[RFC PATCH] dts: automatically build necessary .dtb files
When building for a custom board, it is quite common to maintain a private branch which include some defconfig and .dts files. But to hook up those .dts files requires modifying a file "belonging" to upstream U-Boot, the arch/*/dts/Makefile. Forward-porting that branch to a newer upstream then often results in a conflict which, while it is trivial to resolve by hand, makes it harder to have a CI do "try to build our board against latest upstream".
The .config usually includes information on precisely what .dtb(s) are needed, so to avoid having to modify the Makefile, simply add the files in (SPL_)OF_LIST to dtb-y.
A technicality is that (SPL_)OF_LIST is not always defined, so rework the Kconfig symbols so that (SPL_)OF_LIST is always defined (when (SPL_)OF_CONTROL), but only prompted for in the cases which used to be their "depends on".
nios2 and microblaze already have something like this in their dts/Makefile, and the rationale in commit 41f59f68539 is similar to the above. So this simply generalizes existing practice. Followup patches could remove the logic in those two makefiles, just as there's potential for moving some common boilerplate from all the arch/*/dts/Makefile files to the new scripts/Makefile.dts.
Signed-off-by: Rasmus Villemoes rasmus.villemoes@prevas.dk --- arch/arc/dts/Makefile | 2 ++ arch/arm/dts/Makefile | 2 ++ arch/m68k/dts/Makefile | 2 ++ arch/microblaze/dts/Makefile | 2 ++ arch/mips/dts/Makefile | 2 ++ arch/nds32/dts/Makefile | 2 ++ arch/nios2/dts/Makefile | 2 ++ arch/powerpc/dts/Makefile | 2 ++ arch/riscv/dts/Makefile | 2 ++ arch/sandbox/dts/Makefile | 2 ++ arch/sh/dts/Makefile | 2 ++ arch/x86/dts/Makefile | 2 ++ arch/xtensa/dts/Makefile | 2 ++ dts/Kconfig | 8 ++++---- scripts/Makefile.dts | 3 +++ 15 files changed, 33 insertions(+), 4 deletions(-) create mode 100644 scripts/Makefile.dts
diff --git a/arch/arc/dts/Makefile b/arch/arc/dts/Makefile index 515fe1fe53..532a8131c5 100644 --- a/arch/arc/dts/Makefile +++ b/arch/arc/dts/Makefile @@ -8,6 +8,8 @@ dtb-$(CONFIG_TARGET_EMSDP) += emsdp.dtb dtb-$(CONFIG_TARGET_HSDK) += hsdk.dtb hsdk-4xd.dtb dtb-$(CONFIG_TARGET_IOT_DEVKIT) += iot_devkit.dtb
+include $(srctree)/scripts/Makefile.dts + targets += $(dtb-y)
DTC_FLAGS += -R 4 -p 0x1000 diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index b3e2a9c9d7..ef58be0381 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -1163,6 +1163,8 @@ dtb-$(CONFIG_TARGET_IMX8MM_CL_IOT_GATE_OPTEE) += imx8mm-cl-iot-gate-optee.dtb
dtb-$(CONFIG_TARGET_EA_LPC3250DEVKITV2) += lpc3250-ea3250.dtb
# Add any required device tree compiler flags here diff --git a/arch/m68k/dts/Makefile b/arch/m68k/dts/Makefile index fdd435bc34..7988522eb9 100644 --- a/arch/m68k/dts/Makefile +++ b/arch/m68k/dts/Makefile @@ -18,6 +18,8 @@ dtb-$(CONFIG_TARGET_M5373EVB) += M5373EVB.dtb dtb-$(CONFIG_TARGET_AMCORE) += amcore.dtb dtb-$(CONFIG_TARGET_STMARK2) += stmark2.dtb
DTC_FLAGS += -R 4 -p 0x1000 diff --git a/arch/microblaze/dts/Makefile b/arch/microblaze/dts/Makefile index 4690dc1b9f..427a8f9aac 100644 --- a/arch/microblaze/dts/Makefile +++ b/arch/microblaze/dts/Makefile @@ -2,6 +2,8 @@
dtb-y += $(shell echo $(CONFIG_DEFAULT_DEVICE_TREE)).dtb
