[U-Boot] [PATCH v2 0/7] MIPS: use an unified u-boot.lds script
This patch-set adds an unfied u-boot.lds file for the MIPS architecture, and removes the linker scripts of the individual boards.
The series depends on the following patch: MIPS: remove OUTPUT_FORMAT from linker scripts http://patchwork.ozlabs.org/patch/216892/
Gabor Juhos (7): MIPS: add unified u-boot.lds file MIPS: qemu-mips: use the unified u-boot.lds script MIPS: pb1x00: remove custom u-boot.lds script MIPS: vct: remove custom u-boot.lds script MIPS: incaip: remove custom u-boot.lds script MIPS: dbau1x00: remove custom u-boot.lds script MIPS: qi_lb60: remove custom u-boot.lds script
arch/mips/cpu/u-boot.lds | 84 +++++++++++++++++++++++++++++++++++++++++ board/dbau1x00/u-boot.lds | 65 ------------------------------- board/incaip/u-boot.lds | 65 ------------------------------- board/micronas/vct/u-boot.lds | 68 --------------------------------- board/pb1x00/u-boot.lds | 65 ------------------------------- board/qemu-mips/u-boot.lds | 70 ---------------------------------- board/qi/qi_lb60/u-boot.lds | 61 ------------------------------ 7 files changed, 84 insertions(+), 394 deletions(-) create mode 100644 arch/mips/cpu/u-boot.lds delete mode 100644 board/dbau1x00/u-boot.lds delete mode 100644 board/incaip/u-boot.lds delete mode 100644 board/micronas/vct/u-boot.lds delete mode 100644 board/pb1x00/u-boot.lds delete mode 100644 board/qemu-mips/u-boot.lds delete mode 100644 board/qi/qi_lb60/u-boot.lds
2013/1/30 Gabor Juhos juhosg@openwrt.org:
all patches in this series applied to u-boot-mips/master, thanks
Daniel Schwierzeck
Gabor Juhos
