[PATCH RFC linux] dt-bindings: nvmem: Add binding for U-Boot environment NVMEM provider
Add device tree bindings for U-Boot environment NVMEM provider.
U-Boot environment can be stored at a specific offset of a MTD device, EEPROM, MMC, NAND or SATA device, on an UBI volume, or in a file on a filesystem.
The environment can contain information such as device's MAC address, which should be used by the ethernet controller node.
Signed-off-by: Marek Behún kabel@kernel.org --- .../bindings/nvmem/denx,u-boot-env.yaml | 88 +++++++++++++++++++ include/dt-bindings/nvmem/u-boot-env.h | 18 ++++ 2 files changed, 106 insertions(+) create mode 100644 Documentation/devicetree/bindings/nvmem/denx,u-boot-env.yaml create mode 100644 include/dt-bindings/nvmem/u-boot-env.h
diff --git a/Documentation/devicetree/bindings/nvmem/denx,u-boot-env.yaml b/Documentation/devicetree/bindings/nvmem/denx,u-boot-env.yaml new file mode 100644 index 000000000000..56505c08e622 --- /dev/null +++ b/Documentation/devicetree/bindings/nvmem/denx,u-boot-env.yaml @@ -0,0 +1,88 @@ +# SPDX-License-Identifier: GPL-2.0-only OR BSD-2-Clause +%YAML 1.2 +--- +$id: http://devicetree.org/schemas/nvmem/denx,u-boot-env.yaml# +$schema: http://devicetree.org/meta-schemas/core.yaml# + +title: U-Boot environment NVMEM Device Tree Bindings + +maintainers: + - Marek Behún kabel@kernel.org + +description: + This binding represents U-Boot's environment NVMEM settings which can be + stored on a specific offset of an EEPROM, MMC, NAND or SATA device, or + an UBI volume, or in a file on a filesystem. + +properties: + compatible: + const: denx,u-boot-env + + path: + description: + The path to the file containing the environment if on a filesystem. + $ref: /schemas/types.yaml#/definitions/string + +patternProperties: + "^[^=]+$": + type: object + + description: + This node represents one U-Boot environment variable, which is also one + NVMEM data cell. + + properties: + name: + description: + If the variable name contains characters not allowed in device tree node + name, use this property to specify the name, otherwise the variable name + is equal to node name. + $ref: /schemas/types.yaml#/definitions/string + + type: + description: + Type of the variable. Since variables, even integers and MAC addresses, + are stored as strings in U-Boot environment, for proper conversion the + type needs to be specified. Use one of the U_BOOT_ENV_TYPE_* prefixed + definitions from include/dt-bindings/nvmem/u-boot-env.h. + $ref: /schemas/types.yaml#/definitions/uint32 + minimum: 0 + maximum: 5 + + required: + - type + +required: + - compatible + +additionalProperties: true + +examples: + - | + + #include <dt-bindings/nvmem/u-boot-env.h> + + spi-flash { + partitions { + compatible = "fixed-partitions"; + #address-cells = <1>; + #size-cells = <1>; + + partition@180000 { + compatible = "denx,u-boot-env"; + label = "u-boot-env"; + reg = <0x180000 0x10000>; + + eth0_addr: ethaddr { + type = <U_BOOT_ENV_TYPE_MAC_ADDRESS>; + }; + }; + }; + }; + + ethernet-controller { + nvmem-cells = <ð0_addr>; + nvmem-cell-names = "mac-address"; + }; + +... diff --git a/include/dt-bindings/nvmem/u-boot-env.h b/include/dt-bindings/nvmem/u-boot-env.h new file mode 100644 index 000000000000..760e5b240619 --- /dev/null +++ b/include/dt-bindings/nvmem/u-boot-env.h @@ -0,0 +1,18 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Macros for U-Boot environment NVMEM device tree bindings. + * + * Copyright (C) 2021 Marek Behún kabel@kernel.org + */ + +#ifndef __DT_BINDINGS_NVMEM_U_BOOT_ENV_H +#define __DT_BINDINGS_NVMEM_U_BOOT_ENV_H + +#define U_BOOT_ENV_TYPE_STRING 0 +#define U_BOOT_ENV_TYPE_ULONG 1 +#define U_BOOT_ENV_TYPE_BOOL 2 +#define U_BOOT_ENV_TYPE_MAC_ADDRESS 3 +#define U_BOOT_ENV_TYPE_ULONG_HEX 4 +#define U_BOOT_ENV_TYPE_ULONG_DEC 5 + +#endif /* __DT_BINDINGS_NVMEM_U_BOOT_ENV_H */
Have you looked at ./Documentation/devicetree/bindings/mtd/partitions/nvmem-cells.yaml ?
--srini
+maintainers:
+description:
- This binding represents U-Boot's environment NVMEM settings which can be
- stored on a specific offset of an EEPROM, MMC, NAND or SATA device, or
- an UBI volume, or in a file on a filesystem.
+properties:
- compatible:
- const: denx,u-boot-env
- path:
- description:
- $ref: /schemas/types.yaml#/definitions/string
+patternProperties:
- type: object
- description:
NVMEM data cell.
- properties:
name:
description:
type:
description:
minimum: 0
maximum: 5
- required:
- type
+required:
- compatible
+examples:
- #include <dt-bindings/nvmem/u-boot-env.h>
- spi-flash {
partitions {
#size-cells = <1>;
partition@180000 {
- ethernet-controller {
- Macros for U-Boot environment NVMEM device tree bindings.
