[U-Boot] [PULL] Please pull u-boot-imx: u-boot-imx-20181025
Hi Tom,
please pull from u-boot-imx (tag: u-boot-imx-20181024). It contains the fixes we discussed:
- fix build i.MX8 for Travis - fix warnings (Warp) - fix warning in imx8 DTS
The following changes since commit 0a60a81ba3860946551cb79aa6486aa076e357f3:
Kconfig: sandbox: enable cmd_avb and dependencies (2018-10-07 13:34:19 -0400)
git://www.denx.de/git/u-boot-imx.git tags/u-boot-imx-20181025
for you to fetch changes up to 3c28576bb0f0990d699fd330089412e620706941:
arm: dts: imx8qxp: fix build warining (2018-10-25 11:48:13 +0200)
---------------------------------------------------------------- Merged imx8 architecture, fix build for imx8 + warnings
---------------------------------------------------------------- Anatolij Gustschin (3): imx8: cpu: add function for reading FEC MAC from fuse imx8: cpu: add uclass based CPU driver i2c: imx_lpi2c: fix typo and register base address format
Bernhard Messerklinger (1): serial: mxc: Add match string for i.mx6 quad/dual lite serial
Breno Matheus Lima (7): doc: imx: reorganize i.MX documentation doc: imx: Move SPD related info to the appropriate doc doc: imx: mkimage: reorganize i.MX mkimage documentation doc: imx: Reorganize i.MX SoC common documentation doc: imx: hab: Reorganize High Assurance Boot documentation doc: imx: misc: Reorganize miscellaneous documentation doc: imx: Improve i.MX documentation naming
Dan Cimpoca (1): board: ge: bx50v3: fix initialization of i2c bus0
Fabien Lahoudere (1): board: ge: bx50v3: Change maintainer
Fabio Estevam (5): pico-imx7d: Make SPL binary fit into 64kB pico-imx7d: Add USB Host support colibri_imx7: prime get_ram_size() using imx_ddr_size() configs: mx7: Remove CONFIG_DBG_MONITOR warp7: MAINTAINERS: Add an entry for warp7_bl33_defconfig
Ian Ray (2): board: ge: bx50v3: correct LDB clock board: ge: bx50v3: b{4,6}50v3 modeline
Marcel Ziswiler (1): imx: mx7: fix potential overflow in imx_ddr_size()
Marek Vasut (3): arm: imx: mx5: Make videoskip available on MX5 arm: mx5: Add LDB clock config code arm: mx5: Add M53Menlo board
Otavio Salvador (2): pico-imx6ul, pico-imx7d: Use eMMC user partition by default pico-imx6ul, pico-imx7d: Enable USB and PXE boot support
Peng Fan (35): dt-bindings: pinctrl: add i.MX8QXP pads definition dt-bindings: clock: dt-bindings: pinctrl: add i.MX8QXP clocks definition dt-bindings: soc: add i.MX8QXP pm and rsrc definition imx8: add scfw macro definition imx: add Kconfig entry for i.MX8QXP arm: build mach-imx for i.MX8 arm: global_data: add scu_dev for i.MX8 misc: add i.MX8 misc driver misc: imx8: add scfw api impementation imx: boot_mode: Add FLEXSPI boot entry imx8: add imx-regs header file imx8: pins: include i.MX8QXP pin header when CONFIG_IMX8QXP defined imx: add i.MX8 cpu type armv8: add cpu core helper functions imx8: add basic cpu support imx8: add boot device detection imx8: implement mmc_get_env_dev imx8: add mmu and dram related functions imx8: add