[U-Boot] [PATCH 1/3 v2] net: emaclite: Setup RX/TX ping pong for every instance
Setup RX/TX ping-pong buffer for every emaclite IP separately. The next patch move initialization directly to board code.
Signed-off-by: Michal Simek monstr@monstr.eu
--- v2: Fix coding style violations --- drivers/net/xilinx_emaclite.c | 123 ++++++++++++++++++++++------------------ 1 files changed, 68 insertions(+), 55 deletions(-)
diff --git a/drivers/net/xilinx_emaclite.c b/drivers/net/xilinx_emaclite.c index 8e574cd..9342476 100644 --- a/drivers/net/xilinx_emaclite.c +++ b/drivers/net/xilinx_emaclite.c @@ -66,6 +66,8 @@ struct xemaclite { u32 nexttxbuffertouse; /* Next TX buffer to write to */ u32 nextrxbuffertouse; /* Next RX buffer to read from */ + u32 txpp; /* TX ping pong buffer */ + u32 rxpp; /* RX ping pong buffer */ };
static u32 etherrxbuff[PKTSIZE_ALIGN/4]; /* Receive buffer */ @@ -131,6 +133,7 @@ static void emaclite_halt(struct eth_device *dev)
static int emaclite_init(struct eth_device *dev, bd_t *bis) { + struct xemaclite *emaclite = dev->priv; debug ("EmacLite Initialization Started\n");
/* @@ -150,28 +153,28 @@ static int emaclite_init(struct eth_device *dev, bd_t *bis) XEL_TSR_PROG_MAC_ADDR) != 0) ;
-#ifdef CONFIG_XILINX_EMACLITE_TX_PING_PONG - /* The same operation with PONG TX */ - out_be32 (dev->iobase + XEL_TSR_OFFSET + XEL_BUFFER_OFFSET, 0); - xemaclite_alignedwrite(dev->enetaddr, dev->iobase + - XEL_BUFFER_OFFSET, ENET_ADDR_LENGTH); - out_be32 (dev->iobase + XEL_TPLR_OFFSET, ENET_ADDR_LENGTH); - out_be32 (dev->iobase + XEL_TSR_OFFSET + XEL_BUFFER_OFFSET, - XEL_TSR_PROG_MAC_ADDR); - while ((in_be32 (dev->iobase + XEL_TSR_OFFSET + - XEL_BUFFER_OFFSET) & XEL_TSR_PROG_MAC_ADDR) != 0) - ; -#endif + if (emaclite->txpp) { + /* The same operation with PONG TX */ + out_be32 (dev->iobase + XEL_TSR_OFFSET + XEL_BUFFER_OFFSET, 0); + xemaclite_alignedwrite(dev->enetaddr, dev->iobase + + XEL_BUFFER_OFFSET, ENET_ADDR_LENGTH); + out_be32 (dev->iobase + XEL_TPLR_OFFSET, ENET_ADDR_LENGTH); + out_be32 (dev->iobase + XEL_TSR_OFFSET + XEL_BUFFER_OFFSET, + XEL_TSR_PROG_MAC_ADDR); + while ((in_be32 (dev->iobase + XEL_TSR_OFFSET + + XEL_BUFFER_OFFSET) & XEL_TSR_PROG_MAC_ADDR) != 0) + ; + }
/* * RX - RX_PING & RX_PONG initialization */ /* Write out the value to flush the RX buffer */ out_be32 (dev->iobase + XEL_RSR_OFFSET, XEL_RSR_RECV_IE_MASK); -#ifdef CONFIG_XILINX_EMACLITE_RX_PING_PONG - out_be32 (dev->iobase + XEL_RSR_OFFSET + XEL_BUFFER_OFFSET, - XEL_RSR_RECV_IE_MASK); -#endif + + if (emaclite->rxpp) + out_be32 (dev->iobase + XEL_RSR_OFFSET + XEL_BUFFER_OFFSET, + XEL_RSR_RECV_IE_MASK);
