[PATCH v3 0/4] spi: kirkwood: dm-conversion (part4)
Series of kirkwood boards to switch DM_SPI and drop which are not DM enabled still.
Any inputs? Jagan.
Bhargav Shah (1): spi: kirkwood: Drop nondm code
Jagan Teki (3): arm: Remove d2net_v2 board db-88f6281-bp-nand: Enable DM_SPI/SPI_FLASH arm: Remove netspace_v2 board
arch/arm/mach-kirkwood/Kconfig | 8 - board/LaCie/net2big_v2/Kconfig | 12 - board/LaCie/net2big_v2/MAINTAINERS | 7 - board/LaCie/net2big_v2/Makefile | 13 -- board/LaCie/net2big_v2/kwbimage.cfg | 149 ------------- board/LaCie/net2big_v2/net2big_v2.c | 257 ---------------------- board/LaCie/net2big_v2/net2big_v2.h | 28 --- board/LaCie/netspace_v2/Kconfig | 12 - board/LaCie/netspace_v2/MAINTAINERS | 14 -- board/LaCie/netspace_v2/Makefile | 10 - board/LaCie/netspace_v2/kwbimage-is2.cfg | 149 ------------- board/LaCie/netspace_v2/kwbimage-ns2l.cfg | 149 ------------- board/LaCie/netspace_v2/kwbimage.cfg | 149 ------------- board/LaCie/netspace_v2/netspace_v2.c | 120 ---------- board/LaCie/netspace_v2/netspace_v2.h | 22 -- configs/d2net_v2_defconfig | 53 ----- configs/db-88f6281-bp-nand_defconfig | 4 +- configs/inetspace_v2_defconfig | 53 ----- configs/net2big_v2_defconfig | 53 ----- configs/netspace_lite_v2_defconfig | 53 ----- configs/netspace_max_v2_defconfig | 53 ----- configs/netspace_mini_v2_defconfig | 48 ---- configs/netspace_v2_defconfig | 53 ----- drivers/spi/Kconfig | 12 +- drivers/spi/kirkwood_spi.c | 136 ++---------- include/configs/lacie_kw.h | 152 ------------- scripts/config_whitelist.txt | 1 - 27 files changed, 21 insertions(+), 1749 deletions(-) delete mode 100644 board/LaCie/net2big_v2/Kconfig delete mode 100644 board/LaCie/net2big_v2/MAINTAINERS delete mode 100644 board/LaCie/net2big_v2/Makefile delete mode 100644 board/LaCie/net2big_v2/kwbimage.cfg delete mode 100644 board/LaCie/net2big_v2/net2big_v2.c delete mode 100644 board/LaCie/net2big_v2/net2big_v2.h delete mode 100644 board/LaCie/netspace_v2/Kconfig delete mode 100644 board/LaCie/netspace_v2/MAINTAINERS delete mode 100644 board/LaCie/netspace_v2/Makefile delete mode 100644 board/LaCie/netspace_v2/kwbimage-is2.cfg delete mode 100644 board/LaCie/netspace_v2/kwbimage-ns2l.cfg delete mode 100644 board/LaCie/netspace_v2/kwbimage.cfg delete mode 100644 board/LaCie/netspace_v2/netspace_v2.c delete mode 100644 board/LaCie/netspace_v2/netspace_v2.h delete mode 100644 configs/d2net_v2_defconfig delete mode 100644 configs/inetspace_v2_defconfig delete mode 100644 configs/net2big_v2_defconfig delete mode 100644 configs/netspace_lite_v2_defconfig delete mode 100644 configs/netspace_max_v2_defconfig delete mode 100644 configs/netspace_mini_v2_defconfig delete mode 100644 configs/netspace_v2_defconfig delete mode 100644 include/configs/lacie_kw.h
Drop the nondm code from kirkwood_spi.c since there is no board or any other code using for it.
Signed-off-by: Bhargav Shah bhargavshah1988@gmail.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- Changes for v3: - updated commit message - updated config_whitelist.txt
drivers/spi/Kconfig | 12 ++-- drivers/spi/kirkwood_spi.c | 136 ++++------------------------------- scripts/config_whitelist.txt | 1 - 3 files changed, 19 insertions(+), 130 deletions(-)
diff --git a/drivers/spi/Kconfig b/drivers/spi/Kconfig index 09b9cb17d8..0945177efb 100644 --- a/drivers/spi/Kconfig +++ b/drivers/spi/Kconfig @@ -162,6 +162,12 @@ config ICH_SPI access the SPI NOR flash on platforms embedding this Intel ICH IP core.
+config KIRKWOOD_SPI + bool "Marvell Kirkwood SPI Driver" + help + Enable support for SPI on various Marvell SoCs, such as + Kirkwood and Armada 375. + config MESON_SPIFC bool "Amlogic Meson SPI Flash Controller driver" depends on ARCH_MESON @@ -417,12 +423,6 @@ config SH_QSPI Enable the Renesas Quad SPI controller driver. This driver can be used on Renesas SoCs.
-config KIRKWOOD_SPI - bool "Marvell Kirkwood SPI Driver" - help - Enable support for SPI on various Marvell SoCs, such as - Kirkwood and Armada 375. - config MXC_SPI bool "MXC SPI Driver" help diff --git a/drivers/spi/kirkwood_spi.c b/drivers/spi/kirkwood_spi.c index 3986b06b25..92dc2e13c5 100644 --- a/drivers/spi/kirkwood_spi.c +++ b/drivers/spi/kirkwood_spi.c @@ -19,6 +19,19 @@ #endif #include <asm/arch-mvebu/spi.h>
+struct mvebu_spi_dev { + bool is_errata_50mhz_ac; +}; + +struct mvebu_spi_platdata { + struct kwspi_registers *spireg; + bool is_errata_50mhz_ac; +}; + +struct mvebu_spi_priv { + struct kwspi_registers *spireg; +}; + static void _spi_cs_activate(struct kwspi_registers *reg) { setbits_le32(®->ctrl, KWSPI_CSN_ACT); @@ -94,128 +107,6 @@ static int _spi_xfer(struct kwspi_registers *reg, unsigned int bitlen, return 0; }
-#ifndef CONFIG_DM_SPI - -static struct kwspi_registers *spireg = - (struct kwspi_registers *)MVEBU_SPI_BASE; - -#ifdef CONFIG_ARCH_KIRKWOOD -static u32 cs_spi_mpp_back[2]; -#endif - -struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs, - unsigned int max_hz, unsigned int mode) -{ - struct spi_slave *slave; - u32 data; -#ifdef CONFIG_ARCH_KIRKWOOD - static const u32 kwspi_mpp_config[2][2] = { - { MPP0_SPI_SCn, 0 }, /* if cs == 0 */ - { MPP7_SPI_SCn, 0 } /* if cs != 0 */ - }; -#endif - - if (!spi_cs_is_valid(bus, cs)) - return NULL; - - slave = spi_alloc_slave_base(bus, cs); - if (!slave) - return NULL; - - writel(KWSPI_SMEMRDY, &spireg->ctrl); - - /* calculate spi clock prescaller using max_hz */ - data = ((CONFIG_SYS_TCLK / 2) / max_hz) + 0x10; - data = data < KWSPI_CLKPRESCL_MIN ? KWSPI_CLKPRESCL_MIN : data; - data = data > KWSPI_CLKPRESCL_MASK ? KWSPI_CLKPRESCL_MASK : data; - - /* program spi clock prescaller using max_hz */ - writel(KWSPI_ADRLEN_3BYTE | data, &spireg->cfg); - debug("data = 0x%08x\n", data); - - writel(KWSPI_SMEMRDIRQ, &spireg->irq_cause); - writel(KWSPI_IRQMASK, &spireg->irq_mask); - -#ifdef CONFIG_ARCH_KIRKWOOD - /* program mpp registers to select SPI_CSn */ - kirkwood_mpp_conf(kwspi_mpp_config[cs ? 1 : 0], cs_spi_mpp_back); -#endif - - return slave; -} - -void spi_free_slave(struct spi_slave *slave) -{ -#ifdef CONFIG_ARCH_KIRKWOOD - kirkwood_mpp_conf(cs_spi_mpp_back, NULL); -#endif - free(slave); -} - -__attribute__((weak)) int board_spi_claim_bus(struct spi_slave *slave) -{ - return 0; -} - -int spi_claim_bus(struct spi_slave *slave) -{ - return board_spi_claim_bus(slave); -} - -__attribute__((weak)) void board_spi_release_bus(struct spi_slave *slave) -{ -} - -void spi_release_bus(struct spi_slave *slave) -{ - board_spi_release_bus(slave); -} - -#ifndef CONFIG_SPI_CS_IS_VALID -/* - * you can define this function board specific - * define above CONFIG in board specific config file and - * provide the function in board specific src file - */ -int spi_cs_is_valid(unsigned int bus, unsigned int cs) -{ - return bus == 0 && (cs == 0 || cs == 1); -} -#endif - -void spi_cs_activate(struct spi_slave *slave) -{ - _spi_cs_activate(spireg); -} - -void spi_cs_deactivate(struct spi_slave *slave) -{ - _spi_cs_deactivate(spireg); -} - -int spi_xfer(struct spi_slave *slave, unsigned int bitlen, - const void *dout, void *din, unsigned long flags) -{ - return _spi_xfer(spireg, bitlen, dout, din, flags); -} - -#else - -/* Here now the DM part */ - -struct mvebu_spi_dev { - bool is_errata_50mhz_ac; -}; - -struct mvebu_spi_platdata { - struct kwspi_registers *spireg; - bool is_errata_50mhz_ac; -}; - -struct mvebu_spi_priv { - struct kwspi_registers *spireg; -}; - static int mvebu_spi_set_speed(struct udevice *bus, uint hz) { struct mvebu_spi_platdata *plat = dev_get_platdata(bus); @@ -409,4 +300,3 @@ U_BOOT_DRIVER(mvebu_spi) = { .priv_auto_alloc_size = sizeof(struct mvebu_spi_priv), .probe = mvebu_spi_probe, }; -#endif diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index f6bf6f2474..e6f5bd7e6d 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -1619,7 +1619,6 @@ CONFIG_SPEAR_USBBOOT CONFIG_SPEAR_USBTTY CONFIG_SPI_ADDR CONFIG_SPI_BOOTING -CONFIG_SPI_CS_IS_VALID CONFIG_SPI_DATAFLASH_WRITE_VERIFY CONFIG_SPI_FLASH_QUAD CONFIG_SPI_FLASH_SIZE
This board has not been converted to CONFIG_DM by the deadline.
Remove it.
