Re: [U-Boot] [PATCH v6] net: ll_temac: Add LL TEMAC driver to u-boot
Hello Stefan, Hello Wolfgang, Hello Michal,
I have tried the code on a Propietary Virtex5 fx board (ppc440) and it works.... Thanks for your work.
Regards!
Hello Recardo,
Am Donnerstag, den 22.12.2011, 17:06 +0100 schrieb Ricardo Ribalda Delgado:
OK, thanks for your efforts. Would it be possible for you to test even the latest v7 patch? There were some critical changes between v6 and v7, especially timeout regime, function pointers for plattform specific in/out accessors, and MDIO clock calculation.
Hello Stephan
I just checked it, and I am using v7 :) from: http://patchwork.ozlabs.org/bundle/rexut/net-ll_temac/ Once it is applied I will post the patches for xilinx-ppc440-generic (mainly instantiate it in the config...)
I have tried to download an image with the dhcp command over 100 and 1000M... I have to work more on it, but it looks promising. If you need an specific test, just say it, tomorrow I will be working with the board.
Thanks again for the patch, it was very needed for u-boot.
Regards
On Thu, Dec 22, 2011 at 19:52, Stephan Linz linz@li-pro.net wrote:
Hello Recardo,
-- Best regards, Stephan Linz ______________________________________________________________________________ MB-Ref: http://www.li-pro.de/xilinx_mb:mbref:start OpenDCC: http://www.li-pro.net/opendcc.phtml PC/M: http://www.li-pro.net/pcm.phtml Sourceforge: http://sourceforge.net/users/slz Gitorious: https://gitorious.org/~slz
Am Donnerstag, den 22.12.2011, 19:58 +0100 schrieb Ricardo Ribalda Delgado:
Hello Stephan
Hello Recardo,
OK, fine.
Nice to hear that. So we know the driver consists no bad code and can be applied as fast as possible.
br, Stephan
Regards
Hello Recardo,
Dear Ricardo Ribalda Delgado,
In message CAPybu_3A+PG9LbbWgu4Qb_ZmnewQoVO7UDs_iatRRUTGmMRrPA@mail.gmail.com you wrote:
Can you please send a formal "Acked-by:" message then?
[These get picked up by patchwork, so we don;t have to manually edit the commit message. Also, they have a clearly defined meaning.]
Stephan Linz
