[U-Boot] [PATCH 3/3 v2] ppc4xx: Add routine to retrieve CPU number
Provide a weak defined routine to retrieve the CPU number for reference boards that have multiple CPU's. Default behavior is the existing single CPU print output. Reference boards with multiple CPU's need to provide a board specific routine. See board/amcc/arches/arches.c for an example.
Signed-off-by: Adam Graham agraham@amcc.com Signed-off-by: Victor Gallardo vgallardo@amcc.com --- v2: - Correct return code of the generic get_cpu_num routine and make the return code a defined value.
cpu/ppc4xx/cpu.c | 19 ++++++++++++++++++- include/ppc4xx.h | 3 +++ 2 files changed, 21 insertions(+), 1 deletions(-)
diff --git a/cpu/ppc4xx/cpu.c b/cpu/ppc4xx/cpu.c index bc9335a..67f88f8 100644 --- a/cpu/ppc4xx/cpu.c +++ b/cpu/ppc4xx/cpu.c @@ -41,6 +41,18 @@ DECLARE_GLOBAL_DATA_PTR;
void board_reset(void);
+/* + * To provide an interface to detect CPU number for boards that support + * more then one CPU, we implement the "weak" default functions here. + * + * Returns CPU number + */ +int __get_cpu_num(void) +{ + return __NA_OR_UNKNOWN_CPU; +} +int get_cpu_num(void) __attribute__((weak, alias("__get_cpu_num"))); + #if defined(CONFIG_405GP) || \ defined(CONFIG_440EP) || defined(CONFIG_440GR) || \ defined(CONFIG_440EPX) || defined(CONFIG_440GRX) @@ -274,8 +286,13 @@ int checkcpu (void) #if !defined(CONFIG_IOP480) char addstr[64] = ""; sys_info_t sys_info; + int cpu_num;
- puts ("CPU: "); + cpu_num = get_cpu_num(); + if (cpu_num >= 0) + printf("CPU%d: ", cpu_num); + else + puts("CPU: ");
get_sys_info(&sys_info);
diff --git a/include/ppc4xx.h b/include/ppc4xx.h index e216663..56b3186 100644 --- a/include/ppc4xx.h +++ b/include/ppc4xx.h @@ -218,4 +218,7 @@ static inline void set_mcsr(u32 val)
#endif /* __ASSEMBLY__ */
+/* for multi-cpu support */ +#define __NA_OR_UNKNOWN_CPU -1 + #endif /* __PPC4XX_H__ */
Dear Adam Graham,
Line too long.
- return __NA_OR_UNKNOWN_CPU;
Please don't use identifiers starting with underscores. These have a special meaning in C.
Adam Graham