Cc: Simon Guinot simon.guinot@sequanux.org Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- Changes for v3: - new patch
arch/arm/mach-kirkwood/Kconfig | 4 - board/LaCie/net2big_v2/Kconfig | 12 -- board/LaCie/net2big_v2/MAINTAINERS | 7 - board/LaCie/net2big_v2/Makefile | 13 -- board/LaCie/net2big_v2/kwbimage.cfg | 149 ---------------- board/LaCie/net2big_v2/net2big_v2.c | 257 ---------------------------- board/LaCie/net2big_v2/net2big_v2.h | 28 --- configs/d2net_v2_defconfig | 53 ------ configs/net2big_v2_defconfig | 53 ------ include/configs/lacie_kw.h | 152 ---------------- 10 files changed, 728 deletions(-) delete mode 100644 board/LaCie/net2big_v2/Kconfig delete mode 100644 board/LaCie/net2big_v2/MAINTAINERS delete mode 100644 board/LaCie/net2big_v2/Makefile delete mode 100644 board/LaCie/net2big_v2/kwbimage.cfg delete mode 100644 board/LaCie/net2big_v2/net2big_v2.c delete mode 100644 board/LaCie/net2big_v2/net2big_v2.h delete mode 100644 configs/d2net_v2_defconfig delete mode 100644 configs/net2big_v2_defconfig delete mode 100644 include/configs/lacie_kw.h
diff --git a/arch/arm/mach-kirkwood/Kconfig b/arch/arm/mach-kirkwood/Kconfig index ae44cb665e..ad6aef45bf 100644 --- a/arch/arm/mach-kirkwood/Kconfig +++ b/arch/arm/mach-kirkwood/Kconfig @@ -35,9 +35,6 @@ config TARGET_KM_KIRKWOOD bool "KM Kirkwood Board" select VENDOR_KM
-config TARGET_NET2BIG_V2 - bool "LaCie 2Big Network v2 NAS Board" - config TARGET_NETSPACE_V2 bool "LaCie netspace_v2 Board"
@@ -80,7 +77,6 @@ source "board/cloudengines/pogo_e02/Kconfig" source "board/d-link/dns325/Kconfig" source "board/iomega/iconnect/Kconfig" source "board/keymile/Kconfig" -source "board/LaCie/net2big_v2/Kconfig" source "board/LaCie/netspace_v2/Kconfig" source "board/raidsonic/ib62x0/Kconfig" source "board/Seagate/dockstar/Kconfig" diff --git a/board/LaCie/net2big_v2/Kconfig b/board/LaCie/net2big_v2/Kconfig deleted file mode 100644 index ba460dba45..0000000000 --- a/board/LaCie/net2big_v2/Kconfig +++ /dev/null @@ -1,12 +0,0 @@ -if TARGET_NET2BIG_V2 - -config SYS_BOARD - default "net2big_v2" - -config SYS_VENDOR - default "LaCie" - -config SYS_CONFIG_NAME - default "lacie_kw" - -endif diff --git a/board/LaCie/net2big_v2/MAINTAINERS b/board/LaCie/net2big_v2/MAINTAINERS deleted file mode 100644 index 8fec70315f..0000000000 --- a/board/LaCie/net2big_v2/MAINTAINERS +++ /dev/null @@ -1,7 +0,0 @@ -NET2BIG_V2 BOARD -M: Simon Guinot simon.guinot@sequanux.org -S: Maintained -F: board/LaCie/net2big_v2/ -F: include/configs/lacie_kw.h -F: configs/d2net_v2_defconfig -F: configs/net2big_v2_defconfig diff --git a/board/LaCie/net2big_v2/Makefile b/board/LaCie/net2big_v2/Makefile deleted file mode 100644 index 3d12b72812..0000000000 --- a/board/LaCie/net2big_v2/Makefile +++ /dev/null @@ -1,13 +0,0 @@ -# SPDX-License-Identifier: GPL-2.0+ -# -# Copyright (C) 2011 Simon Guinot sguinot@lacie.com -# -# Based on Kirkwood support: -# (C) Copyright 2009 -# Marvell Semiconductor <www.marvell.com> -# Written-by: Prafulla Wadaskar prafulla@marvell.com - -obj-y := net2big_v2.o ../common/common.o -ifneq ($(and $(CONFIG_KIRKWOOD_GPIO),$(CONFIG_NET2BIG_V2)),) -obj-y += ../common/cpld-gpio-bus.o -endif diff --git a/board/LaCie/net2big_v2/kwbimage.cfg b/board/LaCie/net2big_v2/kwbimage.cfg deleted file mode 100644 index 3897a1197a..0000000000 --- a/board/LaCie/net2big_v2/kwbimage.cfg +++ /dev/null @@ -1,149 +0,0 @@ -# SPDX-License-Identifier: GPL-2.0+ -# -# Copyright (C) 2011 Simon Guinot sguinot@lacie.com -# -# Based on Kirkwood support: -# (C) Copyright 2009 -# Marvell Semiconductor <www.marvell.com> -# Written-by: Prafulla Wadaskar prafulla@marvell.com -# Refer doc/README.kwbimage for more details about how-to configure -# and create kirkwood boot image -# - -# Boot Media configurations -BOOT_FROM spi # Boot from SPI flash - -# SOC registers configuration using bootrom header extension -# Maximum KWBIMAGE_MAX_CONFIG configurations allowed - -# Configure RGMII-0 interface pad voltage to 1.8V -DATA 0xFFD100e0 0x1B1B1B9B - -#Dram initalization for SINGLE x16 CL=5 @ 400MHz -DATA 0xFFD01400 0x43000C30 # DDR Configuration register -# bit13-0: 0xa00 (2560 DDR2 clks refresh rate) -# bit23-14: zero -# bit24: 1= enable exit self refresh mode on DDR access -# bit25: 1 required -# bit29-26: zero -# bit31-30: 01 - -DATA 0xFFD01404 0x38743000 # DDR Controller Control Low -# bit 4: 0=addr/cmd in smame cycle -# bit 5: 0=clk is driven during self refresh, we don't care for APX -# bit 6: 0=use recommended falling edge of clk for addr/cmd -# bit14: 0=input buffer always powered up -# bit18: 1=cpu lock transaction enabled -# bit23-20: 5=recommended value for CL=5 and STARTBURST_DEL disabled bit31=0 -# bit27-24: 8= CL+3, STARTBURST sample stages, for freqs 400MHz, unbuffered DIMM -# bit30-28: 3 required -# bit31: 0=no additional STARTBURST delay - -DATA 0xFFD01408 0x22125451 # DDR Timing (Low) (active cycles value +1) -# bit7-4: TRCD -# bit11- 8: TRP -# bit15-12: TWR -# bit19-16: TWTR -# bit20: TRAS msb -# bit23-21: 0x0 -# bit27-24: TRRD -# bit31-28: TRTP - -DATA 0xFFD0140C 0x00000A32 # DDR Timing (High) -# bit6-0: TRFC -# bit8-7: TR2R -# bit10-9: TR2W -# bit12-11: TW2W -# bit31-13: zero required - -DATA 0xFFD01410 0x0000CCCC # DDR Address Control -# bit1-0: 01, Cs0width=x16 -# bit3-2: 11, Cs0size=1Gb -# bit5-4: 00, Cs2width=nonexistent -# bit7-6: 00, Cs1size =nonexistent -# bit9-8: 00, Cs2width=nonexistent -# bit11-10: 00, Cs2size =nonexistent -# bit13-12: 00, Cs3width=nonexistent -# bit15-14: 00, Cs3size =nonexistent -# bit16: 0, Cs0AddrSel -# bit17: 0, Cs1AddrSel -# bit18: 0, Cs2AddrSel -# bit19: 0, Cs3AddrSel -# bit31-20: 0 required - -DATA 0xFFD01414 0x00000000 # DDR Open Pages Control -# bit0: 0, OpenPage enabled -# bit31-1: 0 required - -DATA 0xFFD01418 0x00000000 # DDR Operation -# bit3-0: 0x0, DDR cmd -# bit31-4: 0 required - -DATA 0xFFD0141C 0x00000662 # DDR Mode -# bit2-0: 2, BurstLen=2 required -# bit3: 0, BurstType=0 required -# bit6-4: 4, CL=5 -# bit7: 0, TestMode=0 normal -# bit8: 0, DLL reset=0 normal -# bit11-9: 6, auto-precharge write recovery ???????????? -# bit12: 0, PD must be zero -# bit31-13: 0 required - -DATA 0xFFD01420 0x00000044 # DDR Extended Mode -# bit0: 0, DDR DLL enabled -# bit1: 1, DDR drive strenght reduced -# bit2: 1, DDR ODT control lsd enabled -# bit5-3: 000, required -# bit6: 1, DDR ODT control msb, enabled -# bit9-7: 000, required -# bit10: 0, differential DQS enabled -# bit11: 0, required -# bit12: 0, DDR output buffer enabled -# bit31-13: 0 required - -DATA 0xFFD01424 0x0000F17F # DDR Controller Control High -# bit2-0: 111, required -# bit3 : 1 , MBUS Burst Chop disabled -# bit6-4: 111, required -# bit7 : 1 , D2P Latency enabled -# bit8 : 1 , add writepath sample stage, must be 1 for DDR freq >= 300MHz -# bit9 : 0 , no half clock cycle addition to dataout -# bit10 : 0 , 1/4 clock cycle skew enabled for addr/ctl signals -# bit11 : 0 , 1/4 clock cycle skew disabled for write mesh -# bit15-12: 1111 required -# bit31-16: 0 required - -DATA 0xFFD01428 0x00096630 # DDR2 ODT Read Timing (default values) -DATA 0xFFD0147C 0x00009663 # DDR2 ODT Write Timing (default values) - -DATA 0xFFD01500 0x00000000 # CS[0]n Base address to 0x0 -DATA 0xFFD01504 0x0FFFFFF1 # CS[0]n Size -# bit0: 1, Window enabled -# bit1: 0, Write Protect disabled -# bit3-2: 00, CS0 hit selected -# bit23-4: ones, required -# bit31-24: 0x07, Size (i.e. 128MB) - -DATA 0xFFD0150C 0x00000000 # CS[1]n Size, window disabled -DATA 0xFFD01514 0x00000000 # CS[2]n Size, window disabled -DATA 0xFFD0151C 0x00000000 # CS[3]n Size, window disabled - -DATA 0xFFD01494 0x00010000 # DDR ODT Control (Low) -# bit3-0: 1, ODT0Rd, MODT[0] asserted during read from DRAM CS0 -# bit19-16:1, ODT0Wr, MODT[0] asserted during write to DRAM CS0 - -DATA 0xFFD01498 0x00000000 # DDR ODT Control (High) -# bit1-0: 00, ODT0 controlled by ODT Control (low) register above -# bit3-2: 01, ODT1 active NEVER! -# bit31-4: zero, required - -DATA 0xFFD0149C 0x0000E40F # CPU ODT Control -# bit3-0: 1, ODT0Rd, Internal ODT asserted during read from DRAM bank0 -# bit7-4: 1, ODT0Wr, Internal ODT asserted during write to DRAM bank0 -# bit11-10:1, DQ_ODTSel. ODT select turned on - -DATA 0xFFD01480 0x00000001 # DDR Initialization Control -#bit0=1, enable DDR init upon this register write - -# End of Header extension -DATA 0x0 0x0 diff --git a/board/LaCie/net2big_v2/net2big_v2.c b/board/LaCie/net2big_v2/net2big_v2.c deleted file mode 100644 index dbd8b5755d..0000000000 --- a/board/LaCie/net2big_v2/net2big_v2.c +++ /dev/null @@ -1,257 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Copyright (C) 2011 Simon Guinot sguinot@lacie.com - * - * Based on Kirkwood support: - * (C) Copyright 2009 - * Marvell Semiconductor <www.marvell.com> - * Written-by: Prafulla Wadaskar prafulla@marvell.com - */ - -#include <common.h> -#include <command.h> -#include <env.h> -#include <i2c.h> -#include <init.h> -#include <net.h> -#include <asm/mach-types.h> -#include <asm/arch/cpu.h> -#include <asm/arch/soc.h> -#include <asm/arch/mpp.h> -#include <asm/arch/gpio.h> - -#include "net2big_v2.h" -#include "../common/common.h" -#include "../common/cpld-gpio-bus.h" - -DECLARE_GLOBAL_DATA_PTR; - -int board_early_init_f(void) -{ - /* GPIO configuration */ - mvebu_config_gpio(NET2BIG_V2_OE_VAL_LOW, NET2BIG_V2_OE_VAL_HIGH, - NET2BIG_V2_OE_LOW, NET2BIG_V2_OE_HIGH); - - /* Multi-Purpose Pins Functionality configuration */ - static const u32 