[U-Boot] Turning optimizations off
Hello,
I am debugging u-boot with a BDI and am running into a case where a variable gets optimized out. For the sake of debugging I am trying to turn off optimizations. I have the following in u-boot-2009.01/config.mk, but GDB still reports optimizations:
OPTFLAGS= -Os -fno-schedule-insns -fno-schedule-insns2 #-fomit-frame-pointer
(gdb) stepi
0x0ff78750 in get_table_entry_name (table=<value optimized out>,
msg=0xff9e1a8 "Unknown Architecture", id=7) at image.c:544
544 }
Does anyone know how to completely turn optimization off? Using no -O flag results in u-boot not compiling.
Fahd Abidi Product Manager - Technical Tools and Development Ultimate Solutions, Inc. ================================================================ Your Single Source for Professional Development Tools and Embedded Solutions Ph: 978-455-3383 x255 Fx: 978-926-3091 Email: fabidi@ultsol.com Visit: http://www.ultsol.com http://www.ultsol.com/
Dear "Fahd Abidi",
In message 71DEA556544D7A4F9C6848402D8184340C45D7@usi01.ultsol.local you wrote:
Well, "-Os" means "optimize for minimal code size"...
(gdb) stepi
... so it is only natural that GCC will eliminate unneeded code.
You cannot globally disable optimization. You might get away with doing this on a per-file level, but there is no guarantee for that.
It is better to arrange to keep optimization turned on - after all, this is the real code that will later be running.
Fahd Abidi wrote:
Hello,
(gdb) stepi
If you (temporarily) put "volatile" on the variable, the compiler should not optimize it out. Obviously, this is a limited solution, but may get your past your problem.
[snip]
Theoretically, you could compile individual files w/o optimization (e.g. if you compile it by hand, make shouldn't re-compile it). I doubt that you want to go there, though...
Fahd Abidi
Good luck, gvb
Fahd Abidi
Jerry Van Baren