debug ("EmacLite Initialization complete\n"); return 0; @@ -221,10 +224,10 @@ static int emaclite_send (struct eth_device *dev, volatile void *ptr, int len) printf ("Error: Timeout waiting for ethernet TX buffer\n"); /* Restart PING TX */ out_be32 (dev->iobase + XEL_TSR_OFFSET, 0); -#ifdef CONFIG_XILINX_EMACLITE_TX_PING_PONG - out_be32 (dev->iobase + XEL_TSR_OFFSET + - XEL_BUFFER_OFFSET, 0); -#endif + if (emaclite->txpp) { + out_be32 (dev->iobase + XEL_TSR_OFFSET + + XEL_BUFFER_OFFSET, 0); + } return -1; }
@@ -237,9 +240,9 @@ static int emaclite_send (struct eth_device *dev, volatile void *ptr, int len) && ((in_be32 ((baseaddress) + XEL_TSR_OFFSET) & XEL_TSR_XMIT_ACTIVE_MASK) == 0)) {
-#ifdef CONFIG_XILINX_EMACLITE_TX_PING_PONG - emaclite->nexttxbuffertouse ^= XEL_BUFFER_OFFSET; -#endif + if (emaclite->txpp) + emaclite->nexttxbuffertouse ^= XEL_BUFFER_OFFSET; + debug ("Send packet from 0x%x\n", baseaddress); /* Write the frame to the buffer */ xemaclite_alignedwrite ((void *) ptr, baseaddress, len); @@ -253,28 +256,30 @@ static int emaclite_send (struct eth_device *dev, volatile void *ptr, int len) out_be32 (baseaddress + XEL_TSR_OFFSET, reg); return 0; } -#ifdef CONFIG_XILINX_EMACLITE_TX_PING_PONG - /* Switch to second buffer */ - baseaddress ^= XEL_BUFFER_OFFSET; - /* Determine if the expected buffer address is empty */ - reg = in_be32 (baseaddress + XEL_TSR_OFFSET); - if (((reg & XEL_TSR_XMIT_BUSY_MASK) == 0) - && ((in_be32 ((baseaddress) + XEL_TSR_OFFSET) - & XEL_TSR_XMIT_ACTIVE_MASK) == 0)) { - debug("Send packet from 0x%x\n", baseaddress); - /* Write the frame to the buffer */ - xemaclite_alignedwrite ((void *) ptr, baseaddress, len); - out_be32 (baseaddress + XEL_TPLR_OFFSET,(len & - (XEL_TPLR_LENGTH_MASK_HI | XEL_TPLR_LENGTH_MASK_LO))); + + if (emaclite->txpp) { + /* Switch to second buffer */ + baseaddress ^= XEL_BUFFER_OFFSET; + /* Determine if the expected buffer address is empty */ reg = in_be32 (baseaddress + XEL_TSR_OFFSET); - reg |= XEL_TSR_XMIT_BUSY_MASK; - if ((reg & XEL_TSR_XMIT_IE_MASK) != 0) { - reg |= XEL_TSR_XMIT_ACTIVE_MASK; + if (((reg & XEL_TSR_XMIT_BUSY_MASK) == 0) + && ((in_be32 ((baseaddress) + XEL_TSR_OFFSET) + & XEL_TSR_XMIT_ACTIVE_MASK) == 0)) { + debug("Send packet from 0x%x\n", baseaddress); + /* Write the frame to the buffer */ + xemaclite_alignedwrite((void *) ptr, baseaddress, len); + out_be32 (baseaddress + XEL_TPLR_OFFSET, (len & + (XEL_TPLR_LENGTH_MASK_HI | + XEL_TPLR_LENGTH_MASK_LO))); + reg = in_be32 (baseaddress + XEL_TSR_OFFSET); + reg |= XEL_TSR_XMIT_BUSY_MASK; + if ((reg & XEL_TSR_XMIT_IE_MASK) != 0) + reg |= XEL_TSR_XMIT_ACTIVE_MASK; + out_be32 (baseaddress + XEL_TSR_OFFSET, reg); + return 0; } - out_be32 (baseaddress + XEL_TSR_OFFSET, reg); - return 0; } -#endif + puts ("Error while sending frame\n"); return -1; } @@ -290,23 +295,24 @@ static int emaclite_recv(struct eth_device *dev) reg = in_be32 (baseaddress + XEL_RSR_OFFSET); debug ("Testing data at address 0x%x\n", baseaddress); if ((reg & XEL_RSR_RECV_DONE_MASK) == XEL_RSR_RECV_DONE_MASK) { -#ifdef CONFIG_XILINX_EMACLITE_RX_PING_PONG - emaclite->nextrxbuffertouse ^= XEL_BUFFER_OFFSET; -#endif + if (emaclite->rxpp) + emaclite->nextrxbuffertouse ^= XEL_BUFFER_OFFSET; } else { -#ifndef CONFIG_XILINX_EMACLITE_RX_PING_PONG - debug ("No data was available - address 0x%x\n", baseaddress); - return 0; -#else - baseaddress ^= XEL_BUFFER_OFFSET; - reg = in_be32 (baseaddress + XEL_RSR_OFFSET); - if ((reg & XEL_RSR_RECV_DONE_MASK) != - XEL_RSR_RECV_DONE_MASK) { + + if (!emaclite->rxpp) { debug ("No data was available - address 0x%x\n", - baseaddress); + baseaddress); return 0; + } else { + baseaddress ^= XEL_BUFFER_OFFSET; + reg = in_be32 (baseaddress + XEL_RSR_OFFSET); + if ((reg & XEL_RSR_RECV_DONE_MASK) != + XEL_RSR_RECV_DONE_MASK) { + debug("No data was available - address 0x%x\n", + baseaddress); + return 0; + } } -#endif } /* Get the length of the frame that arrived */ switch(((ntohl(in_be32 (baseaddress + XEL_RXBUFF_OFFSET + 0xC))) & @@ -358,6 +364,13 @@ int xilinx_emaclite_initialize (bd_t *bis, int base_addr)
dev->priv = emaclite;
+#ifdef CONFIG_XILINX_EMACLITE_TX_PING_PONG + emaclite->txpp = 1; +#endif +#ifdef CONFIG_XILINX_EMACLITE_RX_PING_PONG + emaclite->rxpp = 1; +#endif + sprintf(dev->name, "Xelite.%x", base_addr);
dev->iobase = base_addr;
Do not setup additional ENET_MAX_MTU macro.
Signed-off-by: Michal Simek monstr@monstr.eu --- drivers/net/xilinx_emaclite.c | 10 ++++------ 1 files changed, 4 insertions(+), 6 deletions(-)
diff --git a/drivers/net/xilinx_emaclite.c b/drivers/net/xilinx_emaclite.c index 9342476..aa9ac4b 100644 --- a/drivers/net/xilinx_emaclite.c +++ b/drivers/net/xilinx_emaclite.c @@ -31,8 +31,6 @@
#undef DEBUG
-#define ENET_MAX_MTU PKTSIZE -#define ENET_MAX_MTU_ALIGNED PKTSIZE_ALIGN #define ENET_ADDR_LENGTH 6
/* EmacLite constants */ @@ -212,8 +210,8 @@ static int emaclite_send (struct eth_device *dev, volatile void *ptr, int len)
u32 maxtry = 1000;
- if (len > ENET_MAX_MTU) - len = ENET_MAX_MTU; + if (len > PKTSIZE) + len = PKTSIZE;
while (!xemaclite_txbufferavailable(dev) && maxtry) { udelay (10); @@ -328,8 +326,8 @@ static int emaclite_recv(struct eth_device *dev) debug ("IP Packet\n"); break; default: - debug ("Other Packet\n"); - length = ENET_MAX_MTU; + debug("Other Packet\n"); + length = PKTSIZE; break; }
Checked by checkpatch.pl script. No functional changes.