kwmpp_config[] = { - MPP0_SPI_SCn, - MPP1_SPI_MOSI, - MPP2_SPI_SCK, - MPP3_SPI_MISO, - MPP6_SYSRST_OUTn, - MPP7_GPO, /* Request power-off */ - MPP8_TW_SDA, - MPP9_TW_SCK, - MPP10_UART0_TXD, - MPP11_UART0_RXD, - MPP13_GPIO, /* Rear power switch (on|auto) */ - MPP14_GPIO, /* USB fuse alarm */ - MPP15_GPIO, /* Rear power switch (auto|off) */ - MPP16_GPIO, /* SATA HDD1 power */ - MPP17_GPIO, /* SATA HDD2 power */ - MPP20_SATA1_ACTn, - MPP21_SATA0_ACTn, - MPP24_GPIO, /* USB mode select */ - MPP26_GPIO, /* USB device vbus */ - MPP28_GPIO, /* USB enable host vbus */ - MPP29_GPIO, /* CPLD GPIO bus ALE */ - MPP34_GPIO, /* Rear Push button 0=on 1=off */ - MPP35_GPIO, /* Inhibit switch power-off */ - MPP36_GPIO, /* SATA HDD1 presence */ - MPP37_GPIO, /* SATA HDD2 presence */ - MPP40_GPIO, /* eSATA presence */ - MPP44_GPIO, /* CPLD GPIO bus (data 0) */ - MPP45_GPIO, /* CPLD GPIO bus (data 1) */ - MPP46_GPIO, /* CPLD GPIO bus (data 2) */ - MPP47_GPIO, /* CPLD GPIO bus (addr 0) */ - MPP48_GPIO, /* CPLD GPIO bus (addr 1) */ - MPP49_GPIO, /* CPLD GPIO bus (addr 2) */ - 0 - }; - - kirkwood_mpp_conf(kwmpp_config, NULL); - - return 0; -} - -int board_init(void) -{ - /* Machine number */ - gd->bd->bi_arch_number = MACH_TYPE_NET2BIG_V2; - - /* Boot parameters address */ - gd->bd->bi_boot_params = mvebu_sdram_bar(0) + 0x100; - - return 0; -} - -#if defined(CONFIG_MISC_INIT_R) - -#if defined(CONFIG_CMD_I2C) && defined(CONFIG_SYS_I2C_G762_ADDR) -/* - * Start I2C fan (GMT G762 controller) - */ -static void init_fan(void) -{ - u8 data; - - i2c_set_bus_num(0); - - /* Enable open-loop and PWM modes */ - data = 0x20; - if (i2c_write(CONFIG_SYS_I2C_G762_ADDR, - G762_REG_FAN_CMD1, 1, &data, 1) != 0) - goto err; - data = 0; - if (i2c_write(CONFIG_SYS_I2C_G762_ADDR, - G762_REG_SET_CNT, 1, &data, 1) != 0) - goto err; - /* - * RPM to PWM (set_out register) fan speed conversion array: - * 0 0x00 - * 1500 0x04 - * 2800 0x08 - * 3400 0x0C - * 3700 0x10 - * 4400 0x20 - * 4700 0x30 - * 4800 0x50 - * 5200 0x80 - * 5400 0xC0 - * 5500 0xFF - * - * Start fan at low speed (2800 RPM): - */ - data = 0x08; - if (i2c_write(CONFIG_SYS_I2C_G762_ADDR, - G762_REG_SET_OUT, 1, &data, 1) != 0) - goto err; - - return; -err: - printf("Error: failed to start I2C fan @%02x\n", - CONFIG_SYS_I2C_G762_ADDR); -} -#else -static void init_fan(void) {} -#endif /* CONFIG_CMD_I2C && CONFIG_SYS_I2C_G762_ADDR */ - -#if defined(CONFIG_NET2BIG_V2) && defined(CONFIG_KIRKWOOD_GPIO) -/* - * CPLD GPIO bus: - * - * - address register : bit [0-2] -> GPIO [47-49] - * - data register : bit [0-2] -> GPIO [44-46] - * - enable register : GPIO 29 - */ -static unsigned cpld_gpio_bus_addr[] = { 47, 48, 49 }; -static unsigned cpld_gpio_bus_data[] = { 44, 45, 46 }; - -static struct cpld_gpio_bus cpld_gpio_bus = { - .addr = cpld_gpio_bus_addr, - .num_addr = ARRAY_SIZE(cpld_gpio_bus_addr), - .data = cpld_gpio_bus_data, - .num_data = ARRAY_SIZE(cpld_gpio_bus_data), - .enable = 29, -}; - -/* - * LEDs configuration: - * - * The LEDs are controlled by a CPLD and can be configured through - * the CPLD GPIO bus. - * - * Address register selection: - * - * addr | register - * ---------------------------- - * 0 | front LED - * 1 | front LED brightness - * 2 | SATA LED brightness - * 3 | SATA0 LED - * 4 | SATA1 LED - * 5 | SATA2 LED - * 6 | SATA3 LED - * 7 | SATA4 LED - * - * Data register configuration: - * - * data | LED brightness - * ------------------------------------------------- - * 0 | min (off) - * - | - - * 7 | max - * - * data | front LED mode - * ------------------------------------------------- - * 0 | fix off - * 1 | fix blue on - * 2 | fix red on - * 3 | blink blue on=1 sec and blue off=1 sec - * 4 | blink red on=1 sec and red off=1 sec - * 5 | blink blue on=2.5 sec and red on=0.5 sec - * 6 | blink blue on=1 sec and red on=1 sec - * 7 | blink blue on=0.5 sec and blue off=2.5 sec - * - * data | SATA LED mode - * ------------------------------------------------- - * 0 | fix off - * 1 | SATA activity blink - * 2 | fix red on - * 3 | blink blue on=1 sec and blue off=1 sec - * 4 | blink red on=1 sec and red off=1 sec - * 5 | blink blue on=2.5 sec and red on=0.5 sec - * 6 | blink blue on=1 sec and red on=1 sec - * 7 | fix blue on - */ -static void init_leds(void) -{ - /* Enable the front blue LED */ - cpld_gpio_bus_write(&cpld_gpio_bus, 0, 1); - cpld_gpio_bus_write(&cpld_gpio_bus, 1, 3); - - /* Configure SATA LEDs to blink in relation with the SATA activity */ - cpld_gpio_bus_write(&cpld_gpio_bus, 3, 1); - cpld_gpio_bus_write(&cpld_gpio_bus, 4, 1); - cpld_gpio_bus_write(&cpld_gpio_bus, 2, 3); -} -#else -static void init_leds(void) {} -#endif /* CONFIG_NET2BIG_V2 && CONFIG_KIRKWOOD_GPIO */ - -int misc_init_r(void) -{ - init_fan(); -#if defined(CONFIG_CMD_I2C) && defined(CONFIG_SYS_I2C_EEPROM_ADDR) - if (!env_get("ethaddr")) { - uchar mac[6]; - if (lacie_read_mac_address(mac) == 0) - eth_env_set_enetaddr("ethaddr", mac); - } -#endif - init_leds(); - - return 0; -} -#endif /* CONFIG_MISC_INIT_R */ - -#if defined(CONFIG_CMD_NET) && defined(CONFIG_RESET_PHY_R) -/* Configure and initialize PHY */ -void reset_phy(void) -{ - mv_phy_88e1116_init("egiga0", 8); -} -#endif - -#if defined(CONFIG_KIRKWOOD_GPIO) -/* Return GPIO push button status */ -static int -do_read_push_button(struct cmd_tbl *cmdtp, int flag, int argc, - char *const argv[]) -{ - return !kw_gpio_get_value(NET2BIG_V2_GPIO_PUSH_BUTTON); -} - -U_BOOT_CMD(button, 1, 1, do_read_push_button, - "Return GPIO push button status 0=off 1=on", ""); -#endif diff --git a/board/LaCie/net2big_v2/net2big_v2.h b/board/LaCie/net2big_v2/net2big_v2.h deleted file mode 100644 index d61dd0e998..0000000000 --- a/board/LaCie/net2big_v2/net2big_v2.h +++ /dev/null @@ -1,28 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Copyright (C) 2011 Simon Guinot sguinot@lacie.com - * - * Based on Kirkwood support: - * (C) Copyright 2009 - * Marvell Semiconductor <www.marvell.com> - * Written-by: Prafulla Wadaskar prafulla@marvell.com - */ - -#ifndef NET2BIG_V2_H -#define NET2BIG_V2_H - -/* GPIO configuration */ -#define NET2BIG_V2_OE_LOW 0x0600E000 -#define NET2BIG_V2_OE_HIGH 0x00000134 -#define NET2BIG_V2_OE_VAL_LOW 0x10030000 -#define NET2BIG_V2_OE_VAL_HIGH 0x00000000 - -/* Buttons */ -#define NET2BIG_V2_GPIO_PUSH_BUTTON 34 - -/* GMT G762 registers (I2C fan controller) */ -#define G762_REG_SET_CNT 0x00 -#define G762_REG_SET_OUT 0x03 -#define G762_REG_FAN_CMD1 0x04 - -#endif /* NET2BIG_V2_H */ diff --git a/configs/d2net_v2_defconfig b/configs/d2net_v2_defconfig deleted file mode 100644 index fe3c6c4762..0000000000 --- a/configs/d2net_v2_defconfig +++ /dev/null @@ -1,53 +0,0 @@ -CONFIG_ARM=y -CONFIG_SYS_DCACHE_OFF=y -CONFIG_ARCH_CPU_INIT=y -CONFIG_ARCH_KIRKWOOD=y -CONFIG_SYS_TEXT_BASE=0x600000 -CONFIG_TARGET_NET2BIG_V2=y -CONFIG_ENV_SIZE=0x1000 -CONFIG_ENV_OFFSET=0x70000 -CONFIG_ENV_SECT_SIZE=0x10000 -CONFIG_NR_DRAM_BANKS=2 -CONFIG_IDENT_STRING=" D2 v2" -CONFIG_SYS_EXTRA_OPTIONS="D2NET_V2" -CONFIG_BOOTDELAY=3 -CONFIG_USE_BOOTARGS=y -CONFIG_BOOTARGS="console=ttyS0,115200" -CONFIG_USE_PREBOOT=y -CONFIG_CONSOLE_MUX=y -CONFIG_MISC_INIT_R=y -# CONFIG_DISPLAY_BOARDINFO is not set -CONFIG_HUSH_PARSER=y -CONFIG_SYS_PROMPT="d2v2> " -CONFIG_CMD_EEPROM=y -CONFIG_CMD_IDE=y -CONFIG_CMD_I2C=y -CONFIG_CMD_SF=y -CONFIG_CMD_USB=y -# CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_FAT=y -CONFIG_ISO_PARTITION=y -CONFIG_EFI_PARTITION=y -# CONFIG_PARTITION_UUIDS is not set -CONFIG_OF_CONTROL=y -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-d2net" -CONFIG_ENV_IS_IN_SPI_FLASH=y -CONFIG_USE_ENV_SPI_MAX_HZ=y -CONFIG_ENV_SPI_MAX_HZ=20000000 -CONFIG_ENV_ADDR=0x70000 -CONFIG_MVSATA_IDE=y -# CONFIG_MMC is not set -CONFIG_SPI_FLASH=y -CONFIG_SPI_FLASH_MACRONIX=y -CONFIG_MVGBE=y -CONFIG_MII=y -CONFIG_SYS_NS16550=y -CONFIG_SPI=y -CONFIG_KIRKWOOD_SPI=y -CONFIG_USB=y -CONFIG_USB_EHCI_HCD=y -CONFIG_USB_STORAGE=y diff --git a/configs/net2big_v2_defconfig b/configs/net2big_v2_defconfig deleted file mode 100644 index 1389d30900..0000000000 --- a/configs/net2big_v2_defconfig +++ /dev/null @@ -1,53 +0,0 @@ -CONFIG_ARM=y -CONFIG_SYS_DCACHE_OFF=y -CONFIG_ARCH_CPU_INIT=y -CONFIG_ARCH_KIRKWOOD=y -CONFIG_SYS_TEXT_BASE=0x600000 -CONFIG_TARGET_NET2BIG_V2=y -CONFIG_ENV_SIZE=0x1000 -CONFIG_ENV_OFFSET=0x70000 -CONFIG_ENV_SECT_SIZE=0x10000 -CONFIG_NR_DRAM_BANKS=2 -CONFIG_IDENT_STRING=" 2Big v2" -CONFIG_SYS_EXTRA_OPTIONS="NET2BIG_V2" -CONFIG_BOOTDELAY=3 -CONFIG_USE_BOOTARGS=y -CONFIG_BOOTARGS="console=ttyS0,115200" -CONFIG_USE_PREBOOT=y -CONFIG_CONSOLE_MUX=y -CONFIG_MISC_INIT_R=y -# CONFIG_DISPLAY_BOARDINFO is not set -CONFIG_HUSH_PARSER=y -CONFIG_SYS_PROMPT="2big2> " -CONFIG_CMD_EEPROM=y -CONFIG_CMD_IDE=y -CONFIG_CMD_I2C=y -CONFIG_CMD_SF=y -CONFIG_CMD_USB=y -# CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_FAT=y -CONFIG_ISO_PARTITION=y -CONFIG_EFI_PARTITION=y -# CONFIG_PARTITION_UUIDS is not set -CONFIG_OF_CONTROL=y -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-net2big" -CONFIG_ENV_IS_IN_SPI_FLASH=y -CONFIG_USE_ENV_SPI_MAX_HZ=y -CONFIG_ENV_SPI_MAX_HZ=20000000 -CONFIG_ENV_ADDR=0x70000 -CONFIG_MVSATA_IDE=y -# CONFIG_MMC is not set -CONFIG_SPI_FLASH=y -CONFIG_SPI_FLASH_MACRONIX=y -CONFIG_MVGBE=y -CONFIG_MII=y -CONFIG_SYS_NS16550=y -CONFIG_SPI=y -CONFIG_KIRKWOOD_SPI=y -CONFIG_USB=y -CONFIG_USB_EHCI_HCD=y -CONFIG_USB_STORAGE=y diff --git a/include/configs/lacie_kw.h b/include/configs/lacie_kw.h deleted file mode 100644 index 5bb0255a74..0000000000 --- a/include/configs/lacie_kw.h +++ /dev/null @@ -1,152 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Copyright (C) 2011 Simon Guinot sguinot@lacie.com - */ - -#ifndef _CONFIG_LACIE_KW_H -#define _CONFIG_LACIE_KW_H - -/* - * Machine number definition - */ -#if defined(CONFIG_INETSPACE_V2) -#define CONFIG_MACH_TYPE MACH_TYPE_INETSPACE_V2 -#elif defined(CONFIG_NETSPACE_V2) -#define CONFIG_MACH_TYPE MACH_TYPE_NETSPACE_V2 -#elif defined(CONFIG_NETSPACE_LITE_V2) -#define CONFIG_MACH_TYPE MACH_TYPE_NETSPACE_LITE_V2 -#elif defined(CONFIG_NETSPACE_MINI_V2) -#define CONFIG_MACH_TYPE MACH_TYPE_NETSPACE_MINI_V2 -#elif defined(CONFIG_NETSPACE_MAX_V2) -#define CONFIG_MACH_TYPE MACH_TYPE_NETSPACE_MAX_V2 -#elif defined(CONFIG_D2NET_V2) -#define CONFIG_MACH_TYPE MACH_TYPE_D2NET_V2 -#elif defined(CONFIG_NET2BIG_V2) -#define CONFIG_MACH_TYPE MACH_TYPE_NET2BIG_V2 -#else -#error "Unknown board" -#endif - -/* - * High Level Configuration Options (easy to change) - */ -#define CONFIG_FEROCEON_88FR131 /* CPU Core subversion */ -/* SoC name */ -#if defined(CONFIG_NETSPACE_LITE_V2) || defined(CONFIG_NETSPACE_MINI_V2) -#define CONFIG_KW88F6192 -#else -#define CONFIG_KW88F6281 -#endif -#define CONFIG_SKIP_LOWLEVEL_INIT /* disable board lowlevel_init */ - -/* - * Core clock definition - */ -#define CONFIG_SYS_TCLK 166000000 /* 166MHz */ - -/* - * SDRAM configuration - */ - -/* - * Different SDRAM configuration and size for some of the boards derived - * from the Network Space v2 - */ -#if defined(CONFIG_INETSPACE_V2) -#define CONFIG_SYS_KWD_CONFIG $(CONFIG_BOARDDIR)/kwbimage-is2.cfg -#elif defined(CONFIG_NETSPACE_LITE_V2) || defined(CONFIG_NETSPACE_MINI_V2) -#define CONFIG_SYS_KWD_CONFIG $(CONFIG_BOARDDIR)/kwbimage-ns2l.cfg -#endif - -/* - * mv-common.h should be defined after CMD configs since it used them - * to enable certain macros - */ -#include "mv-common.h" - -/* Remove or override few declarations from mv-common.h */ -#undef CONFIG_SYS_IDE_MAXBUS -#undef CONFIG_SYS_IDE_MAXDEVICE - -/* - * Enable platform initialisation via misc_init_r() function - */ - -/* - * Ethernet Driver configuration - */ -#ifdef CONFIG_CMD_NET -#define CONFIG_MVGBE_PORTS {1, 0} /* enable port 0 only */ -#define CONFIG_NETCONSOLE -#endif - -/* - * SATA Driver configuration - */ -#ifdef CONFIG_MVSATA_IDE -#define CONFIG_SYS_ATA_IDE0_OFFSET MV_SATA_PORT0_OFFSET -#if defined(CONFIG_NETSPACE_MAX_V2) || defined(CONFIG_D2NET_V2) || \ - defined(CONFIG_NET2BIG_V2) -#define CONFIG_SYS_ATA_IDE1_OFFSET MV_SATA_PORT1_OFFSET -#define CONFIG_SYS_IDE_MAXBUS 2 -#define CONFIG_SYS_IDE_MAXDEVICE 2 -#else -#define CONFIG_SYS_IDE_MAXBUS 1 -#define CONFIG_SYS_IDE_MAXDEVICE 1 -#endif -#endif /* CONFIG_MVSATA_IDE */ - -/* - * Enable GPI0 support - */ -#define CONFIG_KIRKWOOD_GPIO - -/* - * Enable I2C support - */ -#ifdef CONFIG_CMD_I2C -/* I2C EEPROM HT24LC04 (512B - 32 pages of 16 Bytes) */ -#define CONFIG_SYS_I2C_EEPROM_ADDR 0x50 -#define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 4 /* 16-byte page size */ -#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 /* 8-bit device address */ -#if defined(CONFIG_NET2BIG_V2) -#define CONFIG_SYS_I2C_G762_ADDR 0x3e -#endif -#endif /* CONFIG_CMD_I2C */ - -/* - * Partition support - */ - -/* - * File systems support - */ - -/* - * Environment variables configurations - */ - -/* - * Default environment variables - */ -#define CONFIG_BOOTCOMMAND \ - "dhcp && run netconsole; " \ - "if run usbload || run diskload; then bootm; fi" - -#define CONFIG_EXTRA_ENV_SETTINGS \ - "stdin=serial\0" \ - "stdout=serial\0" \ - "stderr=serial\0" \ - "bootfile=uImage\0" \ - "loadaddr=0x800000\0" \ - "autoload=no\0" \ - "netconsole=" \ - "set stdin $stdin,nc; " \ - "set stdout $stdout,nc; " \ - "set stderr $stderr,nc;\0" \ - "diskload=ide reset && " \ - "ext2load ide 0:1 $loadaddr /boot/$bootfile\0" \ - "usbload=usb start && " \ - "fatload usb 0:1 $loadaddr /boot/$bootfile\0" - -#endif /* _CONFIG_LACIE_KW_H */
On Thu, Jun 18, 2020 at 11:15:14PM +0530, Jagan Teki wrote: Hi Jagan,
Is that possible to negociate a new deadline ?
Thanks in advance.
Simon
Remove it.
Changes for v3:
- new patch
-config SYS_BOARD
-config SYS_VENDOR
- default "LaCie"
- Copyright (C) 2011 Simon Guinot sguinot@lacie.com
- Based on Kirkwood support:
- (C) Copyright 2009
- Marvell Semiconductor <www.marvell.com>
- Written-by: Prafulla Wadaskar prafulla@marvell.com
MPP0_SPI_SCn,
MPP1_SPI_MOSI,
MPP2_SPI_SCK,
MPP3_SPI_MISO,
MPP6_SYSRST_OUTn,
MPP8_TW_SDA,
MPP9_TW_SCK,
MPP10_UART0_TXD,
MPP11_UART0_RXD,
MPP20_SATA1_ACTn,
MPP21_SATA0_ACTn,
0
- Start I2C fan (GMT G762 controller)
- u8 data;
- data = 0x20;
goto err;
- data = 0;
goto err;
* 0 0x00
* 1500 0x04
* 2800 0x08
* 3400 0x0C
* 3700 0x10
* 4400 0x20
* 4700 0x30
* 4800 0x50
* 5200 0x80
* 5400 0xC0
* 5500 0xFF
- data = 0x08;
goto err;
- return;
-err:
- CPLD GPIO bus:
- .enable = 29,
- LEDs configuration:
- The LEDs are controlled by a CPLD and can be configured through
- the CPLD GPIO bus.
- Address register selection:
- addr | register
- 0 | front LED
- 1 | front LED brightness
- 2 | SATA LED brightness
- 3 | SATA0 LED
- 4 | SATA1 LED
- 5 | SATA2 LED
- 6 | SATA3 LED
- 7 | SATA4 LED
- Data register configuration:
- data | LED brightness
- 0 | min (off)
- 7 | max
- data | front LED mode
- 0 | fix off
- 1 | fix blue on
- 2 | fix red on
- 3 | blink blue on=1 sec and blue off=1 sec
- 4 | blink red on=1 sec and red off=1 sec
- 5 | blink blue on=2.5 sec and red on=0.5 sec
- 6 | blink blue on=1 sec and red on=1 sec
- 7 | blink blue on=0.5 sec and blue off=2.5 sec
- data | SATA LED mode
- 0 | fix off
- 1 | SATA activity blink
- 2 | fix red on
- 7 | fix blue on
- init_fan();
uchar mac[6];
-#endif
- init_leds();
-} -#endif
char *const argv[])
- Machine number definition
- High Level Configuration Options (easy to change)
- Core clock definition
- SDRAM configuration
- Different SDRAM configuration and size for some of the boards derived
- from the Network Space v2
- mv-common.h should be defined after CMD configs since it used them
- to enable certain macros
- Enable platform initialisation via misc_init_r() function
- Ethernet Driver configuration
- SATA Driver configuration
- Enable GPI0 support
- Enable I2C support
- Partition support
- File systems support
- Environment variables configurations
- Default environment variables
- "autoload=no\0" \
- "netconsole=" \
2.25.1
Well, when will you be able to spend some time bringing the platform up to current standards? Doing a quick build for net2big_v2 I see: +(net2big_v2) ===================== WARNING ====================== +(net2big_v2) This board does not use CONFIG_DM. CONFIG_DM will be +(net2big_v2) compulsory starting with the v2020.01 release. +(net2big_v2) Failure to update may result in board removal. +(net2big_v2) See doc/driver-model/migration.rst for more info. +(net2big_v2) ==================================================== +(net2big_v2) This board does not use CONFIG_DM_USB. Please update +(net2big_v2) the board to use CONFIG_DM_USB before the v2019.07 release. +(net2big_v2) Failure to update by the deadline may result in board removal. +(net2big_v2) This board does use CONFIG_MVSATA_IDE which is not +(net2big_v2) ported to driver-model (DM) yet. Please update the storage +(net2big_v2) controller driver to use CONFIG_AHCI before the v2019.07 +(net2big_v2) release. +(net2big_v2) This board does not use CONFIG_DM_SPI_FLASH. Please update +(net2big_v2) the board to use CONFIG_SPI_FLASH before the v2019.07 release. +(net2big_v2) This board does not use CONFIG_DM_ETH (Driver Model +(net2big_v2) for Ethernet drivers). Please update the board to use +(net2big_v2) CONFIG_DM_ETH before the v2020.07 release. Failure to +(net2big_v2) update by the deadline may result in board removal.
So there's a lot of stuff that needs updating. Conversion to CONFIG_DM is what you'll need to then convert SPI, ETH and USB to use DM and the IDE driver also needs attention and conversion. Thanks!
Hi Tom,
I am working on it. But so far it is not going very well and the whole thing is turning into a debug session.
But I'll do my best and whatever the result will be, I'll send you an update by the end of the next week.
Is this acceptable to you ?
Thanks.
Simon
Hi Tom,
Yes, thanks!
Hi Tom,
Hi Tom,
I just sent a patch series converting the LaCie boards to use DM drivers.
I apologize for missing all this DM deadlines.
Simon
Enable DM_SPI, DM_SPI_FLASH for db-88f6281-bp-nand board.
Cc: Chris Packham judge.packham@gmail.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- Changes for v3: - new patch
configs/db-88f6281-bp-nand_defconfig | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/configs/db-88f6281-bp-nand_defconfig b/configs/db-88f6281-bp-nand_defconfig index f98e462d42..5a580f28b5 100644 --- a/configs/db-88f6281-bp-nand_defconfig +++ b/configs/db-88f6281-bp-nand_defconfig @@ -20,7 +20,6 @@ CONFIG_CMD_DM=y CONFIG_CMD_IDE=y CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y -CONFIG_CMD_SF=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y @@ -43,7 +42,7 @@ CONFIG_DM=y CONFIG_MVSATA_IDE=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y -CONFIG_SPI_FLASH=y +CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHY_MARVELL=y CONFIG_DM_ETH=y @@ -53,6 +52,7 @@ CONFIG_DM_RTC=y CONFIG_RTC_MV=y CONFIG_SYS_NS16550=y CONFIG_SPI=y +CONFIG_DM_SPI=y CONFIG_KIRKWOOD_SPI=y CONFIG_USB=y CONFIG_DM_USB=y
On Thu, Jun 18, 2020 at 11:15 PM Jagan Teki jagan@amarulasolutions.com wrote:
Applied to u-boot-spi/master
Remove it.
