_ENDICTL0); + writel(0x00000003, PCIE_ENDICTL1); + writel(0x00000004, PCIE_PBICTL2); +} + +static void finish_spiboot(void) +{ + /* + * SH7757 B0 does not use LBSC. + * So if we set SPIBOOTCAN to 1, SH7757 can not access Area0. + * This setting is not cleared by manual reset, So we have to set it + * to 0. + */ + writel(0x00000000, GCTRL_SPIBOOTCAN); +} + +int board_late_init(void) +{ + init_ethernet_mac(); + init_pcie_bridge(); + init_pcie(); + finish_spiboot(); + + return 0; +} + +int do_sh_g200(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) +{ + unsigned long graofst; + + writel(0xfedcba98, GCTRL_WPROTECT); + graofst = (SH7757LCR_SDRAM_PHYS_TOP + SH7757LCR_GRA_OFFSET) >> 24; + writel(graofst | 0xa0000f00, GCTRL_GRACR3); + + return 0; +} + +U_BOOT_CMD( + sh_g200, 1, 1, do_sh_g200, + "enable sh-g200", + "enable SH-G200 bus (disable PCIe-G200)" +); + +int do_write_mac(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) +{ + int i, ret; + char mac_string[256]; + struct spi_flash *spi; + unsigned char *buf; + + if (argc != 5) { + buf = malloc(256); + if (!buf) { + printf("%s: malloc error.\n", __func__); + return 1; + } + + get_sh_eth_mac_raw(buf, 256); + + /* print current MAC address */ + for (i = 0; i < 4; i++) { + get_sh_eth_mac(i, mac_string, buf); + if (i < 2) + printf(" ETHERC ch%d = %s\n", i, mac_string); + else + printf("GETHERC ch%d = %s\n", i-2, mac_string); + } + free(buf); + return 0; + } + + /* new setting */ + memset(mac_string, 0xff, sizeof(mac_string)); + sprintf(mac_string, "%s\t%s\t%s\t%s", + argv[1], argv[2], argv[3], argv[4]); + + /* write MAC data to SPI rom */ + spi = spi_flash_probe(0, 0, 1000000, SPI_MODE_3); + if (!spi) { + printf("%s: spi_flash probe error.\n", __func__); + return 1; + } + + ret = spi_flash_erase(spi, SH7757LCR_ETHERNET_MAC_BASE_SPI, + SH7757LCR_SPI_SECTOR_SIZE); + if (ret) { + printf("%s: spi_flash erase error.\n", __func__); + return 1; + } + + ret = spi_flash_write(spi, SH7757LCR_ETHERNET_MAC_BASE_SPI, + sizeof(mac_string), mac_string); + if (ret) { + printf("%s: spi_flash write error.\n", __func__); + spi_flash_free(spi); + return 1; + } + spi_flash_free(spi); + + puts("The writing of the MAC address to SPI ROM was completed.\n"); + + return 0; +} + +U_BOOT_CMD( + write_mac, 5, 1, do_write_mac, + "write MAC address for ETHERC/GETHERC", + "[ETHERC ch0] [ETHERC ch1] [GETHERC ch0] [GETHERC ch1]\n" +); diff --git a/board/renesas/sh7757lcr/spi-boot.c b/board/renesas/sh7757lcr/spi-boot.c new file mode 100644 index 0000000..d4c24c9 --- /dev/null +++ b/board/renesas/sh7757lcr/spi-boot.c @@ -0,0 +1,111 @@ +/* + * Copyright (C) 2011 Renesas Solutions Corp. + * + * This file is subject to the terms and conditions of the GNU Lesser + * General Public License. See the file "COPYING.LIB" in the main + * directory of this archive for more details. + */ + +#include <common.h> + +#define CONFIG_RAM_BOOT_PHYS 0x4ef80000 +#if defined(CONFIG_SH7757_OFFSET_SPI) +#define CONFIG_SPI_ADDR 0x00010000 +#else +#define CONFIG_SPI_ADDR 0x00000000 +#endif +#define CONFIG_SPI_LENGTH 0x00030000 +#define CONFIG_RAM_BOOT 0x8ef80000 + +#define SPIWDMADR 0xFE001018 +#define SPIWDMCNTR 0xFE001020 +#define SPIDMCOR 0xFE001028 +#define SPIDMINTSR 0xFE001188 +#define SPIDMINTMR 0xFE001190 + +#define SPIDMINTSR_DMEND 0x00000004 + +#define TBR 0xFE002000 +#define RBR 0xFE002000 + +#define CR1 0xFE002008 +#define CR2 0xFE002010 +#define CR3 0xFE002018 +#define CR4 0xFE002020 + +/* CR1 */ +#define SPI_TBE 0x80 +#define SPI_TBF 0x40 +#define SPI_RBE 0x20 +#define SPI_RBF 0x10 +#define SPI_PFONRD 0x08 +#define SPI_SSDB 0x04 +#define SPI_SSD 0x02 +#define SPI_SSA 0x01 + +/* CR2 */ +#define SPI_RSTF 0x80 +#define SPI_LOOPBK 0x40 +#define SPI_CPOL 0x20 +#define SPI_CPHA 0x10 +#define SPI_L1M0 0x08 + +/* CR4 */ +#define SPI_TBEI 0x80 +#define SPI_TBFI 0x40 +#define SPI_RBEI 0x20 +#define SPI_RBFI 0x10 +#define SPI_SSS 0x01 + +#define spi_write(val, addr) (*(volatile unsigned long *)(addr)) = val +#define spi_read(addr) (*(volatile unsigned long *)(addr)) + +/* M25P80 */ +#define M25_READ 0x03 + +#define __uses_spiboot2 __attribute__((section(".spiboot2.text"))) +static void __uses_spiboot2 spi_reset(void) +{ + spi_write(0xfe, CR1); + + spi_write(0, SPIDMCOR); + spi_write(0x00, CR1); + + spi_write(spi_read(CR2) | SPI_RSTF, CR2); /* fifo reset */ + spi_write(spi_read(CR2) & ~SPI_RSTF, CR2); +} + +static void __uses_spiboot2 spi_read_flash(void *buf, unsigned long addr, + unsigned long len) +{ + volatile unsigned long i; + + spi_write(M25_READ, TBR); + spi_write((addr >> 16) & 0xFF, TBR); + spi_write((addr >> 8) & 0xFF, TBR); + spi_write(addr & 0xFF, TBR); + + spi_write(SPIDMINTSR_DMEND, SPIDMINTSR); + spi_write(buf, SPIWDMADR); + spi_write(len & 0xFFFFFFE0, SPIWDMCNTR); + spi_write(1, SPIDMCOR); + + spi_write(0xff, CR3); + spi_write(spi_read(CR1) | SPI_SSDB, CR1); + spi_write(spi_read(CR1) | SPI_SSA, CR1); + + while (!(spi_read(SPIDMINTSR) & SPIDMINTSR_DMEND)) + ; +} + +void __uses_spiboot2 spiboot_main(void) +{ + void (*_start)(void) = CONFIG_SYS_TEXT_BASE; + + spi_reset(); + spi_read_flash((void *)CONFIG_RAM_BOOT_PHYS, CONFIG_SPI_ADDR, + CONFIG_SPI_LENGTH); + + _start(); +} + diff --git a/board/renesas/sh7757lcr/u-boot.lds b/board/renesas/sh7757lcr/u-boot.lds new file mode 100644 index 0000000..2971481 --- /dev/null +++ b/board/renesas/sh7757lcr/u-boot.lds @@ -0,0 +1,101 @@ +/* + * Copyright (C) 2007 + * Nobuhiro Iwamatsu iwamatsu@nigauri.org + * + * Copyright (C) 2011 + * Yoshihiro Shimoda shimoda.yoshihiro@renesas.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +OUTPUT_FORMAT("elf32-sh-linux", "elf32-sh-linux", "elf32-sh-linux") +OUTPUT_ARCH(sh) +ENTRY(_start) + +SECTIONS +{ + /* + * entry and reloct_dst will be provided via ldflags + */ + . = .; + + PROVIDE (_ftext = .); + PROVIDE (_fcode = .); + PROVIDE (_start = .); + + .text : + { + arch/sh/cpu/sh4/start.o (.text) + *(.spiboot1.text) + *(.spiboot2.text) + . = ALIGN(8192); + common/env_embedded.o (.ppcenv) + . = ALIGN(8192); + common/env_embedded.o (.ppcenvr) + . = ALIGN(8192); + *(.text) + . = ALIGN(4); + } =0xFF + PROVIDE (_ecode = .); + .rodata : + { + *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) + . = ALIGN(4); + } + PROVIDE (_etext = .); + + + PROVIDE (_fdata = .); + .data : + { + *(.data) + . = ALIGN(4); + } + PROVIDE (_edata = .); + + PROVIDE (_fgot = .); + .got : + { + *(.got) + . = ALIGN(4); + } + PROVIDE (_egot = .); + + PROVIDE (__u_boot_cmd_start = .); + .u_boot_cmd : + { + *(.u_boot_cmd) + . = ALIGN(4); + } + PROVIDE (__u_boot_cmd_end = .); + + PROVIDE (reloc_dst_end = .); + /* _reloc_dst_end = .; */ + + PROVIDE (bss_start = .); + PROVIDE (__bss_start = .); + .bss (NOLOAD) : + { + *(.bss) + . = ALIGN(4); + } + PROVIDE (bss_end = .); + + PROVIDE (_end = .); +} diff --git a/boards.cfg b/boards.cfg index 0574bb2..417ed1d 100644 --- a/boards.cfg +++ b/boards.cfg @@ -752,6 +752,7 @@ ms7750se sh sh4 ms7750se - ap325rxa sh sh4 ap325rxa renesas - r2dplus sh sh4 r2dplus renesas - r7780mp sh sh4 r7780mp renesas - +sh7757lcr sh sh4 sh7757lcr renesas - sh7763rdp sh sh4 sh7763rdp renesas - sh7785lcr sh sh4 sh7785lcr renesas - sh7785lcr_32bit sh sh4 sh7785lcr renesas - sh7785lcr:SH_32BIT=1 diff --git a/doc/README.sh7757lcr b/doc/README.sh7757lcr new file mode 100644 index 0000000..cae14e0 --- /dev/null +++ b/doc/README.sh7757lcr @@ -0,0 +1,64 @@ +======================================== +Renesas R0P7757LC0030RL board +======================================== + +This board specification: +========================= + +The R0P7757LC0030RL(board config name:sh7757lcr) has the following device: + + - SH7757 (SH-4A) + - DDR3-SDRAM 256MB (with ECC) + - SPI ROM 8MB + - 2D Graphic controller + - Ethernet controller + + +configuration for This board: +============================= + +You can select the configuration as follows: + + - make sh7785lcr_config + + +This board specific command: +============================ + +This board has the following its specific command: + + - sh_g200 + - write_mac + + +1. sh_g200 + +If we run this command, SH4 can control the G200. +The default setting is that SH4 cannot control the G200. + + +2. write_mac + +You can write MAC address to SPI ROM. + + Usage 1) Write MAC address + + write_mac [ETHERC ch0] [ETHERC ch1] [GETHERC ch0] [GETHERC ch1] + + For example) + => write_mac 00:00:87:6c:21:80 00:00:87:6c:21:81 00:00:87:6c:21:82 00:00:87:6c:21:83 + *) We have to input the command as a single line + (without carriage return) + *) We have to reset after input the command. + + Usage 2) Show current data + + write_mac + + For example) + => write_mac + ETHERC ch0 = 00:00:87:6c:21:80 + ETHERC ch1 = 00:00:87:6c:21:81 + GETHERC ch0 = 00:00:87:6c:21:82 + GETHERC ch1 = 00:00:87:6c:21:83 + diff --git a/include/configs/sh7757lcr.h b/include/configs/sh7757lcr.h new file mode 100644 index 0000000..e064cc1 --- /dev/null +++ b/include/configs/sh7757lcr.h @@ -0,0 +1,145 @@ +/* + * Configuation settings for the sh7757lcr board + * + * Copyright (C) 2011 Renesas Solutions Corp. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __SH7757LCR_H +#define __SH7757LCR_H + +#undef DEBUG +#define CONFIG_SH 1 +#define CONFIG_SH4A 1 +#define CONFIG_SH_32BIT 1 +#define CONFIG_CPU_SH7757 1 +#define CONFIG_SH7757LCR 1 + +#define CONFIG_SYS_TEXT_BASE 0x8ef80000 + +#define CONFIG_CMD_MEMORY +#define CONFIG_CMD_NET +#define CONFIG_CMD_PING +#define CONFIG_CMD_NFS +#define CONFIG_CMD_DFL +#define CONFIG_CMD_SDRAM +#define CONFIG_CMD_SF +#define CONFIG_CMD_RUN +#define