[U-Boot-Users] [PATCH 1/2] [new uImage] ppc: Fix ftd_blob variable init when processing raw blob
Set fdt_blob variable before its value is printed out.
Signed-off-by: Marian Balakowicz m8@semihalf.com ---
lib_ppc/bootm.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/lib_ppc/bootm.c b/lib_ppc/bootm.c index 2901607..b24a064 100644 --- a/lib_ppc/bootm.c +++ b/lib_ppc/bootm.c @@ -626,9 +626,9 @@ static int boot_get_fdt (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[], /* * FDT blob */ + fdt_blob = (char *)fdt_addr; debug ("* fdt: raw FDT blob\n"); printf ("## Flattened Device Tree blob at %08lx\n", fdt_blob); - fdt_blob = (char *)fdt_addr; } break; default:
Before new uImage code was merged, bootm code allowed for the kernel image to get overwritten during decompresion. new uImage introduced a check for image overwrites and refused to boot the image that got overwritten. This patch restores the old behavior. It also adds a warning when the image overwriten is a multi-image file, because in such case accessing componentes other than the first one will fail.
common/cmd_bootm.c | 37 ++++++++++++++++++++++++++----------- common/image.c | 2 +- include/image.h | 3 ++- lib_arm/bootm.c | 2 +- lib_avr32/bootm.c | 2 +- lib_blackfin/bootm.c | 2 +- lib_m68k/bootm.c | 2 +- lib_microblaze/bootm.c | 2 +- lib_mips/bootm.c | 2 +- lib_nios2/bootm.c | 2 +- lib_ppc/bootm.c | 4 ++-- lib_sh/bootm.c | 2 +- 12 files changed, 39 insertions(+), 23 deletions(-)
diff --git a/common/cmd_bootm.c b/common/cmd_bootm.c index 9e5ce4b..3a0c83d 100644 --- a/common/cmd_bootm.c +++ b/common/cmd_bootm.c @@ -286,9 +286,16 @@ int do_bootm (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) debug ("image_start = 0x%lX, image_end = 0x%lx\n", image_start, image_end); debug ("load_start = 0x%lx, load_end = 0x%lx\n", load_start, load_end);
- puts ("ERROR: image overwritten - must RESET the board to recover.\n"); - show_boot_progress (-113); - do_reset (cmdtp, flag, argc, argv); + if (images.legacy_hdr_valid) { + if (image_get_type (&images.legacy_hdr_os_copy) == IH_TYPE_MULTI) + puts ("WARNING: legacy format multi component " + "image overwritten\n"); + } else { + puts ("ERROR: new format image overwritten - " + "must RESET the board to recover\n"); + show_boot_progress (-113); + do_reset (cmdtp, flag, argc, argv); + } }
show_boot_progress (8); @@ -533,9 +540,17 @@ static void *boot_get_kernel (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[] show_boot_progress (-5); return NULL; } + + /* + * copy image header to allow for image overwrites during kernel + * decompression. + */ + memmove (&images->legacy_hdr_os_copy, hdr, sizeof(image_header_t)); + + /* save pointer to image header */ images->legacy_hdr_os = hdr; - images->legacy_hdr_valid = 1;
+ images->legacy_hdr_valid = 1; show_boot_progress (6); break; #if defined(CONFIG_FIT) @@ -890,7 +905,7 @@ static void do_bootm_netbsd (cmd_tbl_t *cmdtp, int flag, * address of the original image header. */ os_hdr = NULL; - if (image_check_type (hdr, IH_TYPE_MULTI)) { + if (image_check_type (&images->legacy_hdr_os_copy, IH_TYPE_MULTI)) { image_multi_getimg (hdr, 1, &kernel_data, &kernel_len); if (kernel_len) os_hdr = hdr; @@ -947,7 +962,7 @@ static void do_bootm_lynxkdi (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[], bootm_headers_t *images) { - image_header_t *hdr = images->legacy_hdr_os; + image_header_t *hdr = &images->legacy_hdr_os_copy;