Signed-off-by: Michal Simek monstr@monstr.eu --- drivers/net/xilinx_emaclite.c | 57 +++++++++++++++++++--------------------- 1 files changed, 27 insertions(+), 30 deletions(-)
diff --git a/drivers/net/xilinx_emaclite.c b/drivers/net/xilinx_emaclite.c index aa9ac4b..bb4fb01 100644 --- a/drivers/net/xilinx_emaclite.c +++ b/drivers/net/xilinx_emaclite.c @@ -70,7 +70,7 @@ struct xemaclite {
-static void xemaclite_alignedread (u32 *srcptr, void *destptr, u32 bytecount) +static void xemaclite_alignedread(u32 *srcptr, void *destptr, u32 bytecount) { u32 i; u32 alignbuffer; @@ -90,14 +90,13 @@ static void xemaclite_alignedread (u32 *srcptr, void *destptr, u32 bytecount) to8ptr = (u8 *) to32ptr;
alignbuffer = *from32ptr++; - from8ptr = (u8 *) & alignbuffer; + from8ptr = (u8 *) &alignbuffer;
- for (i = 0; i < bytecount; i++) { + for (i = 0; i < bytecount; i++) *to8ptr++ = *from8ptr++; - } }
-static void xemaclite_alignedwrite (void *srcptr, u32 destptr, u32 bytecount) +static void xemaclite_alignedwrite(void *srcptr, u32 destptr, u32 bytecount) { u32 i; u32 alignbuffer; @@ -114,25 +113,24 @@ static void xemaclite_alignedwrite (void *srcptr, u32 destptr, u32 bytecount) }
alignbuffer = 0; - to8ptr = (u8 *) & alignbuffer; + to8ptr = (u8 *) &alignbuffer; from8ptr = (u8 *) from32ptr;
*to32ptr++ = alignbuffer; }
static void emaclite_halt(struct eth_device *dev) { - debug ("eth_halt\n"); + debug("eth_halt\n"); }
static int emaclite_init(struct eth_device *dev, bd_t *bis) { struct xemaclite *emaclite = dev->priv; - debug ("EmacLite Initialization Started\n"); + debug("EmacLite Initialization Started\n");
/* * TX - TX_PING & TX_PONG initialization @@ -140,8 +138,7 @@ static int emaclite_init(struct eth_device *dev, bd_t *bis) /* Restart PING TX */ out_be32 (dev->iobase + XEL_TSR_OFFSET, 0); /* Copy MAC address */ - xemaclite_alignedwrite (dev->enetaddr, - dev->iobase, ENET_ADDR_LENGTH); + xemaclite_alignedwrite(dev->enetaddr, dev->iobase, ENET_ADDR_LENGTH); /* Set the length */ out_be32 (dev->iobase + XEL_TPLR_OFFSET, ENET_ADDR_LENGTH); /* Update the MAC address in the EMAC Lite */ @@ -174,7 +171,7 @@ static int emaclite_init(struct eth_device *dev, bd_t *bis) out_be32 (dev->iobase + XEL_RSR_OFFSET + XEL_BUFFER_OFFSET, XEL_RSR_RECV_IE_MASK);
- debug ("EmacLite Initialization complete\n"); + debug("EmacLite Initialization complete\n"); return 0; }
@@ -199,10 +196,10 @@ static int xemaclite_txbufferavailable(struct eth_device *dev) txpongbusy = ((reg & XEL_TSR_XMIT_BUSY_MASK) == XEL_TSR_XMIT_BUSY_MASK);
- return (!(txpingbusy && txpongbusy)); + return !(txpingbusy && txpongbusy); }
-static int emaclite_send (struct eth_device *dev, volatile void *ptr, int len) +static int emaclite_send(struct eth_device *dev, volatile void *ptr, int len) { u32 reg; u32 baseaddress; @@ -214,12 +211,12 @@ static int emaclite_send (struct eth_device *dev, volatile void *ptr, int len) len = PKTSIZE;
while (!xemaclite_txbufferavailable(dev) && maxtry) { - udelay (10); + udelay(10); maxtry--; }
