[U-Boot] [PATCH 3/7] mips: ath79: Use uniform header for reset
Collect all reset operation on platform and move them into a uniform header
Signed-off-by: Wills Wang wills.wang@live.com ---
arch/mips/mach-ath79/include/mach/ath79.h | 3 --- arch/mips/mach-ath79/include/mach/reset.h | 2 ++ board/tplink/wdr4300/wdr4300.c | 1 + 3 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/arch/mips/mach-ath79/include/mach/ath79.h b/arch/mips/mach-ath79/include/mach/ath79.h index 17af082..18d1e26 100644 --- a/arch/mips/mach-ath79/include/mach/ath79.h +++ b/arch/mips/mach-ath79/include/mach/ath79.h @@ -140,9 +140,6 @@ static inline int soc_is_qca956x(void) return soc_is_tp9343() || soc_is_qca9561(); }
-int ath79_eth_reset(void); -int ath79_usb_reset(void); - void ar934x_pll_init(const u16 cpu_mhz, const u16 ddr_mhz, const u16 ahb_mhz); void ar934x_ddr_init(const u16 cpu_mhz, const u16 ddr_mhz, const u16 ahb_mhz);
diff --git a/arch/mips/mach-ath79/include/mach/reset.h b/arch/mips/mach-ath79/include/mach/reset.h index c383bfe..7721e1d 100644 --- a/arch/mips/mach-ath79/include/mach/reset.h +++ b/arch/mips/mach-ath79/include/mach/reset.h @@ -10,5 +10,7 @@ #include <linux/types.h>
u32 get_bootstrap(void); +int ath79_eth_reset(void); +int ath79_usb_reset(void);
#endif /* __ASM_MACH_RESET_H */ diff --git a/board/tplink/wdr4300/wdr4300.c b/board/tplink/wdr4300/wdr4300.c index 6e070fd..8382ce0 100644 --- a/board/tplink/wdr4300/wdr4300.c +++ b/board/tplink/wdr4300/wdr4300.c @@ -9,6 +9,7 @@ #include <asm/addrspace.h> #include <asm/types.h> #include <mach/ath79.h> +#include <mach/reset.h> #include <mach/ar71xx_regs.h> #include <mach/ddr.h> #include <debug_uart.h>
By moving the prototype into reset.h : - New functions are added to a file which can be almost removed - You need to include two headers now
So drop this patch and instead focus on getting rid of reset.h
You mean we should use a header "ath79.h" for all?
diff --git a/arch/mips/mach-ath79/include/mach/ath79.h b/arch/mips/mach-ath79/include/mach/ath79.h index 17af082..18d1e26 100644 --- a/arch/mips/mach-ath79/include/mach/ath79.h +++ b/arch/mips/mach-ath79/include/mach/ath79.h @@ -140,9 +140,6 @@ static inline int soc_is_qca956x(void) return soc_is_tp9343() || soc_is_qca9561(); } -int ath79_eth_reset(void); -int ath79_usb_reset(void);
u16 ahb_mhz); void ar934x_ddr_init(const u16 cpu_mhz, const u16 ddr_mhz, const u16 ahb_mhz); diff --git a/arch/mips/mach-ath79/include/mach/reset.h b/arch/mips/mach-ath79/include/mach/reset.h index c383bfe..7721e1d 100644 --- a/arch/mips/mach-ath79/include/mach/reset.h +++ b/arch/mips/mach-ath79/include/mach/reset.h @@ -10,5 +10,7 @@ #include <linux/types.h> u32 get_bootstrap(void); +int ath79_eth_reset(void); +int ath79_usb_reset(void);
Yes, having one header per function makes no sense and ath79.h already has multiple function prototypes in it.
Am 22.05.2016 um 13:32 schrieb Marek Vasut:
@Wills, could you please send an updated series with patches 3/7 to 7/7 which addresses Marek's comments? The merge window closes on the 4th of June. You can also send patch 7/7 alone to enable ethernet on AP121. Thanks.
Daniel Schwierzeck
Wills Wang