#if defined(CONFIG_FIT) if (!images->legacy_hdr_valid) { @@ -964,7 +979,7 @@ static void do_bootm_rtems (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[], bootm_headers_t *images) { - image_header_t *hdr = images->legacy_hdr_os; + image_header_t *hdr = &images->legacy_hdr_os_copy; void (*entry_point)(bd_t *);
#if defined(CONFIG_FIT) @@ -994,10 +1009,10 @@ static void do_bootm_vxworks (cmd_tbl_t *cmdtp, int flag, bootm_headers_t *images) { char str[80]; - image_header_t *hdr = images->legacy_hdr_os; + image_header_t *hdr = &images->legacy_hdr_os_copy;
#if defined(CONFIG_FIT) - if (hdr == NULL) { + if (!images->legacy_hdr_valid) { fit_unsupported_reset ("VxWorks"); do_reset (cmdtp, flag, argc, argv); } @@ -1014,7 +1029,7 @@ static void do_bootm_qnxelf(cmd_tbl_t *cmdtp, int flag, { char *local_args[2]; char str[16]; - image_header_t *hdr = images->legacy_hdr_os; + image_header_t *hdr = &images->legacy_hdr_os_copy;
#if defined(CONFIG_FIT) if (!images->legacy_hdr_valid) { @@ -1041,7 +1056,7 @@ static void do_bootm_artos (cmd_tbl_t *cmdtp, int flag, int i, j, nxt, len, envno, envsz; bd_t *kbd; void (*entry)(bd_t *bd, char *cmdline, char **fwenv, ulong top); - image_header_t *hdr = images->legacy_hdr_os; + image_header_t *hdr = &images->legacy_hdr_os_copy;
#if defined(CONFIG_FIT) if (!images->legacy_hdr_valid) { diff --git a/common/image.c b/common/image.c index f04826a..e302dda 100644 --- a/common/image.c +++ b/common/image.c @@ -983,7 +983,7 @@ int boot_get_ramdisk (int argc, char *argv[], bootm_headers_t *images, #endif /* CONFIG_B2 || CONFIG_EVB4510 || CONFIG_ARMADILLO */
} else if (images->legacy_hdr_valid && - image_check_type (images->legacy_hdr_os, IH_TYPE_MULTI)) { + image_check_type (&images->legacy_hdr_os_copy, IH_TYPE_MULTI)) { /* * Now check if we have a legacy mult-component image, * get second entry data start address and len. diff --git a/include/image.h b/include/image.h index 36143e2..8c3ad95 100644 --- a/include/image.h +++ b/include/image.h @@ -197,7 +197,8 @@ typedef struct bootm_headers { * then boot_get_ramdisk() and get_fdt() will attempt to get * data from second and third component accordingly. */ - image_header_t *legacy_hdr_os; + image_header_t *legacy_hdr_os; /* image header pointer */ + image_header_t legacy_hdr_os_copy; /* header copy */ ulong legacy_hdr_valid;
#if defined(CONFIG_FIT) diff --git a/lib_arm/bootm.c b/lib_arm/bootm.c index c5e8cb3..6b4a807 100644 --- a/lib_arm/bootm.c +++ b/lib_arm/bootm.c @@ -78,7 +78,7 @@ void do_bootm_linux (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[],
/* find kernel entry point */ if (images->legacy_hdr_valid) { - ep = image_get_ep (images->legacy_hdr_os); + ep = image_get_ep (&images->legacy_hdr_os_copy); #if defined(CONFIG_FIT) } else if (images->fit_uname_os) { ret = fit_image_get_entry (images->fit_hdr_os, diff --git a/lib_avr32/bootm.c b/lib_avr32/bootm.c index b1c651a..5ff8c79 100644 --- a/lib_avr32/bootm.c +++ b/lib_avr32/bootm.c @@ -185,7 +185,7 @@ void do_bootm_linux(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[],
/* find kernel entry point */ if (images->legacy_hdr_valid) { - ep = image_get_ep (images->legacy_hdr_os); + ep = image_get_ep (&images->legacy_hdr_os_copy); #if defined(CONFIG_FIT) } else if (images->fit_uname_os) { ret = fit_image_get_entry (images->fit_hdr_os, diff --git a/lib_blackfin/bootm.c b/lib_blackfin/bootm.c index bea11ed..ef4b112 100644 --- a/lib_blackfin/bootm.c +++ b/lib_blackfin/bootm.c @@ -49,7 +49,7 @@ void do_bootm_linux(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[],