if (!maxtry) { - printf ("Error: Timeout waiting for ethernet TX buffer\n"); + printf("Error: Timeout waiting for ethernet TX buffer\n"); /* Restart PING TX */ out_be32 (dev->iobase + XEL_TSR_OFFSET, 0); if (emaclite->txpp) { @@ -241,16 +238,15 @@ static int emaclite_send (struct eth_device *dev, volatile void *ptr, int len) if (emaclite->txpp) emaclite->nexttxbuffertouse ^= XEL_BUFFER_OFFSET;
- debug ("Send packet from 0x%x\n", baseaddress); + debug("Send packet from 0x%x\n", baseaddress); /* Write the frame to the buffer */ - xemaclite_alignedwrite ((void *) ptr, baseaddress, len); + xemaclite_alignedwrite((void *) ptr, baseaddress, len); out_be32 (baseaddress + XEL_TPLR_OFFSET,(len & (XEL_TPLR_LENGTH_MASK_HI | XEL_TPLR_LENGTH_MASK_LO))); reg = in_be32 (baseaddress + XEL_TSR_OFFSET); reg |= XEL_TSR_XMIT_BUSY_MASK; - if ((reg & XEL_TSR_XMIT_IE_MASK) != 0) { + if ((reg & XEL_TSR_XMIT_IE_MASK) != 0) reg |= XEL_TSR_XMIT_ACTIVE_MASK; - } out_be32 (baseaddress + XEL_TSR_OFFSET, reg); return 0; } @@ -278,7 +274,7 @@ static int emaclite_send (struct eth_device *dev, volatile void *ptr, int len) } }
- puts ("Error while sending frame\n"); + puts("Error while sending frame\n"); return -1; }
@@ -291,14 +287,14 @@ static int emaclite_recv(struct eth_device *dev)
baseaddress = dev->iobase + emaclite->nextrxbuffertouse; reg = in_be32 (baseaddress + XEL_RSR_OFFSET); - debug ("Testing data at address 0x%x\n", baseaddress); + debug("Testing data at address 0x%x\n", baseaddress); if ((reg & XEL_RSR_RECV_DONE_MASK) == XEL_RSR_RECV_DONE_MASK) { if (emaclite->rxpp) emaclite->nextrxbuffertouse ^= XEL_BUFFER_OFFSET; } else {
if (!emaclite->rxpp) { - debug ("No data was available - address 0x%x\n", + debug("No data was available - address 0x%x\n", baseaddress); return 0; } else { @@ -317,12 +313,13 @@ static int emaclite_recv(struct eth_device *dev) 0xFFFF0000 ) >> 16) { case 0x806: length = 42 + 20; /* FIXME size of ARP */ - debug ("ARP Packet\n"); + debug("ARP Packet\n"); break; case 0x800: length = 14 + 14 + - (((ntohl(in_be32 (baseaddress + XEL_RXBUFF_OFFSET + 0x10))) & - 0xFFFF0000) >> 16); /* FIXME size of IP packet */ + (((ntohl(in_be32 (baseaddress + XEL_RXBUFF_OFFSET + + 0x10))) & 0xFFFF0000) >> 16); + /* FIXME size of IP packet */ debug ("IP Packet\n"); break; default: @@ -331,7 +328,7 @@ static int emaclite_recv(struct eth_device *dev) break; }
- xemaclite_alignedread ((u32 *) (baseaddress + XEL_RXBUFF_OFFSET), + xemaclite_alignedread((u32 *) (baseaddress + XEL_RXBUFF_OFFSET), etherrxbuff, length);
/* Acknowledge the frame */ @@ -339,8 +336,8 @@ static int emaclite_recv(struct eth_device *dev) reg &= ~XEL_RSR_RECV_DONE_MASK; out_be32 (baseaddress + XEL_RSR_OFFSET, reg);
- debug ("Packet receive from 0x%x, length %dB\n", baseaddress, length); - NetReceive ((uchar *) etherrxbuff, length); + debug("Packet receive from 0x%x, length %dB\n", baseaddress, length); + NetReceive((uchar *) etherrxbuff, length); return length;
Dear Michal Simek,
Note : this should go into the comment section (pwclient picked the original submit anyway).
Dear Michal Simek,
Applied, thanks.
Dear Michal Simek,
Applied, thanks.
Any comment? If not please add them to mainline tree. I have two more follow-up patches for emaclite.
Thanks, Michal
Dear Michal Simek,
Applied, thanks.
Michal Simek