arch_cpu_init arch_cpu_init_dm imx8: add iomux configuration api imx8: add dummy clock gpio: mxc_gpio: add support for i.MX8 pinctrl: Add pinctrl driver for i.MX8 power: Add power domain driver for i.MX8 clk: imx: add clk driver for i.MX8QXP serial_lpuart: Update lpuart driver to support i.MX8 serial: lpuart: support uclass clk api mmc: fsl_esdhc: add uclass clk support arm: dts: introduce dtsi for i.MX8QXP imx: add i.MX8QXP MEK board support tools: add i.MX8/8X image support arm: imx: include imx8image support imx: imx8qxp_mek: update to build image in U-Boot imx: mkimage: avoid stop CI when required files not exists arm: dts: imx8qxp: fix build warining
Rui Miguel Silva (4): imx: mx7: avoid some initialization if low level is skipped optee: adjust dependencies and default values for dram warp7: include: configs: set skip low level init warp7: configs: add bl33 defconfig
Sébastien Szymanski (1): ARM: opos6ul: make the board boot again
Xiaoliang Yang (1): Kconfig: Convert CONFIG_IMX_WATCHDOG to Kconfig
Ye Li (2): serial: lpuart: Enable RX and TX FIFO fsl_esdhc: Update usdhc driver to support i.MX8
arch/arm/Kconfig | 8 ++ arch/arm/Makefile | 2 +- arch/arm/dts/Makefile | 2 + arch/arm/dts/fsl-imx8-ca35.dtsi | 66 +++++++++++++ arch/arm/dts/fsl-imx8dx.dtsi | 499 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ arch/arm/dts/fsl-imx8dxp.dtsi | 11 +++ arch/arm/dts/fsl-imx8qxp-mek.dts | 244 ++++++++++++++++++++++++++++++++++++++++++++++++ arch/arm/dts/fsl-imx8qxp.dtsi | 51 ++++++++++ arch/arm/dts/imx6ul-opos6ul-u-boot.dtsi | 28 ++++++ arch/arm/dts/imx6ul-opos6ul.dtsi | 2 - arch/arm/dts/imx6ul-opos6uldev-u-boot.dtsi | 24 +++++ arch/arm/dts/imx6ul-opos6uldev.dts | 2 - arch/arm/include/asm/arch-imx/cpu.h | 6 ++ arch/arm/include/asm/arch-imx8/clock.h | 27 ++++++ arch/arm/include/asm/arch-imx8/gpio.h | 21 +++++ arch/arm/include/asm/arch-imx8/imx-regs.h | 46 +++++++++ arch/arm/include/asm/arch-imx8/imx8-pins.h | 15 +++ arch/arm/include/asm/arch-imx8/iomux.h | 40 ++++++++ arch/arm/include/asm/arch-imx8/power-domain.h | 15 +++ arch/arm/include/asm/arch-imx8/sci/rpc.h | 158 +++++++++++++++++++++++++++++++ arch/arm/include/asm/arch-imx8/sci/sci.h | 88 ++++++++++++++++++ arch/arm/include/asm/arch-imx8/sci/svc/misc/api.h | 30 ++++++ arch/arm/include/asm/arch-imx8/sci/svc/pad/api.h | 57 ++++++++++++ arch/arm/include/asm/arch-imx8/sci/svc/pm/api.h | 44 +++++++++ arch/arm/include/asm/arch-imx8/sci/svc/rm/api.h | 69 ++++++++++++++ arch/arm/include/asm/arch-imx8/sci/types.h | 220 +++++++++++++++++++++++++++++++++++++++++++ arch/arm/include/asm/arch-imx8/sys_proto.h | 19 ++++ arch/arm/include/asm/arch-mx5/clock.h | 1 + arch/arm/include/asm/armv8/cpu.h | 26 ++++++ arch/arm/include/asm/global_data.h | 4 + arch/arm/include/asm/mach-imx/boot_mode.h | 1 + arch/arm/include/asm/mach-imx/sys_proto.h | 3 + arch/arm/mach-imx/Makefile | 28 ++++-- arch/arm/mach-imx/imx8/Kconfig | 26 ++++++ arch/arm/mach-imx/imx8/Makefile | 7 ++ arch/arm/mach-imx/imx8/clock.c | 21 +++++ arch/arm/mach-imx/imx8/cpu.c | 646 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ arch/arm/mach-imx/imx8/iomux.c | 43 +++++++++ arch/arm/mach-imx/mx5/Kconfig | 6 ++ arch/arm/mach-imx/mx5/clock.c | 29 ++++++ arch/arm/mach-imx/mx7/ddr.c | 4 + arch/arm/mach-imx/mx7/soc.c | 2 + arch/arm/mach-imx/syscounter.c | 2 + board/freescale/imx8qxp_mek/Kconfig | 14 +++ board/freescale/imx8qxp_mek/MAINTAINERS | 6 ++ board/freescale/imx8qxp_mek/Makefile | 7 ++ board/freescale/imx8qxp_mek/README | 55 +++++++++++ board/freescale/imx8qxp_mek/imx8qxp_mek.c | 170 +++++++++++++++++++++++++++++++++ board/freescale/imx8qxp_mek/imximage.cfg | 25 +++++ board/freescale/mx8mq_evk/README | 81 ++++++++++++++++ board/ge/bx50v3/MAINTAINERS | 2 +- board/ge/bx50v3/bx50v3.c | 38 ++++---- board/menlo/m53menlo/Kconfig | 15 +++ board/menlo/m53menlo/MAINTAINERS | 7 ++ board/menlo/m53menlo/Makefile | 9 ++ board/menlo/m53menlo/imximage.cfg | 91 ++++++++++++++++++ board/menlo/m53menlo/m53menlo.c | 513 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ board/technexion/pico-imx7d/pico-imx7d.c | 29 +++++- board/toradex/colibri_imx7/colibri_imx7.c | 2 +- board/warp7/MAINTAINERS | 1 + common/image.c | 1 + configs/aristainetos2_defconfig | 1 + configs/aristainetos2b_defconfig | 1 + configs/aristainetos_defconfig | 1 + configs/dh_imx6_defconfig | 1 + configs/display5_defconfig | 1 + configs/display5_factory_defconfig | 1 + configs/ge_bx50v3_defconfig | 1 + configs/imx8qxp_mek_defconfig | 52 +++++++++++ configs/kp_imx6q_tpc_defconfig | 1 + configs/m53menlo_defconfig | 60 ++++++++++++ configs/mx53ppd_defconfig | 1 + configs/pico-hobbit-imx7d_defconfig | 1 - configs/pico-imx7d_defconfig | 1 - configs/pico-pi-imx7d_defconfig | 1 - configs/tqma6s_wru4_mmc_defconfig | 1 + configs/warp7_bl33_defconfig | 42 +++++++++ configs/warp7_defconfig | 2 + configs/warp_defconfig | 1 + doc/{README.imx25 => imx/common/imx25.txt} | 0 doc/{README.imx27 => imx/common/imx27.txt} | 0 doc/{README.imx5 => imx/common/imx5.txt} | 0 doc/{README.imx6 => imx/common/imx6.txt} | 25 ----- doc/{README.mxs => imx/common/mxs.txt} | 0 doc/imx/hab/habv4/encrypted_boot.txt | 43 +++++++++ doc/{README.mxc_hab => imx/hab/habv4/secure_boot.txt} | 44 --------- doc/{README.sdp => imx/misc/sdp.txt} | 22 ++++- doc/{README.imximage => imx/mkimage/imximage.txt} | 0 doc/{README.mxsimage => imx/mkimage/mxsimage.txt} | 0 drivers/clk/Kconfig | 1 + drivers/clk/Makefile | 1 + drivers/clk/imx/Kconfig | 6 ++ drivers/clk/imx/Makefile | 5 + drivers/clk/imx/clk-imx8.c | 393 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ drivers/gpio/mxc_gpio.c | 30 ++++-- drivers/i2c/imx_lpi2c.c | 4 +- drivers/misc/Makefile | 1 + drivers/misc/imx8/Makefile | 3 + drivers/misc/imx8/scu.c | 266 ++++++++++++++++++++++++++++++++++++++++++++++++++++ drivers/misc/imx8/scu_api.c | 367 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ drivers/mmc/fsl_esdhc.c | 34 +++++-- drivers/pinctrl/nxp/Kconfig | 18 ++++ drivers/pinctrl/nxp/Makefile | 2 + drivers/pinctrl/nxp/pinctrl-imx.c | 209 ++++++++++++++++++++++------------------- drivers/pinctrl/nxp/pinctrl-imx.h | 16 ++++ drivers/pinctrl/nxp/pinctrl-imx8.c | 40 ++++++++ drivers/pinctrl/nxp/pinctrl-scu.c | 66 +++++++++++++ drivers/power/domain/Kconfig | 8 +- drivers/power/domain/Makefile | 1 + drivers/power/domain/imx8-power-domain.c | 315 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ drivers/serial/serial_lpuart.c | 143 ++++++++++++++++++++++------ drivers/serial/serial_mxc.c | 1 + drivers/watchdog/Kconfig | 7 ++ include/configs/aristainetos-common.h | 3 - include/configs/cl-som-imx7.h | 2 - include/configs/colibri-imx6ull.h | 1 - include/configs/colibri_imx7.h | 3 - include/configs/dh_imx6.h | 2 - include/configs/display5.h | 2 - include/configs/ge_bx50v3.h | 2 - include/configs/imx8qxp_mek.h | 157 +++++++++++++++++++++++++++++++ include/configs/kp_imx6q_tpc.h | 2 - include/configs/m53menlo.h | 246 ++++++++++++++++++++++++++++++++++++++++++++++++ include/configs/mx53ppd.h | 2 - include/configs/mx7dsabresd.h | 1 - include/configs/pico-imx6ul.h | 6 +- include/configs/pico-imx7d.h | 6 +- include/configs/tqma6_wru4.h | 2 - include/configs/warp.h | 2 - include/configs/warp7.h | 11 +++ include/dt-bindings/clock/imx8qxp-clock.h | 583 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ include/dt-bindings/pinctrl/pads-imx8qxp.h | 757 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ include/dt-bindings/soc/imx8_pd.h | 188 +++++++++++++++++++++++++++++++++++++ include/dt-bindings/soc/imx_rsrc.h | 557 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ include/fsl_lpuart.h | 2 +- include/image.h | 1 + include/imx8image.h | 273 +++++++++++++++++++++++++++++++++++++++++++++++++++++ lib/optee/Kconfig | 8 +- scripts/config_whitelist.txt | 2 - tools/Makefile | 1 + tools/imagetool.h | 1 + tools/imx8image.c | 961 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ tools/imx_cntr_image.sh | 29 ++++++ tools/mkimage.c | 7 ++ 144 files changed, 9488 insertions(+), 282 deletions(-) create mode 100644 arch/arm/dts/fsl-imx8-ca35.dtsi create mode 100644 arch/arm/dts/fsl-imx8dx.dtsi create mode 100644 arch/arm/dts/fsl-imx8dxp.dtsi create mode 100644 arch/arm/dts/fsl-imx8qxp-mek.dts create mode 100644 arch/arm/dts/fsl-imx8qxp.dtsi create mode 100644 arch/arm/dts/imx6ul-opos6ul-u-boot.dtsi create mode 100644 arch/arm/dts/imx6ul-opos6uldev-u-boot.dtsi create mode 100644 arch/arm/include/asm/arch-imx8/clock.h create mode 100644 arch/arm/include/asm/arch-imx8/gpio.h create mode 100644 arch/arm/include/asm/arch-imx8/imx-regs.h create mode 100644 arch/arm/include/asm/arch-imx8/imx8-pins.h create mode 100644 arch/arm/include/asm/arch-imx8/iomux.h create mode 100644 arch/arm/include/asm/arch-imx8/power-domain.h create mode 100644 arch/arm/include/asm/arch-imx8/sci/rpc.h create mode 100644 arch/arm/include/asm/arch-imx8/sci/sci.h create mode 100644 arch/arm/include/asm/arch-imx8/sci/svc/misc/api.h create mode 