/* find kernel entry point */ if (images->legacy_hdr_valid) { - ep = image_get_ep (images->legacy_hdr_os); + ep = image_get_ep (&images->legacy_hdr_os_copy); #if defined(CONFIG_FIT) } else if (images->fit_uname_os) { int ret = fit_image_get_entry (images->fit_hdr_os, diff --git a/lib_m68k/bootm.c b/lib_m68k/bootm.c index 6f49c31..61f1a36 100644 --- a/lib_m68k/bootm.c +++ b/lib_m68k/bootm.c @@ -96,7 +96,7 @@ void do_bootm_linux(cmd_tbl_t * cmdtp, int flag,
/* find kernel entry point */ if (images->legacy_hdr_valid) { - ep = image_get_ep (images->legacy_hdr_os); + ep = image_get_ep (&images->legacy_hdr_os_copy); #if defined(CONFIG_FIT) } else if (images->fit_uname_os) { ret = fit_image_get_entry (images->fit_hdr_os, diff --git a/lib_microblaze/bootm.c b/lib_microblaze/bootm.c index fab4a54..30a03ef 100644 --- a/lib_microblaze/bootm.c +++ b/lib_microblaze/bootm.c @@ -44,7 +44,7 @@ void do_bootm_linux (cmd_tbl_t * cmdtp, int flag, int argc, char *argv[],
/* find kernel entry point */ if (images->legacy_hdr_valid) { - ep = image_get_ep (images->legacy_hdr_os); + ep = image_get_ep (&images->legacy_hdr_os_copy); #if defined(CONFIG_FIT) } else if (images->fit_uname_os) { int ret = fit_image_get_entry (images->fit_hdr_os, diff --git a/lib_mips/bootm.c b/lib_mips/bootm.c index e4c139e..f813fc5 100644 --- a/lib_mips/bootm.c +++ b/lib_mips/bootm.c @@ -57,7 +57,7 @@ void do_bootm_linux (cmd_tbl_t * cmdtp, int flag, int argc, char *argv[],
/* find kernel entry point */ if (images->legacy_hdr_valid) { - ep = image_get_ep (images->legacy_hdr_os); + ep = image_get_ep (&images->legacy_hdr_os_copy); #if defined(CONFIG_FIT) } else if (images->fit_uname_os) { ret = fit_image_get_entry (images->fit_hdr_os, diff --git a/lib_nios2/bootm.c b/lib_nios2/bootm.c index 0c89e96..01f4e87 100644 --- a/lib_nios2/bootm.c +++ b/lib_nios2/bootm.c @@ -34,7 +34,7 @@ void do_bootm_linux(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[],
/* find kernel entry point */ if (images->legacy_hdr_valid) { - ep = image_get_ep (images->legacy_hdr_os); + ep = image_get_ep (&images->legacy_hdr_os_copy); #if defined(CONFIG_FIT) } else if (images->fit_uname_os) { int ret = fit_image_get_entry (images->fit_hdr_os, diff --git a/lib_ppc/bootm.c b/lib_ppc/bootm.c index b24a064..0328bad 100644 --- a/lib_ppc/bootm.c +++ b/lib_ppc/bootm.c @@ -146,7 +146,7 @@ do_bootm_linux(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[],
/* find kernel entry point */ if (images->legacy_hdr_valid) { - ep = image_get_ep (images->legacy_hdr_os); + ep = image_get_ep (&images->legacy_hdr_os_copy); #if defined(CONFIG_FIT) } else if (images->fit_uname_os) { ret = fit_image_get_entry (images->fit_hdr_os, @@ -639,7 +639,7 @@ static int boot_get_fdt (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[], printf (" Booting using the fdt blob at 0x%x\n", fdt_blob);
ulong fdt_data, fdt_len;
diff --git a/lib_sh/bootm.c b/lib_sh/bootm.c index 3d5c3bb..dd32a3e 100644 --- a/lib_sh/bootm.c +++ b/lib_sh/bootm.c @@ -67,7 +67,7 @@ void do_bootm_linux (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[],
Applied, thanks.
Applied, thanks.
Marian Balakowicz
