[PATCH] net: pfe_eth: Use spi_flash_read API to access flash memory
Current PFE firmware access spi-nor memory directly. New spi-mem framework does not support direct memory access. So, let's use spi_flash_read API to access memory instead of directly using it.
Signed-off-by: Kuldeep Singh kuldeep.singh@nxp.com --- drivers/net/pfe_eth/pfe_firmware.c | 44 +++++++++++++++++++++++++++++- include/configs/ls1012a_common.h | 5 +++- 2 files changed, 47 insertions(+), 2 deletions(-)
diff --git a/drivers/net/pfe_eth/pfe_firmware.c b/drivers/net/pfe_eth/pfe_firmware.c index e4563f192b..61d1b96305 100644 --- a/drivers/net/pfe_eth/pfe_firmware.c +++ b/drivers/net/pfe_eth/pfe_firmware.c @@ -12,13 +12,14 @@
#include <net/pfe_eth/pfe_eth.h> #include <net/pfe_eth/pfe_firmware.h> +#include <spi_flash.h> #ifdef CONFIG_CHAIN_OF_TRUST #include <fsl_validate.h> #endif
#define PFE_FIRMWARE_FIT_CNF_NAME "config@1"
-static const void *pfe_fit_addr = (void *)CONFIG_SYS_LS_PFE_FW_ADDR; +static const void *pfe_fit_addr;
/* * PFE elf firmware loader. @@ -159,6 +160,43 @@ static int pfe_fit_check(void) return ret; }
+int pfe_spi_flash_init(void) +{ + struct spi_flash *pfe_flash; + int ret = 0; + void *addr = malloc(CONFIG_SYS_QE_FMAN_FW_LENGTH); + +#ifdef CONFIG_DM_SPI_FLASH + struct udevice *new; + + /* speed and mode will be read from DT */ + ret = spi_flash_probe_bus_cs(CONFIG_ENV_SPI_BUS, + CONFIG_ENV_SPI_CS, 0, 0, &new); + + pfe_flash = dev_get_uclass_priv(new); +#else + pfe_flash = spi_flash_probe(CONFIG_ENV_SPI_BUS, + CONFIG_ENV_SPI_CS, + CONFIG_ENV_SPI_MAX_HZ, + CONFIG_ENV_SPI_MODE); +#endif + if (!pfe_flash) { + printf("SF: probe for pfe ucode failed\n"); + } else { + ret = spi_flash_read(pfe_flash, + CONFIG_SYS_LS_PFE_FW_ADDR, + CONFIG_SYS_QE_FMAN_FW_LENGTH, + addr); + if (ret) + printf("SF: read for ucode failed\n"); + + pfe_fit_addr = addr; + spi_flash_free(pfe_flash); + } + + return ret; +} + /* * PFE firmware initialization. * Loads different firmware files from FIT image. @@ -183,6 +221,10 @@ int pfe_firmware_init(void) int ret = 0; int fw_count;
+ ret = pfe_spi_flash_init(); + if (ret) + goto err; + ret = pfe_fit_check(); if (ret) goto err; diff --git a/include/configs/ls1012a_common.h b/include/configs/ls1012a_common.h index 2579e2fb37..cbc5bff21c 100644 --- a/include/configs/ls1012a_common.h +++ b/include/configs/ls1012a_common.h @@ -36,9 +36,12 @@ /* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128 * 1024)
+/* PFE */ +#define CONFIG_SYS_FMAN_FW_ADDR 0x400d0000 +#define CONFIG_SYS_QE_FMAN_FW_LENGTH 0x10000 + /*SPI device */ #if defined(CONFIG_QSPI_BOOT) || defined(CONFIG_TFABOOT) -#define CONFIG_SYS_FMAN_FW_ADDR 0x400d0000 #define CONFIG_SPI_FLASH_SPANSION #define CONFIG_FSL_SPI_INTERFACE #define CONFIG_SF_DATAFLASH
-----Original Message----- From: Kuldeep Singh kuldeep.singh@nxp.com Sent: Wednesday, December 11, 2019 5:24 PM To: u-boot@lists.denx.de Cc: joe.hershberger@ni.com; Priyanka Jain priyanka.jain@nxp.com; tommyhebb@gmail.com; Ashish Kumar ashish.kumar@nxp.com; patrick.delaunay@st.com; simon.k.r.goldschmidt@gmail.com; Yunfeng Ding yunfeng.ding@nxp.com; Kuldeep Singh kuldeep.singh@nxp.com Subject: [PATCH] net: pfe_eth: Use spi_flash_read API to access flash memory
Hi Joe, Sorry for early ping. Can you please review this patch as qspi driver sent [1] is dependent on this patch. It helps in resolving booting crash on LS1012ARDB while testing the same.
Thanks Kuldeep
[1] https://patchwork.ozlabs.org/project/uboot/list/?series=149809
- PFE elf firmware loader.
- struct spi_flash *pfe_flash;
- int ret = 0;
- void *addr = malloc(CONFIG_SYS_QE_FMAN_FW_LENGTH);
- struct udevice *new;
- /* speed and mode will be read from DT */
- ret = spi_flash_probe_bus_cs(CONFIG_ENV_SPI_BUS,
- pfe_flash = dev_get_uclass_priv(new);
+#else
- pfe_flash = spi_flash_probe(CONFIG_ENV_SPI_BUS,
CONFIG_ENV_SPI_CS,
- if (!pfe_flash) {
- } else {
addr);
if (ret)
- return ret;
- PFE firmware initialization.
- Loads different firmware files from FIT image.
- ret = pfe_spi_flash_init();
- if (ret)
goto err;
- ret = pfe_fit_check(); if (ret) goto err;
2.17.1
- int ret = 0;
+#else
CONFIG_ENV_SPI_CS,
- if (!pfe_flash) {
I think you should return some error code in this case. Currently ret could still be 0 at this point.
- } else {
addr);
if (ret)
- return ret;
- if (ret)
goto err;
- /*SPI device */ #if defined(CONFIG_QSPI_BOOT) || defined(CONFIG_TFABOOT)
Hi Frieder,
-----Original Message----- From: Schrempf Frieder frieder.schrempf@kontron.de Sent: Tuesday, January 7, 2020 4:28 PM To: Kuldeep Singh kuldeep.singh@nxp.com; u-boot@lists.denx.de Cc: Yunfeng Ding yunfeng.ding@nxp.com; joe.hershberger@ni.com Subject: [EXT] Re: [PATCH] net: pfe_eth: Use spi_flash_read API to access flash memory
Caution: EXT Email
int ret = 0;
pfe_flash = dev_get_uclass_priv(new); #else
CONFIG_ENV_SPI_CS,
CONFIG_ENV_SPI_MODE); #endif
if (!pfe_flash) {
Ok. I will return error codes in next version.
Thanks Kuldeep
} else {
addr);
if (ret)
return ret;
if (ret)
goto err;
Kuldeep Singh
Schrempf Frieder