Patch-cc: Simon Guinot simon.guinot@sequanux.org Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- Changes for v3: - new patch
arch/arm/mach-kirkwood/Kconfig | 4 - board/LaCie/netspace_v2/Kconfig | 12 -- board/LaCie/netspace_v2/MAINTAINERS | 14 -- board/LaCie/netspace_v2/Makefile | 10 -- board/LaCie/netspace_v2/kwbimage-is2.cfg | 149 ---------------------- board/LaCie/netspace_v2/kwbimage-ns2l.cfg | 149 ---------------------- board/LaCie/netspace_v2/kwbimage.cfg | 149 ---------------------- board/LaCie/netspace_v2/netspace_v2.c | 120 ----------------- board/LaCie/netspace_v2/netspace_v2.h | 22 ---- configs/inetspace_v2_defconfig | 53 -------- configs/netspace_lite_v2_defconfig | 53 -------- configs/netspace_max_v2_defconfig | 53 -------- configs/netspace_mini_v2_defconfig | 48 ------- configs/netspace_v2_defconfig | 53 -------- 14 files changed, 889 deletions(-) delete mode 100644 board/LaCie/netspace_v2/Kconfig delete mode 100644 board/LaCie/netspace_v2/MAINTAINERS delete mode 100644 board/LaCie/netspace_v2/Makefile delete mode 100644 board/LaCie/netspace_v2/kwbimage-is2.cfg delete mode 100644 board/LaCie/netspace_v2/kwbimage-ns2l.cfg delete mode 100644 board/LaCie/netspace_v2/kwbimage.cfg delete mode 100644 board/LaCie/netspace_v2/netspace_v2.c delete mode 100644 board/LaCie/netspace_v2/netspace_v2.h delete mode 100644 configs/inetspace_v2_defconfig delete mode 100644 configs/netspace_lite_v2_defconfig delete mode 100644 configs/netspace_max_v2_defconfig delete mode 100644 configs/netspace_mini_v2_defconfig delete mode 100644 configs/netspace_v2_defconfig
diff --git a/arch/arm/mach-kirkwood/Kconfig b/arch/arm/mach-kirkwood/Kconfig index ad6aef45bf..899c079773 100644 --- a/arch/arm/mach-kirkwood/Kconfig +++ b/arch/arm/mach-kirkwood/Kconfig @@ -35,9 +35,6 @@ config TARGET_KM_KIRKWOOD bool "KM Kirkwood Board" select VENDOR_KM
-config TARGET_NETSPACE_V2 - bool "LaCie netspace_v2 Board" - config TARGET_IB62X0 bool "ib62x0 Board"
@@ -77,7 +74,6 @@ source "board/cloudengines/pogo_e02/Kconfig" source "board/d-link/dns325/Kconfig" source "board/iomega/iconnect/Kconfig" source "board/keymile/Kconfig" -source "board/LaCie/netspace_v2/Kconfig" source "board/raidsonic/ib62x0/Kconfig" source "board/Seagate/dockstar/Kconfig" source "board/Seagate/goflexhome/Kconfig" diff --git a/board/LaCie/netspace_v2/Kconfig b/board/LaCie/netspace_v2/Kconfig deleted file mode 100644 index 930b822dfb..0000000000 --- a/board/LaCie/netspace_v2/Kconfig +++ /dev/null @@ -1,12 +0,0 @@ -if TARGET_NETSPACE_V2 - -config SYS_BOARD - default "netspace_v2" - -config SYS_VENDOR - default "LaCie" - -config SYS_CONFIG_NAME - default "lacie_kw" - -endif diff --git a/board/LaCie/netspace_v2/MAINTAINERS b/board/LaCie/netspace_v2/MAINTAINERS deleted file mode 100644 index 55fd50d4eb..0000000000 --- a/board/LaCie/netspace_v2/MAINTAINERS +++ /dev/null @@ -1,14 +0,0 @@ -NETSPACE_V2 BOARD -M: Simon Guinot simon.guinot@sequanux.org -S: Maintained -F: board/LaCie/netspace_v2/ -F: include/configs/lacie_kw.h -F: configs/inetspace_v2_defconfig -F: configs/netspace_max_v2_defconfig -F: configs/netspace_v2_defconfig - -NETSPACE_LITE_V2 BOARD -#M: - -S: Maintained -F: configs/netspace_lite_v2_defconfig -F: configs/netspace_mini_v2_defconfig diff --git a/board/LaCie/netspace_v2/Makefile b/board/LaCie/netspace_v2/Makefile deleted file mode 100644 index a6270bdd4b..0000000000 --- a/board/LaCie/netspace_v2/Makefile +++ /dev/null @@ -1,10 +0,0 @@ -# SPDX-License-Identifier: GPL-2.0+ -# -# Copyright (C) 2011 Simon Guinot sguinot@lacie.com -# -# Based on Kirkwood support: -# (C) Copyright 2009 -# Marvell Semiconductor <www.marvell.com> -# Written-by: Prafulla Wadaskar prafulla@marvell.com - -obj-y := netspace_v2.o ../common/common.o diff --git a/board/LaCie/netspace_v2/kwbimage-is2.cfg b/board/LaCie/netspace_v2/kwbimage-is2.cfg deleted file mode 100644 index 50f584ae70..0000000000 --- a/board/LaCie/netspace_v2/kwbimage-is2.cfg +++ /dev/null @@ -1,149 +0,0 @@ -# SPDX-License-Identifier: GPL-2.0+ -# -# Copyright (C) 2011 Simon Guinot sguinot@lacie.com -# -# Based on Kirkwood support: -# (C) Copyright 2009 -# Marvell Semiconductor <www.marvell.com> -# Written-by: Prafulla Wadaskar prafulla@marvell.com -# Refer doc/README.kwbimage for more details about how-to configure -# and create kirkwood boot image -# - -# Boot Media configurations -BOOT_FROM spi # Boot from SPI flash - -# SOC registers configuration using bootrom header extension -# Maximum KWBIMAGE_MAX_CONFIG configurations allowed - -# Configure RGMII-0 interface pad voltage to 1.8V -DATA 0xFFD100e0 0x1B1B1B9B - -#Dram initalization for SINGLE x16 CL=5 @ 400MHz -DATA 0xFFD01400 0x43000618 # DDR Configuration register -# bit13-0: 0xa00 (2560 DDR2 clks refresh rate) -# bit23-14: zero -# bit24: 1= enable exit self refresh mode on DDR access -# bit25: 1 required -# bit29-26: zero -# bit31-30: 01 - -DATA 0xFFD01404 0x35143000 # DDR Controller Control Low -# bit 4: 0=addr/cmd in smame cycle -# bit 5: 0=clk is driven during self refresh, we don't care for APX -# bit 6: 0=use recommended falling edge of clk for addr/cmd -# bit14: 0=input buffer always powered up -# bit18: 1=cpu lock transaction enabled -# bit23-20: 5=recommended value for CL=5 and STARTBURST_DEL disabled bit31=0 -# bit27-24: 8= CL+3, STARTBURST sample stages, for freqs 400MHz, unbuffered DIMM -# bit30-28: 3 required -# bit31: 0=no additional STARTBURST delay - -DATA 0xFFD01408 0x11012228 # DDR Timing (Low) (active cycles value +1) -# bit7-4: TRCD -# bit11- 8: TRP -# bit15-12: TWR -# bit19-16: TWTR -# bit20: TRAS msb -# bit23-21: 0x0 -# bit27-24: TRRD -# bit31-28: TRTP - -DATA 0xFFD0140C 0x00000A19 # DDR Timing (High) -# bit6-0: TRFC -# bit8-7: TR2R -# bit10-9: TR2W -# bit12-11: TW2W -# bit31-13: zero required - -DATA 0xFFD01410 0x00000008 # DDR Address Control -# bit1-0: 00, Cs0width=x8 -# bit3-2: 10, Cs0size=512Mb -# bit5-4: 00, Cs2width=nonexistent -# bit7-6: 00, Cs1size =nonexistent -# bit9-8: 00, Cs2width=nonexistent -# bit11-10: 00, Cs2size =nonexistent -# bit13-12: 00, Cs3width=nonexistent -# bit15-14: 00, Cs3size =nonexistent -# bit16: 0, Cs0AddrSel -# bit17: 0, Cs1AddrSel -# bit18: 0, Cs2AddrSel -# bit19: 0, Cs3AddrSel -# bit31-20: 0 required - -DATA 0xFFD01414 0x00000000 # DDR Open Pages Control -# bit0: 0, OpenPage enabled -# bit31-1: 0 required - -DATA 0xFFD01418 0x00000000 # DDR Operation -# bit3-0: 0x0, DDR cmd -# bit31-4: 0 required - -DATA 0xFFD0141C 0x00000632 # DDR Mode -# bit2-0: 2, BurstLen=2 required -# bit3: 0, BurstType=0 required -# bit6-4: 4, CL=5 -# bit7: 0, TestMode=0 normal -# bit8: 0, DLL reset=0 normal -# bit11-9: 6, auto-precharge write recovery ???????????? -# bit12: 0, PD must be zero -# bit31-13: 0 required - -DATA 0xFFD01420 0x00000004 # DDR Extended Mode -# bit0: 0, DDR DLL enabled -# bit1: 1, DDR drive strenght reduced -# bit2: 1, DDR ODT control lsd enabled -# bit5-3: 000, required -# bit6: 1, DDR ODT control msb, enabled -# bit9-7: 000, required -# bit10: 0, differential DQS enabled -# bit11: 0, required -# bit12: 0, DDR output buffer enabled -# bit31-13: 0 required - -DATA 0xFFD01424 0x0000F07F # DDR Controller Control High -# bit2-0: 111, required -# bit3 : 1 , MBUS Burst Chop disabled -# bit6-4: 111, required -# bit7 : 1 , D2P Latency enabled -# bit8 : 1 , add writepath sample stage, must be 1 for DDR freq >= 300MHz -# bit9 : 0 , no half clock cycle addition to dataout -# bit10 : 0 , 1/4 clock cycle skew enabled for addr/ctl signals -# bit11 : 0 , 1/4 clock cycle skew disabled for write mesh -# bit15-12: 1111 required -# bit31-16: 0 required - -DATA 0xFFD01428 0x00085520 # DDR2 ODT Read Timing (default values) -DATA 0xFFD0147C 0x00008552 # DDR2 ODT Write Timing (default values) - -DATA 0xFFD01500 0x00000000 # CS[0]n Base address to 0x0 -DATA 0xFFD01504 0x07FFFFF1 # CS[0]n Size -# bit0: 1, Window enabled -# bit1: 0, Write Protect disabled -# bit3-2: 00, CS0 hit selected -# bit23-4: ones, required -# bit31-24: 0x07, Size (i.e. 128MB) - -DATA 0xFFD0150C 0x00000000 # CS[1]n Size, window disabled -DATA 0xFFD01514 0x00000000 # CS[2]n Size, window disabled -DATA 0xFFD0151C 0x00000000 # CS[3]n Size, window disabled - -DATA 0xFFD01494 0x00010000 # DDR ODT Control (Low) -# bit3-0: 1, ODT0Rd, MODT[0] asserted during read from DRAM CS0 -# bit19-16:1, ODT0Wr, MODT[0] asserted during write to DRAM CS0 - -DATA 0xFFD01498 0x00000000 # DDR ODT Control (High) -# bit1-0: 00, ODT0 controlled by ODT Control (low) register above -# bit3-2: 01, ODT1 active NEVER! -# bit31-4: zero, required - -DATA 0xFFD0149C 0x0000E40F # CPU ODT Control -# bit3-0: 1, ODT0Rd, Internal ODT asserted during read from DRAM bank0 -# bit7-4: 1, ODT0Wr, Internal ODT asserted during write to DRAM bank0 -# bit11-10:1, DQ_ODTSel. ODT select turned on - -DATA 0xFFD01480 0x00000001 # DDR Initialization Control -#bit0=1, enable DDR init upon this register write - -# End of Header extension -DATA 0x0 0x0 diff --git a/board/LaCie/netspace_v2/kwbimage-ns2l.cfg b/board/LaCie/netspace_v2/kwbimage-ns2l.cfg deleted file mode 100644 index 092353a06d..0000000000 --- a/board/LaCie/netspace_v2/kwbimage-ns2l.cfg +++ /dev/null @@ -1,149 +0,0 @@ -# SPDX-License-Identifier: GPL-2.0+ -# -# Copyright (C) 2011 Simon Guinot sguinot@lacie.com -# -# Based on Kirkwood support: -# (C) Copyright 2009 -# Marvell Semiconductor <www.marvell.com> -# Written-by: Prafulla Wadaskar prafulla@marvell.com -# Refer doc/README.kwbimage for more details about how-to configure -# and create kirkwood boot image -# - -# Boot Media configurations -BOOT_FROM spi # Boot from SPI flash - -# SOC registers configuration using bootrom header extension -# Maximum KWBIMAGE_MAX_CONFIG configurations allowed - -# Configure RGMII-0 interface pad voltage to 1.8V -DATA 0xFFD100e0 0x1B1B1B9B - -#Dram initalization for SINGLE x16 CL=5 @ 400MHz -DATA 0xFFD01400 0x43000618 # DDR Configuration register -# bit13-0: 0xa00 (2560 DDR2 clks refresh rate) -# bit23-14: zero -# bit24: 1= enable exit self refresh mode on DDR access -# bit25: 1 required -# bit29-26: zero -# bit31-30: 01 - -DATA 0xFFD01404 0x34143000 # DDR Controller Control Low -# bit 4: 0=addr/cmd in smame cycle -# bit 5: 0=clk is driven during self refresh, we don't care for APX -# bit 6: 0=use recommended falling edge of clk for addr/cmd -# bit14: 0=input buffer always powered up -# bit18: 1=cpu lock transaction enabled -# bit23-20: 5=recommended value for CL=5 and STARTBURST_DEL disabled bit31=0 -# bit27-24: 8= CL+3, STARTBURST sample stages, for freqs 400MHz, unbuffered DIMM -# bit30-28: 3 required -# bit31: 0=no additional STARTBURST delay - -DATA 0xFFD01408 0x11012228 # DDR Timing (Low) (active cycles value +1) -# bit7-4: TRCD -# bit11- 8: TRP -# bit15-12: TWR -# bit19-16: TWTR -# bit20: TRAS msb -# bit23-21: 0x0 -# bit27-24: TRRD -# bit31-28: TRTP - -DATA 0xFFD0140C 0x00000A19 # DDR Timing (High) -# bit6-0: TRFC -# bit8-7: TR2R -# bit10-9: TR2W -# bit12-11: TW2W -# bit31-13: zero required - -DATA 0xFFD01410 0x0000DDDD # DDR Address Control -# bit1-0: 00, Cs0width=x8 -# bit3-2: 10, Cs0size=512Mb -# bit5-4: 00, Cs2width=nonexistent -# bit7-6: 00, Cs1size =nonexistent -# bit9-8: 00, Cs2width=nonexistent -# bit11-10: 00, Cs2size =nonexistent -# bit13-12: 00, Cs3width=nonexistent -# bit15-14: 00, Cs3size =nonexistent -# bit16: 0, Cs0AddrSel -# bit17: 0, Cs1AddrSel -# bit18: 0, Cs2AddrSel -# bit19: 0, Cs3AddrSel -# bit31-20: 0 required - -DATA 0xFFD01414 0x00000000 # DDR Open Pages Control -# bit0: 0, OpenPage enabled -# bit31-1: 0 required - -DATA 0xFFD01418 0x00000000 # DDR Operation -# bit3-0: 0x0, DDR cmd -# bit31-4: 0 required - -DATA 0xFFD0141C 0x00000632 # DDR Mode -# bit2-0: 2, BurstLen=2 required -# bit3: 0, BurstType=0 required -# bit6-4: 4, CL=5 -# bit7: 0, TestMode=0 normal -# bit8: 0, DLL reset=0 normal -# bit11-9: 6, auto-precharge write recovery ???????????? -# bit12: 0, PD must be zero -# bit31-13: 0 required - -DATA 0xFFD01420 0x00000004 # DDR Extended Mode -# bit0: 0, DDR DLL enabled -# bit1: 1, DDR drive strenght reduced -# bit2: 1, DDR ODT control lsd enabled -# bit5-3: 000, required -# bit6: 1, DDR ODT control msb, enabled -# bit9-7: 000, required -# bit10: 0, differential DQS enabled -# bit11: 0, required -# bit12: 0, DDR output buffer enabled -# bit31-13: 0 required - -DATA 0xFFD01424 0x0000F07F # DDR Controller Control High -# bit2-0: 111, required -# bit3 : 1 , MBUS Burst Chop disabled -# bit6-4: 111, required -# bit7 : 1 , D2P Latency enabled -# bit8 : 1 , add writepath sample stage, must be 1 for DDR freq >= 300MHz -# bit9 : 0 , no half clock cycle addition to dataout -# bit10 : 0 , 1/4 clock cycle skew enabled for addr/ctl signals -# bit11 : 0 , 1/4 clock cycle skew disabled for write mesh -# bit15-12: 1111 required -# bit31-16: 0 required - -DATA 0xFFD01428 0x00085520 # DDR2 ODT Read Timing (default values) -DATA 0xFFD0147C 0x00008552 # DDR2 ODT Write Timing (default values) - -DATA 0xFFD01500 0x00000000 # CS[0]n Base address to 0x0 -DATA 0xFFD01504 0x07FFFFF1 # CS[0]n Size -# bit0: 1, Window enabled -# bit1: 0, Write Protect disabled -# bit3-2: 00, CS0 hit selected -# bit23-4: ones, required -# bit31-24: 0x07, Size (i.e. 128MB) - -DATA 0xFFD0150C 0x00000000 # CS[1]n Size, window disabled -DATA 0xFFD01514 0x00000000 # CS[2]n Size, window disabled -DATA 0xFFD0151C 0x00000000 # CS[3]n Size, window disabled - -DATA 0xFFD01494 0x00010000 # DDR ODT Control (Low) -# bit3-0: 1, ODT0Rd, MODT[0] asserted during read from DRAM CS0 -# bit19-16:1, ODT0Wr, MODT[0] asserted during write to DRAM CS0 - -DATA 0xFFD01498 0x00000000 # DDR ODT Control (High) -# bit1-0: 00, ODT0 controlled by ODT Control (low) register above -# bit3-2: 01, ODT1 active NEVER! -# bit31-4: zero, required - -DATA 0xFFD0149C 0x0000E40F # CPU ODT Control -# bit3-0: 1, ODT0Rd, Internal ODT asserted during read from DRAM bank0 -# bit7-4: 1, ODT0Wr, Internal ODT asserted during write to DRAM bank0 -# bit11-10:1, DQ_ODTSel. ODT select turned on - -DATA 0xFFD01480 0x00000001 # DDR Initialization Control -#bit0=1, enable DDR init upon this register write - -# End of Header extension -DATA 0x0 0x0 diff --git a/board/LaCie/netspace_v2/kwbimage.cfg b/board/LaCie/netspace_v2/kwbimage.cfg deleted file mode 100644 index 1ed03fa9a9..0000000000 --- a/board/LaCie/netspace_v2/kwbimage.cfg +++ /dev/null @@ -1,149 +0,0 @@ -# SPDX-License-Identifier: GPL-2.0+ -# -# Copyright (C) 2011 Simon Guinot sguinot@lacie.com -# -# Based on Kirkwood support: -# (C) Copyright 2009 -# Marvell Semiconductor <www.marvell.com> -# Written-by: Prafulla Wadaskar prafulla@marvell.com -# Refer doc/README.kwbimage for more details about how-to configure -# and create kirkwood boot image -# - -# Boot Media configurations -BOOT_FROM spi # Boot from SPI flash - -# SOC registers configuration using bootrom header extension -# Maximum KWBIMAGE_MAX_CONFIG configurations allowed - -# Configure RGMII-0 interface pad voltage to 1.8V -DATA 0xFFD100e0 0x1B1B1B9B - -#Dram initalization for SINGLE x16 CL=5 @ 400MHz -DATA 0xFFD01400 0x43000618 # DDR Configuration register -# bit13-0: 0xa00 (2560 DDR2 clks refresh rate) -# bit23-14: zero -# bit24: 1= enable exit self refresh mode on DDR access -# bit25: 1 required -# bit29-26: zero -# bit31-30: 01 - -DATA 0xFFD01404 0x35143000 # DDR Controller Control Low -# bit 4: 0=addr/cmd in smame cycle -# bit 5: 0=clk is driven during self refresh, we don't care for APX -# bit 6: 0=use recommended falling edge of clk for addr/cmd -# bit14: 0=input buffer always powered up -# bit18: 1=cpu lock transaction enabled -# bit23-20: 5=recommended value for CL=5 and STARTBURST_DEL disabled bit31=0 -# bit27-24: 8= CL+3, STARTBURST sample stages, for freqs 400MHz, unbuffered DIMM -# bit30-28: 3 required -# bit31: 0=no additional STARTBURST delay - -DATA 0xFFD01408 0x11012228 # DDR Timing (Low) (active cycles value +1) -# bit7-4: TRCD -# bit11- 8: TRP -# bit15-12: TWR -# bit19-16: TWTR -# bit20: TRAS msb -# bit23-21: 0x0 -# bit27-24: TRRD -# bit31-28: TRTP - -DATA 0xFFD0140C 0x00000A19 # DDR Timing (High) -# bit6-0: TRFC -# bit8-7: TR2R -# bit10-9: TR2W -# bit12-11: TW2W -# bit31-13: zero required - -DATA 0xFFD01410 0x0000000C # DDR Address Control -# bit1-0: 00, Cs0width=x8 -# bit3-2: 11, Cs0size=1Gb -# bit5-4: 00, Cs2width=nonexistent -# bit7-6: 00, Cs1size =nonexistent -# bit9-8: 00, Cs2width=nonexistent -# bit11-10: 00, Cs2size =nonexistent -# bit13-12: 00, Cs3width=nonexistent -# bit15-14: 00, Cs3size =nonexistent -# bit16: 0, Cs0AddrSel -# bit17: 0, Cs1AddrSel -# bit18: 0, Cs2AddrSel -# bit19: 0, Cs3AddrSel -# bit31-20: 0 required - -DATA 0xFFD01414 0x00000000 # DDR Open Pages Control -# bit0: 0, OpenPage enabled -# bit31-1: 0 required - -DATA 0xFFD01418 0x00000000 # DDR Operation -# bit3-0: 0x0, DDR cmd -# bit31-4: 0 required - -DATA 0xFFD0141C 0x00000632 # DDR Mode -# bit2-0: 2, BurstLen=2 required -# bit3: 0, BurstType=0 required -# bit6-4: 4, CL=5 -# bit7: 0, TestMode=0 normal -# bit8: 0, DLL reset=0 normal -# bit11-9: 6, auto-precharge write recovery ???????????? -# bit12: 0, PD