[GIT PULL] xilinx patches for v2025.04-rc1 v2
Hi Tom,
here are some patches I have collected so far. There is nothing significant in it. Just trying to clean my inbox. I am not expecting many changes for .04 anyway.
Thanks, Michal
The following changes since commit 6a0db9ee030f634731b792d864fc7a9df6cc6b80:
Merge branch 'master' of https://source.denx.de/u-boot/custodians/u-boot-usb (2025-01-13 08:25:00 -0600)
git@source.denx.de:u-boot/custodians/u-boot-microblaze.git tags/xilinx-for-v2025.04-rc1-v2
for you to fetch changes up to 3a2bf24a85b2b35f1c7d6f0633d6aa528a6970b8:
rtc: zynqmp: allow on Versal architectures (2025-01-14 15:34:51 +0100)
---------------------------------------------------------------- AMD/Xilinx changes for v2025.04-rc1 v2
Versal: - Enable dfu support for SPI with multiboot
ZynqMP: - Align multiboot reg description - DT syncups - Wire missing DTs in defconfig - Kria: Remove usb hub initialization via commands - Kria: Update DP reset in psu_init
AMD/Xilinx: - Enable SPI_STACKED_PARALLEL configs
SPI/ZYNQMP_GQSPI: - Update debug message to use log_debug()
RTC: - Enable ZYNQMP_RTC for Versal SOCs
---------------------------------------------------------------- Ibai Erkiaga (1): zynqmp_gqspi: update to log_debug
Jonathan Stroud (1): arm64: zynqmp: Add eeprom labels for System Controller dts
Michal Simek (8): arm64: versal: Wire SPIs for dfu_alt_info variable generation arm64: versal: Support operations around multiboot register arm64: versal: RO multi_boot register in non JTAG bootmode arm64: zynqmp: Do not use hardcoded address in do_zynqmp_reboot() arm64: zynqmp: Sync DTs with Linux v6.13-rc1 zynqmp: Remove usb init initialization for Kria xilinx: Sort OF_LIST and add missing vpk120 and zcu670 platforms arm64: zynqmp: Enable iio-hwmon description only for SOM
Naman Trivedi (1): arm64: zynqmp: add clock-output-names property in clock nodes
Neal Frager (1): board: zynqmp: zynqmp-sm-k26-revA: release DP from reset
Venkatesh Yadav Abbarapu (2): config: xilinx: Enable the SPI_STACKED_PARALLEL config option board: xilinx: Add missing prototype for set_dfu_alt_info
Vincent Fazio (1): rtc: zynqmp: allow on Versal architectures
arch/arm/dts/zynqmp-clk-ccf.dtsi | 15 ++- arch/arm/dts/zynqmp-e-a2197-00-revA.dts | 4 + arch/arm/dts/zynqmp-sc-revB.dts | 1 + arch/arm/dts/zynqmp-sm-k26-revA.dts | 22 +---- arch/arm/dts/zynqmp-zcu100-revC.dts | 4 - arch/arm/dts/zynqmp-zcu102-revA.dts | 4 - arch/arm/dts/zynqmp-zcu104-revA.dts | 4 - arch/arm/dts/zynqmp-zcu104-revC.dts | 4 - arch/arm/dts/zynqmp.dtsi | 102 +++++++++++++++++++- arch/arm/mach-zynqmp/zynqmp.c | 2 +- board/xilinx/versal/board.c | 91 ++++++++++++++--- board/xilinx/zynqmp/zynqmp-sm-k26-revA/psu_init_gpl.c | 2 +- board/xilinx/zynqmp/zynqmp_kria.env | 14 +-- configs/amd_versal2_mini_qspi_defconfig | 1 + configs/xilinx_versal_mini_qspi_defconfig | 1 + configs/xilinx_versal_net_mini_qspi_defconfig | 1 + configs/xilinx_versal_virt_defconfig | 1 + configs/xilinx_zynqmp_kria_defconfig | 1 + configs/xilinx_zynqmp_mini_qspi_defconfig | 1 + configs/xilinx_zynqmp_virt_defconfig | 2 +- configs/zynq_cse_qspi_defconfig | 1 + drivers/rtc/Kconfig | 2 +- drivers/spi/zynqmp_gqspi.c | 2 +- 23 files changed, 212 insertions(+), 70 deletions(-)
On Tue, Jan 14, 2025 at 03:50:16PM +0100, Michal Simek wrote:
Hi Tom,
Thanks, Michal
Michal Simek