100644 arch/arm/include/asm/arch-imx8/sci/svc/pad/api.h create mode 100644 arch/arm/include/asm/arch-imx8/sci/svc/pm/api.h create mode 100644 arch/arm/include/asm/arch-imx8/sci/svc/rm/api.h create mode 100644 arch/arm/include/asm/arch-imx8/sci/types.h create mode 100644 arch/arm/include/asm/arch-imx8/sys_proto.h create mode 100644 arch/arm/include/asm/armv8/cpu.h create mode 100644 arch/arm/mach-imx/imx8/Kconfig create mode 100644 arch/arm/mach-imx/imx8/Makefile create mode 100644 arch/arm/mach-imx/imx8/clock.c create mode 100644 arch/arm/mach-imx/imx8/cpu.c create mode 100644 arch/arm/mach-imx/imx8/iomux.c create mode 100644 board/freescale/imx8qxp_mek/Kconfig create mode 100644 board/freescale/imx8qxp_mek/MAINTAINERS create mode 100644 board/freescale/imx8qxp_mek/Makefile create mode 100644 board/freescale/imx8qxp_mek/README create mode 100644 board/freescale/imx8qxp_mek/imx8qxp_mek.c create mode 100644 board/freescale/imx8qxp_mek/imximage.cfg create mode 100644 board/freescale/mx8mq_evk/README create mode 100644 board/menlo/m53menlo/Kconfig create mode 100644 board/menlo/m53menlo/MAINTAINERS create mode 100644 board/menlo/m53menlo/Makefile create mode 100644 board/menlo/m53menlo/imximage.cfg create mode 100644 board/menlo/m53menlo/m53menlo.c create mode 100644 configs/imx8qxp_mek_defconfig create mode 100644 configs/m53menlo_defconfig create mode 100644 configs/warp7_bl33_defconfig rename doc/{README.imx25 => imx/common/imx25.txt} (100%) rename doc/{README.imx27 => imx/common/imx27.txt} (100%) rename doc/{README.imx5 => imx/common/imx5.txt} (100%) rename doc/{README.imx6 => imx/common/imx6.txt} (73%) rename doc/{README.mxs => imx/common/mxs.txt} (100%) create mode 100644 doc/imx/hab/habv4/encrypted_boot.txt rename doc/{README.mxc_hab => imx/hab/habv4/secure_boot.txt} (68%) rename doc/{README.sdp => imx/misc/sdp.txt} (82%) rename doc/{README.imximage => imx/mkimage/imximage.txt} (100%) rename doc/{README.mxsimage => imx/mkimage/mxsimage.txt} (100%) create mode 100644 drivers/clk/imx/Kconfig create mode 100644 drivers/clk/imx/Makefile create mode 100644 drivers/clk/imx/clk-imx8.c create mode 100644 drivers/misc/imx8/Makefile create mode 100644 drivers/misc/imx8/scu.c create mode 100644 drivers/misc/imx8/scu_api.c create mode 100644 drivers/pinctrl/nxp/pinctrl-imx8.c create mode 100644 drivers/pinctrl/nxp/pinctrl-scu.c create mode 100644 drivers/power/domain/imx8-power-domain.c create mode 100644 include/configs/imx8qxp_mek.h create mode 100644 include/configs/m53menlo.h create mode 100644 include/dt-bindings/clock/imx8qxp-clock.h create mode 100644 include/dt-bindings/pinctrl/pads-imx8qxp.h create mode 100644 include/dt-bindings/soc/imx8_pd.h create mode 100644 include/dt-bindings/soc/imx_rsrc.h create mode 100644 include/imx8image.h create mode 100644 tools/imx8image.c create mode 100755 tools/imx_cntr_image.sh
Best regards, Stefano
On Thu, Oct 25, 2018 at 12:01:10PM +0200, Stefano Babic wrote:
Hi Tom,
Stefano Babic