DTC_FLAGS += -R 4 -p 0x1000 diff --git a/arch/mips/dts/Makefile b/arch/mips/dts/Makefile index 215283cfa0..95144b24dc 100644 --- a/arch/mips/dts/Makefile +++ b/arch/mips/dts/Makefile @@ -34,6 +34,8 @@ dtb-$(CONFIG_SOC_JR2) += jr2_pcb110.dtb jr2_pcb111.dtb serval2_pcb112.dtb dtb-$(CONFIG_SOC_SERVALT) += servalt_pcb116.dtb dtb-$(CONFIG_SOC_SERVAL) += serval_pcb105.dtb serval_pcb106.dtb
# Add any required device tree compiler flags here diff --git a/arch/nds32/dts/Makefile b/arch/nds32/dts/Makefile index a8e23ad9ad..5a09e3b45b 100644 --- a/arch/nds32/dts/Makefile +++ b/arch/nds32/dts/Makefile @@ -2,6 +2,8 @@
dtb-$(CONFIG_TARGET_ADP_AG101P) += ag101p.dtb dtb-$(CONFIG_TARGET_ADP_AE3XX) += ae3xx.dtb +include $(srctree)/scripts/Makefile.dts + targets += $(dtb-y)
DTC_FLAGS += -R 4 -p 0x1000 diff --git a/arch/nios2/dts/Makefile b/arch/nios2/dts/Makefile index 0014acfdfb..2b29fa90f6 100644 --- a/arch/nios2/dts/Makefile +++ b/arch/nios2/dts/Makefile @@ -2,6 +2,8 @@
dtb-y += $(CONFIG_DEFAULT_DEVICE_TREE:"%"=%).dtb
DTC_FLAGS += -R 4 -p 0x1000 diff --git a/arch/powerpc/dts/Makefile b/arch/powerpc/dts/Makefile index ceaa8ce5c8..6f0e4d69f2 100644 --- a/arch/powerpc/dts/Makefile +++ b/arch/powerpc/dts/Makefile @@ -29,6 +29,8 @@ dtb-$(CONFIG_TARGET_TUXX1) += kmtuxa1.dtb dtb-$(CONFIG_TARGET_MCR3000) += mcr3000.dtb dtb-$(CONFIG_TARGET_GAZERBEAM) += gazerbeam.dtb
# Add any required device tree compiler flags here diff --git a/arch/riscv/dts/Makefile b/arch/riscv/dts/Makefile index b6e9166767..45b6381139 100644 --- a/arch/riscv/dts/Makefile +++ b/arch/riscv/dts/Makefile @@ -8,6 +8,8 @@ dtb-$(CONFIG_TARGET_SIFIVE_UNLEASHED) += hifive-unleashed-a00.dtb dtb-$(CONFIG_TARGET_SIFIVE_UNMATCHED) += hifive-unmatched-a00.dtb dtb-$(CONFIG_TARGET_SIPEED_MAIX) += k210-maix-bit.dtb
DTC_FLAGS += -R 4 -p 0x1000 diff --git a/arch/sandbox/dts/Makefile b/arch/sandbox/dts/Makefile index 3e5dc67d53..6cbc9bbcaa 100644 --- a/arch/sandbox/dts/Makefile +++ b/arch/sandbox/dts/Makefile @@ -8,6 +8,8 @@ endif dtb-$(CONFIG_UT_DM) += test.dtb dtb-$(CONFIG_CMD_EXTENSION) += overlay0.dtbo overlay1.dtbo
DTC_FLAGS += -R 4 -p 0x1000 diff --git a/arch/sh/dts/Makefile b/arch/sh/dts/Makefile index e423bfd566..144fd3e7d2 100644 --- a/arch/sh/dts/Makefile +++ b/arch/sh/dts/Makefile @@ -1,5 +1,7 @@ dtb-y += sh7751-r2dplus.dtb
# Add any required device tree compiler flags here diff --git a/arch/x86/dts/Makefile b/arch/x86/dts/Makefile index be209aaaf8..8c1c366546 100644 --- a/arch/x86/dts/Makefile +++ b/arch/x86/dts/Makefile @@ -22,6 +22,8 @@ dtb-y += bayleybay.dtb \ slimbootloader.dtb \ baytrail_som-db5800-som-6867.dtb
DTC_FLAGS += -R 4 -p 0x1000 diff --git a/arch/xtensa/dts/Makefile b/arch/xtensa/dts/Makefile index 06ee25d2da..fbbdefaf2c 100644 --- a/arch/xtensa/dts/Makefile +++ b/arch/xtensa/dts/Makefile @@ -2,6 +2,8 @@
dtb-$(CONFIG_XTFPGA) += ml605.dtb ml605_nommu.dtb kc705.dtb kc705_nommu.dtb
DTC_FLAGS += diff --git a/dts/Kconfig b/dts/Kconfig index b7c4a2fec0..446d709715 100644 --- a/dts/Kconfig +++ b/dts/Kconfig @@ -132,8 +132,8 @@ config DEFAULT_DEVICE_TREE $ make DEVICE_TREE=<device-tree-name>
config OF_LIST - string "List of device tree files to include for DT control" - depends on SPL_LOAD_FIT || MULTI_DTB_FIT + string "List of device tree files to include for DT control" if SPL_LOAD_FIT || MULTI_DTB_FIT + depends on OF_CONTROL default DEFAULT_DEVICE_TREE help This option specifies a list of device tree files to use for DT @@ -240,8 +240,8 @@ config SPL_MULTI_DTB_FIT capabilities, pad configurations).