- Copyright (C) 2021 Marek Behún kabel@kernel.org
On Thu, 14 Oct 2021 09:26:27 +0100 Srinivas Kandagatla srinivas.kandagatla@linaro.org wrote:
Hello srini,
yes, I have. What about it? :)
That binding won't work for u-boot-env, because the data are stored in a different way. A cell does not have a constant predetermined offset on the MTD. The variables are stored as a sequence of values of format "name=value", separated by '\0's, for example: board=turris_mox\0ethaddr=00:11:22:33:44:55\0bootcmd=run distro_bootcmd\0.... Chaning lengths of values of variables, or deleting variables, moves the data around. Integers and MAC addresses are stored as strings, and so on.
Also the mtd/partitions/nvmem-cells.yaml doesn't take into account u-boot-env stored on non-MTD devices.
Marek
Hello srini,
Can't you dynamically update the nodes before nvmem-provider is registered?
Do you already have a provider driver for handing this.
How is pre parsing cell info and post processing data planned to be handled?
Currently in nvmem core we do check for "reg" property for each cell, unless the provider driver is adding/updating dt entries dynamically before registering nvmem provider, It will not work as it is. Alteast this is what I suggested in similar case where cell information is in tlv format.
Secondly mac-address seems to be delimited, we recently introduced post processing callback for provider driver [1], which should help in this case.
If the nvmem-cell names are standard like "mac-address" then you do not need to add a new "type" binding to cell too, you can do post-processing based on name.
[1] https://git.kernel.org/pub/scm/linux/kernel/git/next/linux-next.git/commit/d...
--srini
Marek
On Thu, 14 Oct 2021 11:30:13 +0100 Srinivas Kandagatla srinivas.kandagatla@linaro.org wrote:
Hello srini,
Are you talking about dynamically updating nvmem-cell OF nodes, adding reg properties with actual offsets and lengths found after parsing?
Not yet, I will send the proposal together with a driver in next round.
My plan was to read the variables from the u-boot-env partition, create a nvmem-cell for each variable, and then pair the ones mentioned in device tree with their DT nodes, and post-process according to type (post-processing would be done only for those mentioned in device tree, others would be left as strings).
I don't think updaring DT entries dynamically is a correct solution at all. Is this done in Linux? Updating device properties is something different, but changing DT properties seems wrong to me.
Hmm. OK, I shall try to implement a driver for this and then will return to you.
Cool, I shall use that.
I plan to add functions of_nvmem_get_mac_address() nvmem_get_mac_address() which would look at (in this order): mac-address, address, mac-address-backup We have to keep the name "address" for backwards compatibility with one driver that uses this (drivers/net/ethernet/ni/nixge.c)
Thanks.
Marek
Hello srini,
Yes, atleast for the nodes that are defined in the dt.
Adding cells using nvmem_cell_info should work. I think pairing the one with DT entries is something that is missing. Currently nvmem_cell_info does not have device_node pointer may be that is something that could be added to help here.
Sounds good.
yes, please it should show up in 5.16 anyway.
we already have nvmem_get_mac_address() in ./net/ethernet/eth.c that looks for mac-address.
--srini
Thanks.
Marek
We already have a vendor prefix for U-Boot, "u-boot" which should be used here.
My bot found errors running 'make DT_CHECKER_FLAGS=-m dt_binding_check' on your patch (DT_CHECKER_FLAGS is new in v5.13):
yamllint warnings/errors:
dtschema/dtc warnings/errors: /builds/robherring/linux-dt-review/Documentation/devicetree/bindings/nvmem/denx,u-boot-env.example.dt.yaml: partition@180000: compatible: ['denx,u-boot-env'] is not of type 'object' From schema: /builds/robherring/linux-dt-review/Documentation/devicetree/bindings/nvmem/denx,u-boot-env.yaml /builds/robherring/linux-dt-review/Documentation/devicetree/bindings/nvmem/denx,u-boot-env.example.dt.yaml: partition@180000: label: ['u-boot-env'] is not of type 'object' From schema: /builds/robherring/linux-dt-review/Documentation/devicetree/bindings/nvmem/denx,u-boot-env.yaml /builds/robherring/linux-dt-review/Documentation/devicetree/bindings/nvmem/denx,u-boot-env.example.dt.yaml: partition@180000: reg: [[1572864, 65536]] is not of type 'object' From schema: /builds/robherring/linux-dt-review/Documentation/devicetree/bindings/nvmem/denx,u-boot-env.yaml /builds/robherring/linux-dt-review/Documentation/devicetree/bindings/nvmem/denx,u-boot-env.example.dt.yaml: partition@180000: $nodename: ['partition@180000'] is not of type 'object' From schema: /builds/robherring/linux-dt-review/Documentation/devicetree/bindings/nvmem/denx,u-boot-env.yaml
doc reference errors (make refcheckdocs):
See https://patchwork.ozlabs.org/patch/1540721
This check can fail if there are any dependencies. The base for a patch series is generally the most recent rc1.
If you already ran 'make dt_binding_check' and didn't see the above error(s), then make sure 'yamllint' is installed and dt-schema is up to date:
pip3 install dtschema --upgrade
Please check and re-submit.
+maintainers:
+description:
+properties:
- compatible:
'u-boot' is a vendor prefix. Unless you are saying Denx owns u-boot...
- path:
- description:
+patternProperties:
- type: object
- description:
NVMEM data cell.
- properties:
name:
'name' is already a property for every node, so this would collide. It used to be in the dtb itself, but current revisions generate it from the node name.
description:
type:
'type' is really too generic. Any given property name should have 1 meaning and data type.
But I expect based on other comments already, all this is going away anyways.
description:
minimum: 0
maximum: 5
participants (5)
Marek Behún
Rob Herring
Rob Herring
Srinivas Kandagatla
