Re: [U-Boot] [PATCH] arm: omap3: Update cpuinfo for DM3730, DM3725, AM3715, and AM3703
On Fri, Jan 20, 2017 at 4:32 AM, Ladislav Michl ladis@linux-mips.org wrote:
On Thu, Jan 19, 2017 at 02:04:11PM -0600, Adam Ford wrote:
The check for OMAP3630/3730 only checks for 800MHz 3630/3730, but anything else is lumped into 36XX/37XX with an assumed 1GHz speed.
Based on the DM3730 TRM bit 9 shows the MPU Frequency (800MHz/1GHZ). This also adds the ability to distinguish between the DM3730, DM3725, AM3715, and AM3703 and correctly display their maximum speed.
Prints nicely: AM3703-GP ES1.2, CPU-OPP2, L3-200MHz, Max CPU Clock 1 GHz
Tested-by: Ladislav Michl ladis@linux-mips.org
Btw,
I would be nice to use correct spelling of ISO units, so I propose what's attached (you patch rebased ot top of spelling change). Not sure if you wish to take extra effort to resend, though.
I was originally going to do a separate commit to fix the spelling of MHz and GHz once the first patch was approved, because I didn't want to combine a typo fix with a feature addition. Since you've done the work, why not just submit your patch and take credit for it. :-)
adam
Best regards, ladis
Frequency is measured in Hz.
Signed-off-by: Ladislav Michl ladis@linux-mips.org --- arch/arm/mach-omap2/omap3/sys_info.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/arch/arm/mach-omap2/omap3/sys_info.c b/arch/arm/mach-omap2/omap3/sys_info.c index 6818fab253..1f8b5ad77c 100644 --- a/arch/arm/mach-omap2/omap3/sys_info.c +++ b/arch/arm/mach-omap2/omap3/sys_info.c @@ -292,7 +292,7 @@ int print_cpuinfo (void) cpu_s = "35XX"; break; } - max_clk = "600 Mhz"; + max_clk = "600 MHz"; break; case CPU_OMAP36XX: cpu_family_s = "OMAP"; @@ -304,12 +304,12 @@ int print_cpuinfo (void) cpu_s = "36XX/37XX"; break; } - max_clk = "1 Ghz"; + max_clk = "1 GHz"; break; default: cpu_family_s = "OMAP"; cpu_s = "35XX"; - max_clk = "600 Mhz"; + max_clk = "600 MHz"; }
switch (get_device_type()) {
Signed-off-by: Adam Ford aford173@gmail.com Tested-by: Ladislav Michl ladis@linux-mips.org --- Changes: - v2: rebase on top of spelling fix add Tested-by line indent header file
arch/arm/include/asm/arch-omap3/omap.h | 8 +++++++ arch/arm/mach-omap2/omap3/sys_info.c | 42 ++++++++++++++++++++++++++++++++-- 2 files changed, 48 insertions(+), 2 deletions(-)
diff --git a/arch/arm/include/asm/arch-omap3/omap.h b/arch/arm/include/asm/arch-omap3/omap.h index 417ff895f1..91d73c2f1d 100644 --- a/arch/arm/include/asm/arch-omap3/omap.h +++ b/arch/arm/include/asm/arch-omap3/omap.h @@ -230,6 +230,14 @@ struct gpio { #define AM3517 0x1c00
#define OMAP3730 0x0c00 +#define OMAP3725 0x4c00 +#define AM3715 0x1c00 +#define AM3703 0x5c00 + +#define OMAP3730_1GHZ 0x0e00 +#define OMAP3725_1GHZ 0x4e00 +#define AM3715_1GHZ 0x1e00 +#define AM3703_1GHZ 0x5e00
/* * ROM code API related flags diff --git a/arch/arm/mach-omap2/omap3/sys_info.c b/arch/arm/mach-omap2/omap3/sys_info.c index 1f8b5ad77c..7e6c2633f9 100644 --- a/arch/arm/mach-omap2/omap3/sys_info.c +++ b/arch/arm/mach-omap2/omap3/sys_info.c @@ -295,16 +295,54 @@ int print_cpuinfo (void) max_clk = "600 MHz"; break; case CPU_OMAP36XX: - cpu_family_s = "OMAP"; switch (get_cpu_type()) { + case AM3703: + cpu_family_s = "AM"; + cpu_s = "3703"; + max_clk = "800 MHz"; + break; + case AM3703_1GHZ: + cpu_family_s = "AM"; + cpu_s = "3703"; + max_clk = "1 GHz"; + break; + case AM3715: + cpu_family_s = "AM"; + cpu_s = "3715"; + max_clk = "800 MHz"; + break; + case AM3715_1GHZ: + cpu_family_s = "AM"; + cpu_s = "3715"; + max_clk = "1 GHz"; + break; + case OMAP3725: + cpu_family_s = "OMAP"; + cpu_s = "3625/3725"; + max_clk = "800 MHz"; + break; + case OMAP3725_1GHZ: + cpu_family_s = "OMAP"; + cpu_s = "3625/3725"; + max_clk = "1 GHz"; + break; case OMAP3730: + cpu_family_s = "OMAP"; cpu_s = "3630/3730"; + max_clk = "800 MHz"; + break; + case OMAP3730_1GHZ: + cpu_family_s = "OMAP"; + cpu_s = "3630/3730"; + max_clk = "1 GHz"; break; default: + cpu_family_s = "OMAP/AM"; cpu_s = "36XX/37XX"; + max_clk = "1 GHz"; break; } - max_clk = "1 GHz"; + break; default: cpu_family_s = "OMAP";
Adam Ford
Ladislav Michl