config SPL_OF_LIST - string "List of device tree files to include for DT control in SPL" - depends on SPL_MULTI_DTB_FIT + string "List of device tree files to include for DT control in SPL" if SPL_MULTI_DTB_FIT + depends on SPL_OF_CONTROL default OF_LIST help This option specifies a list of device tree files to use for DT diff --git a/scripts/Makefile.dts b/scripts/Makefile.dts new file mode 100644 index 0000000000..2561025da8 --- /dev/null +++ b/scripts/Makefile.dts @@ -0,0 +1,3 @@ +# SPDX-License-Identifier: GPL-2.0+ + +dtb-y += $(patsubst %,%.dtb,$(subst ",,$(CONFIG_$(SPL_)OF_LIST)))
targets += $(dtb-y)
targets += $(dtb-y)
targets += $(dtb-y)
targets += $(dtb-y)
targets += $(dtb-y)
targets += $(dtb-y)
targets += $(dtb-y)
targets += $(dtb-y)
targets += $(dtb-y)
targets += $(dtb-y)
targets += $(dtb-y)
targets += $(dtb-y)
targets += $(dtb-y)
config OF_LIST
- string "List of device tree files to include for DT control" if SPL_LOAD_FIT || MULTI_DTB_FIT
- depends on OF_CONTROL default DEFAULT_DEVICE_TREE help This option specifies a list of device tree files to use for DT
config SPL_OF_LIST
- string "List of device tree files to include for DT control in SPL" if SPL_MULTI_DTB_FIT
- depends on SPL_OF_CONTROL default OF_LIST help This option specifies a list of device tree files to use for DT
This seems like a good thing to me. Simon?
targets += $(dtb-y)
targets += $(dtb-y)
targets += $(dtb-y)
targets += $(dtb-y)
targets += $(dtb-y)
targets += $(dtb-y)
targets += $(dtb-y)
targets += $(dtb-y)
targets += $(dtb-y)
targets += $(dtb-y)
targets += $(dtb-y)
targets += $(dtb-y)
targets += $(dtb-y)
config OF_LIST
config SPL_OF_LIST
Maybe. This is the second time I've read the patch and I'm still a bit confused. It would help to have a clear statement of what the patch does and some update to the docs.
I really don't like the referred commit though:
41f59f68539 microblaze: Build only DTBs for selected target
I much prefer that we build all the .dts for an SoC, not just the particular one for the single board, since they typically use common .dtsi files and it is easier to detect problems with related boards. So I actually don't like the idea of just building the one DT at all and I think the Makefile should list the .dts files too.
Also, what exactly does it mean to make the prompt depend on an option? Does that make the option such that it can be set by defconfig only if the condition is true?
targets += $(dtb-y)
targets += $(dtb-y)
targets += $(dtb-y)
targets += $(dtb-y)
targets += $(dtb-y)
targets += $(dtb-y)
targets += $(dtb-y)
targets += $(dtb-y)
targets += $(dtb-y)
targets += $(dtb-y)
targets += $(dtb-y)
targets += $(dtb-y)
targets += $(dtb-y)
config OF_LIST
config SPL_OF_LIST
The patch makes the build system DTRT in more cases, and makes it easier to maintain a private branch (which almost all real-world projects end up using) on top of U-Boot master.
The patch changes nothing in that regard. I only add a few elements to dtb-y which are clearly needed (namely, stuff mentioned in CONFIG_OF_LIST). And the only reason I wrote the patch was because I was burnt by the build system clearly _not_ doing the right thing - I've told Kconfig that I need foo.dtb and foo-bootstrap.dtb (both of which being custom .dts files I've added in a private branch, which include an in-tree-soc.dtsi), but neither were being built. Of course, I could patch the Makefile in the same private branch, but as I said, that just leads to eternal merge conflicts. And I believe others have had the same experience.
Yes, as has always been the case. If it's 'depends on BLA', the element only exists (and can only be set via defconfig) if BLA is set. If it's 'string "The prompt" if BLA', the element always exists, but is only settable (manually or from a defconfig) if BLA is set, otherwise it has its default value (in this case, the singleton CONFIG_DEFAULT_DEVICE_TREE). And this is precisely what is needed here - if the conditions for OF_LIST to be changeable (extendable) are not met, it should not be visible, but to make the makefile rule simple, we need CONFIG_OF_LIST to always be defined.
Rasmus
On Mon, 24 Jan 2022 at 14:15, Rasmus Villemoes rasmus.villemoes@prevas.dk wrote:
Applied to u-boot-dm, thanks!
Rasmus Villemoes