must be zero -# bit31-13: 0 required - -DATA 0xFFD01420 0x00000004 # DDR Extended Mode -# bit0: 0, DDR DLL enabled -# bit1: 1, DDR drive strenght reduced -# bit2: 1, DDR ODT control lsd enabled -# bit5-3: 000, required -# bit6: 1, DDR ODT control msb, enabled -# bit9-7: 000, required -# bit10: 0, differential DQS enabled -# bit11: 0, required -# bit12: 0, DDR output buffer enabled -# bit31-13: 0 required - -DATA 0xFFD01424 0x0000F07F # DDR Controller Control High -# bit2-0: 111, required -# bit3 : 1 , MBUS Burst Chop disabled -# bit6-4: 111, required -# bit7 : 1 , D2P Latency enabled -# bit8 : 1 , add writepath sample stage, must be 1 for DDR freq >= 300MHz -# bit9 : 0 , no half clock cycle addition to dataout -# bit10 : 0 , 1/4 clock cycle skew enabled for addr/ctl signals -# bit11 : 0 , 1/4 clock cycle skew disabled for write mesh -# bit15-12: 1111 required -# bit31-16: 0 required - -DATA 0xFFD01428 0x00085520 # DDR2 ODT Read Timing (default values) -DATA 0xFFD0147C 0x00008552 # DDR2 ODT Write Timing (default values) - -DATA 0xFFD01500 0x00000000 # CS[0]n Base address to 0x0 -DATA 0xFFD01504 0x0FFFFFF1 # CS[0]n Size -# bit0: 1, Window enabled -# bit1: 0, Write Protect disabled -# bit3-2: 00, CS0 hit selected -# bit23-4: ones, required -# bit31-24: 0x07, Size (i.e. 128MB) - -DATA 0xFFD0150C 0x00000000 # CS[1]n Size, window disabled -DATA 0xFFD01514 0x00000000 # CS[2]n Size, window disabled -DATA 0xFFD0151C 0x00000000 # CS[3]n Size, window disabled - -DATA 0xFFD01494 0x00010000 # DDR ODT Control (Low) -# bit3-0: 1, ODT0Rd, MODT[0] asserted during read from DRAM CS0 -# bit19-16:1, ODT0Wr, MODT[0] asserted during write to DRAM CS0 - -DATA 0xFFD01498 0x00000000 # DDR ODT Control (High) -# bit1-0: 00, ODT0 controlled by ODT Control (low) register above -# bit3-2: 01, ODT1 active NEVER! -# bit31-4: zero, required - -DATA 0xFFD0149C 0x0000E40F # CPU ODT Control -# bit3-0: 1, ODT0Rd, Internal ODT asserted during read from DRAM bank0 -# bit7-4: 1, ODT0Wr, Internal ODT asserted during write to DRAM bank0 -# bit11-10:1, DQ_ODTSel. ODT select turned on - -DATA 0xFFD01480 0x00000001 # DDR Initialization Control -#bit0=1, enable DDR init upon this register write - -# End of Header extension -DATA 0x0 0x0 diff --git a/board/LaCie/netspace_v2/netspace_v2.c b/board/LaCie/netspace_v2/netspace_v2.c deleted file mode 100644 index 011cc563d1..0000000000 --- a/board/LaCie/netspace_v2/netspace_v2.c +++ /dev/null @@ -1,120 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Copyright (C) 2011 Simon Guinot sguinot@lacie.com - * - * Based on Kirkwood support: - * (C) Copyright 2009 - * Marvell Semiconductor <www.marvell.com> - * Written-by: Prafulla Wadaskar prafulla@marvell.com - */ - -#include <common.h> -#include <command.h> -#include <env.h> -#include <init.h> -#include <net.h> -#include <asm/mach-types.h> -#include <asm/arch/cpu.h> -#include <asm/arch/soc.h> -#include <asm/arch/mpp.h> -#include <asm/arch/gpio.h> - -#include "netspace_v2.h" -#include "../common/common.h" - -DECLARE_GLOBAL_DATA_PTR; - -int board_early_init_f(void) -{ - /* Gpio configuration */ - mvebu_config_gpio(NETSPACE_V2_OE_VAL_LOW, NETSPACE_V2_OE_VAL_HIGH, - NETSPACE_V2_OE_LOW, NETSPACE_V2_OE_HIGH); - - /* Multi-Purpose Pins Functionality configuration */ - static const u32 kwmpp_config[] = { - MPP0_SPI_SCn, - MPP1_SPI_MOSI, - MPP2_SPI_SCK, - MPP3_SPI_MISO, - MPP4_NF_IO6, - MPP5_NF_IO7, - MPP6_SYSRST_OUTn, - MPP7_GPO, /* Fan speed (bit 1) */ - MPP8_TW_SDA, - MPP9_TW_SCK, - MPP10_UART0_TXD, - MPP11_UART0_RXD, - MPP12_GPO, /* Red led */ - MPP14_GPIO, /* USB fuse */ - MPP16_GPIO, /* SATA 0 power */ - MPP17_GPIO, /* SATA 1 power */ - MPP18_NF_IO0, - MPP19_NF_IO1, - MPP20_SATA1_ACTn, - MPP21_SATA0_ACTn, - MPP22_GPIO, /* Fan speed (bit 0) */ - MPP23_GPIO, /* Fan power */ - MPP24_GPIO, /* USB mode select */ - MPP25_GPIO, /* Fan rotation fail */ - MPP26_GPIO, /* USB vbus-in detection */ - MPP28_GPIO, /* USB enable vbus-out */ - MPP29_GPIO, /* Blue led (slow register) */ - MPP30_GPIO, /* Blue led (command register) */ - MPP31_GPIO, /* Board power off */ - MPP32_GPIO, /* Button (0 = Released, 1 = Pushed) */ - MPP33_GPIO, /* Fan speed (bit 2) */ - 0 - }; - kirkwood_mpp_conf(kwmpp_config, NULL); - - return 0; -} - -int board_init(void) -{ - /* Machine number */ - gd->bd->bi_arch_number = CONFIG_MACH_TYPE; - - /* Boot parameters address */ - gd->bd->bi_boot_params = mvebu_sdram_bar(0) + 0x100; - - return 0; -} - -#if defined(CONFIG_MISC_INIT_R) -int misc_init_r(void) -{ -#if defined(CONFIG_CMD_I2C) && defined(CONFIG_SYS_I2C_EEPROM_ADDR) - if (!env_get("ethaddr")) { - uchar mac[6]; - if (lacie_read_mac_address(mac) == 0) - eth_env_set_enetaddr("ethaddr", mac); - } -#endif - return 0; -} -#endif - -#if defined(CONFIG_CMD_NET) && defined(CONFIG_RESET_PHY_R) -/* Configure and initialize PHY */ -void reset_phy(void) -{ -#if defined(CONFIG_NETSPACE_LITE_V2) || defined(CONFIG_NETSPACE_MINI_V2) - mv_phy_88e1318_init("egiga0", 0); -#else - mv_phy_88e1116_init("egiga0", 8); -#endif -} -#endif - -#if defined(CONFIG_KIRKWOOD_GPIO) -/* Return GPIO button status */ -static int -do_read_button(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) -{ - return kw_gpio_get_value(NETSPACE_V2_GPIO_BUTTON); -} - -U_BOOT_CMD(button, 1, 1, do_read_button, - "Return GPIO button status 0=off 1=on", ""); -#endif diff --git a/board/LaCie/netspace_v2/netspace_v2.h b/board/LaCie/netspace_v2/netspace_v2.h deleted file mode 100644 index 2c930171ea..0000000000 --- a/board/LaCie/netspace_v2/netspace_v2.h +++ /dev/null @@ -1,22 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Copyright (C) 2011 Simon Guinot sguinot@lacie.com - * - * Based on Kirkwood support: - * (C) Copyright 2009 - * Marvell Semiconductor <www.marvell.com> - * Written-by: Prafulla Wadaskar prafulla@marvell.com - */ - -#ifndef NETSPACE_V2_H -#define NETSPACE_V2_H - -/* GPIO configuration */ -#define NETSPACE_V2_OE_LOW 0x06004000 -#define NETSPACE_V2_OE_HIGH 0x00000031 -#define NETSPACE_V2_OE_VAL_LOW 0x10030000 -#define NETSPACE_V2_OE_VAL_HIGH 0x00000000 - -#define NETSPACE_V2_GPIO_BUTTON 32 - -#endif /* NETSPACE_V2_H */ diff --git a/configs/inetspace_v2_defconfig b/configs/inetspace_v2_defconfig deleted file mode 100644 index 6144eb5fad..0000000000 --- a/configs/inetspace_v2_defconfig +++ /dev/null @@ -1,53 +0,0 @@ -CONFIG_ARM=y -CONFIG_SYS_DCACHE_OFF=y -CONFIG_ARCH_CPU_INIT=y -CONFIG_ARCH_KIRKWOOD=y -CONFIG_SYS_TEXT_BASE=0x600000 -CONFIG_TARGET_NETSPACE_V2=y -CONFIG_ENV_SIZE=0x1000 -CONFIG_ENV_OFFSET=0x70000 -CONFIG_ENV_SECT_SIZE=0x10000 -CONFIG_NR_DRAM_BANKS=2 -CONFIG_IDENT_STRING=" IS v2" -CONFIG_SYS_EXTRA_OPTIONS="INETSPACE_V2" -CONFIG_BOOTDELAY=3 -CONFIG_USE_BOOTARGS=y -CONFIG_BOOTARGS="console=ttyS0,115200" -CONFIG_USE_PREBOOT=y -CONFIG_CONSOLE_MUX=y -CONFIG_MISC_INIT_R=y -# CONFIG_DISPLAY_BOARDINFO is not set -CONFIG_HUSH_PARSER=y -CONFIG_SYS_PROMPT="ns2> " -CONFIG_CMD_EEPROM=y -CONFIG_CMD_IDE=y -CONFIG_CMD_I2C=y -CONFIG_CMD_SF=y -CONFIG_CMD_USB=y -# CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_FAT=y -CONFIG_ISO_PARTITION=y -CONFIG_EFI_PARTITION=y -# CONFIG_PARTITION_UUIDS is not set -CONFIG_OF_CONTROL=y -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-is2" -CONFIG_ENV_IS_IN_SPI_FLASH=y -CONFIG_USE_ENV_SPI_MAX_HZ=y -CONFIG_ENV_SPI_MAX_HZ=20000000 -CONFIG_ENV_ADDR=0x70000 -CONFIG_MVSATA_IDE=y -# CONFIG_MMC is not set -CONFIG_SPI_FLASH=y -CONFIG_SPI_FLASH_MACRONIX=y -CONFIG_MVGBE=y -CONFIG_MII=y -CONFIG_SYS_NS16550=y -CONFIG_SPI=y -CONFIG_KIRKWOOD_SPI=y -CONFIG_USB=y -CONFIG_USB_EHCI_HCD=y -CONFIG_USB_STORAGE=y diff --git a/configs/netspace_lite_v2_defconfig b/configs/netspace_lite_v2_defconfig deleted file mode 100644 index c744d2c58e..0000000000 --- a/configs/netspace_lite_v2_defconfig +++ /dev/null @@ -1,53 +0,0 @@ -CONFIG_ARM=y -CONFIG_SYS_DCACHE_OFF=y -CONFIG_ARCH_CPU_INIT=y -CONFIG_ARCH_KIRKWOOD=y -CONFIG_SYS_TEXT_BASE=0x600000 -CONFIG_TARGET_NETSPACE_V2=y -CONFIG_ENV_SIZE=0x1000 -CONFIG_ENV_OFFSET=0x70000 -CONFIG_ENV_SECT_SIZE=0x10000 -CONFIG_NR_DRAM_BANKS=2 -CONFIG_IDENT_STRING=" NS v2 Lite" -CONFIG_SYS_EXTRA_OPTIONS="NETSPACE_LITE_V2" -CONFIG_BOOTDELAY=3 -CONFIG_USE_BOOTARGS=y -CONFIG_BOOTARGS="console=ttyS0,115200" -CONFIG_USE_PREBOOT=y -CONFIG_CONSOLE_MUX=y -CONFIG_MISC_INIT_R=y -# CONFIG_DISPLAY_BOARDINFO is not set -CONFIG_HUSH_PARSER=y -CONFIG_SYS_PROMPT="ns2> " -CONFIG_CMD_EEPROM=y -CONFIG_CMD_IDE=y -CONFIG_CMD_I2C=y -CONFIG_CMD_SF=y -CONFIG_CMD_USB=y -# CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_FAT=y -CONFIG_ISO_PARTITION=y -CONFIG_EFI_PARTITION=y -# CONFIG_PARTITION_UUIDS is not set -CONFIG_OF_CONTROL=y -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-ns2lite" -CONFIG_ENV_IS_IN_SPI_FLASH=y -CONFIG_USE_ENV_SPI_MAX_HZ=y -CONFIG_ENV_SPI_MAX_HZ=20000000 -CONFIG_ENV_ADDR=0x70000 -CONFIG_MVSATA_IDE=y -# CONFIG_MMC is not set -CONFIG_SPI_FLASH=y -CONFIG_SPI_FLASH_MACRONIX=y -CONFIG_MVGBE=y -CONFIG_MII=y -CONFIG_SYS_NS16550=y -CONFIG_SPI=y -CONFIG_KIRKWOOD_SPI=y -CONFIG_USB=y -CONFIG_USB_EHCI_HCD=y -CONFIG_USB_STORAGE=y diff --git a/configs/netspace_max_v2_defconfig b/configs/netspace_max_v2_defconfig deleted file mode 100644 index 8602729fcb..0000000000 --- a/configs/netspace_max_v2_defconfig +++ /dev/null @@ -1,53 +0,0 @@ -CONFIG_ARM=y -CONFIG_SYS_DCACHE_OFF=y -CONFIG_ARCH_CPU_INIT=y -CONFIG_ARCH_KIRKWOOD=y -CONFIG_SYS_TEXT_BASE=0x600000 -CONFIG_TARGET_NETSPACE_V2=y -CONFIG_ENV_SIZE=0x1000 -CONFIG_ENV_OFFSET=0x70000 -CONFIG_ENV_SECT_SIZE=0x10000 -CONFIG_NR_DRAM_BANKS=2 -CONFIG_IDENT_STRING=" NS Max v2" -CONFIG_SYS_EXTRA_OPTIONS="NETSPACE_MAX_V2" -CONFIG_BOOTDELAY=3 -CONFIG_USE_BOOTARGS=y -CONFIG_BOOTARGS="console=ttyS0,115200" -CONFIG_USE_PREBOOT=y -CONFIG_CONSOLE_MUX=y -CONFIG_MISC_INIT_R=y -# CONFIG_DISPLAY_BOARDINFO is not set -CONFIG_HUSH_PARSER=y -CONFIG_SYS_PROMPT="ns2> " -CONFIG_CMD_EEPROM=y -CONFIG_CMD_IDE=y -CONFIG_CMD_I2C=y -CONFIG_CMD_SF=y -CONFIG_CMD_USB=y -# CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_FAT=y -CONFIG_ISO_PARTITION=y -CONFIG_EFI_PARTITION=y -# CONFIG_PARTITION_UUIDS is not set -CONFIG_OF_CONTROL=y -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-ns2max" -CONFIG_ENV_IS_IN_SPI_FLASH=y -CONFIG_USE_ENV_SPI_MAX_HZ=y -CONFIG_ENV_SPI_MAX_HZ=20000000 -CONFIG_ENV_ADDR=0x70000 -CONFIG_MVSATA_IDE=y -# CONFIG_MMC is not set -CONFIG_SPI_FLASH=y -CONFIG_SPI_FLASH_MACRONIX=y -CONFIG_MVGBE=y -CONFIG_MII=y -CONFIG_SYS_NS16550=y -CONFIG_SPI=y -CONFIG_KIRKWOOD_SPI=y -CONFIG_USB=y -CONFIG_USB_EHCI_HCD=y -CONFIG_USB_STORAGE=y diff --git a/configs/netspace_mini_v2_defconfig b/configs/netspace_mini_v2_defconfig deleted file mode 100644 index ba9301de4d..0000000000 --- a/configs/netspace_mini_v2_defconfig +++ /dev/null @@ -1,48 +0,0 @@ -CONFIG_ARM=y -CONFIG_SYS_DCACHE_OFF=y -CONFIG_ARCH_CPU_INIT=y -CONFIG_ARCH_KIRKWOOD=y -CONFIG_SYS_TEXT_BASE=0x600000 -CONFIG_TARGET_NETSPACE_V2=y -CONFIG_ENV_SIZE=0x1000 -CONFIG_ENV_OFFSET=0x70000 -CONFIG_ENV_SECT_SIZE=0x10000 -CONFIG_NR_DRAM_BANKS=2 -CONFIG_IDENT_STRING=" NS v2 Mini" -CONFIG_SYS_EXTRA_OPTIONS="NETSPACE_MINI_V2" -CONFIG_BOOTDELAY=3 -CONFIG_USE_BOOTARGS=y -CONFIG_BOOTARGS="console=ttyS0,115200" -CONFIG_USE_PREBOOT=y -CONFIG_CONSOLE_MUX=y -CONFIG_MISC_INIT_R=y -# CONFIG_DISPLAY_BOARDINFO is not set -CONFIG_HUSH_PARSER=y -CONFIG_SYS_PROMPT="ns2> " -CONFIG_CMD_EEPROM=y -CONFIG_CMD_IDE=y -CONFIG_CMD_I2C=y -CONFIG_CMD_SF=y -# CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_FAT=y -CONFIG_EFI_PARTITION=y -# CONFIG_PARTITION_UUIDS is not set -CONFIG_OF_CONTROL=y -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-ns2mini" -CONFIG_ENV_IS_IN_SPI_FLASH=y -CONFIG_USE_ENV_SPI_MAX_HZ=y -CONFIG_ENV_SPI_MAX_HZ=20000000 -CONFIG_ENV_ADDR=0x70000 -CONFIG_MVSATA_IDE=y -# CONFIG_MMC is not set -CONFIG_SPI_FLASH=y -CONFIG_SPI_FLASH_MACRONIX=y -CONFIG_MVGBE=y -CONFIG_MII=y -CONFIG_SYS_NS16550=y -CONFIG_SPI=y -CONFIG_KIRKWOOD_SPI=y diff --git a/configs/netspace_v2_defconfig b/configs/netspace_v2_defconfig deleted file mode 100644 index 6ba1ef423e..0000000000 --- a/configs/netspace_v2_defconfig +++ /dev/null @@ -1,53 +0,0 @@ -CONFIG_ARM=y -CONFIG_SYS_DCACHE_OFF=y -CONFIG_ARCH_CPU_INIT=y -CONFIG_ARCH_KIRKWOOD=y -CONFIG_SYS_TEXT_BASE=0x600000 -CONFIG_TARGET_NETSPACE_V2=y -CONFIG_ENV_SIZE=0x1000 -CONFIG_ENV_OFFSET=0x70000 -CONFIG_ENV_SECT_SIZE=0x10000 -CONFIG_NR_DRAM_BANKS=2 -CONFIG_IDENT_STRING=" NS v2" -CONFIG_SYS_EXTRA_OPTIONS="NETSPACE_V2" -CONFIG_BOOTDELAY=3 -CONFIG_USE_BOOTARGS=y -CONFIG_BOOTARGS="console=ttyS0,115200" -CONFIG_USE_PREBOOT=y -CONFIG_CONSOLE_MUX=y -CONFIG_MISC_INIT_R=y -# CONFIG_DISPLAY_BOARDINFO is not set -CONFIG_HUSH_PARSER=y -CONFIG_SYS_PROMPT="ns2> " -CONFIG_CMD_EEPROM=y -CONFIG_CMD_IDE=y -CONFIG_CMD_I2C=y -CONFIG_CMD_SF=y -CONFIG_CMD_USB=y -# CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_FAT=y -CONFIG_ISO_PARTITION=y -CONFIG_EFI_PARTITION=y -# CONFIG_PARTITION_UUIDS is not set -CONFIG_OF_CONTROL=y -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-ns2" -CONFIG_ENV_IS_IN_SPI_FLASH=y -CONFIG_USE_ENV_SPI_MAX_HZ=y -CONFIG_ENV_SPI_MAX_HZ=20000000 -CONFIG_ENV_ADDR=0x70000 -CONFIG_MVSATA_IDE=y -# CONFIG_MMC is not set -CONFIG_SPI_FLASH=y -CONFIG_SPI_FLASH_MACRONIX=y -CONFIG_MVGBE=y -CONFIG_MII=y -CONFIG_SYS_NS16550=y -CONFIG_SPI=y -CONFIG_KIRKWOOD_SPI=y -CONFIG_USB=y -CONFIG_USB_EHCI_HCD=y -CONFIG_USB_STORAGE=y
I am working at converting this board too, along with net2big_v2.
Simon
Remove it.
Changes for v3:
- new patch
-config SYS_BOARD
-config SYS_VENDOR
- default "LaCie"
MPP0_SPI_SCn,
MPP1_SPI_MOSI,
MPP2_SPI_SCK,
MPP3_SPI_MISO,
MPP4_NF_IO6,
MPP5_NF_IO7,
MPP6_SYSRST_OUTn,
MPP8_TW_SDA,
MPP9_TW_SCK,
MPP10_UART0_TXD,
MPP11_UART0_RXD,
MPP18_NF_IO0,
MPP19_NF_IO1,
MPP20_SATA1_ACTn,
MPP21_SATA0_ACTn,
0
uchar mac[6];
-#endif
-} -#endif
-#else
-#endif -} -#endif
2.25.1
Hi Jagan,
On Fri, 19 Jun 2020, 5:45 AM Jagan Teki, jagan@amarulasolutions.com wrote:
Series of kirkwood boards to switch DM_SPI and drop which are not DM enabled still.
Any inputs? Jagan.
I had a quick glance over the series and it looks good to me.
I'm fortunate enough to be able to get into the office so I'll try and give this a spin on the kirkwood board I have on Monday.
Bhargav Shah (1):
spi: kirkwood: Drop nondm code
Jagan Teki (3): arm: Remove d2net_v2 board db-88f6281-bp-nand: Enable DM_SPI/SPI_FLASH arm: Remove netspace_v2 board
arch/arm/mach-kirkwood/Kconfig | 8 - board/LaCie/net2big_v2/Kconfig | 12 - board/LaCie/net2big_v2/MAINTAINERS | 7 - board/LaCie/net2big_v2/Makefile | 13 -- board/LaCie/net2big_v2/kwbimage.cfg | 149 ------------- board/LaCie/net2big_v2/net2big_v2.c | 257 ---------------------- board/LaCie/net2big_v2/net2big_v2.h | 28 --- board/LaCie/netspace_v2/Kconfig | 12 - board/LaCie/netspace_v2/MAINTAINERS | 14 -- board/LaCie/netspace_v2/Makefile | 10 - board/LaCie/netspace_v2/kwbimage-is2.cfg | 149 ------------- board/LaCie/netspace_v2/kwbimage-ns2l.cfg | 149 ------------- board/LaCie/netspace_v2/kwbimage.cfg | 149 ------------- board/LaCie/netspace_v2/netspace_v2.c | 120 ---------- board/LaCie/netspace_v2/netspace_v2.h | 22 -- configs/d2net_v2_defconfig | 53 ----- configs/db-88f6281-bp-nand_defconfig | 4 +- configs/inetspace_v2_defconfig | 53 ----- configs/net2big_v2_defconfig | 53 ----- configs/netspace_lite_v2_defconfig | 53 ----- configs/netspace_max_v2_defconfig | 53 ----- configs/netspace_mini_v2_defconfig | 48 ---- configs/netspace_v2_defconfig | 53 ----- drivers/spi/Kconfig | 12 +- drivers/spi/kirkwood_spi.c | 136 ++---------- include/configs/lacie_kw.h | 152 ------------- scripts/config_whitelist.txt | 1 - 27 files changed, 21 insertions(+), 1749 deletions(-) delete mode 100644 board/LaCie/net2big_v2/Kconfig delete mode 100644 board/LaCie/net2big_v2/MAINTAINERS delete mode 100644 board/LaCie/net2big_v2/Makefile delete mode 100644 board/LaCie/net2big_v2/kwbimage.cfg delete mode 100644 board/LaCie/net2big_v2/net2big_v2.c delete mode 100644 board/LaCie/net2big_v2/net2big_v2.h delete mode 100644 board/LaCie/netspace_v2/Kconfig delete mode 100644 board/LaCie/netspace_v2/MAINTAINERS delete mode 100644 board/LaCie/netspace_v2/Makefile delete mode 100644 board/LaCie/netspace_v2/kwbimage-is2.cfg delete mode 100644 board/LaCie/netspace_v2/kwbimage-ns2l.cfg delete mode 100644 board/LaCie/netspace_v2/kwbimage.cfg delete mode 100644 board/LaCie/netspace_v2/netspace_v2.c delete mode 100644 board/LaCie/netspace_v2/netspace_v2.h delete mode 100644 configs/d2net_v2_defconfig delete mode 100644 configs/inetspace_v2_defconfig delete mode 100644 configs/net2big_v2_defconfig delete mode 100644 configs/netspace_lite_v2_defconfig delete mode 100644 configs/netspace_max_v2_defconfig delete mode 100644 configs/netspace_mini_v2_defconfig delete mode 100644 configs/netspace_v2_defconfig delete mode 100644 include/configs/lacie_kw.h
-- 2.25.1
On Fri, Jun 19, 2020 at 8:31 PM Chris Packham judge.packham@gmail.com wrote:
Hi Jagan,
Any inputs? Jagan.
Tooks a bit longer to dust off the kirkwood board than I expected. For this series
Tested-by: Chris Packham judge.packham@gmail.com
Chris Packham
Jagan Teki
Simon Guinot