CONFIG_CMD_SAVEENV +#define CONFIG_CMD_MD5SUM +#define CONFIG_MD5 +#define CONFIG_CMD_LOADS + +#define CONFIG_BAUDRATE 115200 +#define CONFIG_BOOTDELAY 3 +#define CONFIG_BOOTARGS "console=ttySC2,115200 root=/dev/nfs ip=dhcp" + +#define CONFIG_VERSION_VARIABLE +#undef CONFIG_SHOW_BOOT_PROGRESS + +/* MEMORY */ +#define SH7757LCR_SDRAM_BASE (0x80000000) +#define SH7757LCR_SDRAM_SIZE (240 * 1024 * 1024) +#define SH7757LCR_SDRAM_ECC_SETTING 0x0f000000 /* 240MByte */ +#define SH7757LCR_SDRAM_DVC_SIZE (16 * 1024 * 1024) + +#define CONFIG_SYS_LONGHELP +#define CONFIG_SYS_PROMPT "=> " +#define CONFIG_SYS_CBSIZE 256 +#define CONFIG_SYS_PBSIZE 256 +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_BARGSIZE 512 +#define CONFIG_SYS_BAUDRATE_TABLE { 115200 } + +/* SCIF */ +#define CONFIG_SCIF_CONSOLE 1 +#define CONFIG_CONS_SCIF2 1 +#undef CONFIG_SYS_CONSOLE_INFO_QUIET +#undef CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE +#undef CONFIG_SYS_CONSOLE_ENV_OVERWRITE + +#define CONFIG_SYS_MEMTEST_START (SH7757LCR_SDRAM_BASE) +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + \ + 224 * 1024 * 1024) +#undef CONFIG_SYS_ALT_MEMTEST +#undef CONFIG_SYS_MEMTEST_SCRATCH +#undef CONFIG_SYS_LOADS_BAUD_CHANGE + +#define CONFIG_SYS_SDRAM_BASE (SH7757LCR_SDRAM_BASE) +#define CONFIG_SYS_SDRAM_SIZE (SH7757LCR_SDRAM_SIZE) +#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + \ + (128 + 16) * 1024 * 1024) + +#define CONFIG_SYS_MONITOR_BASE 0x00000000 +#define CONFIG_SYS_MONITOR_LEN (256 * 1024) +#define CONFIG_SYS_MALLOC_LEN (4 * 1024 * 1024) +#define CONFIG_SYS_BOOTMAPSZ (8 * 1024 * 1024) + +/* FLASH */ +#define CONFIG_SYS_NO_FLASH + +/* Ether */ +#define CONFIG_NET_MULTI 1 +#define CONFIG_SH_ETHER 1 +#define CONFIG_SH_ETHER_USE_PORT 0 +#define CONFIG_SH_ETHER_PHY_ADDR 1 +#define CONFIG_SH_ETHER_CACHE_WRITEBACK 1 + +#define SH7757LCR_ETHERNET_MAC_BASE_SPI 0x000b0000 +#define SH7757LCR_SPI_SECTOR_SIZE (64 * 1024) +#define SH7757LCR_ETHERNET_MAC_BASE SH7757LCR_ETHERNET_MAC_BASE_SPI +#define SH7757LCR_ETHERNET_MAC_SIZE 17 +#define SH7757LCR_ETHERNET_NUM_CH 2 +#define BOARD_LATE_INIT 1 + +/* Gigabit Ether */ +#define SH7757LCR_GIGA_ETHERNET_NUM_CH 2 + +/* SPI */ +#define CONFIG_SH_SPI 1 +#define CONFIG_SH_SPI_BASE 0xfe002000 +#define CONFIG_SPI_FLASH +#define CONFIG_SPI_FLASH_STMICRO 1 + +/* SH7757 board */ +#define SH7757LCR_SDRAM_PHYS_TOP 0x40000000 +#define SH7757LCR_GRA_OFFSET 0x1f000000 +#define SH7757LCR_PCIEBRG_ADDR_B0 0x000a0000 +#define SH7757LCR_PCIEBRG_SIZE_B0 (64 * 1024) +#define SH7757LCR_PCIEBRG_ADDR 0x00090000 +#define SH7757LCR_PCIEBRG_SIZE (96 * 1024) + +/* ENV setting */ +#define CONFIG_ENV_IS_EMBEDDED +#define CONFIG_ENV_IS_IN_SPI_FLASH +#define CONFIG_ENV_SECT_SIZE (64 * 1024) +#define CONFIG_ENV_ADDR (0x00080000) +#define CONFIG_ENV_OFFSET (CONFIG_ENV_ADDR) +#define CONFIG_ENV_OVERWRITE 1 +#define CONFIG_ENV_SIZE (CONFIG_ENV_SECT_SIZE) +#define CONFIG_ENV_SIZE_REDUND (CONFIG_ENV_SECT_SIZE) +#define CONFIG_EXTRA_ENV_SETTINGS \ + "netboot=bootp; bootm\0" + +/* Board Clock */ +#define CONFIG_SYS_CLK_FREQ 48000000 +#define CONFIG_SYS_TMU_CLK_DIV 4 +#define CONFIG_SYS_HZ 1000 +#endif /* __SH7757LCR_H */
Yoshihiro Shimoda
