[U-Boot] Issues with Rockchips make_fit_atf.py on master
Hi Kever,
There's a problem with generating the FIT image for rockchips on recent 2018.05 RCs, errors below, I suspect due to changes in dtc.
Peter
/builddir/build/BUILD/u-boot-2018.05-rc2/"arch/arm/mach-rockchip/make_fit_atf.py" \ arch/arm/dts/rk3399-firefly.dtb > u-boot.its ./tools/mkimage -f u-boot.its -E u-boot.itb >/dev/null && cat /dev/null u-boot.itb.tmp: Warning (unit_address_vs_reg): Node /images/uboot@1 has a unit name, but no reg property u-boot.itb.tmp: Warning (unit_address_vs_reg): Node /images/atf@1 has a unit name, but no reg property u-boot.itb.tmp: Warning (unit_address_vs_reg): Node /images/atf@2 has a unit name, but no reg property u-boot.itb.tmp: Warning (unit_address_vs_reg): Node /images/atf@3 has a unit name, but no reg property u-boot.itb.tmp: Warning (unit_address_vs_reg): Node /images/fdt@1 has a unit name, but no reg property u-boot.itb.tmp: Warning (unit_address_vs_reg): Node /configurations/config@1 has a unit name, but no reg property make[1]: Leaving directory '/builddir/build/BUILD/u-boot-2018.05-rc2/builds/firefly-rk3399'
Hi Peter,
On 04/25/2018 05:44 PM, Peter Robinson wrote:
Hi Kever,
Thanks for reporting this, but I don't know why I can't reproduce the issue, the U-Boot has include dtc code now and we should have the same dtc.
The issue is clear and we can reference commit to fix. https://github.com/RobertCNelson/dtc/commit/c9d9121683b35281239305e15adddfff... https://lkml.org/lkml/2016/4/1/46
But I can't test it because I can't reproduce it :( Could you help to test after I send a fix patch for it?
Thanks, - Kever
Peter
Kever Yang
Peter Robinson
